path: root/arch/frv
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27ptrace: cleanup arch_ptrace() on frvNamhyung Kim
Use new 'regno', 'datap' variables in order to remove duplicated expressions and unnecessary castings. Alse remove checking @addr less than 0 because addr is now unsigned. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Daniel K." <dk@uw.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27mm: fix race in kunmap_atomic()Peter Zijlstra
Christoph reported a nice splat which illustrated a race in the new stack based kmap_atomic implementation. The problem is that we pop our stack slot before we're completely done resetting its state -- in particular clearing the PTE (sometimes that's CONFIG_DEBUG_HIGHMEM). If an interrupt happens before we actually clear the PTE used for the last slot, that interrupt can reuse the slot in a dirty state, which triggers a BUG in kmap_atomic(). Fix this by introducing kmap_atomic_idx() which reports the current slot index without actually releasing it and use that to find the PTE and delay the _pop() until after we're completely done. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Christoph Hellwig <hch@infradead.org> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits) serial8250: ratelimit "too much work" error serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster serial: abstraction for 8250 legacy ports serial/imx: check that the buffer is non-empty before sending it out serial: mfd: add more baud rates support jsm: Remove the uart port on errors Alchemy: Add UART PM methods. 8250: allow platforms to override PM hook. altera_uart: Don't use plain integer as NULL pointer altera_uart: Fix missing prototype for registering an early console altera_uart: Fixup type usage of port flags altera_uart: Make it possible to use Altera UART and 8250 ports together altera_uart: Add support for different address strides altera_uart: Add support for getting mapbase and IRQ from resources altera_uart: Add support for polling mode (IRQ-less) serial: Factor out uart_poll_timeout() from 8250 driver serial: mark the 8250 driver as maintained serial: 8250: Don't delay after transmitter is ready. tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver vcs: invoke the vt update callback when /dev/vcs* is written to ...
2010-10-22ioctl: Use asm-generic/ioctls.h on frv (enables termiox)Jeff Mahoney
This patch converts frv to use asm-generic/ioctls.h instead of its own version. The differences between the arch-specific version and the generic version are as follows: - FRV defines its own value for FIOQSIZE, asm-generic/ioctls.h keeps it - FRV defines TIOCTTYGSTRUCT, kept in arch-specific version - The generic version provides TIOCGRS485 and TIOCSRS485 but they are unused by any driver available for this architecture. - The generic version adds support for termiox Cc: David Howells <dhowells@redhat.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-09-20frv: double syscall restarts, syscall restart in sigreturn()Al Viro
We need to make sure that only the first do_signal() to be handled on the way out syscall will bother with syscall restarts; additionally, the check on the "signal has user handler" path had been wrong - compare with restart prevention in sigreturn()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-20frv: handling of restart into restart_syscall is fsckedAl Viro
do_signal() should place the syscall number in gr7, not gr8 when handling ERESTART_WOULDBLOCK. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-20frv: avoid infinite loop of SIGSEGV deliveryAl Viro
Use force_sigsegv() rather than force_sig(SIGSEGV, ...) as the former resets the SEGV handler pointer which will kill the process, rather than leaving it open to an infinite loop if the SEGV handler itself caused a SEGV signal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-20frv: fix address verification holes in setup_frame/setup_rt_frameAl Viro
a) sa_handler might be maliciously set to point to kernel memory; blindly dereferencing it in FDPIC case is a Bad Idea(tm). b) I'm not sure you need that set_fs(USER_DS) there at all, but if you do, you'd better do it *before* checking the frame you've decided to use with access_ok(), lest sigaltstack() becomes a convenient roothole. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-20frv: restart_block.fn needs to be reset on sigreturnAl Viro
Reset restart_block.fn on executing a sigreturn such that any currently pending system call restarts will be forced to return -EINTR. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-19kbuild: migrate all arch to the kconfig mainmenu upgradeArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-08-17Make do_execve() take a const filename pointerDavid Howells
Make do_execve() take a const filename pointer so that kernel_execve() compiles correctly on ARM: arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type This also requires the argv and envp arguments to be consted twice, once for the pointer array and once for the strings the array points to. This is because do_execve() passes a pointer to the filename (now const) to copy_strings_kernel(). A simpler alternative would be to cast the filename pointer in do_execve() when it's passed to copy_strings_kernel(). do_execve() may not change any of the strings it is passed as part of the argv or envp lists as they are some of them in .rodata, so marking these strings as const should be fine. Further kernel_execve() and sys_execve() need to be changed to match. This has been test built on x86_64, frv, arm and mips. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14archs: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y have same semantic, so drop unifdef-y Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: remove dma_is_consistent APIFUJITA Tomonori
Architectures implement dma_is_consistent() in different ways (some misinterpret the definition of API in DMA-API.txt). So it hasn't been so useful for drivers. We have only one user of the API in tree. Unlikely out-of-tree drivers use the API. Even if we fix dma_is_consistent() in some architectures, it doesn't look useful at all. It was invented long ago for some old systems that can't allocate coherent memory at all. It's better to export only APIs that are definitely necessary for drivers. Let's remove this API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: unify dma_get_cache_alignment implementationsFUJITA Tomonori
