path: root/arch/ia64
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: Phonet: keep TX queue disabled when the device is off SCHED: netem: Correct documentation comment in code. netfilter: update rwlock initialization for nat_table netlabel: Compiler warning and NULL pointer dereference fix e1000e: fix double release of mutex IA64: HP_SIMETH needs to depend upon NET netpoll: fix race on poll_list resulting in garbage entry ipv6: silence log messages for locally generated multicast sungem: improve ethtool output with internal pcs and serdes tcp: tcp_vegas cong avoid fix sungem: Make PCS PHY support partially work again.
2008-12-10IA64: HP_SIMETH needs to depend upon NETAlexander Beregalov
From: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09[IA64] SN: prevent IRQ retargetting in request_irq()John Keller
With the introduction of the generic affinity autoselector, irq_select_affinity(), IRQs are now being retargetted, using a default mask, via the request_irq() path. This results in all IRQs targetted at CPU 0. SN Altix assigns affinity in the SN PROM, and does not expect that to be changed as part of request_irq(). Set the IRQ_AFFINITY_SET flag to prevent request_irq() from resetting affinity. Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-09[IA64] Clear up section mismatch with arch_unregister_cpu()Robin Holt
The generic_defconfig has three section mismatches. This clears arch_unregister_cpu() Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-09[IA64] Clear up section mismatch for sn_check_wars.Robin Holt
The generic_defconfig has three section mismatches. This clears up sn_check_wars(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-09[IA64] Updated the generic_defconfig to work with the 2.6.28-rc7 kernel.Robin Holt
The AUTOFS=y and AUTOFS4=y causes problems with some distros versions of automount. I turned both of those to =m and then followed the default prompts for everything else. I did notice that CONFIG_PNP_DEBUG got changed to CONFIG_PNP_DEBUG_MESSAGES and the default was a =y so I turned that back to a =n. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-09[IA64] eliminate NULL test and memset after alloc_bootmemJulia Lawall
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem and related functions never return NULL and always return a zeroed region of memory. Thus a NULL test or memset after calls to these functions is unnecessary. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-09[IA64] remove BUILD_BUG_ON from paravirt_getreg()Alexey Dobriyan
CC arch/ia64/kernel/asm-offsets.s In file included from include/linux/bitops.h:17, from include/linux/kernel.h:15, from include/linux/sched.h:52, from arch/ia64/kernel/asm-offsets.c:9: arch/ia64/include/asm/bitops.h: In function 'set_bit': arch/ia64/include/asm/bitops.h:47: error: implicit declaration of function 'BUILD_BUG_ON' Obvious inclusion of kernel.h doesn't fix it, because of circular dependencies involving fls.h and log2(). Fixing the latter requires some serious header surgery, it seems, so just remove BUILD_BUG_ON for now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-12-02Merge branch 'kvm-updates/2.6.28' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/2.6.28' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: KVM: MMU: avoid creation of unreachable pages in the shadow KVM: ppc: stop leaking host memory on VM exit KVM: MMU: fix sync of ptes addressed at owner pagetable KVM: ia64: Fix: Use correct calling convention for PAL_VPS_RESUME_HANDLER KVM: ia64: Fix incorrect kbuild CFLAGS override KVM: VMX: Fix interrupt loss during race with NMI KVM: s390: Fix problem state handling in guest sigp handler
2008-11-30remove __ARCH_WANT_COMPAT_SYS_PTRACEChristoph Hellwig
All architectures now use the generic compat_sys_ptrace, as should every new architecture that needs 32bit compat (if we'll ever get another). Remove the now superflous __ARCH_WANT_COMPAT_SYS_PTRACE define, and also kill a comment about __ARCH_SYS_PTRACE that was added after __ARCH_SYS_PTRACE was already gone. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-30sn_pci_controller_fixup() should be __initAl Viro
called only from __init Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-23KVM: ia64: Fix: Use correct calling convention for PAL_VPS_RESUME_HANDLERXiantao Zhang
PAL_VPS_RESUME_HANDLER should use r26 to hold vac fields according to SDM. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-11-23KVM: ia64: Fix incorrect kbuild CFLAGS overrideXiantao Zhang
Use CFLAGS_vcpu.o, not EXTRA_CFLAGS, to provide fixed register information to the compiler. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-11-20[IA64] xen: fix xen_get_eflags.Isaku Yamahata
