path: root/arch/i386/kernel/traps.c
2007-10-11i386: prepare shared kernel/traps.cThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-31x86: be even more careful about checking the stack frame on dumpingLinus Torvalds
lguest didn't initialize the kernel stack the way a real i386 kernel does, and ended up triggering a corner-case in the stack frame checking that doesn't happen on naive i386, and that the stack dumping didn't handle quite right. This makes the frame handling more correct, and tries to clarify the code at the same time so that it's a bit more obvious what is going on. Thanks to Rusty Russell for debugging the lguest failure- Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22x86: Stop MCEs and NMIs during code patchingAndi Kleen
When a machine check or NMI occurs while multiple byte code is patched the CPU could theoretically see an inconsistent instruction and crash. Prevent this by temporarily disabling MCEs and returning early in the NMI handler. Based on discussion with Mathieu Desnoyers. Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22x86: i386-show-unhandled-signals-v3Masoud Asgharifard Sharbiani
This patch makes the i386 behave the same way that x86_64 does when a segfault happens. A line gets printed to the kernel log so that tools that need to check for failures can behave more uniformly between debug.show_unhandled_signals sysctl variable to 0 (or by doing echo 0 > /proc/sys/debug/exception-trace) Also, all of the lines being printed are now using printk_ratelimit() to deny the ability of DoS from a local user with a program like the following: main() { while (1) if (!fork()) *(int *)0 = 0; } This new revision also includes the fix that Andrew did which got rid of new sysctl that was added to the system in earlier versions of this. Also, 'show-unhandled-signals' sysctl has been renamed back to the old 'exception-trace' to avoid breakage of people's scripts. AK: Enabling by default for i386 will be likely controversal, but let's see what happens AK: Really folks, before complaining just fix your segfaults AK: I bet this will find a lot of silent issues Signed-off-by: Masoud Sharbiani <masouds@google.com> Signed-off-by: Andi Kleen <ak@suse.de> [ Personally, I've found the complaints useful on x86-64, so I'm all for this. That said, I wonder if we could do it more prettily.. -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21i386: Remove unneeded test of 'task' in dump_trace()Jesper Juhl
Remove unneeded test of task != NULL from arch/i386/kernel/traps.c::dump_trace() At the start of the function we have this test: if (!task) task = current; so further down there's no need to test 'task'. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21i386: touch_nmi_watchdog() in print_trace_address()Konrad Rzeszutek
Prevent NMI watchdog triggering during long sysrq-T outputs. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19drivers/edac: add new nmi rescanDave Jiang
Provides a way for NMI reported errors on x86 to notify the EDAC subsystem pending ECC errors by writing to a software state variable. Here's the reworked patch. I added an EDAC stub to the kernel so we can have variables that are in the kernel even if EDAC is a module. I also implemented the idea of using the chip driver to select error detection mode via module parameter and eliminate the kernel compile option. Please review/test. Thx! Also, I only made changes to some of the chipset drivers since I am unfamiliar with the other ones. We can add similar changes as we go. Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Douglas Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: export symbols for lguest as a moduleRusty Russell
lguest does some fairly lowlevel things to support a host, which normal modules don't need: math_state_restore: When the guest triggers a Device Not Available fault, we need to be able to restore the FPU __put_task_struct: We need to hold a reference to another task for inter-guest I/O, and put_task_struct() is an inline function which calls __put_task_struct. access_process_vm: We need to access another task for inter-guest I/O. map_vm_area & __get_vm_area: We need to map the switcher shim (ie. monitor) at 0xFFC01000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18i386: fixup TRACE_IRQ breakagePeter Zijlstra
The TRACE_IRQS_ON function in iret_exc: calls a C function without ensuring that the segments are set properly. Move the trace function and the enabling of interrupt into the C stub. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Report that kernel is tainted if there was an OOPSPavel Emelianov
If the kernel OOPSed or BUGed then it probably should be considered as tainted. Thus, all subsequent OOPSes and SysRq dumps will report the tainted kernel. This saves a lot of time explaining oddities in the calltraces. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Added parisc patch from Matthew Wilson -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16generic bug: use show_regs() instead of dump_stack()Heiko Carstens
