path: root/arch/arm
2011-05-23clocksource: convert ARM 32-bit up counting clocksourcesRussell King
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300 to use the generic mmio clocksource recently introduced. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: update sa1100 to reflect PXA updatesRussell King
Update sa1100 clockevents code to reflect what its later derivative does with clockevents_calc_mult_shift(). Use OSSR_M* constants too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: omap1: convert to using readl/writel instead of volatile structRussell King
Tested-by: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: omap1: delete useless interrupt handlerRussell King
The OMAP1 clocksource interrupt handler just increments a variable which otherwise isn't used, so this seems to be unnecessary. Tony Lindgren confirms, so lets remove it. Acked-by: Kevin Hilman <khilman@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: s5p: consolidate selection of timer registerRussell King
s5p duplicates the runtime selection of the timer register three times. Move this out into a separate function. FIXME: It is unclear whether this code needs to support true runtime selection of the timer register, or whether it can be selected once at init time. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-19Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6 * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (44 commits) debugfs: Silence DEBUG_STRICT_USER_COPY_CHECKS=y warning sysfs: remove "last sysfs file:" line from the oops messages drivers/base/memory.c: fix warning due to "memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION" memory hotplug: Speed up add/remove when blocks are larger than PAGES_PER_SECTION SYSFS: Fix erroneous comments for sysfs_update_group(). driver core: remove the driver-model structures from the documentation driver core: Add the device driver-model structures to kerneldoc Translated Documentation/email-clients.txt RAW driver: Remove call to kobject_put(). reboot: disable usermodehelper to prevent fs access efivars: prevent oops on unload when efi is not enabled Allow setting of number of raw devices as a module parameter Introduce CONFIG_GOOGLE_FIRMWARE driver: Google Memory Console driver: Google EFI SMI x86: Better comments for get_bios_ebda() x86: get_bios_ebda_length() misc: fix ti-st build issues params.c: Use new strtobool function to process boolean inputs debugfs: move to new strtobool ... Fix up trivial conflicts in fs/debugfs/file.c due to the same patch being applied twice, and an unrelated cleanup nearby.
2011-05-19Merge branch 'timers-clocksource-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: clocksource: convert mips to generic i8253 clocksource clocksource: convert x86 to generic i8253 clocksource clocksource: convert footbridge to generic i8253 clocksource clocksource: add common i8253 PIT clocksource blackfin: convert to clocksource_register_hz mips: convert to clocksource_register_hz/khz sparc: convert to clocksource_register_hz/khz alpha: convert to clocksource_register_hz microblaze: convert to clocksource_register_hz/khz ia64: convert to clocksource_register_hz/khz x86: Convert remaining x86 clocksources to clocksource_register_hz/khz Make clocksource name const
2011-05-19Merge branches 'sched-core-for-linus' and 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) sched: Fix and optimise calculation of the weight-inverse sched: Avoid going ahead if ->cpus_allowed is not changed sched, rt: Update rq clock when unthrottling of an otherwise idle CPU sched: Remove unused parameters from sched_fork() and wake_up_new_task() sched: Shorten the construction of the span cpu mask of sched domain sched: Wrap the 'cfs_rq->nr_spread_over' field with CONFIG_SCHED_DEBUG sched: Remove unused 'this_best_prio arg' from balance_tasks() sched: Remove noop in alloc_rt_sched_group() sched: Get rid of lock_depth sched: Remove obsolete comment from scheduler_tick() sched: Fix sched_domain iterations vs. RCU sched: Next buddy hint on sleep and preempt path sched: Make set_*_buddy() work on non-task entities sched: Remove need_migrate_task() sched: Move the second half of ttwu() to the remote cpu sched: Restructure ttwu() some more sched: Rename ttwu_post_activation() to ttwu_do_wakeup() sched: Remove rq argument from ttwu_stat() sched: Remove rq->lock from the first half of ttwu() sched: Drop rq->lock from sched_exec() ... * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix rt_rq runtime leakage bug
2011-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (34 commits) PM: Introduce generic prepare and complete callbacks for subsystems PM: Allow drivers to allocate memory from .prepare() callbacks safely PM: Remove CONFIG_PM_VERBOSE Revert "PM / Hibernate: Reduce autotuned default image size" PM / Hibernate: Add sysfs knob to control size of memory for drivers PM / Wakeup: Remove useless synchronize_rcu() call kmod: always provide usermodehelper_disable() PM / ACPI: Remove acpi_sleep=s4_nonvs PM / Wakeup: Fix build warning related to the "wakeup" sysfs file PM: Print a warning if firmware is requested when tasks are frozen PM / Runtime: Rework runtime PM handling during driver removal Freezer: Use SMP barriers PM / Suspend: Do not ignore error codes returned by suspend_enter() PM: Fix build issue in clock_ops.c for CONFIG_PM_RUNTIME unset PM: Revert "driver core: platform_bus: allow runtime override of dev_pm_ops" OMAP1 / PM: Use generic clock manipulation routines for runtime PM PM: Remove sysdev suspend, resume and shutdown operations PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM PM / AVR32: Use struct syscore_ops instead of sysdevs for PM ...
