path: root/arch/m32r/kernel
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: remove redundant declarationKOSAKI Motohiro
They have no meaning. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m32r: convert cpumask apiKOSAKI Motohiro
We plan to remove cpus_xx() old cpumask APIs later. Also, we plan to change mm_cpu_mask() implementation, allocate only nr_cpu_ids, thus *mm_cpu_mask() is dangerous operation. Then, this patch convert them. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-24Merge branch 'fixes-2.6.39' into for-2.6.40Tejun Heo
2011-05-20extable, core_kernel_data(): Make sure all archs define _sdataSteven Rostedt
A new utility function (core_kernel_data()) is used to determine if a passed in address is part of core kernel data or not. It may or may not return true for RO data, but this utility must work for RW data. Thus both _sdata and _edata must be defined and continuous, without .init sections that may later be freed and replaced by volatile memory (memory that can be freed). This utility function is used to determine if data is safe from ever being freed. Thus it should return true for all RW global data that is not in a module or has been allocated, or false otherwise. Also change core_kernel_data() back to the more precise _sdata condition and document the function. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: linux-m68k@lists.linux-m68k.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: JamesE.J.Bottomley <jejb@parisc-linux.org> Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com Signed-off-by: Ingo Molnar <mingo@elte.hu> ---- arch/alpha/kernel/vmlinux.lds.S | 1 + arch/m32r/kernel/vmlinux.lds.S | 1 + arch/m68k/kernel/vmlinux-std.lds | 2 ++ arch/m68k/kernel/vmlinux-sun3.lds | 1 + arch/mips/kernel/vmlinux.lds.S | 1 + arch/parisc/kernel/vmlinux.lds.S | 3 +++ kernel/extable.c | 12 +++++++++++- 7 files changed, 20 insertions(+), 1 deletion(-)
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-24m32r: Use generic show_interrupts()Thomas Gleixner
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-16Merge branch 'for-2.6.39' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu, x86: Add arch-specific this_cpu_cmpxchg_double() support percpu: Generic support for this_cpu_cmpxchg_double() alpha: use L1_CACHE_BYTES for cacheline size in the linker script percpu: align percpu readmostly subsection to cacheline Fix up trivial conflict in arch/x86/kernel/vmlinux.lds.S due to the percpu alignment having changed ("x86: Reduce back the alignment of the per-CPU data section")
2011-03-15Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits) posix-clocks: Check write permissions in posix syscalls hrtimer: Remove empty hrtimer_init_hres_timer() hrtimer: Update hrtimer->state documentation hrtimer: Update base[CLOCK_BOOTTIME].offset correctly timers: Export CLOCK_BOOTTIME via the posix timers interface timers: Add CLOCK_BOOTTIME hrtimer base time: Extend get_xtime_and_monotonic_offset() to also return sleep time: Introduce get_monotonic_boottime and ktime_get_boottime hrtimers: extend hrtimer base code to handle more then 2 clockids ntp: Remove redundant and incorrect parameter check mn10300: Switch do_timer() to xtimer_update() posix clocks: Introduce dynamic clocks posix-timers: Cleanup namespace posix-timers: Add support for fd based clocks x86: Add clock_adjtime for x86 posix-timers: Introduce a syscall for clock tuning. time: Splitout compat timex accessors ntp: Add ADJ_SETOFFSET mode bit time: Introduce timekeeping_inject_offset posix-timer: Update comment ... Fix up new system-call-related conflicts in arch/x86/ia32/ia32entry.S arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/syscall_table_32.S (name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some due to movement of get_jiffies_64() in: kernel/time.c
2011-02-05m32r: Fixup last __do_IRQ leftoverThomas Gleixner
Somehow I managed to miss the last __do_IRQ caller when I cleanup the remaining users. m32r is fully converted to the generic irq layer, but I managed to not commit the conversion of __do_IRQ() to generic_handle_irq() after compile testing the quilt series :( Pointed-out-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2011-01-31m32r: Switch from do_timer() to xtime_update()Torben Hohn
xtime_update() does proper locking. Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127150001.23248.68620.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-25percpu: align percpu readmostly subsection to cachelineTejun Heo
Currently percpu readmostly subsection may share cachelines with other percpu subsections which may result in unnecessary cacheline bounce and performance degradation. This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR() linker macros, makes each arch linker scripts specify its cacheline size and use it to align percpu subsections. This is based on Shaohua's x86 only patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shaohua.li@intel.com>
2011-01-21m32r: Cleanup direct irq_desc accessThomas Gleixner
The irq descriptors are already initialized by the generic code. Remove the redundant init code and set the irq chip with the proper accessor function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
2010-10-27ptrace: cleanup arch_ptrace() on m32rNamhyung Kim
Use new 'datap' variable in order to remove duplicated castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-20Merge branch 'linus' into irq/coreIngo Molnar
Merge reason: update to almost-final-.36 Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-15m32r: add kernel/.gitignore and ignore vmlinux.ldsKyle McMartin
Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-15m32r: get_user takes an lvalue, not a pointerKyle McMartin
Signed-off-by: Kyle McMartin <kyle@redhat.com> Acked-by: Al "my fuckup" Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-15m32r: restore _BLOCKABLEKyle McMartin
