path: root/arch/m68k/atari/time.c
2009-02-22m68k: atari - Rename "mfp" to "st_mfp"Geert Uytterhoeven
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/: | net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile' | net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token | net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type | distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed This is caused by | # define mfp ((*(volatile struct MFP*)MFP_BAS)) in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in net/mac80211/ieee80211_i.h. Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12m68k: atari core - Kill warn_unused_result warningsGeert Uytterhoeven
warning: ignoring return value of 'request_irq', declared with attribute warn_unused_result Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2008-10-14m68k: Define rtc_lock on AtariGeert Uytterhoeven
The nvram and rtc-cmos drivers use the spinlock rtc_lock to protect against concurrent accesses to the CMOS memory. As m68k doesn't support SMP or preempt yet, the spinlock calls tend to get optimized away, but not for all configurations, causing in some rare cases: | ERROR: "rtc_lock" [drivers/rtc/rtc-cmos.ko] undefined! | ERROR: "rtc_lock" [drivers/char/nvram.ko] undefined! Add the spinlock to the Atari core code to avoid this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Michael Schmitz <schmitz@debian.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14m68k: use bcd2bin/bin2bcdAdrian Bunk
This patch changes m68k to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. It also remove local bcd2bin/bin2bcd implementations in favor of the global ones. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-09[PATCH] m68k/Atari: Interrupt updatesGeert Uytterhoeven
Misc Atari fixes: - initialize correct number of atari irqs - silence vbl interrupt until it's used by atafb - use mdelay() to read clock if necessary Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-09IRQ: Use the new typedef for interrupt handler function pointersDavid Howells
Use the new typedef for interrupt handler function pointers rather than actually spelling out the full thing each time. This was scripted with the following small shell script: #!/bin/sh egrep -nHrl -e 'irqreturn_t[ ]*[(][*]' $* | while read i do echo $i perl -pi -e 's/irqreturn_t\s*[(]\s*[*]\s*([_a-zA-Z0-9]*)\s*[)]\s*[(]\s*int\s*,\s*void\s*[*]\s*[)]/irq_handler_t \1/g' $i || exit $? done Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-07[PATCH] m68k pt_regs fixesAl Viro
m68k_handle_int() split in two functions: __m68k_handle_int() takes pt_regs * and does set_irq_regs(); m68k_handle_int() doesn't get pt_regs *. Places where we used to call m68k_handle_int() recursively with the same pt_regs have simply lost the second argument, the rest is switched to __m68k_handle_int(). The rest of patch is just dropping pt_regs * where needed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] m68k: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
