path: root/arch/ia64/include
2011-05-31[IA64] wire up sendmmsg() syscall for ItaniumTony Luck
Add entries in unistd.h and entry.S to make this new syscall visible. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25ia64: mmu_gather reworkPeter Zijlstra
Fix up the ia64 mmu_gather code to conform to the new API. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29ia64: Remove redundant declaration of irq_desc[]Thomas Gleixner
2011-03-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: pstore: cleanups to pstore_dump() [IA64] New syscalls for 2.6.39
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (42 commits) ACPI: minor printk format change in acpi_pad ACPI: make acpi_pad /sys output more readable ACPICA: Update version to 20110316 ACPICA: Header support for SLIC table ACPI: Make sure the FADT is at least rev 2 before using the reset register ACPI: Bug compatibility for Windows on the ACPI reboot vector ACPICA: Fix access width for reset vector ACPI battery: fribble sysfs files from a resume notifier ACPI button: remove unused procfs I/F ACPI, APEI, Add PCIe AER error information printing support PCIe, AER, use pre-generated prefix in error information printing ACPI, APEI, Add ERST record ID cache ACPI: Use syscore_ops instead of sysdev class and sysdev ACPI: Remove the unused EC sysdev class ACPI: use __cpuinit for the acpi_processor_set_pdc() call tree ACPI: use __init where possible in processor driver Thermal_Framework-Fix_crash_during_hwmon_unregister ACPICA: Update version to 20110211. ACPICA: Add mechanism to defer _REG methods for some installed handlers ACPICA: Add support for FunctionalFixedHW in acpi_ut_get_region_name ...
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ia64: fix build breakage in asm/thread_info.hLuck, Tony
In commit 504f52b5439aaf26d3e2c1d45ec10fce38c8dd27 mm: NUMA aware alloc_task_struct_node() Eric Dumazet forgot a "\". Add it. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_thread_info_node()Eric Dumazet
Add a node parameter to alloc_thread_info(), and change its name to alloc_thread_info_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: NUMA aware alloc_task_struct_node()Eric Dumazet
All kthreads being created from a single helper task, they all use memory from a single node for their kernel stack and task struct. This patch suite creates kthread_create_on_cpu(), adding a 'cpu' parameter to parameters already used by kthread_create(). This parameter serves in allocating memory for the new kthread on its memory node if available. Users of this new function are : ksoftirqd, kworker, migration, pktgend... This patch: Add a node parameter to alloc_task_struct(), and change its name to alloc_task_struct_node() This change is needed to allow NUMA aware kthread_create_on_cpu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22[IA64] New syscalls for 2.6.39Tony Luck
Four new syscalls: sys_name_to_handle_at sys_open_by_handle_at sys_clock_adjtime sys_syncfs Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] tioca: Fix assignment from incompatible pointer warnings [IA64] mca.c: Fix cast from integer to pointer warning [IA64] setup.c Typo fix "Architechtuallly" [IA64] Add CONFIG_MISC_DEVICES=y to configs that need it. [IA64] disable interrupts at end of ia64_mca_cpe_int_handler() [IA64] Add DMA_ERROR_CODE define. pstore: fix build warning for unused return value from sysfs_create_file pstore: X86 platform interface using ACPI/APEI/ERST pstore: new filesystem interface to platform persistent storage
2011-03-16Pull misc-2.6.39 into release branchTony Luck
2011-03-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtmutex: tester: Remove the remaining BKL leftovers lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause rtmutex: Simplify PI algorithm and make highest prio task get lock rwsem: Remove redundant asmregparm annotation rwsem: Move duplicate function prototypes to linux/rwsem.h rwsem: Unify the duplicate rwsem_is_locked() inlines rwsem: Move duplicate init macros and functions to linux/rwsem.h rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h x86: Cleanup rwsem_count_t typedef rwsem: Cleanup includes locking: Remove deprecated lock initializers cred: Replace deprecated spinlock initialization kthread: Replace deprecated spinlock initialization xtensa: Replace deprecated spinlock initialization um: Replace deprecated spinlock initialization sparc: Replace deprecated spinlock initialization mips: Replace deprecated spinlock initialization cris: Replace deprecated spinlock initialization alpha: Replace deprecated spinlock initialization rtmutex-tester: Remove BKL tests
2011-03-15Merge branch 'core-futexes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: arm: Remove bogus comment in futex_atomic_cmpxchg_inatomic() futex: Deobfuscate handle_futex_death() plist: Add priority list test plist: Shrink struct plist_head futex,plist: Remove debug lock assignment from plist_node futex,plist: Pass the real head of the priority list to plist_del() futex: Sanitize futex ops argument types futex: Sanitize cmpxchg_futex_value_locked API futex: Remove redundant pagefault_disable in futex_atomic_cmpxchg_inatomic() futex: Avoid redudant evaluation of task_pid_vnr() futex: Update futex_wait_setup comments about locking
2011-03-11futex: Sanitize futex ops argument typesMichel Lespinasse
Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic prototypes to use u32 types for the futex as this is the data type the futex core code uses all over the place. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311025058.GD26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-11futex: Sanitize cmpxchg_futex_value_locked APIMichel Lespinasse
