path: root/arch/m32r/kernel
2006-04-19[PATCH] m32r: update switch_to macro for tuningHirokazu Takata
- Remove unnecessary push/pop's of the switch_to() macro for performance tuning. - Cosmetic updates: change __inline__ to inline, etc. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] m32r: mappi3 reboot supportHirokazu Takata
Here is a patch to support a reboot function for M3A-2170(Mappi-III) evaluation board. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] m32r: Fix pt_regs for !COFNIG_ISA_DSP_LEVEL2 targetHirokazu Takata
This modification is required to fix debugging function for m32r targets with !CONFIG_ISA_DSP_LEVEL2, by unifying 'struct pt_regs' and 'struct sigcontext' size for all M32R ISA. Some m32r processor core with !CONFIG_ISA_DSP_LEVEL2 configuration has only single accumulator a0 (ex. VDEC2 core, M32102 core, etc.), the others with CONFIG_ISA_DSP_LEVEL2 has two accumulators, a0 and a1. This means there are two variations of thread context. So far, we reduced and changed stackframe size at a syscall for their context size. However, this causes a problem that a GDB for processors with CONFIG_ISA_DSP_LEVEL2 cannot be used for processors with !CONFIG_ISA_DSP_LEVEL2. From the viewpoint of GDB support, we should reduce such variation of stackframe size for simplicity. In this patch, dummy members are added to 'struct pt_regs' and 'struct sigcontext' to adjust their size for !CONFIG_ISA_DSP_LEVEL2. This modification is also a one step for a GDB update in future. Currently, on the m32r, GDB can access process's context by using ptrace functions in a simple way of register by register access. By unifying stackframe size, we have a possibility to make use of ptrace functions of not only a single register access but also block register access, PTRACE_{GETREGS,PUTREGS}. However, for this purpose, we might have to modify stackframe structure some more; for example, PSW (processor status word) register should be pre-processed before pushing to stack at a syscall, and so on. In this case, we must update carefully both kernel and GDB at a time... Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Kei Sakamoto <ksakamot@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] No arch-specific strpbrk implementationsKyle McMartin
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't being exported from lib/string.c. Investigating further, I noticed a changeset that removed its export and added it to _ksyms.c on a few more architectures. The justification was that "other arches do it." I think this is wrong, since no architecture currently defines __HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it themselves. Therefore, consolidate the export to lib/string.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] m32r: Remove symbols exported twiceHirokazu Takata
Remove multi-exported symbols from arch/m32r/kernel/m32r_ksyms.c. WARNING: vmlinux: 'enable_irq' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'disable_irq' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'disable_irq_nosync' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'synchronize_irq' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'memchr' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strstr' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'memscan' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'memcmp' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'memmove' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strnlen' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strchr' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strncmp' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strcmp' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strncat' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strcat' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strncpy' exported twice. Previous export was in vmlinux WARNING: vmlinux: 'strcpy' exported twice. Previous export was in vmlinux Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] m32r: security fix of {get,put}_user macrosHirokazu Takata
Update {get,put}_user macros for m32r kernel. - Modify get_user to use __get_user_asm macro, instead of __get_user_x macro. - Remove arch/m32r/lib/{get,put}user.S. - Some cosmetic updates. I would like to thank NIIBE Yutaka for his reporting about the m32r kernel's security problem in {get,put}_user macros. There were no address checking for user space access in {get,put}_user macros. ;-) Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: NIIBE Yutaka <gniibe@fsij.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] m32r: Fix cpu_possible_map and cpu_present_map initialization for ↵Hirokazu Takata
SMP kernel This patch fixes a boot problem of the m32r SMP kernel 2.6.16-rc1-mm3 or later. In this patch, cpu_possible_map is statically initialized, and cpu_present_map is also copied from cpu_possible_map in smp_prepare_cpus(), because the m32r architecture has not supported CPU hotplug yet. Signed-off-by: Hayato Fujiwara <fujiwara.hayato@renesas.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify PFN_* macrosDave Hansen