2011-05-19Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] remove redundant sprintf from request_module call. [CPUFREQ] cpufreq_stats.c: Fixed brace coding style issue [CPUFREQ] Fix memory leak in cpufreq_stat [CPUFREQ] cpufreq.h: Fix some checkpatch.pl coding style issues. [CPUFREQ] use dynamic debug instead of custom infrastructure [CPUFREQ] CPU hotplug, re-create sysfs directory and symlinks [CPUFREQ] Fix _OSC UUID in pcc-cpufreq
2011-05-17Merge branch 'power-domains' into for-linusRafael J. Wysocki
* power-domains: PM: Fix build issue in clock_ops.c for CONFIG_PM_RUNTIME unset PM: Revert "driver core: platform_bus: allow runtime override of dev_pm_ops" OMAP1 / PM: Use generic clock manipulation routines for runtime PM PM / Runtime: Generic clock manipulation rountines for runtime PM (v6) PM / Runtime: Add subsystem data field to struct dev_pm_info OMAP2+ / PM: move runtime PM implementation to use device power domains PM / Platform: Use generic runtime PM callbacks directly shmobile: Use power domains for platform runtime PM PM: Export platform bus type's default PM callbacks PM: Make power domain callbacks take precedence over subsystem ones
2011-05-17Merge branch 'syscore' into for-linusRafael J. Wysocki
* syscore: PM: Remove sysdev suspend, resume and shutdown operations PM / PowerPC: Use struct syscore_ops instead of sysdevs for PM PM / UNICORE32: Use struct syscore_ops instead of sysdevs for PM PM / AVR32: Use struct syscore_ops instead of sysdevs for PM PM / Blackfin: Use struct syscore_ops instead of sysdevs for PM ARM / Samsung: Use struct syscore_ops for "core" power management ARM / PXA: Use struct syscore_ops for "core" power management ARM / SA1100: Use struct syscore_ops for "core" power management ARM / Integrator: Use struct syscore_ops for core PM ARM / OMAP: Use struct syscore_ops for "core" power management ARM: Use struct syscore_ops instead of sysdevs for PM in common code
2011-05-16OMAP1 / PM: Use generic clock manipulation routines for runtime PMRafael J. Wysocki
Convert OMAP1 to using the new generic clock manipulation routines and a device power domain for runtime PM instead of overriding the platform bus type's runtime PM callbacks. This allows us to simplify OMAP1-specific code and to share some code with other platforms (shmobile in particular). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-05-16Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3: set the core dpll clk rate in its set_rate function omap: iommu: Return IRQ_HANDLED in fault handler when no fault occured
2011-05-14clocksource: convert footbridge to generic i8253 clocksourceRussell King
Convert the footbridge isa-timer code to use generic i8253 clocksource. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-13sysfs: remove "last sysfs file:" line from the oops messagesGreg Kroah-Hartman
On some arches (x86, sh, arm, unicore, powerpc) the oops message would print out the last sysfs file accessed. This was very useful in finding a number of sysfs and driver core bugs in the 2.5 and early 2.6 development days, but it has been a number of years since this file has actually helped in debugging anything that couldn't also be trivially determined from the stack traceback. So it's time to delete the line. This is good as we need all the space we can get for oops messages at times on consoles. Acked-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-13OMAP3: set the core dpll clk rate in its set_rate functionAvinash H.M
The debug l3_ick/rate is not displaying the actual rate of the clock in hardware. This is because, the core dpll set_rate function doesn't update the clk.rate. After fixing, the l3_ick/rate is displaying proper values. Signed-off-by: Shweta Gulati <shweta.gulati@ti.com> Signed-off-by: Avinash.H.M <avinashhm@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Paul Wamsley <paul@pwsan.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accesses ARM: 6892/1: handle ptrace requests to change PC during interrupted system calls ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEM ARM: zImage: the page table memory must be considered before relocation ARM: zImage: make sure not to relocate on top of the relocation code ARM: zImage: Fix bad SP address after relocating kernel ARM: zImage: make sure the stack is 64-bit aligned ARM: RiscPC: acornfb: fix section mismatches ARM: RiscPC: etherh: fix section mismatches
2011-05-12ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accessesCatalin Marinas
Since mandatory barriers may be used (explicitly or implicitly via readl etc.) to ensure the ordering between Device and Normal memory accesses, a DMB is not enough. This patch converts it to a DSB. Cc: Colin Cross <ccross@android.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6892/1: handle ptrace requests to change PC during interrupted system callsArnd Bergmann