dma_get_cache_alignment returns the minimum DMA alignment. Architectures defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we can unify dma_get_cache_alignment implementations. Note that some architectures implement dma_get_cache_alignment wrongly. dma_get_cache_alignment() should return the minimum DMA alignment. So fully-coherent architectures should return 1. This patch also fixes this issue. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11dma-mapping: rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGNFUJITA Tomonori
Now each architecture has the own dma_get_cache_alignment implementation. dma_get_cache_alignment returns the minimum DMA alignment. Architectures define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed buffer is DMA-safe; the buffer doesn't share a cache with the others). So we can unify dma_get_cache_alignment implementations. This patch: dma_get_cache_alignment() needs to know if an architecture defines ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if architectures doesn't define it. Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN. ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub (except for crypto). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10tty: Add EXTPROC support for LINEMODEhyc@symas.com
This patch is against the 2.6.34 source. Paraphrased from the 1989 BSD patch by David Borman @ cray.com: These are the changes needed for the kernel to support LINEMODE in the server. There is a new bit in the termios local flag word, EXTPROC. When this bit is set, several aspects of the terminal driver are disabled. Input line editing, character echo, and mapping of signals are all disabled. This allows the telnetd to turn off these functions when in linemode, but still keep track of what state the user wants the terminal to be in. New ioctl: TIOCSIG Generate a signal to processes in the current process group of the pty. There is a new mode for packet driver, the TIOCPKT_IOCTL bit. When packet mode is turned on in the pty, and the EXTPROC bit is set, then whenever the state of the pty is changed, the next read on the master side of the pty will have the TIOCPKT_IOCTL bit set. This allows the process on the server side of the pty to know when the state of the terminal has changed; it can then issue the appropriate ioctl to retrieve the new state. Since the original BSD patches accompanied the source code for telnet I've left that reference here, but obviously the feature is useful for any remote terminal protocol, including ssh. The corresponding feature has existed in the BSD tty driver since 1989. For historical reference, a good copy of the relevant files can be found here: http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741 Signed-off-by: Howard Chu <hyc@symas.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-09kmap_atomic: make kunmap_atomic() harder to misuseCesar Eduardo Barros
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse" list[1] ("Follow common convention and you'll get it wrong"), except in some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3]. kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes takes a pointer to within the page itself. This seems to once in a while trip people up (the convention they are following is the one from kunmap()). Make it much harder to misuse, by moving it to level 9 on Rusty's list[4] ("The compiler/linker won't let you get it wrong"). This is done by refusing to build if the type of its first argument is a pointer to a struct page. The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck() (which is what you would call in case for some strange reason calling it with a pointer to a struct page is not incorrect in your code). The previous version of this patch was compile tested on x86-64. [1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html [2] In these cases, it is at level 5, "Do it right or it will always break at runtime." [3] At least mips and powerpc look very similar, and sparc also seems to share a common ancestor with both; there seems to be quite some degree of copy-and-paste coding here. The include/asm/highmem.h file for these three archs mention x86 CPUs at its top. [4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html [5] As an aside, could someone tell me why mn10300 uses unsigned long as the first parameter of kunmap_atomic() instead of void *? Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Russell King <linux@arm.linux.org.uk> (arch/arm) Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips) Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300) Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300) Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc) Cc: Helge Deller <deller@gmx.de> (arch/parisc) Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc) Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc) Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc) Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc) Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86) Cc: Ingo Molnar <mingo@redhat.com> (arch/x86) Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86) Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic) Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07remove needless ISA_DMA_THRESHOLDFUJITA Tomonori
Architectures don't need to define ISA_DMA_THRESHOLD anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: James Bottomley <James.Bottomley@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-04Merge commit 'v2.6.35' into kbuild/kbuildMichal Marek
Conflicts: arch/powerpc/Makefile
2010-08-03frv: clean up arch/frv/MakefileSam Ravnborg
- removed a lot of unused variable assignmnets - removed unused bootstrap target - replaced ARCHMODFLAGS with proper KBUILD_{A,C}FLAGS_MODULE assignmnets The resuting Makefile has not been tested due to lack of toolchain, but these were all trivial changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-18Merge commit 'v2.6.35-rc3' into perf/coreIngo Molnar
Merge reason: Go from -rc1 base to -rc3 base, merge in fixes.