Just about every architecture defines some macros to do operations on pfns. They're all virtually identical. This patch consolidates all of them. One minor glitch is that at least i386 uses them in a very skeletal header file. To keep away from #include dependency hell, I stuck the new definitions in a new, isolated header. Of all of the implementations, sh64 is the only one that varied by a bit. It used some masks to ensure that any sign-extension got ripped away before the arithmetic is done. This has been posted to that sh64 maintainers and the development list. Compiles on x86, x86_64, ia64 and ppc64. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] m32r: fix and update for gcc-4.0Hirokazu Takata
Fix and update for gcc-4.0. - arch/m32r/kernel/signal.c: Change type of the 8th parameter of sys_rt_sigsuspend() from 'struct pt_regs' to 'struct pt_regs *'. This functions make use of the 'regs' parameter to return status value, but gcc-4.0 optimizes and removes it as a dead code. Functions, sys_sigaltstack() and sys_rt_sigreturn(), have also modified. - arch/m32r/lib/usercopy.c, include/asm-m32r/uaccess.h: Add early-clobber constraints('&') to output values of asm statements; these constraints seems to be required for gcc-4.0 register assignment. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-20[PATCH] m32r: update sys_tas() routineHirokazu Takata
This patch updates and fixes sys_tas() routine for m32r. In the previous implementation, a lockup rarely caused at sys_tas() routine in SMP environment. > > The problem is that touching *addr will generate an oops if that page isn't > > paged in. If we convert it to use get_user() then that's an improvement, > > but we must not run get_user() under spinlock or local_irq_disable(). I rewrote sys_tas() routine by using "lock -> unlock" instructions, and utilizing the m32r's interrupt handling characteristics; the m32r processor can accept interrupts only at the 32-bit instruction boundary. So, the "unlock" instruction can be executed continuously after the "lock" instruction execution without any interruptions. In addition, to solve such a page_fault problem, I use a fixup code like get_user(). And, as for the kernel lockup problem, we found that a calling do_page_fault() routine with disabling interrupts might cause a lockup at flush_tlb_others(), because we checked a completion of IPI handler's operations in a spin-locked critical section. Therefore, by using "lock -> unlock" code, we can implement the sys_tas() rouitine without disabling interrupts explicitly, then no lockups would happen at flush_tlb_others(), I hope. Compile check and some working test in SMP environment have done. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] drive_info removal outside of arch/i386Al Viro
drive_info is used only by hd.c and that happens under #ifdef __i386__. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-12[PATCH] m32r: task_pt_regs(), task_stack_page(), task_thread_info()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Don't attempt to power off if power off is not implementedEric W. Biederman
The problem. It is expected that /sbin/halt -p works exactly like /sbin/halt, when the kernel does not implement power off functionality. The kernel can do a lot of work in the reboot notifiers and in device_shutdown before we even get to machine_power_off. Some of that shutdown is not safe if you are leaving the power on, and it definitely gets in the way of using sysrq or pressing ctrl-alt-del. Since the shutdown happens in generic code there is no way to fix this in architecture specific code :( Some machines are kernel oopsing today because of this. The simple solution is to turn LINUX_REBOOT_CMD_POWER_OFF into LINUX_REBOOT_CMD_HALT if power_off functionality is not implemented. This has the unfortunate side effect of disabling the power off functionality on architectures that leave pm_power_off to null and still implement something in machine_power_off. And it will break the build on some architectures that don't have a pm_power_off variable at all. On both counts I say tough. For architectures like alpha that don't implement the pm_power_off variable pm_power_off is declared in linux/pm.h and it is a generic part of our power management code, and all architectures should implement it. For architectures like parisc that have a default power off method in machine_power_off if pm_power_off is not implemented or fails. It is easy enough to set the pm_power_off variable. And nothing bad happens there, the machines just stop powering off. The current semantics are impossible without a flag at the top level so we can avoid the problem code if a power off is not implemented. pm_power_off is as good a flag as any with the bonus that it works without modification on at least x86, x86_64, powerpc, and ppc today. Andrew can you pick this up and put this in the mm tree. Kernels that don't compile or don't power off seem saner than kernels that oops or panic. Until we get the arch specific patches for the problem architectures this probably isn't smart to push into the stable kernel. Unfortunately I don't have the time at the moment to walk through every architecture and make them work. And even if I did I couldn't test it :( From: Hirokazu Takata <takata@linux-m32r.org> Add pm_power_off() for build fix of arch/m32r/kernel/process.c. From: Miklos Szeredi <miklos@szeredi.hu> UML build fix Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] use ptrace_get_task_struct in various placesChristoph Hellwig