The cmpxchg_futex_value_locked API was funny in that it returned either the original, user-exposed futex value OR an error code such as -EFAULT. This was confusing at best, and could be a source of livelocks in places that retry the cmpxchg_futex_value_locked after trying to fix the issue by running fault_in_user_writeable(). This change makes the cmpxchg_futex_value_locked API more similar to the get_futex_value_locked one, returning an error code and updating the original value through a reference argument. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile] Acked-by: Tony Luck <tony.luck@intel.com> [ia64] Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Michal Simek <monstr@monstr.eu> [microblaze] Acked-by: David Howells <dhowells@redhat.com> [frv] Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311024851.GC26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-01xen: ia64 build broken due to "xen: switch to new schedop hypercall by default."Ian Campbell
The git commit: > commit a8b7458363b9174f3c2196ca6085630b4b30b7a1 > Author: Ian Campbell <ian.campbell@citrix.com> > Date: Thu Feb 17 11:04:20 2011 +0000 > > xen: switch to new schedop hypercall by default. > > Rename old interface to sched_op_compat and rename sched_op_new to > simply sched_op. > breaks the IA64 build. This patch fixes it. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ian Campbell <Ian.Campbell@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-02-24ACPI / PM: Merge do_suspend_lowlevel() into acpi_save_state_mem()Rafael J. Wysocki
The function do_suspend_lowlevel() is specific to x86 and defined in assembly code, so it should be called from the x86 low-level suspend code rather than from acpi_suspend_enter(). Merge do_suspend_lowlevel() into the x86's acpi_save_state_mem() and change the name of the latter to acpi_suspend_lowlevel(), so that the function's purpose is better reflected by its name. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-24ACPI / PM: Drop acpi_restore_state_mem()Rafael J. Wysocki
The function acpi_restore_state_mem() has never been and most likely never will be used, so remove it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-02-15Merge branch 'master' into for-nextJiri Kosina
2011-02-02fix typos 'comamnd' -> 'command' in commentsJustin P. Mattock
2011-01-27rwsem: Move duplicate function prototypes to linux/rwsem.hThomas Gleixner
All architecture specific rwsem headers carry the same function prototypes. Just x86 adds asmregparm, which is an empty define on all other architectures. S390 has a stale rwsem_downgrade_write() prototype. Remove the duplicates and add the prototypes to linux/rwsem.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.970840140@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Unify the duplicate rwsem_is_locked() inlinesThomas Gleixner
Instead of having the same implementation in each architecture, move it to linux/rwsem.h and remove the duplicates. It's unlikely that an arch will ever implement something different, but we can deal with that when it happens. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.876773757@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Move duplicate init macros and functions to linux/rwsem.hThomas Gleixner
The rwsem initializers and related macros and functions are mostly the same. Some of them lack the lockdep initializer, but having it in place does not matter for architectures which do not support lockdep. powerpc, sparc, x86: No functional change sh, s390: Removes the duplicate init_rwsem (inline and #define) alpha, ia64, xtensa: Use the lockdep capable init function in lib/rwsem.c which is just uninlining the init function for the LOCKDEP=n case Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.771812729@linutronix.de>
2011-01-27rwsem: Move duplicate struct rwsem declaration to linux/rwsem.hThomas Gleixner
The difference between these declarations is the data type of the count member and the lack of lockdep in some architectures/ long is equivivalent to signed long and the #ifdef guarded dep_map member does not hurt anyone. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.679641914@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-27rwsem: Cleanup includesThomas Gleixner
All rwsem implementations include the same headers. Include them from include/linux/rwsem.h Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Matt Turner <mattst88@gmail.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: David Miller <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> LKML-Reference: <20110126195833.483520950@linutronix.de>
2011-01-14[IA64] fix ia64 build failure in pmdp_get_and_clearAndrea Arcangeli
Implement __pmd macro for ia64 too. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-01-13Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits) ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework ACPI: fix resource check message ACPI / Battery: Update information on info notification and resume ACPI: Drop device flag wake_capable ACPI: Always check if _PRW is present before trying to evaluate it ACPI / PM: Check status of power resources under mutexes ACPI / PM: Rename acpi_power_off_device() ACPI / PM: Drop acpi_power_nocheck ACPI / PM: Drop acpi_bus_get_power() Platform / x86: Make fujitsu_laptop use acpi_bus_update_power() ACPI / Fan: Rework the handling of power resources ACPI / PM: Register power resource devices as soon as they are needed ACPI / PM: Register acpi_power_driver early ACPI / PM: Add function for updating device power state consistently ACPI / PM: Add function for device power state initialization ACPI / PM: Introduce __acpi_bus_get_power() ACPI / PM: Introduce function for refcounting device power resources ACPI / PM: Add functions for manipulating lists of power resources ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes ACPICA: Update version to 20101209 ...
