Use the new helper function introduced in commit 5e6292c0f28f ("signal:
add block_sigmask() for adding sigmask to current->blocked") which
centralises the code for updating current->blocked after successfully
delivering a signal and reduces the amount of duplicate code across
architectures.
In the past some architectures got this code wrong, so using this helper
function should stop that from happening again.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Havard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
It is wrong to change ->blocked directly, see e6fa16ab. Change
handle_signal() and sys_rt_sigreturn() to use the right helper,
set_current_blocked().
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Reviewed-by: Matt Fleming <matt.fleming@intel.com>
The current handle_signal() implementation is broken - it will mask
signals if we fail to setup the signal stack frame, which isn't the
desired behaviour, we should only be masking signals if we succeed in
setting up the stack frame. It looks like this code was copied from the
old (broken) arm implementation but wasn't updated when the arm code was
fixed in commit a6c61e9dfdd0 ("[ARM] 3168/1: Update ARM signal delivery
and masking").
Same code. Use the generic version.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Link: http://lkml.kernel.org/r/20120503085034.281527118@linutronix.de
Coccinelle based conversion.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org
It's a very old and now unused prototype marking so just delete it.
Neaten panic pointer argument style to keep checkpatch quiet.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: "Venkatesh Pallipadi
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem
and converts the devices to regular devices. The sysdev drivers are
implemented as subsystem interfaces now.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Userspace relies on events and generic sysfs subsystem infrastructure
from sysdev devices, which are made available with this conversion.
Cc: Borislav Petkov <bp@amd64.org>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Len Brown <lenb@kernel.org>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Those two APIs were provided to optimize the calls of
tick_nohz_idle_enter() and rcu_idle_enter() into a single
irq disabled section. This way no interrupt happening in-between would
needlessly process any RCU job.
Now we are talking about an optimization for which benefits
have yet to be measured. Let's start simple and completely decouple
idle rcu and dyntick idle logics to simplify.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
It is assumed that rcu won't be used once we switch to tickless
mode and until we restart the tick. However this is not always
true, as in x86-64 where we dereference the idle notifiers after
the tick is stopped.
To prepare for fixing this, add two new APIs:
tick_nohz_idle_enter_norcu() and tick_nohz_idle_exit_norcu().
If no use of RCU is made in the idle loop between
tick_nohz_enter_idle() and tick_nohz_exit_idle() calls, the arch
must instead call the new *_norcu() version such that the arch doesn't
need to call rcu_idle_enter() and rcu_idle_exit().
Otherwise the arch must call tick_nohz_enter_idle() and
tick_nohz_exit_idle() and also call explicitly:
- rcu_idle_enter() after its last use of RCU before the CPU is put
to sleep.
- rcu_idle_exit() before the first use of RCU after the CPU is woken
up.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The tick_nohz_stop_sched_tick() function, which tries to delay
the next timer tick as long as possible, can be called from two
places:
- From the idle loop to start the dytick idle mode
- From interrupt exit if we have interrupted the dyntick
idle mode, so that we reprogram the next tick event in
case the irq changed some internal state that requires this
action.
There are only few minor differences between both that
are handled by that function, driven by the ts->inidle
cpu variable and the inidle parameter. The whole guarantees
that we only update the dyntick mode on irq exit if we actually
interrupted the dyntick idle mode, and that we enter in RCU extended
quiescent state from idle loop entry only.
Split this function into:
- tick_nohz_idle_enter(), which sets ts->inidle to 1, enters
dynticks idle mode unconditionally if it can, and enters into RCU
extended quiescent state.
- tick_nohz_irq_exit() which only updates the dynticks idle mode
when ts->inidle is set (ie: if tick_nohz_idle_enter() has been called).
To maintain symmetry, tick_nohz_restart_sched_tick() has been renamed
into tick_nohz_idle_exit().
This simplifies the code and micro-optimize the irq exit path (no need
for local_irq_save there). This also prepares for the split between
dynticks and rcu extended quiescent state logics. We'll need this split to
further fix illegal uses of RCU in extended quiescent states in the idle
loop.
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
This patch removes all the module loader hook implementations in the
architecture specific code where the functionality is the same as that
now provided by the recently added default hooks.
Signed-off-by: Jonas Bonn <jonas@southpole.se>
Tested-by: Michal Simek <monstr@monstr.eu>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
The ATAG_BOARDINFO is intended to hand over the information
bd->bi_board_number from u-boot to the kernel.
