path: root/arch/frv/include/asm/system.h
2011-03-29FRV: Do some cleanupsAmerigo Wang
1. frv doesn't support SMP, remove the useless SMP bits. 2. frv has its own alloc_task_struct, so define __HAVE_ARCH_TASK_STRUCT_ALLOCATOR (I am not sure if frv should use generic alloc_task_struct().) Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2009-07-01FRV: Implement atomic64_tDavid Howells
Implement atomic64_t and its ops for FRV. Tested with the following patch: diff --git a/arch/frv/kernel/setup.c b/arch/frv/kernel/setup.c index 55e4fab..086d50d 100644 --- a/arch/frv/kernel/setup.c +++ b/arch/frv/kernel/setup.c @@ -746,6 +746,52 @@ static void __init parse_cmdline_early(char *cmdline) } /* end parse_cmdline_early() */ +static atomic64_t xxx; + +static void test_atomic64(void) +{ + atomic64_set(&xxx, 0x12300000023LL); + + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000023LL); + mb(); + if (atomic64_inc_return(&xxx) != 0x12300000024LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x12300000024LL); + mb(); + if (atomic64_sub_return(0x36900000050LL, &xxx) != -0x2460000002cLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002cLL); + mb(); + if (atomic64_dec_return(&xxx) != -0x2460000002dLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != -0x2460000002dLL); + mb(); + if (atomic64_add_return(0x36800000001LL, &xxx) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x123456789abcdefLL, 0x121ffffffd4LL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x121ffffffd4LL); + mb(); + if (atomic64_cmpxchg(&xxx, 0x121ffffffd4LL, 0x123456789abcdefLL) != 0x121ffffffd4LL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0x123456789abcdefLL); + mb(); + if (atomic64_xchg(&xxx, 0xabcdef123456789LL) != 0x123456789abcdefLL) + BUG(); + mb(); + BUG_ON(atomic64_read(&xxx) != 0xabcdef123456789LL); + mb(); +} + /*****************************************************************************/ /* * @@ -845,6 +891,8 @@ void __init setup_arch(char **cmdline_p) // asm volatile("movgs %0,timerd" :: "r"(10000000)); // __set_HSR(0, __get_HSR(0) | HSR0_ETMD); + test_atomic64(); + } /* end setup_arch() */ #if 0 Note that this doesn't cover all the trivial wrappers, but does cover all the substantial implementations. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10FRV: Move to arch/frv/include/asm/David Howells
Move arch headers from include/asm-frv/ to arch/frv/include/asm/. Signed-off-by: David Howells <dhowells@redhat.com>
