path: root/arch/ia64
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/viro/mmapLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/viro/mmap: Add missing alignment check in arch/score sys_mmap() fix broken aliasing checks for MAP_FIXED on sparc32, mips, arm and sh Get rid of open-coding in ia64_brk() sparc_brk() is not needed anymore switch do_brk() to get_unmapped_area() Take arch_mmap_check() into get_unmapped_area() fix a struct file leak in do_mmap_pgoff() Unify sys_mmap* Cut hugetlb case early for 32bit on ia64 arch_mmap_check() on mn10300 Kill ancient crap in s390 compat mmap arm: add arch_mmap_check(), get rid of sys_arm_mremap() file ->get_unmapped_area() shouldn't duplicate work of get_unmapped_area() kill useless checks in sparc mremap variants fix pgoff in "have to relocate" case of mremap() fix the arch checks in MREMAP_FIXED case fix checks for expand-in-place mremap do_mremap() untangling, part 3 do_mremap() untangling, part 2 untangling do_mremap(), part 1
2009-12-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (109 commits) PCI: fix coding style issue in pci_save_state() PCI: add pci_request_acs PCI: fix BUG_ON triggered by logical PCIe root port removal PCI: remove ifdefed pci_cleanup_aer_correct_error_status PCI: unconditionally clear AER uncorr status register during cleanup x86/PCI: claim SR-IOV BARs in pcibios_allocate_resource PCI: portdrv: remove redundant definitions PCI: portdrv: remove unnecessary struct pcie_port_data PCI: portdrv: minor cleanup for pcie_port_device_register PCI: portdrv: add missing irq cleanup PCI: portdrv: enable device before irq initialization PCI: portdrv: cleanup service irqs initialization PCI: portdrv: check capabilities first PCI: portdrv: move PME capability check PCI: portdrv: remove redundant pcie type calculation PCI: portdrv: cleanup pcie_device registration PCI: portdrv: remove redundant pcie_port_device_probe PCI: Always set prefetchable base/limit upper32 registers PCI: read-modify-write the pcie device control register when initiating pcie flr PCI: show dma_mask bits in /sys ... Fixed up conflicts in: arch/x86/kernel/amd_iommu_init.c drivers/pci/dmar.c drivers/pci/hotplug/acpiphp_glue.c
2009-12-11Get rid of open-coding in ia64_brk()Al Viro
The comment in there used to be true, but these days do_brk() does the arch-specific check that covers what we open-coded here. So we can use sys_brk() just fine, only need to do force_successful_syscall_return() after it. See commit 3a459756810912d2c2bf188cef566af255936b4d - that's when the checks in do_brk() had been originally added. Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-11Cut hugetlb case early for 32bit on ia64Al Viro
It won't work anyway (hugetlb addresses there are way beyond 4Gb) and it's easier to stop it here. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-09Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPICA: Update version to 20091112. ACPICA: Add additional module-level code support ACPICA: Deploy new create integer interface where appropriate ACPICA: New internal utility function to create Integer objects ACPICA: Add repair for predefined methods that must return sorted lists ACPICA: Fix possible fault if return Package objects contain NULL elements ACPICA: Add post-order callback to acpi_walk_namespace ACPICA: Change package length error message to an info message ACPICA: Reduce severity of predefined repair messages, Warning to Info ACPICA: Update version to 20091013 ACPICA: Fix possible memory leak for Scope ASL operator ACPICA: Remove possibility of executing _REG methods twice ACPICA: Add repair for bad _MAT buffers ACPICA: Add repair for bad _BIF/_BIX packages
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-09Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix cut/paste detritus from unistd.h
2009-12-08Merge branch 'timers-for-linus-urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: hrtimer: Fix /proc/timer_list regression itimers: Fix racy writes to cpu_itimer fields timekeeping: Fix clock_gettime vsyscall time warp
2009-12-08[IA64] Fix cut/paste detritus from unistd.hTony Luck
Build warning: <stdin>:1523:2: warning: #warning syscall recvmmsg not implemented Because when recvmmesg was added, the previous syscall define was cut&pasted, and a spurious "rt_" left in the name of the define. Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-08Merge branch 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (84 commits) KVM: VMX: Fix comparison of guest efer with stale host value KVM: s390: Fix prefix register checking in arch/s390/kvm/sigp.c KVM: Drop user return notifier when disabling virtualization on a cpu KVM: VMX: Disable unrestricted guest when EPT disabled KVM: x86 emulator: limit instructions to 15 bytes KVM: s390: Make psw available on all exits, not just a subset KVM: x86: Add KVM_GET/SET_VCPU_EVENTS KVM: VMX: Report unexpected simultaneous exceptions as internal errors KVM: Allow internal errors reported to userspace to carry extra data KVM: Reorder IOCTLs in main kvm.h KVM: x86: Polish exception injection via KVM_SET_GUEST_DEBUG KVM: only clear irq_source_id if irqchip is present KVM: x86: disallow KVM_{SET,GET}_LAPIC without allocated in-kernel lapic KVM: x86: disallow multiple KVM_CREATE_IRQCHIP KVM: VMX: Remove vmx->msr_offset_efer KVM: MMU: update invlpg handler comment KVM: VMX: move CR3/PDPTR update to vmx_set_cr3 KVM: remove duplicated task_switch check KVM: powerpc: Fix BUILD_BUG_ON condition KVM: VMX: Use shared msr infrastructure ... Trivial conflicts due to new Kconfig options in arch/Kconfig and kernel/Makefile
