path: root/arch/arm
2006-10-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode support [ARM] 3880/1: remove the last trace of iop31x support [ARM] 3879/1: ep93xx: instantiate platform devices for ep93xx ethernet [ARM] 3809/3: get rid of 4 megabyte kernel image size limit [ARM] Fix XIP_KERNEL build error in arch/arm/mm/mmu.c [ARM] 3874/1: Remove leftover usage of asm/timeofday.h
2006-10-03[PATCH] arm build fail: vfpsingle.cFrederik Deweerdt
It looks like Zach Brown's patch pr_debug-check-pr_debug-arguments worked as inteded. That is, it doesn't "allow completely incorrect code to build." :). The arm build fails with the following message: CC arch/arm/vfp/vfpsingle.o arch/arm/vfp/vfpsingle.c: In function `__vfp_single_normaliseround': arch/arm/vfp/vfpsingle.c:201: error: `func' undeclared (first use in this function) arch/arm/vfp/vfpsingle.c:201: error: (Each undeclared identifier is reported only once arch/arm/vfp/vfpsingle.c:201: error: for each function it appears in.) make[1]: *** [arch/arm/vfp/vfpsingle.o] Error 1 make: *** [arch/arm/vfp] Error 2 The following patch fixes the issue by using func only when DEBUG is defined. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[WATCHDOG] pnx4008: add watchdog supportVitaly Wool
Add watchdog support for Philips PNX4008 ARM board inlined. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2006-10-02[PATCH] rename the provided execve functions to kernel_execveArnd Bergmann
Some architectures provide an execve function that does not set errno, but instead returns the result code directly. Rename these to kernel_execve to get the right semantics there. Moreover, there is no reasone for any of these architectures to still provide __KERNEL_SYSCALLS__ or _syscallN macros, so remove these right away. [akpm@osdl.org: build fix] [bunk@stusta.de: build fix] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@muc.de> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: use init_utsname when appropriateSerge E. Hallyn
In some places, particularly drivers and __init code, the init utsns is the appropriate one to use. This patch replaces those with a the init_utsname helper. Changes: Removed several uses of init_utsname(). Hope I picked all the right ones in net/ipv4/ipconfig.c. These are now changed to utsname() (the per-process namespace utsname) in the previous patch (2/7) [akpm@osdl.org: CIFS fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] nsproxy: move init_nsproxy into kernel/nsproxy.cSerge E. Hallyn
Move the init_nsproxy definition out of arch/ into kernel/nsproxy.c. This avoids all arches having to be updated. Compiles and boots on s390. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: add nsproxySerge E. Hallyn
This patch adds a nsproxy structure to the task struct. Later patches will move the fs namespace pointer into this structure, and introduce a new utsname namespace into the nsproxy. The vserver and openvz functionality, then, would be implemented in large part by virtualizing/isolating more and more resources into namespaces, each contained in the nsproxy. [akpm@osdl.org: build fix] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] cpumask: export cpu_online_map and cpu_possible_map consistentlyGreg Banks
cpumask: ensure that the cpu_online_map and cpu_possible_map bitmasks, and hence all the macros in <linux/cpumask.h> that require them, are available to modules for all supported combinations of architecture and CONFIG_SMP. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[ARM] 3848/1: pxafb: Add option of fixing video modes and spitz QVGA mode ↵Richard Purdie
support Add the ability to have pxafb use only certain fixed video modes (selected on a per platform basis). This is useful on production hardware such as the Zaurus cxx00 models where the valid modes are known in advance and any other modes could result in hardware damage. Following this, add support for the cxx00 QVGA mode. Mode information is passed to the lcd_power call to allowing the panel drivers to configure the display hardware accordingly (corgi_lcd already contains the functionality for the cxx00 panel). This mirrors the setup already used by w100fb. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] completions: lockdep annotate on stack completionsPeter Zijlstra
All on stack DECLARE_COMPLETIONs should be replaced by: DECLARE_COMPLETION_ONSTACK Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[ARM] 3880/1: remove the last trace of iop31x supportLennert Buytenhek
Remove the last trace of iop31x support from the kernel. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-30[ARM] 3879/1: ep93xx: instantiate platform devices for ep93xx ethernetLennert Buytenhek
Instantiate platform devices for the ep93xx ethernet driver in a couple of ep93xx board support files. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-30[ARM] 3809/3: get rid of 4 megabyte kernel image size limitLennert Buytenhek
