path: root/arch/m32r
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: remove redundant declarationKOSAKI Motohiro
They have no meaning. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: convert cpumask apiKOSAKI Motohiro
We plan to remove cpus_xx() old cpumask APIs later. Also, we plan to change mm_cpu_mask() implementation, allocate only nr_cpu_ids, thus *mm_cpu_mask() is dangerous operation. Then, this patch convert them. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Remove unused PROC_CHANGE_PENALTY constantStephen Boyd
This constant hasn't been used since before the git era (2.6.12) and thus can be dropped. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Richard Weinberger <richard@nod.at> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25m32r, mm: set all online nodes in N_NORMAL_MEMORYDavid Rientjes
For m32r, N_NORMAL_MEMORY represents all nodes that have present memory since it does not support HIGHMEM. This patch sets the bit at the time the node is initialized. If N_NORMAL_MEMORY is not accurate, slub may encounter errors since it uses this nodemask to setup per-cache kmem_cache_node data structures. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-20extable, core_kernel_data(): Make sure all archs define _sdataSteven Rostedt
A new utility function (core_kernel_data()) is used to determine if a passed in address is part of core kernel data or not. It may or may not return true for RO data, but this utility must work for RW data. Thus both _sdata and _edata must be defined and continuous, without .init sections that may later be freed and replaced by volatile memory (memory that can be freed). This utility function is used to determine if data is safe from ever being freed. Thus it should return true for all RW global data that is not in a module or has been allocated, or false otherwise. Also change core_kernel_data() back to the more precise _sdata condition and document the function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: JamesE.J.Bottomley <jejb@parisc-linux.org> Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com Signed-off-by: Ingo Molnar <mingo@elte.hu> ---- arch/alpha/kernel/vmlinux.lds.S | 1 + arch/m32r/kernel/vmlinux.lds.S | 1 + arch/m68k/kernel/vmlinux-std.lds | 2 ++ arch/m68k/kernel/vmlinux-sun3.lds | 1 + arch/mips/kernel/vmlinux.lds.S | 1 + arch/parisc/kernel/vmlinux.lds.S | 3 +++ kernel/extable.c | 12 +++++++++++- 7 files changed, 20 insertions(+), 1 deletion(-)
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-24m32r: Use generic show_interrupts()Thomas Gleixner
2011-03-24m32r: Convert genirq namespaceThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-23remove dma64_addr_tFUJITA Tomonori
There is no user now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: David Miller <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce CONFIG_GENERIC_FIND_BIT_LEAkinobu Mita
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic implementation of find_*_bit_le() in lib/find_next_bit.c or not. For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which enable CONFIG_GENERIC_FIND_NEXT_BIT. But m68knommu wants to define own faster find_next_zero_bit_le() and continues using generic find_next_{,zero_}bit(). (CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE) Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-02-05m32r: Fixup last __do_IRQ leftoverThomas Gleixner
Somehow I managed to miss the last __do_IRQ caller when I cleanup the remaining users. m32r is fully converted to the generic irq layer, but I managed to not commit the conversion of __do_IRQ() to generic_handle_irq() after compile testing the quilt series :( Pointed-out-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-31m32r: Switch from do_timer() to xtime_update()Torben Hohn
xtime_update() does proper locking. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127150001.23248.68620.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-25percpu: align percpu readmostly subsection to cachelineTejun Heo
Currently percpu readmostly subsection may share cachelines with other percpu subsections which may result in unnecessary cacheline bounce and performance degradation. This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR() linker macros, makes each arch linker scripts specify its cacheline size and use it to align percpu subsections. This is based on Shaohua's x86 only patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shaohua.li@intel.com>
2011-01-21m32r: Convert to generic irq KconfigThomas Gleixner
Use the generic irq Kconfig. Select GENERIC_HARDIRQS_NO_DEPRECATED as we have converted all irq_chip functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21m32r: Convert usrv platform irq handlingThomas Gleixner
Convert the irq chips to the new functions and use proper flow handlers. handle_level_irq is appropriate. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21m32r: Convert opsput_lcdpld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput lanpld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput pld irq chipThomas Gleixner
2011-01-21m32r: Convert opsput irq chipThomas Gleixner
2011-01-21m32r: Convert oaks32r irq chipsThomas Gleixner
2011-01-21m32r: Convert mappi3 irq chipThomas Gleixner
2011-01-21m32r: Convert mappi2 irq chipThomas Gleixner
2011-01-21m32r: Convert mappi irq chipsThomas Gleixner
2011-01-21m32r: Convert m32700ut lcdpld irq chipThomas Gleixner
Convert the irq chip to the new functions and use proper flow handlers. handle_level_irq is appropriate. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-21m32r: Convert m32700ut lanpld irq chipThomas Gleixner
2011-01-21m32r: Convert m32700ut pld irq chipThomas Gleixner
2011-01-21m32r: Convert m32104ut irq chipThomas Gleixner
2011-01-21m32r: Convert m32104ut irq handlingThomas Gleixner
2011-01-21m32r: Cleanup direct irq_desc accessThomas Gleixner
The irq descriptors are already initialized by the generic code. Remove the redundant init code and set the irq chip with the proper accessor function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
