path: root/arch/i386/mm/init.c
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] i386: Preserve EFI run time regions with memmap parameterArtiom Myaskouvskey
When using memmap kernel parameter in EFI boot we should also add to memory map memory regions of runtime services to enable their mapping later. AK: merged and cleaned up the patch Signed-off-by: Artiom Myaskouvskey <artiom.myaskouvskey@intel.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-10-03BUG_ON cleanups in arch/i386Eric Sesterhenn
This changes a couple of if() BUG(); constructs to BUG_ON(); so it can be safely optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] paravirt: update pte hookZachary Amsden
Add a pte_update_hook which notifies about pte changes that have been made without using the set_pte / clear_pte interfaces. This allows shadow mode hypervisors which do not trap on page table access to maintain synchronized shadows. It also turns out, there was one pte update in PAE mode that wasn't using any accessor interface at all for setting NX protection. Considering it is PAE specific, and the accessor is i386 specific, I didn't want to add a generic encapsulation of this behavior yet. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26[PATCH] x86: make __FIXADDR_TOP variable to allow it to make space for a ↵Jeremy Fitzhardinge
hypervisor Make __FIXADDR_TOP a variable, so that it can be set to not get in the way of address space a hypervisor may want to reserve. Original patch by Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: remove two strange uses of MAX_NR_ZONESChristoph Lameter
I keep seeing zones on various platforms that are never used and wonder why we compile support for them into the kernel. Counters show up for HIGHMEM and DMA32 that are alway zero. This patch allows the removal of ZONE_DMA32 for non x86_64 architectures and it will get rid of ZONE_HIGHMEM for arches not using highmem (like 64 bit architectures). If an arch does not define CONFIG_HIGHMEM then ZONE_HIGHMEM will not be defined. Similarly if an arch does not define CONFIG_ZONE_DMA32 then ZONE_DMA32 will not be defined. No current architecture uses all the 4 zones (DMA,DMA32,NORMAL,HIGH) that we have now. The patchset will reduce the number of zones for all platforms. On many platforms that do not have DMA32 or HIGHMEM this will reduce the number of zones by 50%. F.e. ia64 only uses DMA and NORMAL. Large amounts of memory can be saved for larger systemss that may have a few hundred NUMA nodes. With ZONE_DMA32 and ZONE_HIGHMEM support optional MAX_NR_ZONES will be 2 for many non i386 platforms and even for i386 without CONFIG_HIGHMEM set. Tested on ia64, x86_64 and on i386 with and without highmem. The patchset consists of 11 patches that are following this message. One could go even further than this patchset and also make ZONE_DMA optional because some platforms do not need a separate DMA zone and can do DMA to all of memory. This could reduce MAX_NR_ZONES to 1. Such a patchset will hopefully follow soon. This patch: Fix strange uses of MAX_NR_ZONES Sometimes we use MAX_NR_ZONES - x to refer to a zone. Make that explicit. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386: Replace i386 open-coded cmdline parsing withRusty Russell
This patch replaces the open-coded early commandline parsing throughout the i386 boot code with the generic mechanism (already used by ppc, powerpc, ia64 and s390). The code was inconsistent with whether it deletes the option from the cmdline or not, meaning some of these will get passed through the environment into init. This transformation is mainly mechanical, but there are some notable parts: 1) Grammar: s/linux never set's it up/linux never sets it up/ 2) Remove hacked-in earlyprintk= option scanning. When someone actually implements CONFIG_EARLY_PRINTK, then they can use early_param(). [AK: actually it is implemented, but I'm adding the early_param it in the next x86-64 patch] 3) Move declaration of generic_apic_probe() from setup.c into asm/apic.h 4) Various parameters now moved into their appropriate files (thanks Andi). 5) All parse functions which examine arg need to check for NULL, except one where it has subtle humor value. AK: readded acpi_sci handling which was completely dropped AK: moved some more variables into acpi/boot.c Cc: len.brown@intel.com Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: initialize end-of-memory variables as early as possibleJan Beulich
Move initialization of all memory end variables to as early as possible, so that dependent code doesn't need to check whether these variables have already been set. Change the range check in kunmap_atomic to actually make use of this so that the no-mapping-estabished path (under CONFIG_DEBUG_HIGHMEM) gets used only when the address is inside the lowmem area (and BUG() otherwise). Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-07-01[PATCH] add __[start|end]_rodata sections to asm-generic/sections.hHeiko Carstens
Add __start_rodata and __end_rodata to sections.h to avoid extern declarations. Needed by s390 code (see following patch). [akpm@osdl.org: update architectures] Cc: Arjan van de Ven <arjan@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] add poison.h and patch primary usersRandy Dunlap
Localize poison values into one header file for better documentation and easier/quicker debugging and so that the same values won't be used for multiple purposes. Use these constants in core arch., mm, driver, and fs code. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pgdat allocation for new node add (specify node id)Yasunori Goto
Change the name of old add_memory() to arch_add_memory. And use node id to get pgdat for the node at NODE_DATA(). Note: Powerpc's old add_memory() is defined as __devinit. However, add_memory() is usually called only after bootup. I suppose it may be redundant. But, I'm not well known about powerpc. So, I keep it. (But, __meminit is better at least.) Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] don't use flush_tlb_all in suspend timeShaohua Li
flush_tlb_all uses on_each_cpu, which will disable/enable interrupt. In suspend/resume time, this will make interrupt wrongly enabled. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] build fix: CONFIG_MEMORY_HOTPLUG=y on i386KAMEZAWA Hiroyuki
