path: root/arch/ia64/kernel/irq.c
2007-08-13[IA64] SN2 needs platform specific irq_to_vector() function.Kenji Kaneshige
Add base support for implementing platform_irq_to_vector(), and then use it on SN2. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Acked-by: John Keller <jpk@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-17[IA64] Add mapping table between irq and vectorYasuaki Ishimatsu
Add mapping tables between irqs and vectors, and its management code. This is necessary for supporting multiple vector domain because 1:1 mapping between irq and vector will be changed to n:1. The irq == vector relationship between irqs and vectors is explicitly remained for percpu interrupts, platform interrupts, isa IRQs and vectors assigned using assign_irq_vector() because some programs might depend on it. And I should consider the following problem. When pci drivers enabled/disabled devices dynamically, its irq number is changed to the different one. Therefore, suspend/resume code may happen problem. To fix this problem, I bound gsi to irq. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] spelling fixes: arch/ia64/Simon Arlott
Spelling and apostrophe fixes in arch/ia64/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-05-11[IA64] SN: validate smp_affinity mask on intr redirectJohn Keller
On SN, only allow one bit to be set in the smp_affinty mask when redirecting an interrupt. Currently setting multiple bits is allowed, but only the first bit is used in determining the CPU to redirect to. This has caused confusion among some customers. [akpm@linux-foundation.org: fixes] Signed-off-by: John Keller <jpk@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-03[PATCH] kexec: Avoid migration of already disabled irqs (ia64)Magnus Damm
This patch fixes up ia64 kexec support for HP rx2620 hardware. It does this by skipping migration of already disabled irqs. This is most likely a problem on other ia64 platforms as well, but I've only been able to reproduce it on one machine so far. The full story is that handle_bad_irq() gets invoked before starting the new kernel without this patch. This seems to happen when fixup_irqs() calls generic_handle_irq() on already migrated (and disabled) irqs. So by avoiding migration of disabled irqs we stay away of handle_bad_irq(). The code has been tested on three different ia64 machines, all with good results. It is possible to trigger the same bug by offlining a processor using echo 0 > /sys/devices/system/cpu/cpuX/online. More detailed information is available in the following mail thread: http://lists.osdl.org/pipermail/fastboot/2007-January/thread.html#5774 Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Zou, Nanhai <nanhai.zou@intel.com> Acked-by: Jay Lan <jlan@sgi.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-16[IA64] use generic_handle_irq()Ingo Molnar
Use generic_handle_irq() to handle mixed-type irq handling. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-11-16[IA64] irqs: use `name' not `typename'Andrew Morton
`typename' is going away and is usually uninitialised anwyay. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-10-06[IA64] Fix breakage from irq changeTony Luck
A few missed spots in ia64-land from this gigantic commit: 7d12e780e003f93433d49ce78cfedf4b4c52adc5 Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-06-29[PATCH] genirq: cleanup: remove irq_descp()Ingo Molnar
Cleanup: remove irq_descp() - explicit use of irq_desc[] is shorter and more readable. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: cleanup: merge irq_affinity[] into irq_desc[]Ingo Molnar
Consolidation: remove the irq_affinity[NR_IRQS] array and move it into the irq_desc[NR_IRQS].affinity field. [akpm@osdl.org: sparc64 build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-17[IA64] one-line cleanup on set_irq_affinity_infoChen, Kenneth W
Calls to set_irq_info in set_irq_affinity_info() is redundant because irq_affinity mask was set just one line immediately above it. Remove that duplicate call. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-01-05[IA64] support for cpu0 removalAshok Raj
here is the BSP removal support for IA64. Its pretty much the same thing that was released a while back, but has your feedback incorporated. - Removed CONFIG_BSP_REMOVE_WORKAROUND and associated cmdline param - Fixed compile issue with sn2/zx1 due to a undefined fix_b0_for_bsp - some formatting nits (whitespace etc) This has been tested on tiger and long back by alex on hp systems as well. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-10-25[IA64] wider use of for_each_cpu_mask() in arch/ia64hawkes@sgi.com
In arch/ia64 change the explicit use of for-loops and NR_CPUS into the general for_each_cpu() or for_each_online_cpu() constructs, as appropriate. This widens the scope of potential future optimizations of the general constructs, as well as takes advantage of the existing optimizations of first_cpu() and next_cpu(). Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-07[PATCH] x86/x86_64: deferred handling of writes to /proc/irqxx/smp_affinityAshok Raj
When handling writes to /proc/irq, current code is re-programming rte entries directly. This is not recommended and could potentially cause chipset's to lockup, or cause missing interrupts. CONFIG_IRQ_BALANCE does this correctly, where it re-programs only when the interrupt is pending. The same needs to be done for /proc/irq handling as well. Otherwise user space irq balancers are really not doing the right thing. - Changed pending_irq_balance_cpumask to pending_irq_migrate_cpumask for lack of a generic name. - added move_irq out of IRQ_BALANCE, and added this same to X86_64 - Added new proc handler for write, so we can do deferred write at irq handling time. - Display of /proc/irq/XX/smp_affinity used to display CPU_MASKALL, instead it now shows only active cpu masks, or exactly what was set. - Provided a common move_irq implementation, instead of duplicating when using generic irq framework. Tested on i386/x86_64 and ia64 with CONFIG_PCI_MSI turned on and off. Tested UP builds as well. MSI testing: tbd: I have cards, need to look for a x-over cable, although I did test an earlier version of this patch. Will test in a couple days. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Acked-by: Zwane Mwaikambo <zwane@holomorphy.com> Grudgingly-acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Coywolf Qi Hunt <coywolf@lovecn.org> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