This piece of information can be used to implement some kind of board
identification while booting the kernel. Therefore it is placed in .initdata
section and can be accessed via the new symbol board_number only while
initializing the kernel.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
We can delete the code that checks to see if we're sending an ignored
signal to init because force_sig_info() already handles this case.
force_sig_info() will kill init even if the signal handler is SIG_DFL
and the scenario described in the comment where init might "generate
the same exception over and over again" cannot occur (force_sig_info()
clears SIGNAL_UNKILLABLE to ensure that init will die).
Also, the use of is_global_init() is not correct in the multhreaded
case, as Oleg Nesterov explains,
"is_global_init() is not right in theory, /sbin/init can be
multithreaded. And, this doesn't cover the sub-namespace
inits... I'd suggest to check SIGNAL_UNKILLABLE, but looking
closer I think you can simply remove this code."
It seems this code was copied from arch/powerpc in March 2007 in commit
623b0355d5b1 "[AVR32] Clean up exception handling code"
but the code was deleted from arch/powerpc in November 2009 in commit
a0592d42fe3e "powerpc: kill the obsolete code under is_global_init()"
So catch up with powerpc and delete the bogus code.
Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com>
* 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits)
genirq: Expand generic show_interrupts()
gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler
gpio: Cleanup genirq namespace
arm: ep93xx: Add basic interrupt info
arm/gpio: Remove three copies of broken and racy debug code
xtensa: Use generic show_interrupts()
xtensa: Convert genirq namespace
xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED
xtensa: Convert s6000 gpio irq_chip to new functions
xtensa: Convert main irq_chip to new functions
um: Use generic show_interrupts()
um: Convert genirq namespace
m32r: Use generic show_interrupts()
m32r: Convert genirq namespace
h8300: Use generic show_interrupts()
h8300: Convert genirq namespace
avr32: Cleanup eic_set_irq_type()
avr32: Use generic show_interrupts()
avr: Cleanup genirq namespace
avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED
Fix up trivial conflict in drivers/gpio/timbgpio.c
As a preparation for providing little-endian bitops for all architectures,
This renames generic implementation of little-endian bitops. (remove
"generic_" prefix and postfix "_le")
s/generic_find_next_le_bit/find_next_bit_le/
s/generic_find_next_zero_le_bit/find_next_zero_bit_le/
s/generic_find_first_zero_le_bit/find_first_zero_bit_le/
s/generic___test_and_set_le_bit/__test_and_set_bit_le/
s/generic___test_and_clear_le_bit/__test_and_clear_bit_le/
s/generic_test_le_bit/test_bit_le/
s/generic___set_le_bit/__set_bit_le/
s/generic___clear_le_bit/__clear_bit_le/
s/generic_test_and_set_le_bit/test_and_set_bit_le/
s/generic_test_and_clear_le_bit/test_and_clear_bit_le/
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Greg Ungerer <gerg@uclinux.org>
This converts the avr32 clocksource to use clocksource_register_hz.
This is untested, so any assistance in testing would be appreciated!
CC: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
This patch will fix the arguments to the architecture sys_clone() function to
match the asm-generic/syscalls.h prototype. In the same go remove the
architecture specific prototype for the same function.
The sys_clone() function is only called from assembly, hence the argument types
were not having any affect.
use new 'datap' variable type of void pointer in order to remove unnecessary
castings.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Cc: <linux-arch@vger.kernel.org>
Acked-by: Roland McGrath <roland@redhat.com>
With all the recent module loading cleanups, we've minimized the code
that sits under module_mutex, fixing various deadlocks and making it
possible to do most of the module loading in parallel.
However, that whole conversion totally missed the rather obscure code
that adds a new module to the list for BUG() handling. That code was
doubly obscure because (a) the code itself lives in lib/bugs.c (for
dubious reasons) and (b) it gets called from the architecture-specific
"module_finalize()" rather than from generic code.
Calling it from arch-specific code makes no sense what-so-ever to begin
with, and is now actively wrong since that code isn't protected by the
module loading lock any more.
So this commit moves the "module_bug_{finalize,cleanup}()" calls away
from the arch-specific code, and into the generic code - and in the
process protects it with the module_mutex so that the list operations
are now safe.
Future fixups:
- move the module list handling code into kernel/module.c where it
belongs.
- get rid of 'module_bug_list' and just use the regular list of modules
(called 'modules' - imagine that) that we already create and maintain
for other reasons.
Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Adrian Bunk <bunk@kernel.org>
Cc: stable@kernel.org
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
* 'timers-for-linus-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
avr32: Fix typo in read_persistent_clock()
sparc: Convert sparc to use read/update_persistent_clock
cris: Convert cris to use read/update_persistent_clock
m68k: Convert m68k to use read/update_persistent_clock
m32r: Convert m32r to use read/update_peristent_clock
blackfin: Convert blackfin to use read/update_persistent_clock
ia64: Convert ia64 to use read/update_persistent_clock
avr32: Convert avr32 to use read/update_persistent_clock
h8300: Convert h8300 to use read/update_persistent_clock
frv: Convert frv to use read/update_persistent_clock
mn10300: Convert mn10300 to use read/update_persistent_clock
alpha: Convert alpha to use read/update_persistent_clock
xtensa: Fix unnecessary setting of xtime
time: Clean up direct xtime usage in xen
This patch fixes a build failure introduced by 1d8393171 ("avr32: use
generic ptrace_resume code") which had the static keyword as a leftover.
arch/avr32/kernel/ptrace.c:32: error: static declaration of `user_enable_single_step' follows non-static declaration
include/linux/ptrace.h:268: error: previous declaration of `user_enable_single_step' was here
References:
[1]http://kisskb.ellerman.id.au/kisskb/buildresult/2448162/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Fix fallout from the persistent_clock changes.
Cc: John Stultz <johnstul@us.ibm.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch converts the avr32 architecture to use the generic
read_persistent_clock and update_persistent_clock interfaces, reducing
the amount of arch specific code we have to maintain, and allowing for
further cleanups in the future.
I have not built or tested this patch, so help from arch maintainers
would be appreciated.
LKML-Reference: <1267675049-12337-7-git-send-email-johnstul@us.ibm.com>
Use the generic ptrace_resume code for PTRACE_SYSCALL, PTRACE_CONT,
PTRACE_KILL and PTRACE_SINGLESTEP. This implies defining
arch_has_single_step in <asm/ptrace.h> and implementing the
user_enable_single_step and user_disable_single_step functions, which also
causes the breakpoint information to be cleared on fork, which could be
considered a bug fix.
Also the TIF_SYSCALL_TRACE thread flag is now cleared on PTRACE_KILL which
it previously wasn't which is consistent with all architectures using the
modern ptrace code.
Currently avr32 doesn't implement any code to disable single stepping when
one of the non-syscall requests is called which seems wrong, but I've left
it as-is for now.
Cc: Roland McGrath <roland@redhat.com>
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits)
clockevents: Convert to raw_spinlock
clockevents: Make tick_device_lock static
debugobjects: Convert to raw_spinlocks
perf_event: Convert to raw_spinlock
hrtimers: Convert to raw_spinlocks
genirq: Convert irq_desc.lock to raw_spinlock
smp: Convert smplocks to raw_spinlocks
rtmutes: Convert rtmutex.lock to raw_spinlock
sched: Convert pi_lock to raw_spinlock
sched: Convert cpupri lock to raw_spinlock
sched: Convert rt_runtime_lock to raw_spinlock
sched: Convert rq->lock to raw_spinlock
plist: Make plist debugging raw_spinlock aware
bkl: Fixup core_lock fallout
locking: Cleanup the name space completely
locking: Further name space cleanups
alpha: Fix fallout from locking changes
locking: Implement new raw_spinlock
locking: Convert raw_rwlock functions to arch_rwlock
locking: Convert raw_rwlock to arch_rwlock
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6:
avr32: update default configurations for ATNGW100, ATSTK1002 and ATSTK1006
avr32: add default configurations for ATNGW100 mkII and EVKLCD10X
avr32: add support for ATNGW100 mkII board
avr32: convert to asm-generic/hardirq.h
avr32: add two new at91 to cpu.h definition
avr32: clean up linker script using standard macros.
avr32: MRMT: correct setup of SPI slaves
avr32: function for independently setting up SPI slaves
avr32: re-instate MCI WP/CD pin assignments for ATNGW100
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
New helper - sys_mmap_pgoff(); switch syscalls to using it.
Meaning receive multiple messages, reducing the number of syscalls and
net stack entry/exit operations.
Next patches will introduce mechanisms where protocols that want to
optimize this operation will provide an unlocked_recvmsg operation.
This takes into account comments made by:
. Paul Moore: sock_recvmsg is called only for the first datagram,
sock_recvmsg_nosec is used for the rest.
. Caitlin Bestler: recvmmsg now has a struct timespec timeout, that
works in the same fashion as the ppoll one.
If the underlying protocol returns a datagram with MSG_OOB set, this
will make recvmmsg return right away with as many datagrams (+ the OOB
one) it has received so far.
. Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen
datagrams and then recvmsg returns an error, recvmmsg will return
the successfully received datagrams, store the error and return it
in the next call.
