path: root/arch/avr32/configs
2007-06-23[AVR32] Update defconfigsHaavard Skinnemoen
Update defconfigs for ATNGW100 and ATSTK1002. This will enable the SLUB allocator by default on both, and will enable NFS root on ATSTK1002 (ATNGW100 had it enabled before.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27[AVR32] Board code for ATNGW100Haavard Skinnemoen
Add board code and defconfig for the ATNGW100 Network Gateway kit. For more information about this board, see http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4102 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-01-26[AVR32] Update ATSTK1000 defconfig: Enable macb by defaultHaavard Skinnemoen
Enable the Atmel MACB ethernet driver by default on ATSTK1000. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-25[PATCH] AVR32: Update defconfigHaavard Skinnemoen
Sync atstk1002_defconfig with latest git, turn off non-existent drivers and enable a few more userspace-visible options like SysV IPC and inotify support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] at91_serial -> atmel_serial: Kconfig symbolsHaavard Skinnemoen
Rename the following Kconfig symbols: * CONFIG_SERIAL_AT91 -> CONFIG_SERIAL_ATMEL * CONFIG_SERIAL_AT91_CONSOLE -> CONFIG_SERIAL_ATMEL_CONSOLE * CONFIG_SERIAL_AT91_TTYAT -> CONFIG_SERIAL_ATMEL_TTYAT Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