We currently have a hardcoded 4 megabyte uncompressed kernel image size limit, which is easily exceeded by, for example, enabling some of the various kernel debugging options. When setting up the initial page tables (which is where this 4M limit is hardcoded), it's actually relatively easy to find out the true size of the uncompressed kernel image and create enough page table entries for things to fit, so this patch makes it so. In the decompressor, we also need to know the size of the uncompressed kernel image, to figure out whether there is any chance that uncompressing the kernel might overwrite the compressed kernel image stored elsewhere in memory. We don't have that info at this boot stage, though, so we approximate the size of the uncompressed kernel by taking the compressed kernel image size and allowing for a maximum 4x expansion. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-30[ARM] Fix XIP_KERNEL build error in arch/arm/mm/mmu.cRussell King
XIP kernels need to know the start/end of text, but we were missing the declaration of _etext in mmu.c. Add it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] pidspace: is_init()Sukadev Bhattiprolu
This is an updated version of Eric Biederman's is_init() patch. (http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and replaces a few more instances of ->pid == 1 with is_init(). Further, is_init() checks pid and thus removes dependency on Eric's other patches for now. Eric's original description: There are a lot of places in the kernel where we test for init because we give it special properties. Most significantly init must not die. This results in code all over the kernel test ->pid == 1. Introduce is_init to capture this case. With multiple pid spaces for all of the cases affected we are looking for only the first process on the system, not some other process that has pid == 1. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: <lxc-devel@lists.sourceforge.net> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] OMAP: Update OMAP1/2 boards to give keymapsize and other pdataKomal Shah
This patch adds keymapsize, delay and debounce flag in the keypad platform data for various TI OMAP1/2 based boards like F-sample, H2, H3, Innovator, Nokia770, OSK, Perseus and H4. Signed-off-by: Komal Shah <komal_shah802003@yahoo.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] make PROT_WRITE imply PROT_READJason Baron
Make PROT_WRITE imply PROT_READ for a number of architectures which don't support write only in hardware. While looking at this, I noticed that some architectures which do not support write only mappings already take the exact same approach. For example, in arch/alpha/mm/fault.c: " if (cause < 0) { if (!(vma->vm_flags & VM_EXEC)) goto bad_area; } else if (!cause) { /* Allow reads even for write-only mappings */ if (!(vma->vm_flags & (VM_READ | VM_WRITE))) goto bad_area; } else { if (!(vma->vm_flags & VM_WRITE)) goto bad_area; } " Thus, this patch brings other architectures which do not support write only mappings in-line and consistent with the rest. I've verified the patch on ia64, x86_64 and x86. Additional discussion: Several architectures, including x86, can not support write-only mappings. The pte for x86 reserves a single bit for protection and its two states are read only or read/write. Thus, write only is not supported in h/w. Currently, if i 'mmap' a page write-only, the first read attempt on that page creates a page fault and will SEGV. That check is enforced in arch/blah/mm/fault.c. However, if i first write that page it will fault in and the pte will be set to read/write. Thus, any subsequent reads to the page will succeed. It is this inconsistency in behavior that this patch is attempting to address. Furthermore, if the page is swapped out, and then brought back the first read will also cause a SEGV. Thus, any arbitrary read on a page can potentially result in a SEGV. According to the SuSv3 spec, "if the application requests only PROT_WRITE, the implementation may also allow read access." Also as mentioned, some archtectures, such as alpha, shown above already take the approach that i am suggesting. The counter-argument to this raised by Arjan, is that the kernel is enforcing the write only mapping the best it can given the h/w limitations. This is true, however Alan Cox, and myself would argue that the inconsitency in behavior, that is applications can sometimes work/sometimes fails is highly undesireable. If you read through the thread, i think people, came to an agreement on the last patch i posted, as nobody has objected to it... Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Andi Kleen <ak@muc.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (130 commits) [ARM] 3856/1: Add clocksource for Intel IXP4xx platforms [ARM] 3855/1: Add generic time support [ARM] 3873/1: S3C24XX: Add irq_chip names [ARM] 3872/1: S3C24XX: Apply consistant tabbing to irq_chips [ARM] 3871/1: S3C24XX: Fix ordering of EINT4..23 [ARM] nommu: confirms the CR_V bit in nommu mode [ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores. [ARM] 3870/1: AT91: Start removing static memory mappings [ARM] 3869/1: AT91: NAND support for DK and KB9202 boards [ARM] 3868/1: AT91 hardware header update [ARM] 3867/1: AT91 GPIO update [ARM] 3866/1: AT91 clock update [ARM] 3865/1: AT91RM9200 header updates [ARM] 3862/2: S3C2410 - add basic power management support for AML M5900 series [ARM] kthread: switch arch/arm/kernel/apm.c [ARM] Off-by-one in arch/arm/common/icst* [ARM] 3864/1: Refactore sharpsl_pm [ARM] 3863/1: Add Locomo SPI Device [ARM] 3847/2: Convert LOMOMO to use struct device for GPIOs [ARM] Use CPU_CACHE_* where possible in asm/cacheflush.h ...
