path: root/arch/ia64/mm/discontig.c
2008-04-17Pull miscellaneous into release branchTony Luck
Conflicts: arch/ia64/kernel/mca.c
2008-04-11[IA64] Fix NUMA configuration issueZoltan Menyhart
There is a NUMA memory configuration issue in 2.6.24: A 2-node machine of ours has got the following memory layout: Node 0: 0 - 2 Gbytes Node 0: 4 - 8 Gbytes Node 1: 8 - 16 Gbytes Node 0: 16 - 18 Gbytes "efi_memmap_init()" merges the three last ranges into one. "register_active_ranges()" is called as follows: efi_memmap_walk(register_active_ranges, NULL); i.e. once for the 4 - 18 Gbytes range. It picks up the node number from the start address, and registers all the memory for the node #0. "register_active_ranges()" should be called as follows to make sure there is no merged address range at its entry: efi_memmap_walk(filter_memory, register_active_ranges); "filter_memory()" is similar to "filter_rsvd_memory()", but the reserved memory ranges are not filtered out. Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-09[IA64] remove redundant display of free swap space in show_mem()Johannes Weiner
show_mem() has no need to print the amount of free swap space manually because show_free_areas() does this already and is called by the former. The two outputs only differ in text formatting: printk("Free swap = %lukB\n", ...); printk("Free swap: %6ldkB\n", ...); Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Minimize per_cpu reservations.holt@sgi.com
This attached patch significantly shrinks boot memory allocation on ia64. It does this by not allocating per_cpu areas for cpus that can never exist. In the case where acpi does not have any numa node description of the cpus, I defaulted to assigning the first 32 round-robin on the known nodes.. For the !CONFIG_ACPI I used for_each_possible_cpu(). Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-04-08[IA64] Correct pernodesize calculation.holt@sgi.com
A simple fix. The existing pernodesize reservation is not taking into account a second array of pg_data_t structures. This is normally not important because the PAGE_ALIGN macro reserves adequate space. I made the compute_pernodesize steps in the same order as the fill_pernode steps to make the correlation more clear. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Add vmcoreinfoKen'ichi Ohmichi
This patch set frees the restriction that makedumpfile users should install a vmlinux file (including the debugging information) into each system. makedumpfile command is the dump filtering feature for kdump. It creates a small dumpfile by filtering unnecessary pages for the analysis. To distinguish unnecessary pages, it needs a vmlinux file including the debugging information. These days, the debugging package becomes a huge file, and it is hard to install it into each system. To solve the problem, kdump developers discussed it at lkml and kexec-ml. As the result, we reached the conclusion that necessary information for dump filtering (called "vmcoreinfo") should be embedded into the first kernel file and it should be accessed through /proc/vmcore during the second kernel. (http://www.uwsg.iu.edu/hypermail/linux/kernel/0707.0/1806.html) Dan Aloni created the patch set for the above implementation. (http://www.uwsg.iu.edu/hypermail/linux/kernel/0707.1/1053.html) And I updated it for multi architectures and memory models. (http://lists.infradead.org/pipermail/kexec/2007-August/000479.html) Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Ken'ichi Ohmichi <oomichi@mxs.nes.nec.co.jp> Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16IA64: SPARSEMEM_VMEMMAP 16K page size supportChristoph Lameter
Equip IA64 sparsemem with a virtual memmap. This is similar to the existing CONFIG_VIRTUAL_MEM_MAP functionality for DISCONTIGMEM. It uses a PAGE_SIZE mapping. This is provided as a minimally intrusive solution. We split the 128TB VMALLOC area into two 64TB areas and use one for the virtual memmap. This should replace CONFIG_VIRTUAL_MEM_MAP long term. [apw@shadowen.org: convert to new helper based initialisation] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-01[IA64] Stop bogus NMI & softlockup warnings in ia64 show_memPrarit Bhargava
When dumping memory via sysrq-m it is possible to take a bogus NMI watchdog or softlockup watchdog because the dump can take a long time on big memory systems. Occasionally tickle the watchdog when doing the dump. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] Quicklist support for IA64Christoph Lameter
IA64 is the origin of the quicklist implementation. So cut out the pieces that are now in core code and modify the functions called. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-08Fix section mismatch of memory hotplug related code.Yasunori Goto