2010-06-09FRV: Reinstate null behaviour for the GDB remote protocol 'p' commandDavid Howells
Reinstate the null behaviour that the in-kernel gdbstub had for the GDB remote protocol 'p' command (retrieve a single register value) prior to commit 7ca8b9c0dafd ("frv: extend gdbstub to support more features of gdb"). Before that, the 'p' command just returned an empty reply, which causes gdb to then go and use the 'g' command. However, since that commit, the 'p' command returns an error string, which causes gdb to abort its connection to the target. Not all gdb versions are affected, some use try 'g' first, and if that works, don't bother with 'p', and so don't see the error. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-09arch: Implement local64_tPeter Zijlstra
On 64bit, local_t is of size long, and thus we make local64_t an alias. On 32bit, we fall back to atomic64_t. (architecture can provide optimized 32-bit version) (This new facility is to be used by perf events optimizations.) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-arch@vger.kernel.org Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-04frv: invoke oom-killer from page faultNick Piggin
As explained in commit 1c0fe6e3bd ("mm: invoke oom-killer from page fault") , we want to call the architecture independent oom killer when getting an unexplained OOM from handle_mm_fault, rather than simply killing current. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: David Howells <dhowells@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-28FRV: ARCH_KMALLOC_MINALIGN was already definedDavid Howells
ARCH_KMALLOC_MINALIGN was already defined in asm/mem-layout.h and so shouldn't have been added to asm/cache.h as well, but rather altered in place. The commit that added it to asm/cache.h was: commit 69dcf3db03626c4f18de624e8632454ea12ff260 Author: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Date: Mon May 24 14:32:54 2010 -0700 frv: set ARCH_KMALLOC_MINALIGN Architectures that handle DMA-non-coherent memory need to set ARCH_KMALLOC_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: David Howells <dhowells@redhat.com> cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27frv: remove "struct file *" argument from sysctl ->proc_handlerJan Blunck
Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27frv: use asm-generic/scatterlist.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27ptrace: unify FDPIC implementationsMike Frysinger
The Blackfin/FRV/SuperH guys all have the same exact FDPIC ptrace code in their arch handlers (since they were probably copied & pasted). Since these ptrace interfaces are an arch independent aspect of the FDPIC code, unify them in the common ptrace code so new FDPIC ports don't need to copy and paste this fundamental stuff yet again. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25frv: set ARCH_KMALLOC_MINALIGNFUJITA Tomonori
Architectures that handle DMA-non-coherent memory need to set ARCH_KMALLOC_MINALIGN to make sure that kmalloc'ed buffer is DMA-safe: the buffer doesn't share a cache with the others. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25frv: extend gdbstub to support more features of gdbDavid Howells
Extend gdbstub to support more features of gdb remote protocol to keep gdb-7 and emacs gud mode happy: (*) The D command. Detach debugger. (*) The H command. Handle setting the target thread by ignoring it. (*) The qAttached command. Indicate we 'attached' to an existing process. (*) The qC command. Indicate that the current thread ID is 0. (*) The qOffsets command. Indicate that no relocation has been done. (*) The qSymbol:: command. Indicate that we're not interested in looking up any symbol addresses. (*) The qSupported command. Indicate the maximum packet size and the fact that reverse step and continue aren't supported. (*) The vCont? command. Indicate that we don't support any of its variants. Also make it possible to trace the commands and replies without tracing the individual character I/O. [akpm@linux-foundation.org: make gdbstub_handle_query() static] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-19Merge branch 'timers-for-linus-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: avr32: Fix typo in read_persistent_clock() sparc: Convert sparc to use read/update_persistent_clock cris: Convert cris to use read/update_persistent_clock m68k: Convert m68k to use read/update_persistent_clock m32r: Convert m32r to use read/update_peristent_clock blackfin: Convert blackfin to use read/update_persistent_clock ia64: Convert ia64 to use read/update_persistent_clock avr32: Convert avr32 to use read/update_persistent_clock h8300: Convert h8300 to use read/update_persistent_clock frv: Convert frv to use read/update_persistent_clock mn10300: Convert mn10300 to use read/update_persistent_clock alpha: Convert alpha to use read/update_persistent_clock xtensa: Fix unnecessary setting of xtime time: Clean up direct xtime usage in xen
2010-05-17atomic_t: Cast to volatile when accessing atomic variablesAnton Blanchard
In preparation for removing volatile from the atomic_t definition, this patch adds a volatile cast to all the atomic read functions. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-14add descriptive comment for TIF_MEMDIE task flag declaration.Andreas Dilger
Signed-off-by: Andreas Dilger <adilger@dilger.ca> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-07frv: fix kernel/user segment handling in NOMMU modeDavid Howells
In NOMMU mode, the FRV segment handling is broken because KERNEL_DS == USER_DS. This causes tests of the following sort: /* don't pin down non-user-based iovecs */ if (segment_eq(get_fs(), KERNEL_DS)) return NULL; to malfunction. To fix this, make USER_DS the top of RAM instead of the top of the non-IO address space, and make KERNEL_DS one more than the top of the non-IO address space. Also get rid of FRV's __addr_ok() as nothing uses it. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
