path: root/arch/m32r/kernel
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-04m32r: Fix IPI function calls for SMPToshihiro HANAWA
This patch fixes the m32r SMP kernel after 2.6.27. A part of the following patch breaks m32r SMP operation. > m32r: convert to generic helpers for IPI function calls > commit 7b7426c8a615cf61df9a77b9df7d5b75d91e3fa0 In the above patch, a CALL_FUNC_SINGLE_IPI was newly introduced, but the its IPI vector number was wrong in the patch code. The m32r SMP kernel hanged-up during boot operation, because the CPU_BOOT_IPI was called instead of CALL_FUNC_SINGLE_IPI (CPU_BOOT_IPI had no side effect at that time because the 2nd core had already been started up), as a result, csd_unlock() was not called, then a dead lock occurred in csd_lock_wait() after the detection of Compact Flash memory as IDE generic disk. Signed-off-by: Toshihiro HANAWA <hanawa@ccs.tsukuba.ac.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-10-04m32r: add rtc_lock variableHirokazu Takata
Add a spinlock variable "rtc_lock". This is taken from arch/arm/kernel/time.c. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-10-04m32r: export delay loop symbolsHirokazu Takata
- Move EXPORT_SYMBOL lines of delay loop functions from arch/m32r/kernel/m32r_ksyms.c to arch/m32r/lib/delay.c. - Export __ndelay. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-24Merge branch 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_devLinus Torvalds
* 'for-linus' of git://www.linux-m32r.org/git/takata/linux-2.6_dev: m32r: Cleanup linker script using new linker script macros. m32r: Move the spi_stack_top and spu_stack_top into .init.data section. m32r: Remove unused .altinstructions and .exit.* code from linker script. m32r: Move GET_THREAD_INFO definition out of asm/thread_info.h. m32r: Define THREAD_SIZE only once. m32r: make PAGE_SIZE available to assembly.
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-24cpumask: use mm_cpumask() wrapper: m32rRusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask. It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Hirokazu Takata <takata@linux-m32r.org> (fixes)
2009-09-24cpumask: Use accessors for cpu_*_mask: m32rRusty Russell
Use the accessors rather than frobbing bits directly (the new versions are const). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2009-09-24cpumask: arch_send_call_function_ipi_mask: m32rRusty Russell
We're weaning the core code off handing cpumask's around on-stack. This introduces arch_send_call_function_ipi_mask(), and by defining it, the old arch_send_call_function_ipi is defined by the core code. We also take the chance to wean the implementations off the obsolescent for_each_cpu_mask(): making send_ipi_mask take the pointer seemed the most natural way to ensure all implementations used for_each_cpu. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23m32r: Cleanup linker script using new linker script macros.Tim Abbott
This patch is largely a straightforward conversion. One thing to note is that the new macros use fewer separate output sections than the old code; this should have no functional impact but is relevant for people objdumping vmlinux files. Also note that it moves the .data.init_task output sections inside _edata. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-23m32r: Move the spi_stack_top and spu_stack_top into .init.data section.Tim Abbott
Since these get squashed into the .data output section by the m32r linker script, it seems likely that they don't need their own input sections. At Hirokazu Takata's suggestion, we place these structures in .init.data rather than just placing them in .data (since they are only used at init time). This patch is preparation for cleaning up the m32r architecture to use the new macros in vmlinux.lds.h; if these sections are indeed not needed, then we can use the RW_DATA_SECTION macro for m32r and save a bunch of redundant code. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-23m32r: Remove unused .altinstructions and .exit.* code from linker script.Tim Abbott
It appears that m32r copied the .altinstructions definition from x86 when the architecture was first merged into Linux. m32r doesn't put anything in .altinstructions, so this is just dead code. The following block affecting .exit.text/.exit.data, which has a comment also copied from x86, should also be deleted; the linker script later discards the .exit.text and .exit.data sections. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-23m32r: Move GET_THREAD_INFO definition out of asm/thread_info.h.Tim Abbott
