This reverts commit 5491d0f3e206beb95eeb506510d62a1dab462df1.
As per Andi:
"After some discussion with people who have the affected system it
seems best to revert for 2.6.17. It broke a common BIOS workaround
and PCI-X still doesn't work. Alternative is for people to change
the BIOS which seems to be better right now."
This is needed to see all devices.
The system has multiple PCI segments and we don't handle that properly
yet in PCI and ACPI. Short term before this is fixed blacklist it to
pci=noacpi.
Acked-by: len.brown@intel.com
Cc: gregkh@suse.de
Signed-off-by: Andi Kleen <ak@suse.de>
We only need to check cpu_has_apic in the IO-APIC/L-APIC parsing, not for
all of ACPI.
The patch I submitted earlier to fix disabled LAPIC handling in ACPI was
mismerged for some reason I still don't quite understand. Parts of it was
applied to the wrong function.
This patch fixes it up.
Cc: <len.brown@intel.com>
was mismerged for some reason I still don't quite understand. Parts
of it was applied to the wrong function.
Cc: len.brown@intel.com
When nolapic was passed or the local APIC was disabled
for another reason ACPI would still parse the IO-APICs
until these were explicitely disabled with noapic.
Usually this resulted in a non booting configuration unless
"nolapic noapic" was used.
I also disabled the local APIC parsing in this case, although
that's only cosmetic (suppresses a few printks)
This hopefully makes nolapic work in all cases.
Cc: Len Brown <len.brown@intel.com>
Almost all users of the table addresses from the EFI system table want
physical addresses. So rather than doing the pa->va->pa conversion, just keep
physical addresses in struct efi.
This fixes a DMI bug: the efi structure contained the physical SMBIOS address
on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap()
on a virtual address on ia64.
This is essentially the same as an earlier patch by Matt Tolentino:
http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2
except that this changes all table addresses, not just ACPI addresses.
Matt's original patch was backed out because it caused MCAs on HP sx1000
systems. That problem is resolved by the ioremap() attribute checking added
for ia64.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Matt Domsch <Matt_Domsch@dell.com>
Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com>
Cc: "Brown, Len" <len.brown@intel.com>
Cc: Andi Kleen <ak@muc.de>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
ATI chipsets tend to generate double timer interrupts for the local APIC
timer when both the 8254 and the IO-APIC timer pins are enabled. This is
because they route it to both and the result is anded together and the CPU
ends up processing it twice.
This patch changes check_timer to disable the 8254 routing for interrupt 0.
I think it would be safe on all chipsets actually (i tested it on a couple
and it worked everywhere) and Windows seems to do it in a similar way, but
to be conservative this patch only enables this mode on ATI (and adds
options to enable/disable too)
Ported over from a similar x86-64 change.
I reused the ACPI earlyquirk infrastructure for the ATI bridge check, but
tweaked it a bit to work even without ACPI.
Inspired by a patch from Chuck Ebbert, but redone.
Cc: Chuck Ebbert <76306.1226@compuserve.com>
TSC assumption on IBM systems"
This reverts commit 13a229abc25640813f1480c0478dfc6bdbc1c19e.
Quoth Andi:
"After some consideration and feedback from various people it turns
out this wasn't that good an idea. It has some problems and needs
more work. Since it was only an optimization anyways it's best to
just back it out again for now."
Big Unisys systems have multiple clusters too, but they have an
synchronized TSC.
I'm using the SMBIOS to check for vendor == IBM.
Cc: Chris McDermott <lcm@us.ibm.com>
Cc: "Protasevich, Natalie" <Natalie.Protasevich@unisys.com>
Some broken BIOS's had processors disabled, but
same apic id as a valid processor. This causes
acpi_processor_start() to think this disabled
cpu is ok, and croak. So we dont record bad
apicid's anymore.
http://bugzilla.kernel.org/show_bug.cgi?id=5930
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
branches into release
Signed-off-by: Len Brown <len.brown@intel.com>
And fix the test to include the size
Noticed by Vivek Goyal
Use the #define for ACPI_LEVEL_SENSITIVE instead of assuming
non-zero, because ACPICA 20051021 changes its value to zero.
Also, use uniform variable names:
edge_level -> triggering
active_high_low -> polarity
Handle FADT 2.0 xpmtmr address 0 case.
http://bugzilla.kernel.org/show_bug.cgi?id=5283
Signed-off-by: Shaohua Li<shaohua.li@intel.com>
Needed to make the earlier use disabled CPUs for CPU hotplug patch
actually work.
Need to register disabled processors as well, so we can count them
towards cpu_possible_map as hot pluggable cpus.
We should zap the low mappings, as soon as possible, so that we can catch
kernel bugs more effectively. Previously early boot had NULL mapped
and didn't trap on NULL references.
