path: root/arch/ia64/kernel/gate.S
2005-04-27[IA64] need r29=psr *after* rsm psr.iDavid Mosberger-Tang
Yanmin Zhang pointed out a sequence problem when saving the psr. David Mosberger provided this patch (which gave up a cycle). Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-27[IA64] Annotate __kernel_syscall_via_epc() with McKinley dispatch info.David Mosberger-Tang
Two other very minor changes: use "mov.i" instead of "mov" for reading ar.pfs (for clarity; doesn't affect the code at all). Also, predicate the load of r14 for consistency. Signed-off-by: David Mosberger-Tang <davidm@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-27[IA64] Reschedule __kernel_syscall_via_epc().David Mosberger-Tang
Avoid some stalls, which is good for about 2 cycles when invoking a light-weight handler. When invoking a heavy-weight handler, this helps by about 7 cycles, with most of the improvement coming from the improved branch-prediction achieved by splitting the BBB bundle into two MIB bundles. Signed-off-by: David Mosberger-Tang <davidm@hpl.hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
