It was used on Apollo only, before its conversion to genirq.
This code was obsoleted during the irq restructuring in 2006.
This is a wrapper around m68k_setup_irq_chip() that discards its dummy
second parameter, to ease the future transition to genirq.
Make it more similar to the genirq version:
- Remove lock (unused as we don't do SMP anyway),
- Prepend methods with irq_,
- Make irq_startup() return unsigned int.
It's a way too generic name for a global #define and conflicts with a variable
with the same name, causing build errors like:
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c: In function ‘_si_clkctl_cc’:
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected identifier or ‘(’ before ‘volatile’
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1364: error: expected ‘)’ before ‘(’ token
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1421: error: incompatible types in assignment
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1422: error: invalid operands to binary &
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1423: error: invalid operands to binary &
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1424: error: invalid operands to binary |
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: aggregate value used where an integer was expected
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1425: error: incompatible type for argument 4 of ‘bcmsdh_reg_write’
| drivers/staging/brcm80211/brcmfmac/../util/siutils.c:1428: error: invalid operands to binary &
| make[8]: *** [drivers/staging/brcm80211/brcmfmac/../util/siutils.o] Error 1
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/:
| net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile'
| net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token
| net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type
| distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed
This is caused by
| # define mfp ((*(volatile struct MFP*)MFP_BAS))
in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in
net/mac80211/ieee80211_i.h.
Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define.
This patch removes the Hades support that was marked as BROKEN 5 years ago.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
EXPORT_SYMBOL's belong to the actual code.
Cc: Roman Zippel <zippel@linux-m68k.org>
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
Misc Atari fixes:
- initialize correct number of atari irqs
- silence vbl interrupt until it's used by atafb
- use mdelay() to read clock if necessary
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Use separate entry points for auto and user vector interrupts and cleanup
naming a little.
infrastructure for it.
Let it rip!