Previously, asm/thread_info.h was not usable from linker scripts because it contains a piece of .macro code. Since that code was only used in the m32r entry.S, the right fix is probably to move the macro there. Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-09-22m32r: convert to use arch_gettimeoffset()john stultz
Convert m32r to use GENERIC_TIME via the arch_getoffset() infrastructure, reducing the amount of arch specific code we need to maintain. I also noted that m32r doesn't seem to be taking the xtime write lock before calling do_timer()! That looks like a pretty bad bug to me. If folks agree, let me know and I can move the lock grab to the correct spot. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22m32r: remove redundant tests on unsignedRoel Kluin
`off' and `max_cpus' are unsigned. When negative they are wrapped and caught by the other test. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-09KEYS: Add missing linux/tracehook.h #inclusionsDavid Howells
Add #inclusions of linux/tracehook.h to those arch files that had the tracehook call for TIF_NOTIFY_RESUME added when support for that flag was added to that arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-18ptrace: remove PT_DTRACE from arch/m32rOleg Nesterov
m32r: PTRACE_SINGLESTEP sets PT_DTRACE, it is never used except cleared after do_execve(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-12module: cleanup FIXME comments about trimming exception table entries.Rusty Russell
Everyone cut and paste this comment from my original one. We now do it generically, so cut the comments. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Amerigo Wang <amwang@redhat.com>
2009-05-02m32r: build fix for __stringify macroHirokazu Takata
This patch fixes the following build error of 2.6.30-rc3-git2: AS arch/m32r/kernel/head.o In file included from /include/linux/init.h:7, from /arch/m32r/kernel/head.S:11: /include/linux/stringify.h:9: error: syntax error in macro parameter list /include/linux/stringify.h:10: error: syntax error in macro parameter list This build error was caused at __HEAD macro in arch/m32r/kernel/head.S, which uses __stringify() macro. Remove -traditional option from EXTRA_AFLAGS for the m32r, because the __stringify() macro depends on the gcc's variadic macro extension function, due to commit: Make __stringify support variable argument macros too commit: 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4 Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2009-04-26m32r: convert to use __HEAD and HEAD_TEXT macros.Tim Abbott
This has the consequence of changing the section name use for head code from ".text.head" to ".head.text". Since this commit changes all users in the architecture, this change should be harmless. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Simplify copy_thread()Alexey Dobriyan
First argument unused since 2.3.11. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2009-01-11sparseirq: use kstat_irqs_cpu insteadYinghai Lu
Impact: build fix Ingo Molnar wrote: > tip/arch/blackfin/kernel/irqchip.c: In function 'show_interrupts': > tip/arch/blackfin/kernel/irqchip.c:85: error: 'struct kernel_stat' has no member named 'irqs' > make[2]: *** [arch/blackfin/kernel/irqchip.o] Error 1 > make[2]: *** Waiting for unfinished jobs.... > So could move kstat_irqs array to irq_desc struct. (s390, m68k, sparc) are not touched yet, because they don't support genirq Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-03Merge branch 'cpus4096-for-linus-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits) x86: setup_per_cpu_areas() cleanup cpumask: fix compile error when CONFIG_NR_CPUS is not defined cpumask: use alloc_cpumask_var_node where appropriate cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t x86: use cpumask_var_t in acpi/boot.c x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids sched: put back some stack hog changes that were undone in kernel/sched.c x86: enable cpus display of kernel_max and offlined cpus ia64: cpumask fix for is_affinity_mask_valid() cpumask: convert RCU implementations, fix xtensa: define __fls mn10300: define __fls m32r: define __fls h8300: define __fls frv: define __fls cris: define __fls cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS cpumask: zero extra bits in alloc_cpumask_var_node cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/ cpumask: convert mm/ ...
