[CPUFREQ] acpi-cpufreq: Proper ReadModifyWrite of PERF_CTL MSR
During recent acpi-cpufreq changes, writing to PERF_CTL msr
changed from RMW of entire 64 bit to RMW of low 32 bit and clearing of
upper 32 bit. Fix it back to do a proper RMW of the MSR.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Mark Langsdorf points out that the correct define for this
revision bump is 0x80000. Also to save us having to keep
renaming the #define, give it a more meaningful name.
When the PST tables are broken, powernow-k7 uses ACPI's processor_perflib to
deduce the available frequency multipliers from the _PSS tables.
Upon frequency change, processor_perflib performs some verification on the
frequency (checks that it's within allowable bounds).
powernow-k7 deals with absolute frequencies in KHz, whereas perflib only
deals with MHz values. When performing the above verification, perflib
multiplies the MHz values by 1000 to obtain the KHz value.
We then end up with situations like the following:
- powernow-k7 multiplies the multiplier by the FSB, and obtains a value
such as 1266768 KHz
- perflib belives the same state has frequency of 1266 MHz
- acpi_processor_ppc_notifier calls cpufreq_verify_within_limits to verify
that 1266768 is in the allowable range of 0 to 1266000 (i.e. 1266 * 1000)
- it's not, so that frequency is rejected
- the maximum CPU frequency is not reachable
This patch solves the problem by rounding up the MHz values stored in perflib's
tables. Additionally it corrects a broken URL.
It also fixes http://bugzilla.kernel.org/show_bug.cgi?id=8255 although this
case is a bit different: the frequencies in the _PSS tables are wildly wrong,
but we get better results if we force ACPI to respect the fsb * multiplier
calculations (even though it seems that the multiplier values aren't entirely
correct either).
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Reported-by: Calvin Dodge <caldodge@gmail.com>
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (59 commits)
PCI: Free resource files in error path of pci_create_sysfs_dev_files()
pci-quirks: disable MSI on RS400-200 and RS480
PCI hotplug: Use menuconfig objects
PCI: ZT5550 CPCI Hotplug driver fix
PCI: rpaphp: Remove semaphores
PCI: rpaphp: Ensure more pcibios_add/pcibios_remove symmetry
PCI: rpaphp: Use pcibios_remove_pci_devices() symmetrically
PCI: rpaphp: Document is_php_dn()
PCI: rpaphp: Document find_php_slot()
PCI: rpaphp: Rename rpaphp_register_pci_slot() to rpaphp_enable_slot()
PCI: rpaphp: refactor tail call to rpaphp_register_slot()
PCI: rpaphp: remove rpaphp_set_attention_status()
PCI: rpaphp: remove print_slot_pci_funcs()
PCI: rpaphp: Remove setup_pci_slot()
PCI: rpaphp: remove a call that does nothing but a pointer lookup
PCI: rpaphp: Remove another wrappered function
PCI: rpaphp: Remve another call that is a wrapper
PCI: rpaphp: remove a function that does nothing but wrap debug printks
PCI: rpaphp: Remove un-needed goto
PCI: rpaphp: Fix a memleak; slot->location string was never freed
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/kernel/xtensa_ksyms.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
The PowerNow! driver for Opteron reports the number of cores
in the system, but claims to report the number of processors.
Fix this minor cosmetic bug.
Signed-off-by: Bhavana Nagendra <bhavana.nagendra@amd.com>
Acked-by: Mark Langsdorf <mark.langsdorf@amd.com>
fill_powernow_table_pstate() and fill_powernow_table_fidvid() are only
defined and used for X86_POWERNOW_K8_ACPI.
Signed-off-by: David Rientjes <rientjes@google.com>
There is something wrong with this code. It needs more
testing. It is better to disable it for now because support
for some machines will be broken.
Signed-off-by: Rafal Bilski <rafalbilski@interia.pl>
BUG: using smp_processor_id() in preemptible [00000001] code:
kondemand/0/2473
caller is centrino_target+0xfb/0x600
[<401e3646>] debug_smp_processor_id+0x9e/0xb0
[<40112afb>] centrino_target+0xfb/0x600
[<40112a00>] centrino_target+0x0/0x600
[<40305bd9>] __cpufreq_driver_target+0x5c/0x6b
[<f897a537>] do_dbs_timer+0x1bc/0x208 [cpufreq_ondemand]
[<40134a46>] run_workqueue+0x85/0x125
[<40374f7f>] _spin_lock_irqsave+0x18/0x66
[<f897a37b>] do_dbs_timer+0x0/0x208 [cpufreq_ondemand]
[<401353fb>] worker_thread+0xf9/0x124
[<401213b9>] default_wake_function+0x0/0xc
[<40135302>] worker_thread+0x0/0x124
[<40137b37>] kthread+0xb0/0xd9
[<40137a87>] kthread+0x0/0xd9
[<40104b2f>] kernel_thread_helper+0x7/0x10
Replace obsolete pci_find_device with pci_get_device.