The ptrace_get_task_struct() helper that I added as part of the ptrace consolidation is useful in variety of places that currently opencode it. Switch them to the common helpers. Add a ptrace_traceme() helper that needs to be explicitly called, and simplify the ptrace_get_task_struct() interface. We don't need the request argument now, and we return the task_struct directly, using ERR_PTR() for error returns. It's a bit more code in the callers, but we have two sane routines that do one thing well now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Remove unnecessary icu_data_t definitionsHirokazu Takata
This patch removes unnecessary struct icu_data_t definitions of arch/m32r/kernel/setup_*.c. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Update _port2addr to use NONCACHE_OFFSETHirokazu Takata
Modify _port2addr*() routines in arch/m32r/kernel/io_*.c to use NONCACHE_OFFSET instead of hard-coding of a constant address. This modification is also required to support an M3A-ZA36 FPGA eva board in case an MMU-less synthesizable m32r core is used. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Support M32104UT target platformHirokazu Takata
This patch is for supporting a new target platform, Renesas M32104UT evaluation board. The M32104UT is an eval board based on an uT-Engine specification. This board has an MMU-less M32R family processor, M32104. http://www-wa0.personal-media.co.jp/pmc/archive/te/te_m32104_e.pdf This board is one of the most popular M32R platform, so we have ported Linux/M32R to it. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: trivial fix to remove unused instructionsHirokazu Takata
A trivial fix to remove unused instructions. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] m32r: M3A-2170(Mappi-III) IDE supportHirokazu Takata
This patch is for supporting IDE interface for M3A-2170(Mappi-III) board. Signed-off-by: Mamoru Sakugawa <sakugawa@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] m32r: Fix sys_tas() syscallHirokazu Takata
This patch fixes a deadlock problem of the m32r SMP kernel. In the m32r kernel, sys_tas() system call is provided as a test-and-set function for userspace, for backward compatibility. In some multi-threading application program, deadlocks were rarely caused at sys_tas() funcion. Such a deadlock was caused due to a collision of __pthread_lock() and __pthread_unlock() operations. The "tas" syscall is repeatedly called by pthread_mutex_lock() to get a lock, while a lock variable's value is not 0. On the other hand, pthead_mutex_unlock() sets the lock variable to 0 for unlocking. In the previous implementation of sys_tas() routine, there was a possibility that a unlock operation was ignored in the following case: - Assume a lock variable (*addr) was equal to 1 before sys_tas() execution. - __pthread_unlock() operation is executed by the other processor and the lock variable (*addr) is set to 0, between a read operation ("oldval = *addr;") and the following write operation ("*addr = 1;") during a execution of sys_tas(). In this case, the following write operation ("*addr = 1;") overwrites the __pthread_unlock() result, and sys_tas() fails to get a lock in the next turn and after that. According to the attatched patch, sys_tas() returns 0 value in the next turn and deadlocks never happen. Signed-off-by: Hitoshi Yamamoto <Yamamoto.Hitoshi@ap.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] unify sys_ptrace prototypeChristoph Hellwig
Make sure we always return, as all syscalls should. Also move the common prototype to <linux/syscalls.h> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: SMC91x driver updateHirokazu Takata
Update SMC91x driver for m32r. - Remove needless NONCACHE_OFFSET adjustment. > [PATCH 2.6.14-rc4] m32r: NONCACHE_OFFSET in _port2addr > Change _port2addr() not to add NONCACHE_OFFSET. > Adding NONCACHE_OFFSET requires needless address adjusting by a driver > using ioremap() like a SMC91x driver. - Fix lots of warnings as following: /usr/src/ctest/git/kernel/drivers/net/smc91x.c: In function `smc_reset': /usr/src/ctest/git/kernel/drivers/net/smc91x.c:324: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:325: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:341: warning: passing arg 2 of `_outw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:342: warning: passing arg 2 of `_outw' makes integer from pointer without a cast : /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast /usr/src/ctest/git/kernel/drivers/net/smc91x.c:1915: warning: passing arg 1 of `_inw' makes integer from pointer without a cast Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: NONCACHE_OFFSET in _port2addrHirokazu Takata