This patch introduces boot_level4_pgt, which will always have low identity
addresses mapped. Druing boot, all the processors will use this as their
level4 pgt. On BP, we will switch to init_level4_pgt as soon as we enter C
code and zap the low mappings as soon as we are done with the usage of
identity low mapped addresses. On AP's we will zap the low mappings as
soon as we jump to C code.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
interrupt sources
Here's a patch that builds on Natalie Protasevich's IRQ compression
patch and tries to work for MPS boots as well as ACPI. It is meant for
a 4-node IBM x460 NUMA box, which was dying because it had interrupt
pins with GSI numbers > NR_IRQS and thus overflowed irq_desc.
The problem is that this system has 270 GSIs (which are 1:1 mapped with
I/O APIC RTEs) and an 8-node box would have 540. This is much bigger
than NR_IRQS (224 for both i386 and x86_64). Also, there aren't enough
vectors to go around. There are about 190 usable vectors, not counting
the reserved ones and the unused vectors at 0x20 to 0x2F. So, my patch
attempts to compress the GSI range and share vectors by sharing IRQs.
I need the following patch to compile -git8 here, otherwise these
files fail to compile (asm/hw_irq.h needs definitions from
linux/irq.h and that file provides the required include ordering).
I did not do a full audit, though there looks to be many other
places that should get the same treatment, if this is the right
way to do it.
Most of these guys are simply not needed (pulled by other stuff
via asm-i386/hardirq.h). One that is not entirely useless is hilarious -
arch/i386/oprofile/nmi_timer_int.c includes linux/irq.h... as a way to
get linux/errno.h
i386 generic subarchitecture requires explicit dmi strings or command line
to enable bigsmp mode. The patch below removes that restriction, and uses
bigsmp as soon as it finds more than 8 logical CPUs, Intel processors and
xAPIC support.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Delete the ability to build an ACPI kernel that does
not include PCI support. When such a machine is created
and it requires a tuned kernel, send a patch.
http://bugzilla.kernel.org/show_bug.cgi?id=1364
it is a synonym for CONFIG_ACPI
Current acpi_register_gsi() function has no way to indicate errors to its
callers even though acpi_register_gsi() can fail to register gsi because of
some reasons (out of memory, lack of interrupt vectors, incorrect BIOS, and so
on). As a result, caller of acpi_register_gsi() cannot handle the case that
acpi_register_gsi() fails. I think failure of acpi_register_gsi() should be
handled properly.
This series of patches changes acpi_register_gsi() to return negative value on
error, and also changes callers of acpi_register_gsi() to handle failure of
acpi_register_gsi().
This patch changes the type of return value of acpi_register_gsi() from
"unsigned int" to "int" to indicate an error. If acpi_register_gsi() fails to
register gsi, it returns negative value.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
This patch is the first step in properly handling the MCFG PCI table.
It defines the structures properly, and saves off the table so that the
pci mmconfig code can access it. It moves the parsing of the table a
little later in the boot process, but still before the information is
needed.
This patch adds the following new interfaces for I/O xAPIC
hotplug. The implementation of these interfaces depends on each
architecture.
o int acpi_register_ioapic(acpi_handle handle, u64 phys_addr,
u32 gsi_base);
This new interface is to add a new I/O xAPIC specified by
phys_addr and gsi_base pair. phys_addr is the physical address
to which the I/O xAPIC is mapped and gsi_base is global system
interrupt base of the I/O xAPIC. acpi_register_ioapic returns
0 on success, or negative value on error.
o int acpi_unregister_ioapic(acpi_handle handle, u32 gsi_base);
This new interface is to remove a I/O xAPIC specified by
gsi_base. acpi_unregister_ioapic returns 0 on success, or
This patch moves ACPI sleep quirk out of dmi_scan.c
Signed-off-by: Andrey Panin <pazke@donpac.ru>
This patch moves ACPI boot quirks out of dmi_scan.c
Noticed by Jakub Jermar <jermar@itbs.cz>
The recent acpi boot patch breaks for me: acpi_fadt needs CONFIG_ACPI_BUS.
Signed-off-By: Chris Wedgwood <cw@f00f.org>
Acked-by: Andi Kleen <ak@suse.de>
x86_64 genapic mechanism should be aware of machines that use physical APIC
mode regardless of how many clusters/processors are detected.
ACPI 3.0 FADT makes this determination very simple by providing a feature
flag "force_apic_physical_destination_mode" to state whether the machine
unconditionally uses physical APIC mode.
Unisys' next generation x86_64 ES7000 will need to utilize this FADT
feature flag in order to boot the x86_64 kernel in the correct APIC mode.
This patch has been tested on both x86_64 commodity and ES7000 boxes.
Signed-off-by: Jason Davis <jason.davis@unisys.com>
infrastructure for it.
Let it rip!