The current generic bug implementation has a call to dump_stack() in case a WARN_ON(whatever) gets hit. Since report_bug(), which calls dump_stack(), gets called from an exception handler we can do better: just pass the pt_regs structure to report_bug() and pass it to show_regs() in case of a warning. This will give more debug informations like register contents, etc... In addition this avoids some pointless lines that dump_stack() emits, since it includes a stack backtrace of the exception handler which is of no interest in case of a warning. E.g. on s390 the following lines are currently always present in a stack backtrace if dump_stack() gets called from report_bug(): [<000000000001517a>] show_trace+0x92/0xe8) [<0000000000015270>] show_stack+0xa0/0xd0 [<00000000000152ce>] dump_stack+0x2e/0x3c [<0000000000195450>] report_bug+0x98/0xf8 [<0000000000016cc8>] illegal_op+0x1fc/0x21c [<00000000000227d6>] sysc_return+0x0/0x10 Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andi Kleen <ak@suse.de> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14Revert "ipmi: add new IPMI nmi watchdog handling"Linus Torvalds
This reverts commit f64da958dfc83335de1d2bef9d3868f30feb4e53. Andi Kleen is unhappy with the changes, and they really do not seem worth it. IPMI could use DIE_NMI_IPI instead of the new callback, even though that ends up having its own set of problems too, mainly because the IPMI code cannot really know the NMI was from IPMI or not. Manually fix up conflicts in arch/x86_64/kernel/traps.c and drivers/char/ipmi/ipmi_watchdog.c. Cc: Andi Kleen <ak@suse.de> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Corey Minyard <minyard@acm.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09wrap access to thread_infoRoman Zippel
Recently a few direct accesses to the thread_info in the task structure snuck back, so this wraps them with the appropriate wrapper. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ipmi: add new IPMI nmi watchdog handlingCorey Minyard
Convert over to the new NMI handling for getting IPMI watchdog timeouts via an NMI. This add config options to know if there is the ability to receive NMIs and if it has an NMI post processing call. Then it modifies the IPMI watchdog to take advantage of this so that it can know if an NMI comes in. It also adds testing that the IPMI NMI watchdog works. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] i386: Page-align the GDTJeremy Fitzhardinge
Xen wants a dedicated page for the GDT. I believe VMI likes it too. lguest, KVM and native don't care. Simple transformation to page-aligned "struct gdt_page". Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com>
2007-05-02[PATCH] i386: i386 separate hardware-defined TSS from Linux additionsRusty Russell
On Thu, 2007-03-29 at 13:16 +0200, Andi Kleen wrote: > Please clean it up properly with two structs. Not sure about this, now I've done it. Running it here. If you like it, I can do x86-64 as well. == lguest defines its own TSS struct because the "struct tss_struct" contains linux-specific additions. Andi asked me to split the struct in processor.h. Unfortunately it makes usage a little awkward. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de>
2007-05-02[PATCH] i386: cleanup GDT AccessRusty Russell
Now we have an explicit per-cpu GDT variable, we don't need to keep the descriptors around to use them to find the GDT: expose cpu_gdt directly. We could go further and make load_gdt() pack the descriptor for us, or even assume it means "load the current cpu's GDT" which is what it always does. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-05-02[PATCH] x86: Fix i386 and x86_64 fault information pollutionAndi Kleen
a userspace fault or a kernelspace fault which will result in the immediate death of the process. They should not be filled in as a result of a kernelspace fault which can be fixed up. Otherwise, if the process is handling SIGSEGV and examining the fault information, this can result in the kernel space fault trashing the previously stored fault information if it arrives between the userspace fault happening and the SIGSEGV being delivered to the process. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Jan Beulich <jbeulich@novell.com> -- arch/i386/kernel/traps.c | 24 ++++++++++++++++++------ arch/x86_64/kernel/traps.c | 30 +++++++++++++++++++++++------- 2 files changed, 41 insertions(+), 13 deletions(-)
2007-02-13[PATCH] i386: add option to show more code in oops reportsChuck Ebbert
Sometimes developers need to see more object code in an oops report, e.g. when kernel may be corrupted at runtime. Add the "code_bytes" option for this. Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-13[PATCH] i386: Convert i386 PDA code to use %fsJeremy Fitzhardinge
Convert the PDA code to use %fs rather than %gs as the segment for per-processor data. This is because some processors show a small but measurable performance gain for reloading a NULL segment selector (as %fs generally is in user-space) versus a non-NULL one (as %gs generally is). On modern processors the difference is very small, perhaps undetectable. Some old AMD "K6 3D+" processors are noticably slower when %fs is used rather than %gs; I have no idea why this might be, but I think they're sufficiently rare that it doesn't matter much. This patch also fixes the math emulator, which had not been adjusted to match the changed struct pt_regs. [frederik.deweerdt@gmail.com: fixit with gdb] [mingo@elte.hu: Fix KVM too] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Ian Campbell <Ian.Campbell@XenSource.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Zachary Amsden <zach@vmware.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-15Remove stack unwinder for nowLinus Torvalds
It has caused more problems than it ever really solved, and is apparently not getting cleaned up and fixed. We can put it back when it's stable and isn't likely to make warning or bug events worse. In the meantime, enable frame pointers for more readable stack traces. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] Generic BUG for i386Jeremy Fitzhardinge