Change _port2addr() not to add NONCACHE_OFFSET. Adding NONCACHE_OFFSET requires needless address adjusting by a driver using ioremap() like a SMC91x driver. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: fix #if warningsHirokazu Takata
Fix warnings for #if directives. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] m32r: remove unused instructionsHirokazu Takata
Remove unused instructions for debugging. Signed-off-by: Naoto Sugai <sugai@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-14[PATCH] m32r: Fix smp.c for preempt kernelHirokazu Takata
This patch fixes the following BUG message of arch/m32r/smp.c for CONFIG_DEBUG_PREEMPT: BUG: using smp_processor_id() in preemptible This message is displayed by an smp_processor_id() execution during kernel's preemptible-state. Signed-off-by: Hitoshi Yamamoto <hitoshiy@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11[PATCH] m32r: trap handler code for illegal trapsHirokazu Takata
This patch prevents illegal traps from causing m32r kernel's infinite loop execution. Signed-off-by: Naoto Sugai <sugai@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: frv,m32r,sparc64 introduce fake asm-offsets.h fileSam Ravnborg
Needed to get them to build. And a hint to avoid hardcoding to many constants in assembler. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] m32r icu_data gcc4 fixesAl Viro
either icu_data declaration for SMP case should be taken out of m32102.h, or its declarations for m32700ut and opsput should not be static for SMP. Patch does the latter - judging by comments in m32102.h it is intended to be non-static. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] m32r smp.h gcc4 fixesAl Viro
extern on physid_2_cpu[] does not belong in smp.h - the thing is static. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] m32r: Fix local-timer event handlingHirokazu Takata
There was a scheduling problem of the m32r SMP kernel; A process rarely stopped and gave no responding but the other process have been handled by the other CPU still lives, then if we did something in the other terminal or something like that, the stopped process came back to life and continued its operation... (ex. LMbench: lat_sig) In the m32r SMP kernel, a local-timer event is delivered by using an IPI(inter processor interrupts); LOCAL_TIMER_IPI. And a function smp_send_timer() is prepared to send the LOCAL_TIMER_IPI from the current CPU to the other CPUs. The funtion smp_send_timer() was placed and used in do_IRQ() in former times (before 2.6.10-rc3-mm1 kernel), however, it was unintentionally removed when arch/m32r/kernel/irq.c was modified to employ the generic hardirq framework (CONFIG_GENERIC_HARDIRQ) in my previous patch. [PATCH 2.6.10-rc3-mm1] m32r: Use generic hardirq framework http://www.ussg.iu.edu/hypermail/linux/kernel/0412.2/0358.html The following patch fixes the above problem. Signed-off-by: Hitoshi Yamamoto <hitoshiy@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] m32r: framebuffer device supportHirokazu Takata
This patch is for supporting Epson s1d13xxx framebuffer device for m32r. # Sorry, a little bigger. The Epson s1d13806 is already supported by 2.6.12 kernel, and its driver is placed as drivers/video/s1d13xxxfb.c. For the m32r, a header file include/asm-m32r/s1d13806.h was prepared for several m32r target platforms. It was originally generated by an Epson tool S1D13806CFG.EXE, and modified manually for the m32r platforms. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Update setup_xxxxx.cHirokazu Takata
Change coding styles of hw_interrupt_type struct's initialization portions. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Support M3A-2170(Mappi-III) platformHirokazu Takata
This patchset is for supporting a new m32r platform, M3A-2170(Mappi-III) evaluation board. An M32R chip multiprocessor is equipped on the board. http://http://www.linux-m32r.org/eng/platform/platform.html * arch/m32r/Kconfig: Support Mappi-III platform. * arch/m32r/kernel/Makefile: ditto. * arch/m32r/kernel/io_mappi3.c: ditto. * arch/m32r/kernel/setup.c: ditto. * arch/m32r/kernel/setup_mappi3.c: ditto. * include/asm-m32r/m32102.h: ditto. * include/asm-m32r/m32r.h: ditto. * include/asm-m32r/mappi3/mappi3_pld.h: ditto. * include/asm-m32r/ide.h: CF support for Mappi-III. * arch/m32r/kernel/setup_mappi3.c: ditto. * arch/m32r/mappi3/defconfig.smp: A default config file for Mappi-III. * arch/m32r/mappi3/dot.gdbinit: A default .gdbinit file for Mappi-III. * arch/m32r/boot/compressed/m32r_sio.c: Modified for Mappi-III - At boot time, m32r-g00ff bootloader makes MMU off for Mappi-III, on the contrary it makes MMU on for Mappi-II. * arch/m32r/kernel/io_mappi2.c: Update comments. * arch/m32r/kernel/setup_mappi2.c: ditto. Signed-off-by: Mamoru Sakugawa <sakugawa@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] convert that currently tests _NSIG directly to use valid_signal()Jesper Juhl
Convert most of the current code that uses _NSIG directly to instead use valid_signal(). This avoids gcc -W warnings and off-by-one errors. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