2011-01-13Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: cpuidle/x86/perf: fix power:cpu_idle double end events and throw cpu_idle events from the cpuidle layer intel_idle: open broadcast clock event cpuidle: CPUIDLE_FLAG_CHECK_BM is omap3_idle specific cpuidle: CPUIDLE_FLAG_TLB_FLUSHED is specific to intel_idle cpuidle: delete unused CPUIDLE_FLAG_SHALLOW, BALANCED, DEEP definitions SH, cpuidle: delete use of NOP CPUIDLE_FLAGS_SHALLOW cpuidle: delete NOP CPUIDLE_FLAG_POLL ACPI: processor_idle: delete use of NOP CPUIDLE_FLAGs cpuidle: Rename X86 specific idle poll state[0] from C0 to POLL ACPI, intel_idle: Cleanup idle= internal variables cpuidle: Make cpuidle_enable_device() call poll_idle_init() intel_idle: update Sandy Bridge core C-state residency targets
2011-01-12ACPI, intel_idle: Cleanup idle= internal variablesThomas Renninger
Having four variables for the same thing: idle_halt, idle_nomwait, force_mwait and boot_option_idle_overrides is rather confusing and unnecessary complex. if idle= boot param is passed, only set up one variable: boot_option_idle_overrides Introduces following functional changes/fixes: - intel_idle driver does not register if any idle=xy boot param is passed. - processor_idle.c will also not register a cpuidle driver and get active if idle=halt is passed. Before a cpuidle driver with one (C1, halt) state got registered Now the default_idle function will be used which finally uses the same idle call to enter sleep state (safe_halt()), but without registering a whole cpuidle driver. That means idle= param will always avoid cpuidle drivers to register with one exception (same behavior as before): idle=nomwait may still register acpi_idle cpuidle driver, but C1 will not use mwait, but hlt. This can be a workaround for IO based deeper sleep states where C1 mwait causes problems. Signed-off-by: Thomas Renninger <trenn@suse.de> cc: x86@kernel.org Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12KVM: Clean up vm creation and releaseJan Kiszka
IA64 support forces us to abstract the allocation of the kvm structure. But instead of mixing this up with arch-specific initialization and doing the same on destruction, split both steps. This allows to move generic destruction calls into generic code. It also fixes error clean-up on failures of kvm_create_vm for IA64. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-11[IA64] Add DMA_ERROR_CODE define.Konrad Rzeszutek Wilk
This piggybacks on git commit 8fd524b355daef0945692227e726fb444cebcd4f ("x86: Kill bad_dma_address variable") wherein we use now the dma_map_ops->mapping_error to check for errors and the standard check is against DMA_ERROR_CODE. Introduce it to the IA64 world. CC: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> CC: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-01-07ACPI: Use ioremap_cache()Len Brown
Although the temporary boot-time ACPI table mappings were set up with CPU caching enabled, the permanent table mappings and AML run-time region memory accesses were set up with ioremap(), which on x86 is a synonym for ioremap_nocache(). Changing this to ioremap_cache() improves performance as seen when accessing the tables via acpidump, or /sys/firmware/acpi/tables. It should also improve AML run-time performance. No change on ia64. Reported-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-27taskstats: use real microsecond granularity for CPU timesMichael Holzheu
The taskstats interface uses microsecond granularity for the user and system time values. The conversion from cputime to the taskstats values uses the cputime_to_msecs primitive which effectively limits the granularity to milliseconds. Add the cputime_to_usecs primitive for architectures that have better, more precise CPU time values. Remove cputime_to_msecs primitive because there are no more users left. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Luck Tony <tony.luck@intel.com> Cc: Shailabh Nagar <nagar1234@in.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (22 commits) Add _addr_lsb field to ia64 siginfo Fix migration.c compilation on s390 HWPOISON: Remove retry loop for try_to_unmap HWPOISON: Turn addr_valid from bitfield into char HWPOISON: Disable DEBUG by default HWPOISON: Convert pr_debugs to pr_info HWPOISON: Improve comments in memory-failure.c x86: HWPOISON: Report correct address granuality for huge hwpoison faults Encode huge page size for VM_FAULT_HWPOISON errors Fix build error with !CONFIG_MIGRATION hugepage: move is_hugepage_on_freelist inside ifdef to avoid warning Clean up __page_set_anon_rmap HWPOISON, hugetlb: fix unpoison for hugepage HWPOISON, hugetlb: soft offlining for hugepage HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASED hugetlb: move refcounting in hugepage allocation inside hugetlb_lock HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page() hugetlb: hugepage migration core hugetlb: redefine hugepage copy functions hugetlb: add allocate function for hugepage migration ...
