The swiotlb implementation is shared by both IA-64 and EM64T. However,
the source itself lives under arch/ia64. This patch moves swiotlb.c
from arch/ia64/lib to lib/ and fixes-up the appropriate Makefile and
Kconfig files. No actual changes are made to swiotlb.c.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Machine vector selection has always been a bit of a hack given how
early in system boot it needs to be done. Services like ACPI namespace
are not available and there are non-trivial problems to moving them to
early boot. However, there's no reason we can't change to a different
machvec later in boot when the services we need are available. By
adding a entry point for later initialization of the swiotlb, we can add
an error path for the hpzx1 machevec initialization and fall back to the
DIG machine vector if IOMMU hardware isn't found in the system. Since
ia64 uses 4GB for zone DMA (no ISA support), it's trivial to allocate a
contiguous range from the slab for bounce buffer usage.
Signed-off-by: Alex Williamson <alex.williamson@hp.com>
Fix swiotlb sizing to match what the comments and the kernel
parameters documentation indicate. Given a default 16k page size kernel
(ia64) and a 2k swiotlb page size, we're off by a multiple of 8 trying
to size the swiotlb. When specified on the boot line, the swiotlb is
made 8x bigger than requested. When left to the default value, it's 8x
smaller than the comments indicate. For x86_64 the multiplier would be
2x. The patch below fixes this. Now, what's a good default swiotlb
size? Apparently we don't really need 64MB.
infrastructure for it.
Let it rip!