This is to fix many section mismatches of code related to memory hotplug. I checked compile with memory hotplug on/off on ia64 and x86-64 box. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-20[IA64] min_low_pfn and max_low_pfn calculation fixZou Nan hai
We have seen bad_pte_print when testing crashdump on an SN machine in recent 2.6.20 kernel. There are tons of bad pte print (pfn < max_low_pfn) reports when the crash kernel boots up, all those reported bad pages are inside initmem range; That is because if the crash kernel code and data happens to be at the beginning of the 1st node. build_node_maps in discontig.c will bypass reserved regions with filter_rsvd_memory. Since min_low_pfn is calculated in build_node_map, so in this case, min_low_pfn will be greater than kernel code and data. Because pages inside initmem are freed and reused later, we saw pfn_valid check fail on those pages. I think this theoretically happen on a normal kernel. When I check min_low_pfn and max_low_pfn calculation in contig.c and discontig.c. I found more issues than this. 1. min_low_pfn and max_low_pfn calculation is inconsistent between contig.c and discontig.c, min_low_pfn is calculated as the first page number of boot memmap in contig.c (Why? Though this may work at the most of the time, I don't think it is the right logic). It is calculated as the lowest physical memory page number bypass reserved regions in discontig.c. max_low_pfn is calculated include reserved regions in contig.c. It is calculated exclude reserved regions in discontig.c. 2. If kernel code and data region is happen to be at the begin or the end of physical memory, when min_low_pfn and max_low_pfn calculation is bypassed kernel code and data, pages in initmem will report bad. 3. initrd is also in reserved regions, if it is at the begin or at the end of physical memory, kernel will refuse to reuse the memory. Because the virt_addr_valid check in free_initrd_mem. So it is better to fix and clean up those issues. Calculate min_low_pfn and max_low_pfn in a consistent way. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Acked-by: Jay Lan <jlan@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-06[IA64] point saved_max_pfn to the max_pfn of the entire systemHorms
Make saved_max_pfn point to max_pfn of entire system. Without this patch is so that vmcore is zero length on ia64. This is because saved_max_pfn was wrongly being set to the max_pfn of the crash kernel's address space, rather than the max_pfg on the physical memory of the machine - the whole purpose of vmcore is to access physical memory that is not part of the crash kernel's addresss space. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Sort-Of-Acked-By: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-11[PATCH] optional ZONE_DMA: optional ZONE_DMA for ia64Christoph Lameter
ZONE_DMA less operation for IA64 SGI platform Disable ZONE_DMA for SGI SN2. All memory is addressable by all devices and we do not need any special memory pool. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05[IA64] clean up sparsemem memory_present callBob Picco
Eliminate arch specific memory_present call ia64 NUMA by utilizing sparse_memory_present_with_active_regions. Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] register memory ranges in a consistent mannerBob Picco
While pursuing and unrelated issue with 64Mb granules I noticed a problem related to inconsistent use of add_active_range. There doesn't appear any reason to me why FLATMEM versus DISCONTIG_MEM should register memory to add_active_range with different code. So I've changed the code into a common implementation. The other subtle issue fixed by this patch was calling add_active_range in count_node_pages before granule aligning is performed. We were lucky with 16MB granules but not so with 64MB granules. count_node_pages has reserved regions filtered out and as a consequence linked kernel text and data aren't covered by calls to count_node_pages. So linked kernel regions wasn't reported to add_active_regions. This resulted in free_initmem causing numerous bad_page reports. This won't occur with this patch because now all known memory regions are reported by register_active_ranges. Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Acked-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-05[IA64] Zero size /proc/vmcore on ia64Horms
Set saved_max_pfn when discontig memory is in use. This sets up saved_max_pfn when disctontig memory is in use. This mirrors the code for contig memory. This patch does not entirely solve the problem of making vmcore work, however it does appear to be neccessary. Please consider applying. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-10-11[PATCH] mm: use symbolic names instead of indices for zone initialisationMel Gorman