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2009-01-01percpu: fix percpu accessors to potentially !cpu_possible() cpus: m32rRusty Russell
Impact: CPU iterator bugfixes Percpu areas are only allocated for possible cpus. In general, you shouldn't access random cpu's percpu areas. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Hirokazu Takata <takata@linux-m32r.org>
2008-12-31take init_fs to saner placeAl Viro
2008-12-13cpumask: centralize cpu_online_map and cpu_possible_mapRusty Russell
Impact: cleanup Each SMP arch defines these themselves. Move them to a central location. Twists: 1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a CONFIG_INIT_ALL_POSSIBLE for this rather than break them. 2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'. Those archs simply have phys_cpu_present_map replaced everywhere. 3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky so I just manipulate them both in sync. 4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map' declarations. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Travis <travis@sgi.com> Cc: ink@jurassic.park.msu.ru Cc: rmk@arm.linux.org.uk Cc: starvik@axis.com Cc: tony.luck@intel.com Cc: takata@linux-m32r.org Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: paulus@samba.org Cc: schwidefsky@de.ibm.com Cc: lethal@linux-sh.org Cc: wli@holomorphy.com Cc: davem@davemloft.net Cc: jdike@addtoit.com Cc: mingo@redhat.com
2008-11-30m32r: section noise in head.SAl Viro
usual "introduce .text.head, put it in front of TEXT_TEXT in vmlinux.lds.S, make the stuff up to jump to start_kernel live in it", same as on other targets. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: m32r: fix build due to notify_cpu_starting() change powerpc: fix linux-next build failure
2008-10-16misc: replace __FUNCTION__ with __func__Harvey Harrison
2008-10-16m32r: fix build due to notify_cpu_starting() changeIngo Molnar
fix: arch/m32r/kernel/smpboot.c:501: err or: implicit declaration of function 'notify_cpu_starting' make[2]: *** [arch/m32r/kernel/smpboot.o] Error 1 make[2]: *** Waiting for unfinished jobs.... Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-08Merge branches 'sched/devel', 'sched/cpu-hotplug', 'sched/cpusets' and ↵Ingo Molnar
'sched/urgent' into sched/core
2008-09-27m32r/kernel/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - entry.S: resume_userspace - process.c: pm_idle - process.c: default_idle() - smp.c: send_IPI_allbutself() - time.c: timer_interrupt() - time.c: struct irq0 - traps.c: set_eit_vector_entries() - traps.c: kstack_depth_to_print - traps.c: show_trace() - traps.c: die_lock - remove the following unused code: - head.S: startup_32 - process.c: hlt_counter - process.c: disable_hlt() - process.c: enable_hlt() - process.c: dump_task_regs() - remove the following variables and their usages since they were always 0: - irq.c: irq_err_count - irq.c: irq_mis_count Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: export empty_zero_pageAdrian Bunk
ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-08kernel/cpu.c: create a CPU_STARTING cpu_chain notifierManfred Spraul
Right now, there is no notifier that is called on a new cpu, before the new cpu begins processing interrupts/softirqs. Various kernel function would need that notification, e.g. kvm works around by calling smp_call_function_single(), rcu polls cpu_online_map. The patch adds a CPU_STARTING notification. It also adds a helper function that sends the message to all cpu_chain handlers. Tested on x86-64. All other archs are untested. Especially on sparc, I'm not sure if I got it right. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26smp_call_function: get rid of the unused nonatomic/retry argumentJens Axboe
It's never used and the comments refer to nonatomic and retry interchangably. So get rid of it. Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-26m32r: convert to generic helpers for IPI function callsJens Axboe
This converts m32r to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Not tested, not even compiled. Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-16[PATCH] take init_files to fs/file.cAl Viro
2008-05-09m32r: use generic sys_pipeChristoph Hellwig
m32r can use the generic sys_pipe implementation. The current sys_pipe implementation on m32r only differes from the generic one by passing a lot of additional unused registers to sys_pipe. Reviewed and tested by Hirokazu Takata. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