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits) serial8250: ratelimit "too much work" error serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster serial: abstraction for 8250 legacy ports serial/imx: check that the buffer is non-empty before sending it out serial: mfd: add more baud rates support jsm: Remove the uart port on errors Alchemy: Add UART PM methods. 8250: allow platforms to override PM hook. altera_uart: Don't use plain integer as NULL pointer altera_uart: Fix missing prototype for registering an early console altera_uart: Fixup type usage of port flags altera_uart: Make it possible to use Altera UART and 8250 ports together altera_uart: Add support for different address strides altera_uart: Add support for getting mapbase and IRQ from resources altera_uart: Add support for polling mode (IRQ-less) serial: Factor out uart_poll_timeout() from 8250 driver serial: mark the 8250 driver as maintained serial: 8250: Don't delay after transmitter is ready. tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver vcs: invoke the vt update callback when /dev/vcs* is written to ...
2010-10-22ioctl: Use asm-generic/ioctls.h on ia64 (enables termiox)Jeff Mahoney
This patch converts ia64 to use asm-generic/ioctls.h instead of its own version. The differences between the arch-specific version and the generic version are as follows: - The generic version adds TIOCSRS485 and TIOCGRS485, which are unused by any driver available on this architecture. - The generic version adds support for termiox Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Merge branch 'hwpoison-fixes-2.6.37' into hwpoisonAndi Kleen
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-21Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Cannot use register_percpu_irq() from ia64_mca_init() [IA64] Initialize interrupts later (from init_IRQ()) [IA64] enable ARCH_DMA_ADDR_T_64BIT [IA64] ioc3_serial: release resources in error return path [IA64] Stop using the deprecated __do_IRQ() code path [IA64] Remove unnecessary casts of private_data in perfmon.c [IA64] Fix missing iounmap in error path in cyclone.c [IA64] salinfo: sema_init instead of init_MUTEX [IA64] xen: use ARRAY_SIZE macro in xen_pv_ops.c [IA64] Use static const char * const in palinfo.c [IA64] remove asm/compat.h [IA64] Add CONFIG_STACKTRACE_SUPPORT [IA64] Move local_softirq_pending() definition [IA64] iommu: Add a dummy iommu_table.h file in IA64. [IA64] unwind - optimise linked-list searches for modules [IA64] unwind: remove preprocesser noise, and correct comment
2010-10-21Merge branch 'x86-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, iommu: Update header comments with appropriate naming ia64, iommu: Add a dummy iommu_table.h file in IA64. x86, iommu: Fix IOMMU_INIT alignment rules x86, doc: Adding comments about .iommu_table and its neighbors. x86, iommu: Utilize the IOMMU_INIT macros functionality. x86, VT-d: Make Intel VT-d IOMMU use IOMMU_INIT_* macros. x86, GART/AMD-VI: Make AMD GART and IOMMU use IOMMU_INIT_* macros. x86, calgary: Make Calgary IOMMU use IOMMU_INIT_* macros. x86, xen-swiotlb: Make Xen-SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Make SWIOTLB use IOMMU_INIT_* macros. x86, swiotlb: Simplify SWIOTLB pci_swiotlb_detect routine. x86, iommu: Add proper dependency sort routine (and sanity check). x86, iommu: Make all IOMMU's detection routines return a value. x86, iommu: Add IOMMU_INIT macros, .iommu_table section, and iommu_table_entry structure
2010-10-21Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits) sched: Export account_system_vtime() sched: Call tick_check_idle before __irq_enter sched: Remove irq time from available CPU power sched: Do not account irq time to current task x86: Add IRQ_TIME_ACCOUNTING sched: Add IRQ_TIME_ACCOUNTING, finer accounting of irq time sched: Add a PF flag for ksoftirqd identification sched: Consolidate account_system_vtime extern declaration sched: Fix softirq time accounting sched: Drop group_capacity to 1 only if local group has extra capacity sched: Force balancing on newidle balance if local group has capacity sched: Set group_imb only a task can be pulled from the busiest cpu sched: Do not consider SCHED_IDLE tasks to be cache hot sched: Drop all load weight manipulation for RT tasks sched: Create special class for stop/migrate work sched: Unindent labels sched: Comment updates: fix default latency and granularity numbers tracing/sched: Add sched_pi_setprio tracepoint sched: Give CPU bound RT tasks preference sched: Try not to migrate higher priority RT tasks ...