fix xen_get_eflags. It doesn't take any argument. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-20[IA64] ia64/pv_ops/pv_cpu_ops: fix _IA64_REG_IP case.Isaku Yamahata
pv_cpu_ops.getreg(_IA64_REG_IP) returned constant. But the returned ip valued should be the one in the caller, not of the callee. This patch fixes that. Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-20[IA64] remove duplicate include iommu.hHuang Weiyi
arch/ia64/kernel/pci-dma.c only needs to include iommu once. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-20[IA64] use mprintk instead of printk, in ia64_mca_modify_original_stackHidetoshi Seto
Using printk from MCA/INIT context is unsafe since it can cause deadlock. The ia64_mca_modify_original_stack is called from both of mca handler and init handler, so it should use mprintk instead of printk. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-20[IA64] Rationalize kernel mode alignment checkingTony Luck
Itanium processors can handle some misaligned data accesses. They also provide a mode where all such accesses are forced to trap. The kernel was schizophrenic about use of this mode: * Base kernel code ran in permissive mode where the only traps generated were from those cases that the h/w could not handle. * Interrupt, syscall and trap code ran in strict mode where all unaligned accesses caused traps to the 0x5a00 unaligned reference vector. Use strict alignment checking throughout the kernel, but make sure that we continue to let user mode use more relaxed mode as the default. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the IA64 archDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-ia64@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-11KVM: ia64: fix vmm_spin_{un}lock for !CONFIG_SMPXiantao Zhang
In the case of !CONFIG_SMP, raw_spinlock_t is empty and the spinlock functions don't build. Fix by defining spinlock functions for the uniprocessor case. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-11-11KVM: Require the PCI subsystemAvi Kivity
PCI device assignment makes calls to pci code, so require it to be built into the kernel. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-11-11KVM: ia64: Use guest signal mask when blockingXiantao Zhang
Before a vcpu blocks, it should switch to the guest signal mask to allow signals to unblock it. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-11-07[IA64] Reserve elfcorehdr memory in CONFIG_CRASH_DUMPJay Lan
IA64 kdump kernel failed to initialize /proc/vmcore in 2.6.28-rc2. A bug was introduced in this patch commit: d9a9855d0b06ca6d6cc92596fedcc03f8512e062 always reserve elfcore header memory in crash kernel The problem was that the call to reserve_elfcorehdr() should be placed in CONFIG_CRASH_DUMP rather than in CONFIG_CRASH_KERNEL, which does not exist. Signed-off-by: Jay Lan <jlan@sgi.com> Acked-by: Simon Hormon <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-06[IA64] fix boot panic caused by offline CPUsDoug Chapman
This fixes a regression introduced by 2c6e6db41f01b6b4eb98809350827c9678996698 "Minimize per_cpu reservations." That patch incorrectly used information about what CPUs are possible that was not yet initialized by ACPI. The end result was that per_cpu structures for offline CPUs were not initialized causing a NULL pointer reference. Since we cannot do the full acpi_boot_init() call any earlier, the simplest fix is to just parse the MADT for SAPIC entries early to find the CPU info. This should also allow for some cleanup of the code added by the "Minimize per_cpu reservations". This patch just fixes the regressions, the cleanup will come in a later patch. Signed-off-by: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> CC: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-06[IA64] reorder Kconfig options to match x86Bjorn Helgaas
No functional change, just reorder some config options and update the "Power management and ACPI" label to match the defacto x86 standard. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] Build VT-D iommu support into generic kernelTony Luck
Now that all the ia64 mmu pieces are in the tree we can build support into the generic kernel. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] remove dead BIO_VMERGE_BOUNDARY definitionFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY definition is meaningless now (For IA64, BIO_VMERGE_BOUNDARY has been meaningless for a long time since IA64 disables the virtual merge feature). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] remove duplicated #include from pci-dma.cHuang Weiyi
Removed duplicated #include <asm/machvec.h> and <linux/string.h> in arch/ia64/kernel/pci-dma.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] use common header for software IO/TLBJoerg Roedel
