path: root/arch/m32r/kernel/setup_mappi.c
2007-09-03m32r: Rearrange platform-dependent codesHirokazu Takata
Rearrange platform-dependent codes from arch/m32r/kernel/*.c to arch/m32r/platforms/{platform}/. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2007-07-26m32r: Fix ei_tx_timeout() in drivers/net/lib8390.cHirokazu Takata
Change INT0 trigger mode from edge-sense mode to level-sense mode, in order to fix the following timeout error: 'NETDEV WATCHDOG: eth0: transmit timed out'. This patch is required only for the Mappi platform. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Hitoshi Yamamoto <hitoshiy@linux-m32r.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-11[PATCH] m32r: NULL noise removalAl Viro
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m32r: Remove unnecessary icu_data_t definitionsHirokazu Takata
This patch removes unnecessary struct icu_data_t definitions of arch/m32r/kernel/setup_*.c. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-07[PATCH] m32r: framebuffer device supportHirokazu Takata
This patch is for supporting Epson s1d13xxx framebuffer device for m32r. # Sorry, a little bigger. The Epson s1d13806 is already supported by 2.6.12 kernel, and its driver is placed as drivers/video/s1d13xxxfb.c. For the m32r, a header file include/asm-m32r/s1d13806.h was prepared for several m32r target platforms. It was originally generated by an Epson tool S1D13806CFG.EXE, and modified manually for the m32r platforms. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] m32r: Update setup_xxxxx.cHirokazu Takata
Change coding styles of hw_interrupt_type struct's initialization portions. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