2006-09-28Merge nommu branchRussell King
2006-09-28[ARM] 3856/1: Add clocksource for Intel IXP4xx platformsKevin Hilman
Enables the ixp4xx platforms to use Generic time-of-day. Signed-off-by: Kevin Hilman <khilman@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3855/1: Add generic time supportKevin Hilman
This patch adds Generic time-of-day support for the ARM architecture. The support is currently added using #ifdef's so that it can support sub-arches that do not (yet) have a clocksource added. As sub-arches add clocksource support, they should 'select GENERIC_TIME' Signed-off-by: Deepak Saxena <dsaxena@mvista.com> Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3873/1: S3C24XX: Add irq_chip namesBen Dooks
Add names to all the irq_chip structes Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3872/1: S3C24XX: Apply consistant tabbing to irq_chipsBen Dooks
Apply consistant tabbing to the IRQ chip structures in arch/arm/mach-s3c2410/irq.c Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3871/1: S3C24XX: Fix ordering of EINT4..23Ben Dooks
The demux code for the IRQ EINTs above 3 was using find last set instead of finding first set. Also fix it so that we only check EINT4..7 when the parent EINT4t7 goes off, and the 8..23 when EINT8t23 goes off. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] nommu: confirms the CR_V bit in nommu modeHyok S. Choi
In nommu mode, the exception vector location depends on the platforms. Some of the implementations may have some special exception control forwarding method in their ROM/flash and for some of them has its own re-mapping mechanism by the h/w. This patch introduces a special configuration CONFIG_CPU_HIGH_VECTOR which turns on the CR_V bit in nommu mode. The CR_V bit is turned off by default. This feature depends on CP15 and does not supported by ARM740. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores.Hyok S. Choi
There is no FSR/FAR register on no-CP15 or MPU cores. This patch adds a dummy abort handler which returns zero for the base restored Data Abort model !CPU_CP15_MMU cores. The abort-lv4t.S is still used with the fix-up for the base updated Data Abort model cores. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3870/1: AT91: Start removing static memory mappingsAndrew Victor
This patch removes the static memory mapping for the currently-unused peripherals [Synchronous Serial, Timer/Counter unit], and for those drivers that already ioremap() their registers [UART]. Also, the Ethernet driver now uses the platform_device resources but doesn't yet use ioremap() so we need to pass it the virtual address instead of the physical address. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3869/1: AT91: NAND support for DK and KB9202 boardsAndrew Victor
This patch adds support for the NAND flash on the Atmel AT91RM9200-DK and KwikByte KB920x boards. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3867/1: AT91 GPIO updateAndrew Victor
This patch makes the AT91 gpio.c support processor-generic (AT91RM9200 and AT91SAM9xxx). The GPIO controllers supported by a particular AT91 processor are defined in the processor-specific file and are registered with gpio.c at startup. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3866/1: AT91 clock updateAndrew Victor
This patch makes the AT91 clock.c support processor-generic (AT91RM9200 and AT91SAM9xxx). The clocks supported by a particular AT91 processor are defined in the processor-specific file and are registered with clock.c at startup. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] 3865/1: AT91RM9200 header updatesAndrew Victor
This is more preparation for adding support for the new Atmel AT91SAM9 processors. Changes include: - Replace AT91_BASE_* with AT91RM9200_BASE_* - Replace AT91_ID_* with AT91RM9200_ID_* - ROM, SRAM and UHP address definitions moved to at91rm9200.h. - The raw AT91_P[ABCD]_* definitions are now depreciated in favour of the GPIO API. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3862/2: S3C2410 - add basic power management support for AML M5900 seriesDavid Anders
this patch registers the wakeup irq, sets a gpio pin to indicate the status of system for suspend/resume operations, and adds the machine to the supported machines for use with the simtec-pm Signed-off-by: David Anders <danders@amltd.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] kthread: switch arch/arm/kernel/apm.cSerge E. Hallyn
Switch arch/arm/kernel/apm.c from using kernel_thread - whose export is deprecated - to kthread. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] Off-by-one in arch/arm/common/icst*Eric Sesterhenn
