path: root/arch/i386/power/suspend.c
2007-05-02[PATCH] x86: Move swsusp __pa() dependent code to arch portionVivek Goyal
o __pa() should be used only on kernel linearly mapped virtual addresses and not on kernel text and data addresses. o Hibernation code needs to determine the physical address associated with kernel symbol to mark a section boundary which contains pages which don't have to be saved and restored during hibernate/resume operation. o Move this piece of code in arch dependent section. So that architectures which don't have kernel text/data mapped into kernel linearly mapped region can come up with their own ways of determining physical addresses associated with a kernel text. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] swsusp: Support i386 systems with PAE or without PSERafael J. Wysocki
Make swsusp support i386 systems with PAE or without PSE. This is done by creating temporary page tables located in resume-safe page frames before the suspend image is restored in the same way as x86_64 does it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Andi Kleen <ak@suse.de> Cc: Dave Jones <davej@redhat.com> Cc: Nigel Cunningham <ncunningham@linuxmail.org> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