Dances with cpumasks go away.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Support for Longhaul ver. 2 broke driver for VIA C3 Eden 600MHz with
Samuel 2 core. Processor is not able to switch frequency anymore. I
don't know much about this issue at the moment, but until (if ever) I
will know why, this part should be reversed.
This reverts commit aeeddc1435c37fa3fc844f31d39c185b08de4158, which was
half-baked and broken. It just resulted in compile errors, since
cpufreq_register_driver() still changes the 'driver_data' by setting
bits in the flags field. So claiming it is 'const' _really_ doesn't
work.
Not all cases are possible due to ->flags being set at runtime
on some drivers.
Revert default on deprecated config X86_SPEEDSTEP_CENTRINO_ACPI
Signed-off-by: Thomas Renninger <trenn@suse.de>
arch/i386/kernel/cpu/cpufreq/Kconfig | 1 -
arch/x86_64/kernel/cpufreq/Kconfig | 1 -
2 files changed, 2 deletions(-)
Start using v2 version of Longhaul when available. It provides
voltage scaling and can use ACPI C3 state. That's curious. CPU
will not change frequency on ACPI C3 when v1 is in use, but it will
when v2 is used. Driver will return max frequency all the time if
this isn't true for all processors. There is strange thing with
mobile voltage. Looks like only Nehemiah (C3-M) supports it.
Earlier processors have different mobile VRM (in docs), but I can't
find any which is using it. Looks like all are using VRM 8.5. So
fail for non Nehemiah with mobile VRM.
Solution for small, but nasty bug: access beyond end of f_table for C7 brand.
This change should make Longhaul more compatible with
both ver. 2 and Powersaver processors. Voltage transitions
will be done before or after frequency transition. That depends
on direction of change. I don't know how to force conservative
governor when voltage scaling is enabled, so there is only
a warning for user. Minimal voltage is calculated in different
way now because in this way more power is saved at lower
multipliers.
Borowed from VIA driver.
Simple cleanup in code which is setting minmult.
This is driver for Enhanced Powersaver which is present in VIA C7
processors. Beta tested by Jorgen (jorgen (at) greven dot dk).
Thanks! Based on documentation provided by Dave Jones (Thanks!)
and C7 Eden datasheet available from www.via.com.tw. Looks like all
these C7 Eden CPU's don't have P-states in BIOS. I know that 2
p-states is low, but Jorgen finds it usefull anyway because board
is passive cooled.
There are 3 different types of C7 processors (called brands):
0. C7-M - these processors can set any maultiplier between min and
max, any voltage between min and max.
1. C7 - only min and max states are supported. Voltage is different
for min and max states.
2. Eden - only min and max states are supported. Looks like this
brand can only change multiplier. Voltage seems to be the same for
min and max frequency.
I don't know why it is working and how, but it is working. On my
Epia transition time is by default set to 100us. I'm changing it to
200us. After that I can change frequency from min (x4.0) to max (x7.5)
without lockup. Many times.
There is a paranoid check at a beginning of a patch. Probably dead
code, but I don't have better ideas for CL10000 case at the moment.
Only way to to detect broken chip seems to be looking in log for
spurious interrupts.
This is bug reported by John-Marc Chandonia:
> Detected 1002.292 MHz processor.
> longhaul: VIA C3 'Nehemiah B' [C5N] CPU detected. Powersaver supported.
> longhaul: Using throttling support.
> longhaul: Invalid (reserved) FSB!
FSB is correcly guessed for 999.554 MHz CPU.
To fix this error:
- ROUNDING should be range, not mask - at it's current value it is +7 -8,
- more precise calculations inside guess_fsb - 7.5x133MHz is 1000MHz now.
Now there is no need to depend on -1 in Nehemiah tables. After
previous change code is eliminating multipliers lower then 5.0
by minmult for Nehemiah A and B.
Signed-off-by: Rafał Bilski <rafalbilski@interia.pl>
Looks like some time ago I introduced a bug to Longhaul.
I had report that 9x133Mhz CPU is seen as 5x133MHz. So I
changed multipliers table. That was a mistake. According to
documentation table was correct. So only way to avoid 5 or 9
dilema is not use MaxMHzBR for PowerSaver 1.0. One code that
works on all processors. To do it I need also separate flag for
Nehemiah C (min = x4.0) and Nehemiah (min = x5.0).
This fixes the cpuinfo_cur_freq value by using the correct
find_khz_freq_from_fiddid() when the CPU uses hardware p-states.
Signed-off-by: Joachim Deguara <joachim.deguara@amd.com>
There is no need to have this option in Longhaul anymore.
It was for laptop with CLE266 chipset in times, when only
ACPI C3 was used to switch frequency. Now we have native
support not only for CLE266, but CN400 too. Would be good
to have support for PN266, but I can't find datasheet for it.