hi, a quick find -iname \*.[ch] | xargs grep "> ARRAY_SIZE(", revealed these in the icst drivers. If i == ARRAY_SIZE, we get past the idx2s array. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3864/1: Refactore sharpsl_pmDirk Opfer
This patch adds another hook into sharpsl_pm to notify the machine specific driver immediately after resume. This is needed to support the Sharp SL-6000 (Tosa). Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3863/1: Add Locomo SPI DeviceDirk Opfer
The Locomo chip has a SPI interface which is used for SD/MMC cards (only collie). This patch adds the definition for the SPI device inside the Locomo chip. Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3847/2: Convert LOMOMO to use struct device for GPIOsRichard Purdie
Convert LOMOMO to use struct device * for GPIOs instead of struct locomo_dev. This enables access to the GPIOs from code which is not a locomo device itself (such as audio). Access for gpio 31 is removed for error handling (no such hardware exists). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27USB: pxa2xx_udc understands GPIO based VBUS sensingDavid Brownell
This updates the PXA 25x UDC board-independent infrastructure for VBUS sensing and the D+ pullup. The original code evolved from rather bizarre support on Intel's "Lubbock" reference hardware, so that on more sensible hardware it doesn't work as well as it could/should. The change is just to teach the UDC driver how to use built-in PXA GPIO pins directly. This reduces the amount of board-specfic object code needed, and enables the use of a VBUS sensing IRQ on boards (like Gumstix) that have one. With VBUS sensing, the UDC is unclocked until a host is actually connected. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: move <linux/usb_otg.h> to <linux/usb/otg.h>David Brownell
Move <linux/usb_otg.h> to <linux/usb/otg.h>. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27Merge master.kernel.org:/pub/scm/linux/kernel/git/tmlind/linux-omap-upstream ↵Russell King
into devel
2006-09-27[ARM] Make !MMU CPUs depend on !MMURussell King
Don't offer non-MMU based CPUs for selection when CONFIG_MMU is set. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM946E-S core supportHyok S. Choi
This patch adds ARM946E-S core support which has typically 8KB I&D cache. It has a MPU and supports ARMv5TE instruction set. Because the ARM946E-S core can be synthesizable with various cache size, CONFIG_CPU_DCACHE_SIZE is defined for vendor specific configurations. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM940T core supportHyok S. Choi
This patch adds ARM940T core support which has 4KB D-cache, 4KB I-cache and a MPU. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM9TDMI core supportHyok S. Choi
This patch adds ARM9TDMI core support which has no cache and no CP15 register(no memory control unit). Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM740T core supportHyok S. Choi
This patch adds ARM740T core support which has a MPU and 4KB or 8KB cache. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM7TDMI core supportHyok S. Choi
This patch adds ARM7TDMI core support which has no cache and no CP15 register(no memory control unit). Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: manage the CP15 thingsHyok S. Choi
All the current CP15 access codes in ARM arch can be categorized and conditioned by the defines as follows: Related operation Safe condition a. any CP15 access !CPU_CP15 b. alignment trap CPU_CP15_MMU c. D-cache(C-bit) CPU_CP15 d. I-cache CPU_CP15 && !( CPU_ARM610 || CPU_ARM710 || CPU_ARM720 || CPU_ARM740 || CPU_XSCALE || CPU_XSC3 ) e. alternate vector CPU_CP15 && !CPU_ARM740 f. TTB CPU_CP15_MMU g. Domain CPU_CP15_MMU h. FSR/FAR CPU_CP15_MMU For example, alternate vector is supported if and only if "CPU_CP15 && !CPU_ARM740" is satisfied. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: defines CPU_CP15, CPU_CP15_MMU and CPU_CP15_MPUHyok S. Choi
By merging of uClinux/ARM, we need to treat various CPU cores which have MMU, MPU or even none for memory management. The memory management coprocessors are controlled by CP15 register set and the ARM core family can be categorized by 5 groups by the register ; G-a. CP15 is MMU : 610, 710, 720, 920, 922, 925, 926, 1020, 1020e, 1022, v6 and the derivations sa1100, sa110, xscale, xsc3. G-b. CP15 is MPU : 740, 940, 946, 996, 1156. G-c. CP15 is MPU or MMU : 1026 (selectable by schematic design) G-d. CP15 is exist, but nothing for memory managemnt : 966, 968. G-e. no-CP15 : 7tdmi, 9tdmi, 9e, 9ej This patch defines CPU_CP15, CPU_CP15_MMU and CPU_CP15_MPU. Thus the family can be defined as : - CPU_CP15 only : G-d - CPU_CP15_MMU(implies CPU_CP15) : G-a, G-c(selectable) - CPU_CP15_MPU(implies CPU_CP15) : G-b, G-c(selectable) - !CPU_CP15 : G-e Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
