path: root/arch/m32r/kernel/time.c
2006-01-06[PATCH] m32r: Support M32104UT target platformHirokazu Takata
This patch is for supporting a new target platform, Renesas M32104UT evaluation board. The M32104UT is an eval board based on an uT-Engine specification. This board has an MMU-less M32R family processor, M32104. http://www-wa0.personal-media.co.jp/pmc/archive/te/te_m32104_e.pdf This board is one of the most popular M32R platform, so we have ported Linux/M32R to it. Signed-off-by: Naoto Sugai <Sugai.Naoto@ak.MitsubishiElectric.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] m32r: Fix local-timer event handlingHirokazu Takata
There was a scheduling problem of the m32r SMP kernel; A process rarely stopped and gave no responding but the other process have been handled by the other CPU still lives, then if we did something in the other terminal or something like that, the stopped process came back to life and continued its operation... (ex. LMbench: lat_sig) In the m32r SMP kernel, a local-timer event is delivered by using an IPI(inter processor interrupts); LOCAL_TIMER_IPI. And a function smp_send_timer() is prepared to send the LOCAL_TIMER_IPI from the current CPU to the other CPUs. The funtion smp_send_timer() was placed and used in do_IRQ() in former times (before 2.6.10-rc3-mm1 kernel), however, it was unintentionally removed when arch/m32r/kernel/irq.c was modified to employ the generic hardirq framework (CONFIG_GENERIC_HARDIRQ) in my previous patch. [PATCH 2.6.10-rc3-mm1] m32r: Use generic hardirq framework http://www.ussg.iu.edu/hypermail/linux/kernel/0412.2/0358.html The following patch fixes the above problem. Signed-off-by: Hitoshi Yamamoto <hitoshiy@isl.melco.co.jp> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