GDB's interrupt.exp test cases currenly fail on ARM. The problem is how do_signal handled restarting interrupted system calls: The entry.S assembler code determines that we come from a system call; and that information is passed as "syscall" parameter to do_signal. That routine then calls get_signal_to_deliver [*] and if a signal is to be delivered, calls into handle_signal. If a system call is to be restarted either after the signal handler returns, or if no handler is to be called in the first place, the PC is updated after the get_signal_to_deliver call, either in handle_signal (if we have a handler) or at the end of do_signal (otherwise). Now the problem is that during [*], the call to get_signal_to_deliver, a ptrace intercept may happen. During this intercept, the debugger may change registers, including the PC. This is done by GDB if it wants to execute an "inferior call", i.e. the execution of some code in the debugged program triggered by GDB. To this purpose, GDB will save all registers, allocate a stack frame, set up PC and arguments as appropriate for the call, and point the link register to a dummy breakpoint instruction. Once the process is restarted, it will execute the call and then trap back to the debugger, at which point GDB will restore all registers and continue original execution. This generally works fine. However, now consider what happens when GDB attempts to do exactly that while the process was interrupted during execution of a to-be- restarted system call: do_signal is called with the syscall flag set; it calls get_signal_to_deliver, at which point the debugger takes over and changes the PC to point to a completely different place. Now get_signal_to_deliver returns without a signal to deliver; but now do_signal decides it should be restarting a system call, and decrements the PC by 2 or 4 -- so it now points to 2 or 4 bytes before the function GDB wants to call -- which leads to a subsequent crash. To fix this problem, two things need to be supported: - do_signal must be able to recognize that get_signal_to_deliver changed the PC to a different location, and skip the restart-syscall sequence - once the debugger has restored all registers at the end of the inferior call sequence, do_signal must recognize that *now* it needs to restart the pending system call, even though it was now entered from a breakpoint instead of an actual svc instruction This set of issues is solved on other platforms, usually by one of two mechanisms: - The status information "do_signal is handling a system call that may need restarting" is itself carried in some register that can be accessed via ptrace. This is e.g. on Intel the "orig_eax" register; on Sparc the kernel defines a magic extra bit in the flags register for this purpose. This allows GDB to manage that state: reset it when doing an inferior call, and restore it after the call is finished. - On s390, do_signal transparently handles this problem without requiring GDB interaction, by performing system call restarting in the following way: first, adjust the PC as necessary for restarting the call. Then, call get_signal_to_deliver; and finally just continue execution at the PC. This way, if GDB does not change the PC, everything is as before. If GDB *does* change the PC, execution will simply continue there -- and once GDB restores the PC it saved at that point, it will automatically point to the *restarted* system call. (There is the minor twist how to handle system calls that do *not* need restarting -- do_signal will undo the PC change in this case, after get_signal_to_deliver has returned, and only if ptrace did not change the PC during that call.) Because there does not appear to be any obvious register to carry the syscall-restart information on ARM, we'd either have to introduce a new artificial ptrace register just for that purpose, or else handle the issue transparently like on s390. The patch below implements the second option; using this patch makes the interrupt.exp test cases pass on ARM, with no regression in the GDB test suite otherwise. Cc: patches@linaro.org Signed-off-by: Ulrich Weigand <ulrich.weigand@linaro.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEMWill Deacon
The SPARSEMEM code allocates memmap entries only for sections which are present (i.e. those which contain some valid memory). The membank checks in free_unused_memmap do not take this into account and can incorrectly attempt to free memory which is not allocated, resulting in a BUG() in the bootmem code. However, if memory is configured as follows: |<----section---->|<----hole---->|<----section---->| +--------+--------+--------------+--------+--------+ | bank 0 | unused | | bank 1 | unused | +--------+--------+--------------+--------+--------+ where a bank only occupies part of a section, the memmap allocated for the remainder of the section *can* be freed. This patch modifies the checks in free_unused_memmap so that only valid memmap entries are considered for removal. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12Merge commit 'v2.6.39-rc7' into sched/coreIngo Molnar