Remove the swiotlb prototypes from the architecture code and use the common header file instead. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] fix the difference between node_mem_map and node_start_pfnKen'ichi Ohmichi
makedumpfile[1] cannot run on ia64 discontigmem kernel, because the member node_mem_map of struct pgdat_list has invalid value. This patch fixes it. node_start_pfn shows the start pfn of each node, and node_mem_map should point 'struct page' of each node's node_start_pfn. On my machine, node0's node_start_pfn shows 0x400 and its node_mem_map points 0xa0007fffbf000000. This address is the same as vmem_map, so the node_mem_map points 'struct page' of pfn 0, even if its node_start_pfn shows 0x400. The cause is due to the round down of min_pfn in count_node_pages() and node0's node_mem_map points 'struct page' of inactive pfn (0x0). This patch fixes it. makedumpfile[1]: dump filtering command https://sourceforge.net/projects/makedumpfile/ Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Cc: Bernhard Walle <bwalle@suse.de> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] Add error_recovery_info field to SAL section headerRuss Anderson
Add the error_recovery_info field to the SAL section header, as defined in the SAL Spec. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] Add UV watchlist support.Russ Anderson
This is used by SGI xp drivers (drivers/misc/sgi-xp). Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-04[IA64] Simplify SGI uv vs. sn2 driver issuesRuss Anderson
Add partition id, coherence id, and region size to UV to make life simpler for drivers shared between sn2 & uv. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/PCI: build failure at x86/kernel/pci-dma.c with !CONFIG_PCI
2008-10-28KVM: ia64: Makefile fix for forcing to re-generate asm-offsets.hXiantao Zhang
To avoid using stale asm-offsets.h. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-28KVM: ia64: Fix halt emulation logicXiantao Zhang
Common halt logic was changed by x86 and did not update ia64. This patch updates halt for ia64. Fixes a regression causing guests to hang with more than 2 vcpus. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-28KVM: Fix guest shared interrupt with in-kernel irqchipSheng Yang
Every call of kvm_set_irq() should offer an irq_source_id, which is allocated by kvm_request_irq_source_id(). Based on irq_source_id, we identify the irq source and implement logical OR for shared level interrupts. The allocated irq_source_id can be freed by kvm_free_irq_source_id(). Currently, we support at most sizeof(unsigned long) different irq sources. [Amit: - rebase to kvm.git HEAD - move definition of KVM_USERSPACE_IRQ_SOURCE_ID to common file - move kvm_request_irq_source_id to the update_irq ioctl] [Xiantao: - Add kvm/ia64 stuff and make it work for kvm/ia64 guests] Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-24x86/PCI: build failure at x86/kernel/pci-dma.c with !CONFIG_PCIFenghua Yu
On Thu, Oct 23, 2008 at 04:09:52PM -0700, Alexander Beregalov wrote: > arch/x86/kernel/built-in.o: In function `iommu_setup': > pci-dma.c:(.init.text+0x36ad): undefined reference to `forbid_dac' > pci-dma.c:(.init.text+0x36cc): undefined reference to `forbid_dac' > pci-dma.c:(.init.text+0x3711): undefined reference to `forbid_dac This patch partially reverts a patch to add IOMMU support to ia64. The forbid_dac variable was incorrectly moved to quirks.c, which isn't built when PCI is disabled. Tested-by: "Alexander Beregalov" <a.beregalov@gmail.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-23Merge branch 'v28-range-hrtimers-for-linus-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'v28-range-hrtimers-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits) hrtimers: add missing docbook comments to struct hrtimer hrtimers: simplify hrtimer_peek_ahead_timers() hrtimers: fix docbook comments DECLARE_PER_CPU needs linux/percpu.h hrtimers: fix typo rangetimers: fix the bug reported by Ingo for real rangetimer: fix BUG_ON reported by Ingo rangetimer: fix x86 build failure for the !HRTIMERS case select: fix alpha OSF wrapper select: fix alpha OSF wrapper hrtimer: peek at the timer queue just before going idle hrtimer: make the futex() system call use the per process slack value hrtimer: make the nanosleep() syscall use the per process slack hrtimer: fix signed/unsigned bug in slack estimator hrtimer: show the timer ranges in /proc/timer_list hrtimer: incorporate feedback from Peter Zijlstra hrtimer: add a hrtimer_start_range() function hrtimer: another build fix hrtimer: fix build bug found by Ingo hrtimer: make select() and poll() use the hrtimer range feature ...