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits) security/tomoyo: Remove now unnecessary handling of security_sysctl. security/tomoyo: Add a special case to handle accesses through the internal proc mount. sysctl: Drop & in front of every proc_handler. sysctl: Remove CTL_NONE and CTL_UNNUMBERED sysctl: kill dead ctl_handler definitions. sysctl: Remove the last of the generic binary sysctl support sysctl net: Remove unused binary sysctl code sysctl security/tomoyo: Don't look at ctl_name sysctl arm: Remove binary sysctl support sysctl x86: Remove dead binary sysctl support sysctl sh: Remove dead binary sysctl support sysctl powerpc: Remove dead binary sysctl support sysctl ia64: Remove dead binary sysctl support sysctl s390: Remove dead sysctl binary support sysctl frv: Remove dead binary sysctl support sysctl mips/lasat: Remove dead binary sysctl support sysctl drivers: Remove dead binary sysctl support sysctl crypto: Remove dead binary sysctl support sysctl security/keys: Remove dead binary sysctl support sysctl kernel: Remove binary sysctl logic ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-05Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/pcmcia/fmvj18x_cs.c drivers/net/pcmcia/nmclan_cs.c drivers/net/pcmcia/xirc2ps_cs.c drivers/net/wireless/ray_cs.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03Merge branch 'master' into for-2.6.33Jens Axboe
2009-12-03KVM: Activate Virtualization On DemandAlexander Graf
X86 CPUs need to have some magic happening to enable the virtualization extensions on them. This magic can result in unpleasant results for users, like blocking other VMMs from working (vmx) or using invalid TLB entries (svm). Currently KVM activates virtualization when the respective kernel module is loaded. This blocks us from autoloading KVM modules without breaking other VMMs. To circumvent this problem at least a bit, this patch introduces on demand activation of virtualization. This means, that instead virtualization is enabled on creation of the first virtual machine and disabled on destruction of the last one. So using this, KVM can be easily autoloaded, while keeping other hypervisors usable. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move assigned device code to own fileAvi Kivity
2009-12-03KVM: Return -ENOTTY on unrecognized ioctlsAvi Kivity
Not the incorrect -EINVAL. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Drop kvm->irq_lock lock from irq injection pathGleb Natapov
The only thing it protects now is interrupt injection into lapic and this can work lockless. Even now with kvm->irq_lock in place access to lapic is not entirely serialized since vcpu access doesn't take kvm->irq_lock. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move IO APIC to its own lockGleb Natapov
The allows removal of irq_lock from the injection path. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq ack notifier list to arch independent codeGleb Natapov
Mask irq notifier list is already there. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Maintain back mapping from irqchip/pin to gsiGleb Natapov
Maintain back mapping from irqchip/pin to gsi to speedup interrupt acknowledgment notifications. [avi: build fix on non-x86/ia64] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-24ACPICA: Add post-order callback to acpi_walk_namespaceLin Ming
The existing interface only has a pre-order callback. This change adds an additional parameter for a post-order callback which will be more useful for bus scans. ACPICA BZ 779. Also update the external calls to acpi_walk_namespace. http://www.acpica.org/bugzilla/show_bug.cgi?id=779 Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-17timekeeping: Fix clock_gettime vsyscall time warpLin Ming
Since commit 0a544198 "timekeeping: Move NTP adjusted clock multiplier to struct timekeeper" the clock multiplier of vsyscall is updated with the unmodified clock multiplier of the clock source and not with the NTP adjusted multiplier of the timekeeper. This causes user space observerable time warps: new CLOCK-warp maximum: 120 nsecs, 00000025c337c537 -> 00000025c337c4bf Add a new argument "mult" to update_vsyscall() and hand in the timekeeping internal NTP adjusted multiplier. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Cc: "Zhang Yanmin" <yanmin_zhang@linux.intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> LKML-Reference: <1258436990.17765.83.camel@minggr.sh.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-11-15swiotlb: Remove duplicate swiotlb_force extern declarationsFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: tony.luck@intel.com LKML-Reference: <1258199198-16657-4-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-12sysctl ia64: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-10swiotlb: Defer swiotlb init printing, export swiotlb_print_info()FUJITA Tomonori
This enables us to avoid printing swiotlb memory info when we initialize swiotlb. After swiotlb initialization, we could find that we don't need swiotlb. This patch removes the code to print swiotlb memory info in swiotlb_init() and exports the function to do that. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com Cc: tony.luck@intel.com Cc: benh@kernel.crashing.org LKML-Reference: <1257849980-22640-9-git-send-email-fujita.tomonori@lab.ntt.co.jp> [ -v2: merge up conflict ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-06ia64/xen: compilation fixIsaku Yamahata