2011-05-11omap: iommu: Return IRQ_HANDLED in fault handler when no fault occuredLaurent Pinchart
Commit d594f1f31afe13edd8c02f3854a65cc58cfb3b74 (omap: IOMMU: add support to callback during fault handling) broke interrupt line sharing between the OMAP3 ISP and its IOMMU. Because of this, every interrupt generated by the OMAP3 ISP is handled by the IOMMU driver instead of being passed to the OMAP3 ISP driver. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-07Merge first four commits of 'zImage_fixes' of ↵Russell King
git://git.linaro.org/people/nico/linux into fixes
2011-05-07ARM: zImage: the page table memory must be considered before relocationNicolas Pitre
For correctness, the initial page table located right before the decompressed kernel should be considered when determining if relocation is required. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2011-05-07ARM: zImage: make sure not to relocate on top of the relocation codeNicolas Pitre
If the zImage load address is slightly below the relocation address, there is a risk for the copied data to overwrite the copy loop or cache flush code that the relocation process requires. Always bump the relocation address by the size of that code to avoid this issue. Noticed by Tony Lindgren <tony@atomide.com>. While at it, let's start the copy from the restart symbol which makes the above code size computation possible by the assembler directly (same sections), given that we don't need to preserve the code before that point anyway. And therefore we don't need to carry the _start pointer in r5 anymore. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-05-06ARM: zImage: Fix bad SP address after relocating kernelTony Lindgren
Otherwise cache_clean_flush can overwrite some of the relocated area depending on where the kernel image gets loaded. This fixes booting on n900 after commit 6d7d0ae51574943bf571d269da3243257a2d15db (ARM: 6750/1: improvements to compressed/head.S). Thanks to Aaro Koskinen <aaro.koskinen@nokia.com> for debugging the address of the relocated area that gets corrupted, and to Nicolas Pitre <nicolas.pitre@linaro.org> for the other uncompress related fixes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-05-06ARM: zImage: make sure the stack is 64-bit alignedNicolas Pitre
With ARMv5+ and EABI, the compiler expects a 64-bit aligned stack so instructions like STRD and LDRD can be used. Without this, mysterious boot failures were seen semi randomly with the LZMA decompressor. While at it, let's align .bss as well. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> CC: stable@kernel.org
2011-05-06Merge branch 'master' of ↵Ingo Molnar
ssh://master.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into perf/urgent
2011-05-05Merge branch 'for-linus' of git://github.com/at91linux/linux-2.6-at91Linus Torvalds
* 'for-linus' of git://github.com/at91linux/linux-2.6-at91: at91: Add ARCH_ID and basic cpu macros definition for 5series chips family. arm: at91: fix compiler warning for eb01 board build arm: at91: minimal defconfig for at91x40 SoC ARM: at91: AT91CAP9 has a macb device
2011-05-04Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/urgent
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-02Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: (47 commits) CLKDEV: Fix clkdev return value for NULL clk case ARM: 6891/1: prevent heap corruption in OABI semtimedop ARM: kprobes: Tidy-up kprobes-decode.c ARM: kprobes: Add emulation of hint instructions like NOP and WFI ARM: kprobes: Add emulation of SBFX, UBFX, BFI and BFC instructions ARM: kprobes: Add emulation of MOVW and MOVT instructions ARM: kprobes: Reject probing of undefined data processing instructions ARM: kprobes: Remove redundant code in space_1111 ARM: kprobes: Fix emulation of PLD instructions ARM: kprobes: Reject probing of SETEND instructions ARM: kprobes: Consolidate stub decoding functions ARM: kprobes: Reject probing of all coprocessor instructions ARM: kprobes: Fix emulation of USAD8 instructions ARM: kprobes: Fix emulation of SMUAD, SMUSD and SMMUL instructions ARM: kprobes: Fix emulation of SXTB16, SXTB, SXTH, UXTB16, UXTB and UXTH instructions ARM: kprobes: Reject probing of undefined media instructions ARM: kprobes: Add emulation of RBIT instruction ARM: kprobes: Reject probing of LDRB instructions which load PC ARM: kprobes: Fix emulation of LDRD and STRD instructions ARM: kprobes: Reject probing of LDR/STR instructions which update PC unpredictably ...