typo in #ifdefs. Fixes http://bugme.osdl.org/show_bug.cgi?id=6538 Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-09[PATCH] x86_64: Support memory hotadd without sparsememAndi Kleen
Memory hotadd doesn't need SPARSEMEM, but can be handled by just preallocating mem_maps. This only needs some untangling of ifdefs to enable the necessary code even without SPARSEMEM. Originally from Keith Mannthey, hacked by AK. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] x86: SMP alternativesGerd Hoffmann
Implement SMP alternatives, i.e. switching at runtime between different code versions for UP and SMP. The code can patch both SMP->UP and UP->SMP. The UP->SMP case is useful for CPU hotplug. With CONFIG_CPU_HOTPLUG enabled the code switches to UP at boot time and when the number of CPUs goes down to 1, and switches to SMP when the number of CPUs goes up to 2. Without CONFIG_CPU_HOTPLUG or on non-SMP-capable systems the code is patched once at boot time (if needed) and the tables are released afterwards. The changes in detail: * The current alternatives bits are moved to a separate file, the SMP alternatives code is added there. * The patch adds some new elf sections to the kernel: .smp_altinstructions like .altinstructions, also contains a list of alt_instr structs. .smp_altinstr_replacement like .altinstr_replacement, but also has some space to save original instruction before replaving it. .smp_locks list of pointers to lock prefixes which can be nop'ed out on UP. The first two are used to replace more complex instruction sequences such as spinlocks and semaphores. It would be possible to deal with the lock prefixes with that as well, but by handling them as special case the table sizes become much smaller. * The sections are page-aligned and padded up to page size, so they can be free if they are not needed. * Splitted the code to release init pages to a separate function and use it to release the elf sections if they are unused. Signed-off-by: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] x86_64: add __meminit for memory hotplugMatt Tolentino
Add __meminit to the __init lineup to ensure functions default to __init when memory hotplug is not enabled. Replace __devinit with __meminit on functions that were changed when the memory hotplug code was introduced. Signed-off-by: Matt Tolentino <matthew.e.tolentino@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] x86/x86_64: mark rodata section read only: x86 partsArjan van de Ven
x86 specific parts to make the .rodata section read only Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] arch/i386/mm/init.c: small cleanupsAdrian Bunk
This patch contains the following cleanups: - make a needlessly global function static - every file should include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] memory hotplug: i386 addition functionsDave Hansen
Adds the necessary for non-NUMA hot-add of highmem to an existing zone on i386. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Additions to .data.read_mostly sectionRavikiran G Thirumalai
Mark variables which are usually accessed for reads with __readmostly. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] i386: use set_pte macros in a couple places where they were missingZachary Amsden
Also, setting PDPEs in PAE mode does not require atomic operations, since the PDPEs are cached by the processor, and only reloaded on an explicit or implicit reload of CR3. Since the four PDPEs must always be present in an active root, and the kernel PDPE is never updated, we are safe even from SMIs and interrupts / NMIs using task gates (which reload CR3). Actually, much of this is moot, since the user PDPEs are never updated either, and the only usage of task gates is by the doublefault handler. It appears the only place PGDs get updated in PAE mode is in init_low_mappings() / zap_low_mapping() for initial page table creation and recovery from ACPI sleep state, and these sites are safe by inspection. Getting rid of the cmpxchg8b saves code space and 720 cycles in pgd_alloc on P4. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] x86: fix EFI memory map parsingMatt Tolentino
The memory descriptors that comprise the EFI memory map are not fixed in stone such that the size could change in the future. This uses the memory descriptor size obtained from EFI to iterate over the memory map entries during boot. This enables the removal of an x86 specific pad (and ifdef) in the EFI header. I also couldn't stomach the broken up nature of the function to put EFI runtime calls into virtual mode any longer so I fixed that up a bit as well. For reference, this patch only impacts x86. Signed-off-by: Matt Tolentino <matthew.e.tolentino@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] swsusp: kill config_pm_diskPavel Machek
CONFIG_PM_DISK is long gone, but it still managed to survived at few places. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Remove i386_ksyms.c, almost.Alexey Dobriyan
* EXPORT_SYMBOL's moved to other files * #include <linux/config.h>, <linux/module.h> where needed * #include's in i386_ksyms.c cleaned up * After copy-paste, redundant due to Makefiles rules preprocessor directives removed: #ifdef CONFIG_FOO EXPORT_SYMBOL(foo); #endif obj-$(CONFIG_FOO) += foo.o * Tiny reformat to fit in 80 columns Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem memory model for i386Andy Whitcroft
Provide the architecture specific implementation for SPARSEMEM for i386 SMP and NUMA systems. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Martin Bligh <mbligh@aracnet.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] sparsemem base: teach discontig about sparse rangesDave Hansen
discontig.c has some assumptions that mem_map[]s inside of a node are contiguous. Teach it to make sure that each region that it's bringing online is actually made up of valid ranges of ram. Written-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] mm: remove PG_highmemBadari Pulavarty
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll generate a little more code, but we don't use PageHigheMem() in many places. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