Arch-independent zone-sizing is using indices instead of symbolic names to offset within an array related to zones (max_zone_pfns). The unintended impact is that ZONE_DMA and ZONE_NORMAL is initialised on powerpc instead of ZONE_DMA and ZONE_HIGHMEM when CONFIG_HIGHMEM is set. As a result, the the machine fails to boot but will boot with CONFIG_HIGHMEM turned off. The following patch properly initialises the max_zone_pfns[] array and uses symbolic names instead of indices in each architecture using arch-independent zone-sizing. Two users have successfully booted their powerpcs with it (one an ibook G4). It has also been boot tested on x86, x86_64, ppc64 and ia64. Please merge for 2.6.19-rc2. Credit to Benjamin Herrenschmidt for identifying the bug and rolling the first fix. Additional credit to Johannes Berg and Andreas Schwab for reporting the problem and testing on powerpc. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] minor reformatting to vmlinux.lds.S [IA64] CMC/CPE: Reverse the order of fetching log and checking poll threshold [IA64] PAL calls need physical mode, stacked [IA64] ar.fpsr not set on MCA/INIT kernel entry [IA64] printing support for MCA/INIT [IA64] trim output of show_mem() [IA64] show_mem() printk levels [IA64] Make gp value point to Region 5 in mca handler Revert "[IA64] Unwire set/get_robust_list" [IA64] Implement futex primitives [IA64-SGI] Do not request DMA memory for BTE [IA64] Move perfmon tables from thread_struct to pfm_context [IA64] Add interface so modules can discover whether multithreading is on. [IA64] kprobes: fixup the pagefault exception caused by probehandlers [IA64] kprobe opcode 16 bytes alignment on IA64 [IA64] esi-support [IA64] Add "model name" to /proc/cpuinfo
2006-09-27[PATCH] Have ia64 use add_active_range() and free_area_init_nodesMel Gorman
Size zones and holes in an architecture independent manner for ia64. [bob.picco@hp.com: fix ia64 FLATMEM+VIRTUAL_MEM_MAP] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[IA64] trim output of show_mem()Jes Sorensen
Cut the number of lines of memory info output per node from five to one line. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-09-26[IA64] show_mem() printk levelsJes Sorensen
Use the default sysrq printk level for printing show_mem() output both for disconfig and contig versions. This is consistent with the printk level used on other architectures (well ia32 at least). Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-08-03[IA64] fix show_mem for VIRTUAL_MEM_MAP+FLATMEMBob Picco
contig.c (FLATMEM) requires the same optimization as in discontig.c for show_mem when VIRTUAL_MEM_MAP is in use. Otherwise FLATMEM has softlockup timeouts. This was boot tested for memory configuration: SPARSEMEM, DISCONTIG+VIRTUAL_MEM_MAP, FLATMEM, FLATMEM+VIRTUAL_MEM_MAP and FLATMEM+VIRTUAL_MEM_MAP with largest memory gap less than LARGE_GAP by using boot parameter "mem=". This was boot tested and "echo m >/proc/sysrq-trigger" output evaluated for : FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and SPARSEMEM. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-08-03[IA64] align high endpoint of VIRTUAL_MEM_MAPBob Picco
Assure that vmem_map's high endpoint is MAX_ORDER aligned. Not doing so violates the buddy allocator algorithm. Also anyone using mem=XXX on boot line and not aligned to MAX_ORDER requires this patch in order to satisfy buddy allocator. vmem_map always starts at pfn 0. The potentially large MAX_ORDER on ia64 (due to hugetlbfs) requires that the end of vmem_map be aligned to MAX_ORDER_NR_PAGES. This was boot tested for: FLATMEM, FLATMEM+VIRTUAL_MEM_MAP, DISCONTIGMEM+VIRTUAL_MEM_MAP and SPARSEMEM. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-07-04[PATCH] Fix copying of pgdat array on each node for ia64 memory hotplugYasunori Goto
I found a bug in memory hot-add code for ia64. IA64's code has copies of pgdat's array on each node to reduce memory access over crossing node. This array is used by NODE_DATA() macro. When new node is hot-added, this pgdat's array should be updated and copied on new node too. However, I used for_each_online_node() in scatter_node_data() to copy it. This meant its array is not copied on new node. Because initialization of structures for new node was halfway, so online_node_map couldn't be set at this time. To copy arrays on new node, I changed it to check value of pgdat_list[] which is source array of copies. I tested this patch with my Memory Hotadd emulation on Tiger4. This patch is for 2.6.17-git20. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation and update for ia64 of memory hotplug: allocate ↵Yasunori Goto
pgdat and per node data This is a patch to allocate pgdat and per node data area for ia64. The size for them can be calculated by compute_pernodesize(). Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation and update for ia64 of memory hotplug: update pgdat ↵Yasunori Goto
