git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull pile 2 of execve and kernel_thread unification work from Al Viro:
"Stuff in there: kernel_thread/kernel_execve/sys_execve conversions for
several more architectures plus assorted signal fixes and cleanups.
There'll be more (in particular, real fixes for the alpha
do_notify_resume() irq mess)..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (43 commits)
alpha: don't open-code trace_report_syscall_{enter,exit}
Uninclude linux/freezer.h
m32r: trim masks
avr32: trim masks
tile: don't bother with SIGTRAP in setup_frame
microblaze: don't bother with SIGTRAP in setup_rt_frame()
mn10300: don't bother with SIGTRAP in setup_frame()
frv: no need to raise SIGTRAP in setup_frame()
x86: get rid of duplicate code in case of CONFIG_VM86
unicore32: remove pointless test
h8300: trim _TIF_WORK_MASK
parisc: decide whether to go to slow path (tracesys) based on thread flags
parisc: don't bother looping in do_signal()
parisc: fix double restarts
bury the rest of TIF_IRET
sanitize tsk_is_polling()
bury _TIF_RESTORE_SIGMASK
unicore32: unobfuscate _TIF_WORK_MASK
mips: NOTIFY_RESUME is not needed in TIF masks
mips: merge the identical "return from syscall" per-ABI code
arch/arm/include/asm/thread_info.h
These ia64 uses of current_uid and current_gid slipped through the
cracks when I was converting everything to kuids and kgids convert
them now.
Does block_sigmask() + tracehook_signal_handler(); called when
sigframe has been successfully built. All architectures converted
to it; block_sigmask() itself is gone now (merged into this one).
I'm still not too happy with the signature, but that's a separate
story (IMO we need a structure that would contain signal number +
siginfo + k_sigaction, so that get_signal_to_deliver() would fill one,
signal_delivered(), handle_signal() and probably setup...frame() -
take one).
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
As described in e6fa16ab ("signal: sigprocmask() should do
retarget_shared_pending()") the modification of current->blocked is
incorrect as we need to check whether the signal we're about to block is
pending in the shared queue.
Also, use the new helper function introduced in commit 5e6292c0f28f
("signal: add block_sigmask() for adding sigmask to current->blocked")
which centralises the code for updating current->blocked after
successfully delivering a signal and reduces the amount of duplicate code
across architectures. In the past some architectures got this code wrong,
so using this helper function should stop that from happening again.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
This has been broken since May 2008 when Al Viro killed altroot support.
Since nobody has complained, it would appear that there are no users of
this code (A plausible theory since the main OSVs that support ia64 prefer
to use the IA32-EL software emulation).
Signed-off-by: Tony Luck <tony.luck@intel.com>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: linux-ia64@vger.kernel.org
Signed-off-by: James Morris <jmorris@namei.org>
Make IA64 use generic trace hook in some paths.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Replace TIF_RESTORE_SIGMASK with TS_RESTORE_SIGMASK and define
our own set_restore_sigmask() function. This saves the costly
SMP-safe set_bit operation, which we do not need for the sigmask
flag since TIF_SIGPENDING always has to be set too.
Signed-off-by: Roland McGrath <roland@redhat.com>
The similar check has been added to x86_32(i386) in commit
id 83bd01024b1fdfc41d9b758e5669e80fca72df66.
So we add this check to ia64 and improve it a liitle bit in that
we need to check for stack overflow only when the signal is on stack.
Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com>
This patch removes some redundant code in the function setup_sigcontext().
The registers ar.ccv,b7,r14,ar.csd,ar.ssd,r2-r3 and r16-r31 are not
restored in restore_sigcontext() when (flags & IA64_SC_FLAG_IN_SYSCALL) is
true. So we don't need to zero those variables in setup_sigcontext().
Not all the return value of __copy_from_user and
__put_user is checked.This patch fixed it.
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul Menage <menage@google.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] wire up pselect, ppoll
[IA64] Add TIF_RESTORE_SIGMASK
[IA64] unwind did not work for processes born with CLONE_STOPPED
[IA64] Optional method to purge the TLB on SN systems
[IA64] SPIN_LOCK_UNLOCKED macro cleanup in arch/ia64
[IA64-SN2][KJ] mmtimer.c-kzalloc
[IA64] fix stack alignment for ia32 signal handlers
[IA64] - Altix: hotplug after intr redirect can crash system
[IA64] save and restore cpus_allowed in cpu_idle_wait
[IA64] Removal of percpu TR cleanup in kexec code
[IA64] Fix some section mismatch errors
Preparation for pselect and ppoll.
ia32 compat code not tested. :-(
Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The only user of the MCA/INIT sigdelayed code (SGI's I/O probing) has
moved from the kernel into SAL. Delete the MCA/INIT sigdelayed code.
Signed-off-by: Keith Owens <kaos@sgi.com>
on ia64 thread_info is at the constant offset from task_struct and stack
is embedded into the same beast. Set __HAVE_THREAD_FUNCTIONS, made
task_thread_info() just add a constant.
At the moment, attempting to invoke a signal-handler on the normal
stack is guaranteed to fail if the stack-pointer happens not to be
16-byte aligned. This is because the signal-trampoline will attempt
to store fp-regs with stf.spill instructions, which will trap for
misaligned addresses. This isn't terribly useful behavior. It's
better to just always align the signal frame to the next lower 16-byte
boundary.
Signed-off-by: David Mosberger-Tang <David.Mosberger@acm.org>
It has been reported that the way Linux handles NODEFER for signals is
not consistent with the way other Unix boxes handle it. I've written a
program to test the behavior of how this flag affects signals and had
several reports from people who ran this on various Unix boxes,
confirming that Linux seems to be unique on the way this is handled.
The way NODEFER affects signals on other Unix boxes is as follows:
1) If NODEFER is set, other signals in sa_mask are still blocked.
2) If NODEFER is set and the signal is in sa_mask, then the signal is
still blocked. (Note: this is the behavior of all tested but Linux _and_
NetBSD 2.0 *).
The way NODEFER affects signals on Linux:
1) If NODEFER is set, other signals are _not_ blocked regardless of
sa_mask (Even NetBSD doesn't do this).
2) If NODEFER is set and the signal is in sa_mask, then the signal being
handled is not blocked.
The patch converts signal handling in all current Linux architectures to
the way most Unix boxes work.
Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU
3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX.
* NetBSD was the only other Unix to behave like Linux on point #2. The
main concern was brought up by point #1 which even NetBSD isn't like
Linux. So with this patch, we leave NetBSD as the lonely one that
behaves differently here with #2.
restore_sigcontext calls ia64_set_local_fpu_owner() which requires that
preempt be disabled.
This patch fixes handling of accesses to ar.rsc via ptrace & restore_sigcontext
[With Thanks to Chris Wright for noticing the restore_sigcontext path]
Signed-off-by: Matthew Chapman <matthewc@hp.com>
Acked-by: David Mosberger <davidm@hpl.hp.com>
Attached is a patch against David's audit.17 kernel that adds checks
for the TIF_SYSCALL_AUDIT thread flag to the ia64 system call and
signal handling code paths. The patch enables auditing of system
calls set up via fsys_bubble_down, as well as ensuring that
audit_syscall_exit() is called on return from sigreturn.
Neglecting to check for TIF_SYSCALL_AUDIT at these points results in
incorrect information in audit_context, causing frequent system panics
when system call auditing is enabled on an ia64 system.
I have tested this patch and have seen no problems with it.
[Original patch from Amy Griffis ported to current kernel by David Woodhouse]
Signed-off-by: Chris Wright <chrisw@osdl.org>
infrastructure for it.
Let it rip!