This makes i386 use the generic BUG machinery. There are no functional changes from the old i386 implementation. The main advantage in using the generic BUG machinery for i386 is that the inlined overhead of BUG is just the ud2a instruction; the file+line(+function) information are no longer inlined into the instruction stream. This reduces cache pollution, and makes disassembly work properly. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Andi Kleen <ak@muc.de> Cc: Hugh Dickens <hugh@veritas.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: name some old style locksPeter Zijlstra
Name some of the remaning 'old_style_spin_init' locks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] unwinder: more sanity checks in Dwarf2 unwinderJan Beulich
Tighten the requirements on both input to and output from the Dwarf2 unwinder. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] i386: touch softlockup during backtracingDave Jones
Sometimes the soft watchdog fires after we're done oopsing. See http://projects.info-pull.com/mokb/MOKB-25-11-2006.html for an example. AK: changed to touch_nmi_watchdog() Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] x86: add sysctl for kstack_depth_to_printChuck Ebbert
Add sysctl for kstack_depth_to_print. This lets users change the amount of raw stack data printed in dump_stack() without having to reboot. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] i386: Use probe_kernel_address instead of __get_user in fault pathsAndi Kleen
Makes the intention of the code cleaner to read and avoids a potential deadlock on mmap_sem. Also change the types of the arguments to not include __user because they're really not user addresses. Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] x86: Mention PCI instead of RAM in NMI parity error messageAndi Kleen
On modern systems RAM errors don't cause NMIs, but it's usually caused by PCI SERR. Mention PCI instead of RAM in the printk. Reported by r_hayashi@ctc-g.co.jp (Ryutaro Hayashi) Cc: r_hayashi@ctc-g.co.jp Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] i386: add sleazy FPU optimizationChuck Ebbert
i386 port of the sLeAZY-fpu feature. Chuck reports that this gives him a +/- 0.4% improvement on his simple benchmark x86_64 description follows: Right now the kernel on x86-64 has a 100% lazy fpu behavior: after *every* context switch a trap is taken for the first FPU use to restore the FPU context lazily. This is of course great for applications that have very sporadic or no FPU use (since then you avoid doing the expensive save/restore all the time). However for very frequent FPU users... you take an extra trap every context switch. The patch below adds a simple heuristic to this code: After 5 consecutive context switches of FPU use, the lazy behavior is disabled and the context gets restored every context switch. If the app indeed uses the FPU, the trap is avoided. (the chance of the 6th time slice using FPU after the previous 5 having done so are quite high obviously). After 256 switches, this is reset and lazy behavior is returned (until there are 5 consecutive ones again). The reason for this is to give apps that do longer bursts of FPU use still the lazy behavior back after some time. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] i386: espfix cleanupStas Sergeev
Clean up the espfix code: - Introduced PER_CPU() macro to be used from asm - Introduced GET_DESC_BASE() macro to be used from asm - Rewrote the fixup code in asm, as calling a C code with the altered %ss appeared to be unsafe - No longer altering the stack from a .fixup section - 16bit per-cpu stack is no longer used, instead the stack segment base is patched the way so that the high word of the kernel and user %esp are the same. - Added the limit-patching for the espfix segment. (Chuck Ebbert) [jeremy@goop.org: use the x86 scaling addressing mode rather than shifting] Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Zachary Amsden <zach@vmware.com> Acked-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] i386: remove default_ldt, and simplify ldt-setting.Jeremy Fitzhardinge
This patch removes the default_ldt[] array, as it has been unused since iBCS stopped being supported. This means it is now possible to actually set an empty LDT segment. In order to deal with this, the set_ldt_desc/load_LDT pair has been replaced with a single set_ldt() operation which is responsible for both setting up the LDT descriptor in the GDT, and reloading the LDT register. If there are no LDT entries, the LDT register is loaded with a NULL descriptor. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Acked-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] i386: remove pointless printk from i386 oops outputDave Jones
This just got removed on x86-64, do the same on 32bit. It always annoyed me when this ate a line of oops output pushing interesting stuff off the screen. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] x86: Compress stack unwinder outputAndi Kleen
The unwinder has some extra newlines, which eat up loads of screen space when it spews. (See https://bugzilla.redhat.com/bugzilla/attachment.cgi?id=137900 for a nasty example). warning_symbol-> and warning-> already printk a newline, so don't add one in the strings passed to them. [AK: redone for new code] Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-12-07[PATCH] x86: shorten lines in unwinder to be <= 80 charactersAndi Kleen