address array This is to refresh node_data[] array for ia64. As I mentioned previous patches, ia64 has copies of information of pgdat address array on each node as per node data. At v2 of node_add, this function used stop_machine_run() to update them. (I wished that they were copied safety as much as possible.) But, in this patch, this arrays are just copied simply, and set node_online_map bit after completion of pgdat initialization. So, kernel must touch NODE_DATA() macro after checking node_online_map(). (Current code has already done it.) This is more simple way for just hot-add..... Note : It will be problem when hot-remove will occur, because, even if online_map bit is set, kernel may touch NODE_DATA() due to race condition. :-( Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation and update for ia64 of memory hotplug: hold pgdat ↵Yasunori Goto
address at system running This is a preparatory patch to make common code for updating of NODE_DATA() of ia64 between boottime and hotplug. Current code remembers pgdat address in mem_data which is used at just boot time. But its information can be used at hotplug time by moving to global value. The next patch uses this array. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-13[IA64] Make show_mem() skip holes in a pgdatRobin Holt
This patch modifies ia64's show_mem() to walk the vmem_map page tables and rapidly skip forward across regions where the page tables are missing. This prevents the pfn_valid() check from causing numerous unnecessary page faults. Without this patch on a 512 node 512 cpu system where every node has four memory holes, the show_mem() call takes 1 hour 18 minutes. With this patch, it takes less than 3 seconds. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-27[PATCH] for_each_online_pgdat: remove sorting pgdatKAMEZAWA Hiroyuki
Because pgdat_list was linked to pgdat_list in *reverse* order, (By default) some of arch has to sort it by themselves. for_each_pgdat has gone..for_each_online_pgdat() uses node_online_map, which doesn't need to be sorted. This patch removes codes for sorting pgdat. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] for_each_online_pgdat: renaming for_each_pgdatKAMEZAWA Hiroyuki
Replace for_each_pgdat() with for_each_online_pgdat(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[IA64] add init declaration to cpu initialization functionsChen, Kenneth W
Add init declaration to cpu initialization functions. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-05[IA64] support for cpu0 removalAshok Raj
here is the BSP removal support for IA64. Its pretty much the same thing that was released a while back, but has your feedback incorporated. - Removed CONFIG_BSP_REMOVE_WORKAROUND and associated cmdline param - Fixed compile issue with sn2/zx1 due to a undefined fix_b0_for_bsp - some formatting nits (whitespace etc) This has been tested on tiger and long back by alex on hp systems as well. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-12-06[IA64] Limit the maximum NODEDATA_ALIGN() offsetJack Steiner
The per-node data structures are allocated with strided offsets that are a function of the node number. This prevents excessive cache-aliasing from occurring. On systems with a large number of nodes, the strided offset becomes too large. This patch restricts the maximum offset to 32MB. This is far larger than the size of any current L3 cache. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-11-08[IA64] fix memory less node allocationBob Picco
The original memory less node allocation attempted to use NODEDATA_ALIGN for alignment. The bootmem allocator only allows a power of two alignments. This causes a BUG_ON for some nodes. For cpu only nodes just allocate with a PERCPU_PAGE_SIZE alignment. Some older firmware reports SLIT distances of 0xff and results in bestnode not being computed. This is now treated correctly. The failed allocation check was removed because it's redundant. The bootmem allocator already makes this check. This fix has been boot tested on 4 node machine which has 4 cpu only nodes and 1 memory node. Thanks to Pete Keilty for reporting this and helping me test it. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-10-29[PATCH] memory hotplug locking: node_size_lockDave Hansen
pgdat->node_size_lock is basically only neeeded in one place in the normal code: show_mem(), which is the arch-specific sysrq-m printing function. Strictly speaking, the architectures not doing memory hotplug do no need this locking in show_mem(). However, they are all included for completeness. This should also make any future consolidation of all of the implementations a little more straightforward. This lock is also held in the sparsemem code during a memory removal, as sections are invalidated. This is the place there pfn_valid() is made false for a memory area that's being removed. The lock is only required when doing pfn_valid() operations on memory which the user does not already have a reference on the page, such as in show_mem(). Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] V5 ia64 SPARSEMEM - SPARSEMEM code changesBob Picco