2008-10-23Merge branch 'x86/um-header' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/um-header' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) x86: canonicalize remaining header guards x86: drop double underscores from header guards x86: Fix ASM_X86__ header guards x86, um: get rid of uml-config.h x86, um: get rid of arch/um/Kconfig.arch x86, um: get rid of arch/um/os symlink x86, um: get rid of excessive includes of uml-config.h x86, um: get rid of header symlinks x86, um: merge Kconfig.i386 and Kconfig.x86_64 x86, um: get rid of sysdep symlink x86, um: trim the junk from uml ptrace-*.h x86, um: take vm-flags.h to sysdep x86, um: get rid of uml asm/arch x86, um: get rid of uml highmem.h x86, um: get rid of uml unistd.h x86, um: get rid of system.h -> system.h include x86, um: uml atomic.h is not needed anymore x86, um: untangle uml ldt.h x86, um: get rid of more uml asm/arch uses x86, um: remove dead header (uml module-generic.h; never used these days) ...
2008-10-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (123 commits) dock: make dock driver not a module ACPI: fix ia64 build warning ACPI: hack around sysfs warning with link order ACPI suspend: fix build warning when CONFIG_ACPI_SLEEP=n intel_menlo: fix build warning panasonic-laptop: fix build ACPICA: Update version to 20080926 ACPICA: Add support for zero-length buffer-to-string conversions ACPICA: New: Validation for predefined ACPI methods/objects ACPICA: Fix for implicit return compatibility ACPICA: Fixed a couple memory leaks associated with "implicit return" ACPICA: Optimize buffer allocation procedure ACPICA: Fix possible memory leak, error exit path ACPICA: Fix fault after mem allocation failure in AML parser ACPICA: Remove unused ACPI register bit definition ACPICA: Update version to 20080829 ACPICA: Fix possible memory leak in acpi_ns_get_external_pathname ACPICA: Cleanup for internal Reference Object ACPICA: Update comments - no functional changes ACPICA: Update for Reference ACPI_OPERAND_OBJECT ...
2008-10-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile: (21 commits) OProfile: Fix buffer synchronization for IBS oprofile: hotplug cpu fix oprofile: fixing whitespaces in arch/x86/oprofile/* oprofile: fixing whitespaces in arch/x86/oprofile/* oprofile: fixing whitespaces in drivers/oprofile/* x86/oprofile: add the logic for enabling additional IBS bits x86/oprofile: reordering functions in nmi_int.c x86/oprofile: removing unused function parameter in add_ibs_begin() oprofile: more whitespace fixes oprofile: whitespace fixes OProfile: Rename IBS sysfs dir into "ibs_op" OProfile: Rework string handling in setup_ibs_files() OProfile: Rework oprofile_add_ibs_sample() function oprofile: discover counters for op ppro too oprofile: Implement Intel architectural perfmon support oprofile: Don't report Nehalem as core_2 oprofile: drop const in num counters field Revert "Oprofile Multiplexing Patch" x86, oprofile: BUG: using smp_processor_id() in preemptible code x86/oprofile: fix on_each_cpu build error ... Manually fixed trivial conflicts in drivers/oprofile/{cpu_buffer.c,event_buffer.h}
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (41 commits) [IA64] Fix annoying IA64_TR_ALLOC_MAX message. [IA64] kill sys32_pipe [IA64] remove sys32_pause [IA64] Add Variable Page Size and IA64 Support in Intel IOMMU ia64/pv_ops: paravirtualized instruction checker. ia64/xen: a recipe for using xen/ia64 with pv_ops. ia64/pv_ops: update Kconfig for paravirtualized guest and xen. ia64/xen: preliminary support for save/restore. ia64/xen: define xen machine vector for domU. ia64/pv_ops/xen: implement xen pv_time_ops. ia64/pv_ops/xen: implement xen pv_irq_ops. ia64/pv_ops/xen: define the nubmer of irqs which xen needs. ia64/pv_ops/xen: implement xen pv_iosapic_ops. ia64/pv_ops/xen: paravirtualize entry.S for ia64/xen. ia64/pv_ops/xen: paravirtualize ivt.S for xen. ia64/pv_ops/xen: paravirtualize DO_SAVE_MIN for xen. ia64/pv_ops/xen: define xen paravirtualized instructions for hand written assembly code ia64/pv_ops/xen: define xen pv_cpu_ops. ia64/pv_ops/xen: define xen pv_init_ops for various xen initialization. ia64/pv_ops/xen: elf note based xen startup. ...