2011-04-30PM / Runtime: Generic clock manipulation rountines for runtime PM (v6)Rafael J. Wysocki
Many different platforms and subsystems may want to disable device clocks during suspend and enable them during resume which is going to be done in a very similar way in all those cases. For this reason, provide generic routines for the manipulation of device clocks during suspend and resume. Convert the ARM shmobile platform to using the new routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-04-29Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3+: voltage: remove initial voltage OMAP4: Intialize IVA Device in addition to DSP device. omap: rx51: mark reserved memory earlier OMAP3: l3: fix for "irq 10: nobody cared" message arm: omap2: enable smc instruction for sleep34xx OMAP2/3: hwmod: fix gpio-reset timeouts seen during bootup. OMAP3: PM: Do not rely on ROM code to restore CM_AUTOIDLE_PLL.AUTO_PERIPH_DPLL OMAP2+: PM: Fix the saving of CM_AUTOIDLE_PLL register on scratchpad area OMAP4: clock data: Change DSS clock aliases OMAP2+: hwmod data: Fix wrong dma_system end address
2011-04-29ARM: 6891/1: prevent heap corruption in OABI semtimedopDan Rosenberg
When CONFIG_OABI_COMPAT is set, the wrapper for semtimedop does not bound the nsops argument. A sufficiently large value will cause an integer overflow in allocation size, followed by copying too much data into the allocated buffer. Fix this by restricting nsops to SEMOPM. Untested. Cc: stable@kernel.org Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-04-29Merge branch 'kprobes' of git://git.linaro.org/people/nico/linux into fixesRussell King
2011-04-28ARM: kprobes: Tidy-up kprobes-decode.cJon Medhurst
- Remove coding standard violations reported by checkpatch.pl - Delete comment about handling of conditional branches which is no longer true. - Delete comment at end of file which lists all ARM instructions. This duplicates data available in the ARM ARM and seems like an unnecessary maintenance burden to keep this up to date and accurate. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Add emulation of hint instructions like NOP and WFIJon Medhurst
Being able to probe NOP instructions is useful for hard-coding probeable locations and is used by the kprobes test code. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Add emulation of SBFX, UBFX, BFI and BFC instructionsJon Medhurst
These bit field manipulation instructions occur several thousand times in an ARMv7 kernel. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Add emulation of MOVW and MOVT instructionsJon Medhurst
The MOVW and MOVT instructions account for approximately 7% of all instructions in a ARMv7 kernel as GCC uses them instead of a literal pool. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Reject probing of undefined data processing instructionsJon Medhurst
The instruction decoding in space_cccc_000x needs to reject probing of instructions with undefined patterns as they may in future become defined and then emulated faultily - as has already happened with the SMC instruction. This fix is achieved by testing for the instruction patterns we want to probe and making the the default fall-through paths reject probes. This also allows us to remove some explicit tests for instructions that we wish to reject, as that is now the default action. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Remove redundant code in space_1111Jon Medhurst
The tests to explicitly reject probing CPS, RFE and SRS instructions are redundant as the default case is now to reject undecoded patterns. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Fix emulation of PLD instructionsJon Medhurst
The PLD instructions wasn't being decoded correctly and the emulation code wasn't adjusting PC correctly. As the PLD instruction is only a performance hint we emulate it as a simple nop, and we can broaden the instruction decoding to take into account newer PLI and PLDW instructions. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Reject probing of SETEND instructionsJon Medhurst
The emulation of SETEND was broken as it changed the endianess for the running kprobes handling code. Rather than adding a new simulation routine to fix this we'll just reject probing of SETEND as these should be very rare in the kernel. Note, the function emulate_none is now unused but it is left in the source code as future patches will use it. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Consolidate stub decoding functionsJon Medhurst
Following the change to remove support for coprocessor instructions we are left with three stub functions which can be consolidated. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Reject probing of all coprocessor instructionsJon Medhurst
The kernel doesn't currently support VFP or Neon code, and probing of code with CP15 operations is fraught with bad consequences. Therefore we don't need the ability to probe coprocessor instructions and the code to support this can be removed. The removed code also had at least two bugs: - MRC into R15 should set CPSR not trash PC - LDC and STC which use PC as base register needed the address offset by 8 Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Fix emulation of USAD8 instructionsJon Medhurst
The USAD8 instruction wasn't being explicitly decoded leading to the incorrect emulation routine being called. It can be correctly decoded in the same way as the signed multiply instructions so we move the decoding there. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Fix emulation of SMUAD, SMUSD and SMMUL instructionsJon Medhurst
The signed multiply instructions were being decoded incorrectly. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-04-28ARM: kprobes: Fix emulation of SXTB16, SXTB, SXTH, UXTB16, UXTB and UXTH ↵Jon Medhurst
instructions These sign extension instructions are encoded as extend-and-add instructions where the register to add is specified as r15. The decoding routines weren't checking for this and were using the incorrect emulation code, giving incorrect results. Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