This patch fixes the following compilation error introduced by a PCI related features. The change set of 5dd1af9f84c79bedd589db89e71ca733f3bf0ebd moves some xen related definitions from the arch header file (x86/include/asm/xen/hypervisor.h) to the common header file (include/xen/xen.h). So ia64/xen also follows it. In file included from linux-next/include/xen/grant_table.h:41, from linux-next/drivers/block/xen-blkfront.c:48: linux-next/arch/ia64/include/asm/xen/hypervisor.h:43: error: nested redefinition of 'enum xen_domain_type' linux-next/arch/ia64/include/asm/xen/hypervisor.h:43: error: redeclaration of 'enum xen_domain_type' linux-next/arch/ia64/include/asm/xen/hypervisor.h:44: error: redeclaration of enumerator 'XEN_NATIVE' linux-next/include/xen/xen.h:5: error: previous definition of 'XEN_NATIVE' was here linux-next/arch/ia64/include/asm/xen/hypervisor.h:45: error: redeclaration of enumerator 'XEN_PV_DOMAIN' linux-next/include/xen/xen.h:6: error: previous definition of 'XEN_PV_DOMAIN' was here linux-next/arch/ia64/include/asm/xen/hypervisor.h:46: error: redeclaration of enumerator 'XEN_HVM_DOMAIN' linux-next/include/xen/xen.h:7: error: previous definition of 'XEN_HVM_DOMAIN' was here Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-06sysctl: ia64 Use the compat_sys_sysctlEric W. Biederman
Now that we have a generic 32bit compatibility implementation there is no need for ia64 to implement it's own. Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04ia64/PCI: print resources consistently with %pRtBjorn Helgaas
This uses %pRt to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: determine CLS more intelligentlyJesse Barnes
Till now, CLS has been determined either by arch code or as L1_CACHE_BYTES. Only x86 and ia64 set CLS explicitly and x86 doesn't always get it right. On most configurations, the chance is that firmware configures the correct value during boot. This patch makes pci_init() determine CLS by looking at what firmware has configured. It scans all devices and if all non-zero values agree, the value is used. If none is configured or there is a disagreement, pci_dfl_cache_line_size is used. arch can set the dfl value (via PCI_CACHE_LINE_BYTES or pci_dfl_cache_line_size) or override the actual one. ia64, x86 and sparc64 updated to set the default cls instead of the actual one. While at it, declare pci_cache_line_size and pci_dfl_cache_line_size in pci.h and drop private declarations from arch code. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Miller <davem@davemloft.net> Acked-by: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-02Revert "[IA64] fix percpu warnings"Tony Luck
This reverts commit b94b08081fcecf83fa690d6c5664f6316fe72208. genksyms currently cannot handle complicated types for exported percpu variables. Drop this patch for now as it prevents a module from being loaded on sn2 systems: xpc: no symbol version for per_cpu____sn_cnodeid_to_nasid xpc: Unknown symbol per_cpu____sn_cnodeid_to_nasid Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-29percpu: make percpu symbols in ia64 uniqueTejun Heo
This patch updates percpu related symbols in ia64 such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * arch/ia64/kernel/setup.c: s/cpu_info/ia64_cpu_info/ Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: linux-ia64@vger.kernel.org
2009-10-29percpu: make percpu symbols in xen uniqueTejun Heo
This patch updates percpu related symbols in xen such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * arch/x86/xen/smp.c, arch/x86/xen/time.c, arch/ia64/xen/irq_xen.c: add xen_ prefix to percpu variables * arch/ia64/xen/time.c: add xen_ prefix to percpu variables, drop processed_ prefix and make them static Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org>
2009-10-23Pull ticket-spinaphore into release branchTony Luck
2009-10-23Pull ticket4byte into release branchTony Luck
2009-10-15[IA64] fix percpu warningsRandy Dunlap
Fix percpu types warning in ia64/sn: arch/ia64/sn/kernel/setup.c:74: error: conflicting types for '__pcpu_scope___sn_cnodeid_to_nasid' arch/ia64/include/asm/sn/arch.h:74: error: previous declaration of '__pcpu_scope___sn_cnodeid_to_nasid' was here Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jes Sorensen <jes@sgi.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-14ia64: Fix up the syscall table for recvmmsgArnaldo Carvalho de Melo
Reported-by: "Tony Luck" <tony.luck@intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13[IA64] SMT friendly version of spin_unlock_wait()Tony Luck
We can be kinder to SMT systems in spin_unlock_wait. Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-13[IA64] use printk_once() unaligned.c/io_common.cMarcin Slusarz
Use printk_once() in a couple of places. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-13[IA64] Require SAL 3.2 in order to do extended config space opsMatthew Wilcox
We had assumed that SAL firmware would return an error if it didn't understand extended config space. Unfortunately, the SAL on the SGI 750 doesn't do that, it panics the machine. So, condition the extended PCI config space accesses on SAL revision 3.2. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Tested-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-10-13[IA64] unsigned cannot be less than 0 in sn_hwperf_ioctl()Roel Kluin
struct sn_hwperf_ioctl_args member arg (u64) cannot be less than 0. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