Commit a7f8388e accidentally removed it... Al explains: "Sorry, reordering breakage. In the signals tree here I have static inline void sig_set_blocked(struct sigset_t *set) ... and it's used all over the place (including quite a few places where we currently have sigprocmask(SIG_SETMASK, set, NULL), which is what it's equivalent to). With that done, m32r doesn't use _BLOCKABLE anywhere, so it got removed. And that chunk got picked when I'd been reordering the queue to pull the arch-specific fixes in front. Sorry." Signed-off-by: Kyle McMartin <kyle@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-12Merge branch 'x86/urgent' of into irq/sparseirqThomas Gleixner
Reason: Pull in the latest io_apic bugfixes Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-09-24m32r: fix breakage from "m32r: use generic ptrace_resume code"Al Viro
2010-09-24m32r: hole in shifting pc backAl Viro
It's a userland pointer; worse, an untrustable one since ptrace has just provided a chance to modify it. X-Roothole-Covering-Cabal: TINRCC Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-24m32r: don't block signals if sigframe setup has failedAl Viro
2010-09-24make m32r handle multiple pending signalsAl Viro
2010-09-24m32r: fix rt_sigsuspend()Al Viro
do_signal() should know about saved_mask for it to work... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-23genirq: Cleanup irq_chip->typename leftoversThomas Gleixner
3 years transition phase is enough. Cleanup the last users and remove the cruft. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Leo Chen <leochen@broadcom.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-13m32r: Convert m32r to use read/update_peristent_clockJohn Stultz
This patch converts the m32r architecture to use the generic read_persistent_clock and update_persistent_clock interfaces, reducing the amount of arch specific code we have to maintain, and allowing for further cleanups in the future. I have not built or tested this patch, so help from arch maintainers would be appreciated. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1267675049-12337-11-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-03-12m32r: use generic ptrace_resume codeChristoph Hellwig
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT, PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining arch_has_single_step in <asm/ptrace.h> and implementing the user_enable_single_step and user_disable_single_step functions, which also causes the breakpoint information to be cleared on fork, which could be considered a bug fix. Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which it previously wasn't, which is consistent with all architectures using the modern ptrace code. The old code only disables the breakpoints on PTRACE_KILL, while after this patch this also happens for PTRACE_CONT and PTRACE_SYSCALL which matches the behaviour of the other architetures. I think this is a bugfixes, but please double verify this is correct. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_olduname()Christoph Hellwig
Add generic implementations of the old and really old uname system calls. Note that sh only implements sys_olduname but not sys_oldolduname, but I'm not going to bother with another ifdef for that special case. m32r implemented an old uname but never wired it up, so kill it, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-11-04m32r: Should index be positive?Roel Kluin
Index `ipi_num' is signed, test whether it is negative to make sure we don't get a negative array element. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-11-04m32r: add NOTES to vmlinux.lds.S to remove .note.gnu.build-id sectionHirokazu Takata
Building with --build-id option, .note.gnu.build-id section is added to vmlinux.bin. But some old buggy binutils creates a huge vmlinux.bin, and a bootloader fails to boot its zImage as well. This patch adds a NOTES macro to a linker script vmlinux.ld.S to put .note.gnu.build-id section into .note section. Then, the .note section will be removed, because "-R .note" option is specified in OBJCOPYFLAGS to make a vmlinux.bin binary. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-11-04arch/m32r: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-04m32r: Fix IPI function calls for SMPToshihiro HANAWA
This patch fixes the m32r SMP kernel after 2.6.27. A part of the following patch breaks m32r SMP operation. > m32r: convert to generic helpers for IPI function calls > commit 7b7426c8a615cf61df9a77b9df7d5b75d91e3fa0 In the above patch, a CALL_FUNC_SINGLE_IPI was newly introduced, but the its IPI vector number was wrong in the patch code. The m32r SMP kernel hanged-up during boot operation, because the CPU_BOOT_IPI was called instead of CALL_FUNC_SINGLE_IPI (CPU_BOOT_IPI had no side effect at that time because the 2nd core had already been started up), as a result, csd_unlock() was not called, then a dead lock occurred in csd_lock_wait() after the detection of Compact Flash memory as IDE generic disk. Signed-off-by: Toshihiro HANAWA <hanawa@ccs.tsukuba.ac.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-10-04m32r: add rtc_lock variableHirokazu Takata
Add a spinlock variable "rtc_lock". This is taken from arch/arm/kernel/time.c. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-10-04m32r: export delay loop symbolsHirokazu Takata
- Move EXPORT_SYMBOL lines of delay loop functions from arch/m32r/kernel/m32r_ksyms.c to arch/m32r/lib/delay.c. - Export __ndelay. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-24Merge branch 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_devLinus Torvalds
* 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_dev: m32r: Cleanup linker script using new linker script macros. m32r: Move the spi_stack_top and spu_stack_top into .init.data section. m32r: Remove unused .altinstructions and .exit.* code from linker script. m32r: Move GET_THREAD_INFO definition out of asm/thread_info.h. m32r: Define THREAD_SIZE only once. m32r: make PAGE_SIZE available to assembly.
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-24cpumask: use mm_cpumask() wrapper: m32rRusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask. It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Hirokazu Takata <takata@linux-m32r.org> (fixes)
2009-09-24cpumask: Use accessors for cpu_*_mask: m32rRusty Russell
Use the accessors rather than frobbing bits directly (the new versions are const). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
