path: root/arch/m68k/kernel/entry.S
2005-11-13[PATCH] m68k: convert thread flags to use bit fieldsRoman Zippel
Remove task_work structure, use the standard thread flags functions and use shifts in entry.S to test the thread flags. Add a few local labels to entry.S to allow gas to generate short jumps. Finally it changes a number of inline functions in thread_info.h to macros to delay the current_thread_info() usage, which requires on m68k a structure (task_struct) not yet defined at this point. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