This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg,
where we will be able to acquire the lock only at batch start and end, not at
every underlying recvmsg call.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
As a side effect, this patch changes the .init.ramfs data to be
PAGE_SIZE-aligned, instead of 32-byte aligned. Also, the init data is
moved into its own output sections rather than the .init output
section.
There should be no other changes to the resulting vmlinux as a result
of this patch.
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits)
powerpc64: convert to dynamic percpu allocator
sparc64: use embedding percpu first chunk allocator
percpu: kill lpage first chunk allocator
x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA
percpu: update embedding first chunk allocator to handle sparse units
percpu: use group information to allocate vmap areas sparsely
vmalloc: implement pcpu_get_vm_areas()
vmalloc: separate out insert_vmalloc_vm()
percpu: add chunk->base_addr
percpu: add pcpu_unit_offsets[]
percpu: introduce pcpu_alloc_info and pcpu_group_info
percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward
percpu: add @align to pcpu_fc_alloc_fn_t
percpu: make @dyn_size mandatory for pcpu_setup_first_chunk()
percpu: drop @static_size from first chunk allocators
percpu: generalize first chunk allocator selection
percpu: build first chunk allocators selectively
percpu: rename 4k first chunk allocator to page
percpu: improve boot messages
percpu: fix pcpu_reclaim() locking
Fix trivial conflict as by Tejun Heo in kernel/sched.c
Add #inclusions of linux/tracehook.h to those arch files that had the tracehook
call for TIF_NOTIFY_RESUME added when support for that flag was added to that
arch.
Signed-off-by: James Morris <jmorris@namei.org>
Add a keyctl to install a process's session keyring onto its parent. This
replaces the parent's session keyring. Because the COW credential code does
not permit one process to change another process's credentials directly, the
change is deferred until userspace next starts executing again. Normally this
will be after a wait*() syscall.
To support this, three new security hooks have been provided:
cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in
the blank security creds and key_session_to_parent() - which asks the LSM if
the process may replace its parent's session keyring.
The replacement may only happen if the process has the same ownership details
as its parent, and the process has LINK permission on the session keyring, and
the session keyring is owned by the process, and the LSM permits it.
Note that this requires alteration to each architecture's notify_resume path.
This has been done for all arches barring blackfin, m68k* and xtensa, all of
which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the
replacement to be performed at the point the parent process resumes userspace
execution.
This allows the userspace AFS pioctl emulation to fully emulate newpag() and
the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to
alter the parent process's PAG membership. However, since kAFS doesn't use
PAGs per se, but rather dumps the keys into the session keyring, the session
keyring of the parent must be replaced if, for example, VIOCSETTOK is passed
the newpag flag.
This can be tested with the following program:
#include <stdio.h>
#include <stdlib.h>
#include <keyutils.h>
#define KEYCTL_SESSION_TO_PARENT 18
#define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0)
int main(int argc, char **argv)
key_serial_t keyring, key;
long ret;
keyring = keyctl_join_session_keyring(argv[1]);
OSERROR(keyring, "keyctl_join_session_keyring");
key = add_key("user", "a", "b", 1, keyring);
OSERROR(key, "add_key");
ret = keyctl(KEYCTL_SESSION_TO_PARENT);
OSERROR(ret, "KEYCTL_SESSION_TO_PARENT");
return 0;
Compiled and linked with -lkeyutils, you should see something like:
[dhowells@andromeda ~]$ keyctl show
Session Keyring
-3 --alswrv 4043 4043 keyring: _ses
355907932 --alswrv 4043 -1 \_ keyring: _uid.4043
[dhowells@andromeda ~]$ /tmp/newpag
Session Keyring
1055658746 --alswrv 4043 4043 \_ user: a
[dhowells@andromeda ~]$ /tmp/newpag hello
Session Keyring
-3 --alswrv 4043 4043 keyring: hello
340417692 --alswrv 4043 4043 \_ user: a
Where the test program creates a new session keyring, sticks a user key named
'a' into it and then installs it on its parent.
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet
available, and, whilst we're at it, have it call the appropriate tracehook.
After this patch, blackfin, m68k* and xtensa still lack support and need
alteration of assembly code to make it work.
Resume notification can then be used (by a later patch) to install a new
session keyring on the parent of a process.
cc: linux-arch@vger.kernel.org
arch/sparc/kernel/smp_64.c
arch/x86/kernel/cpu/perf_counter.c
arch/x86/kernel/setup_percpu.c
drivers/cpufreq/cpufreq_ondemand.c
mm/percpu.c
Conflicts in core and arch percpu codes are mostly from commit
ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many
num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all
the first chunk allocators into mm/percpu.c, the changes are moved
from arch code to mm/percpu.c.