This patch is the minimal set of changes required by ia64 to use SPARSEMEM. Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-07-06[IA64] fix generic/up buildsTony Luck
Jesse Barnes provided the original version of this patch months ago, but other changes kept conflicting with it, so it got deferred. Greg Edwards dug it out of obscurity just over a week ago, and almost immediately another conflicting patch appeared (Bob Picco's memory-less nodes). I've resolved the conflicts and got it running again. CONFIG_SGI_TIOCX is set to "y" in defconfig, which causes a Tiger to not boot (oops in tiocx_init). But that can be resolved later ... get this in now before it gets stale again. Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-07-06[IA64] memory-less-nodes repostbob.picco
I reworked how nodes with only CPUs are treated. The patch below seems simpler to me and has eliminated the complicated routine reassign_cpu_only_nodes. There isn't any longer the requirement to modify ACPI NUMA information which was in large part the complexity introduced in reassign_cpu_only_nodes. This patch will produce a different number of nodes. For example, reassign_cpu_only_nodes would reduce two CPUonly nodes and one memory node configuration to one memory+CPUs node configuration. This patch doesn't change the number of nodes which means the user will see three. Two nodes without memory and one node with all the memory. While doing this patch, I noticed that early_nr_phys_cpus_node isn't serving any useful purpose. It is called once in find_pernode_space but the value isn't used to computer pernode space. Signed-off-by: bob.picco <bob.picco@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-06-23[PATCH] remove non-DISCONTIG use of pgdat->node_mem_mapDave Hansen
This patch effectively eliminates direct use of pgdat->node_mem_map outside of the DISCONTIG code. On a flat memory system, these fields aren't currently used, neither are they on a sparsemem system. There was also a node_mem_map(nid) macro on many architectures. Its use along with the use of ->node_mem_map itself was not consistent. It has been removed in favor of two new, more explicit, arch-independent macros: pgdat_page_nr(pgdat, pagenr) nid_page_nr(nid, pagenr) I called them "pgdat" and "nid" because we overload the term "node" to mean "NUMA node", "DISCONTIG node" or "pg_data_t" in very confusing ways. I believe the newer names are much clearer. These macros can be overridden in the sparsemem case with a theoretically slower operation using node_start_pfn and pfn_to_page(), instead. We could make this the only behavior if people want, but I don't want to change too much at once. One thing at a time. This patch removes more code than it adds. Compile tested on alpha, alpha discontig, arm, arm-discontig, i386, i386 generic, NUMAQ, Summit, ppc64, ppc64 discontig, and x86_64. Full list here: http://sr71.net/patches/2.6.12/2.6.12-rc1-mhp2/configs/ Boot tested on NUMAQ, x86 SMP and ppc64 power4/5 LPARs. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Martin J. Bligh <mbligh@aracnet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[IA64] Percpu quicklist for combined allocator for pgd/pmd/pte.Robin Holt
This patch introduces using the quicklists for pgd, pmd, and pte levels by combining the alloc and free functions into a common set of routines. This greatly simplifies the reading of this header file. This patch is simple but necessary for large numa configurations. It simply ensures that only pages from the local node are added to a cpus quicklist. This prevents the trapping of pages on a remote nodes quicklist by starting a process, touching a large number of pages to fill pmd and pte entries, migrating to another node, and then unmapping or exiting. With those conditions, the pages get trapped and if the machine has more than 100 nodes of the same size, the calculation of the pgtable high water mark will be larger than any single node so page table cache flushing will never occur. I ran lmbench lat_proc fork and lat_proc exec on a zx1 with and without this patch and did not notice any change. On an sn2 machine, there was a slight improvement which is possibly due to pages from other nodes trapped on the test node before starting the run. I did not investigate further. This patch shrinks the quicklist based upon free memory on the node instead of the high/low water marks. I have written it to enable preemption periodically and recalculate the amount to shrink every time we have freed enough pages that the quicklist size should have grown. I rescan the nodes zones each pass because other processess may be draining node memory at the same time as we are adding. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