Looks like BIOS for CPU's faster then 1GHz don't support
ACPI C2 nor C3.
Signed-off-by: Len Brown <len.brown@intel.com>
This workaround unnecessarily cripples functionality to work
around an errata that doesn't seem possible to hit due to
us using the automatic clock throttling in the p4 mcheck code.
See http://lkml.org/lkml/2006/10/28/148 for complete reasoning
and lack of disconsent.
Bunch of unused vars + one case where gcc isn't smart enough.
arch/i386/kernel/cpu/cpufreq/acpi-cpufreq.c:acpi_cpufreq_target()
cmd.val was used uninitialized on the line below.
Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
This is patch that solves Ebox mini PC issue and make
FSB code more specification compilant. At start guess_fsb
function is guessing 200MHz FSB too. It is better to
make it in this way because, thanks to this function, driver
will fail for bogus FSB values caused by bogus multiplier
value. For PowerSaver processors we can't depend on Max /
MinMHzFSB because these values are only used for
PowerSaver 2.0 and 3.0. Most processors on which Longhaul
is used are PowerSaver 1.0 only. I'm changing code for older
CPU's too, but not so much as previously, and this code was
already used for Ezra. Using MinMHzBR for Ezra-T is outside
spec. It is for voltage scaling purpose and don't have to
be equal to minmult (but it is). Same for Nehemiah (it
isn't for sure). Added mult - current multiplier value.
ACPI PM2 register was fallback for "Longhaul ver. 1" CPU's.
My assumption that this register isn't present at
"PowerSaver" motherboards is so far true, but current code
will not work correctly in other case. There are three possible
supports: ACPI C3, PM2 and northbridge. That was my assumption
that ACPI C3 and northbridge is for PS and northbridge and PM2
is for V1. In current code we can only check if it is ACPI
support or not by port22_en. So remove port22_en and add
longhaul_flags. If USE_ACPI_C3 and USE_NORTHBRIDGE are both
clear then it means ACPI PM2 support. Also change order of
support probe from ACPI C3, PM2, northbridge to ACPI C3,
northbridge, ACPI PM2. Paranoid protection against port 0x22
cast as ACPI PM2 register. Bit 1 clear in such case - lockup
on AGP DMA. And obvious (now) fixup for do_powersaver. Use
cx->address only for ACPI C3 ("PowerSaver" processor using
PM2 support).
Signed-off-by: Rafaż Bilski <rafalbilski@interia.pl>
Signed-off-by: RafaĆ Bilski <rafalbilski@interia.pl>
A space and a bracket are missing (and indentation is wrong).
Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org>
change notification
Fixes the oops in cpufreq_stats with acpi_cpufreq driver. The issue was
that the frequency was reported as 0 in acpi-cpufreq.c. The bug is due to
different indicies for freq_table and ACPI perf table.
Also adds a check in cpufreq_stats to check for error return from
freq_table_get_index() and avoid using the error return value.
Patch fixes the issue reported at
http://www.ussg.iu.edu/hypermail/linux/kernel/0611.2/0629.html
and also other similar issue here
http://bugme.osdl.org/show_bug.cgi?id=7383 comment 53
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
Some gcc's are more anal than others about empty switch labels.
error: label at end of compound statement
C7's are centrino speedstep-alike.
Check the correct variable and set policy->cur upon acpi-cpufreq
initialization to allow the userspace governor to be used as default.
Signed-off-by: Mattia Dongili <malattia@linux.it>
Acked-by: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com>
Small cleanup in acpi-cpufreq.
Support for CN400 northbridge when ACPI C3 isn't available.
Tested on Epia SP13000. Thanks to Robert for testing it.
On board of Epia SP13000 is 10x133Mhz VIA Nehemiah. It is reported
as 10x200MHz. This patch is fixing this issue.
Support for Core CPUs was broken in two ways in speedstep-lib: for x86_64,
we missed a MSR definition; for both x86_64 and i386, the FSB calculation
was wrong by four (it's a quad-pumped bus). Also increase the accuracy
of the calculation.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Fix the bug in duplicate states elimination in acpi-cpufreq.
Bug: Due to duplicate state elimiation in the loop earlier, the number
of valid_states can be less than perf->state_count, in which case
freq_table was ending up with some garbage/uninitialized entries
in the table.
From: Alexey Starikovskiy <alexey.y.starikovskiy@intel.com>
On some systems there could be bits set in the upper half of
the control value provided by the _PSS object. These bits are
only relevant for cpufreq drivers that use IO ports which are not
currently supported by the speedstep-centrino driver. The current
MSR oriented code assumes that upper bits are not set and thus
fails to work correctly when they are. e.g. the control and status
value equality check failed on the IBM x3650 even though the ACPI
spec allows inequality.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
We don't need a temporary variable to get the PCI revision ID.