Andrew complained about > 80 character lines in the new unwinder. Fix that. Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-17x86: be more careful when walking back the frame pointer chainLinus Torvalds
When showing the stack backtrace, make sure that we never accept not only an unchanging frame pointer, but also a frame pointer that moves back down the stack frame. It must always grow up (toward older stack frames). I doubt this has triggered, but a subtly corrupt stack with extremely unlucky contents could cause us to loop forever on a bogus endless frame pointer chain. This review was triggered by much worse problems happening in some of the other stack unwinding code. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] x86: Clean up x86 NMI sysctlsAndi Kleen
Use prototypes in headers Don't define panic_on_unrecovered_nmi for all architectures Cc: dzickus@redhat.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-27[PATCH] x86: use probe_kernel_address in handle_BUG()Andrew Morton
Avoid possible deadlock on a BUG() inside down_write(mmap_sem). The deadlock can only occur if something has gone horridly wrong, because a fault here shouldn't happen. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26[PATCH] i386: show_registers(): try harder to print failing codeChuck Ebbert
show_registers() tries to dump failing code starting 43 bytes before the offending instruction, but this address can be bad, for example in a device driver where the failing instruction is less than 43 bytes from the start of the driver's code. When that happens, try to dump code starting at the failing instruction instead of printing no code at all. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Cc: Andi Kleen <ak@muc.de> Cc: Keith Owens <kaos@ocs.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] i386: Split multi-line printk in oops output.Dave Jones
Sometimes, bug reports come in where we've had an oops, and the only record we have is what the reporter saw on screen shortly before the system locked up completely. Unfortunatly, syslog only prints lines beginning with KERN_EMERG to the console, so some lines get lost. An example of this can be seen at https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=203723 Some of this information isn't vital to diagnosis, but some parts are useful, such as the tainted flag. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: Disallow kprobes on NMI handlersFernando Luis Vázquez Cao
A kprobe executes IRET early and that could cause NMI recursion and stack corruption. Note: This problem was originally spotted and solved by Andi Kleen in the x86_64 architecture. This patch is an adaption of his patch for i386. AK: Merged with current code which was a bit different. AK: Removed printk in nmi handler that shouldn't be there in the first time AK: Added missing include. AK: added KPROBES_END Signed-off-by: Fernando Vazquez <fernando@intellilink.co.jp> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: Descriptor and trap table cleanups.Rusty Russell
The implementation comes from Zach's [RFC, PATCH 10/24] i386 Vmi descriptor changes: Descriptor and trap table cleanups. Add cleanly written accessors for IDT and GDT gates so the subarch may override them. Note that this allows the hypervisor to transparently tweak the DPL of the descriptors as well as the RPL of segments in those descriptors, with no unnecessary kernel code modification. It also allows the hypervisor implementation of the VMI to tweak the gates, allowing for custom exception frames or extra layers of indirection above the guest fault / IRQ handlers. Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: Get ebp from unwinder state when continuing fallback backtraceAndi Kleen
Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: Terminate backtrace fallback early if unwinder stack pointer ↵Andi Kleen
is zero Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] i386: Do stacktracer conversion tooAndi Kleen
Following x86-64 patches. Reuses code from them in fact. Convert the standard backtracer to do all output using callbacks. Use the x86-64 stack tracer implementation that uses these callbacks to implement the stacktrace interface. This allows to use the new dwarf2 unwinder for stacktrace and get better backtraces. Cc: mingo@elte.hu Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] x86: x86 clean up nmi panic messagesDon Zickus
Clean up some of the output messages on the nmi error paths to make more sense when they are displayed. This is mainly a cosmetic fix and shouldn't impact any normal code path. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] x86: Allow users to force a panic on NMIDon Zickus
To quote Alan Cox: The default Linux behaviour on an NMI of either memory or unknown is to continue operation. For many environments such as scientific computing it is preferable that the box is taken out and the error dealt with than an uncorrected parity/ECC error get propogated. A small number of systems do generate NMI's for bizarre random reasons such as power management so the default is unchanged. In other respects the new proc/sys entry works like the existing panic controls already in that directory. This is separate to the edac support - EDAC allows supported chipsets to handle ECC errors well, this change allows unsupported cases to at least panic rather than cause problems further down the line. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
