path: root/arch/i386/kernel/cpu/cpufreq/p4-clockmod.c
2007-10-11i386: move kernel/cpu/cpufreqThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-04-26[CPUFREQ] p4-clockmod: switch to rdmsr_on_cpu/wrmsr_on_cpuAlexey Dobriyan
Dances with cpumasks go away. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Dave Jones <davej@redhat.com>
2007-01-29[CPUFREQ] Remove unneeded errata workaround from p4-clockmod.Dave Jones
This workaround unnecessarily cripples functionality to work around an errata that doesn't seem possible to hit due to us using the automatic clock throttling in the p4 mcheck code. See http://lkml.org/lkml/2006/10/28/148 for complete reasoning and lack of disconsent. Signed-off-by: Dave Jones <davej@redhat.com>
2006-11-06[CPUFREQ] p4-clockmod: add more CPUsDominik Brodowski
Several more Intel CPUs are now capable using the p4-clockmod cpufreq driver. As it is of limited use most of the time, print a big bold warning if a better cpufreq driver might be available. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2006-03-10[CPUFREQ] Fix the p4-clockmod N60 errata workaround.Pallipadi, Venkatesh
Fix the code to disable freqs less than 2GHz in N60 errata. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Dave Jones <davej@redhat.com>
2006-02-28[CPUFREQ] Lots of whitespace & CodingStyle cleanup.Dave Jones
2006-01-26[CPUFREQ] p4-clockmod: Workaround for CPU's with N60 errataBen Collins
Ignore clock frequencies below 2Ghz for CPU's detected with N60 errata bug. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Jones <davej@redhat.com>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
