Debug (printascii) and IRQ handler macros for the LPC32XX
arch
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Header files for the LPC32xx arch
* master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: 6265/1: kirkwood: move qnap_tsx1x_register_flash() to .init.text
ARM: 6263/1: ns9xxx: fix FTBFS for zImage
ARM: 6262/1: arm/clps711x: fix debug macro compilation failure
ARM: 6261/1: arm/shark: fix debug macro compilation failure
ARM: 6260/1: arm/plat-spear: fix debug macro compilation failure
ARM: 6259/1: arm/ns9xxx: fix debug macro compilation failure
ARM: 6258/1: arm/h720x: fix debug macro compilation failure
ARM: 6233/1: Delete a wrong redundant right parenthesis
ARM: 6230/1: fix nuc900 touchscreen clk definition bug
[ARM] pxa: fix incorrect CONFIG_CPU_PXA27x to CONFIG_PXA27x
[ARM] pxa/colibri-pxa300: fix AC97 init
[ARM] pxa: fix incorrect order of AC97 reset pin configs
[ARM] pxa: fix frequency scaling for pcmcia/pxa2xx_base
[ARM] pxa: cpufreq-pxa2xx: fix DRI recomputation routine
[ARM] pxa/corgi: fix MMC/SD card detection failure
Commit 3fea60261e73 ("Input: twl40300-keypad - fix handling of "all
ground" rows") broke compilation as I managed to use non-existent
keycodes.
Reported-by: Arjan van de Ven <arjan@infradead.org>
qnap_tsx1x_register_flash is only called by qnap_ts219_init and
qnap_ts41x_init which both live in .init.text, too. So the move is OK.
This fixes the following warning in kirkwood_defconfig:
WARNING: vmlinux.o(.text+0x9334): Section mismatch in reference from the function qnap_tsx1x_register_flash() to the variable .init.data:qnap_tsx1x_spi_slave_info
The function qnap_tsx1x_register_flash() references
the variable __initdata qnap_tsx1x_spi_slave_info.
This is often because qnap_tsx1x_register_flash lacks a __initdata
annotation or the annotation of qnap_tsx1x_spi_slave_info is wrong.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
the different putc variants used an initialized local static variable
which is broken since
5de813b (ARM: Eliminate decompressor -Dstatic= PIC hack)
This needs to be initialized at runtime and so needs to be global.
While at it give it a better name.
We need mach/hardware.h for CLPS7111_VIRT_BASE.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
We need a waituart macro.
mov rx, =<immediate> isn't valid, use #<immediate> instead.
We need asm/memory.h for NS9XXX_CSxSTAT_PHYS (via mach/memory.h).
IO_BASE shoule be IO_VIRT, and IO_START should be IO_PHYS. We also need
mach/hardware.h for these definitions.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: synaptics - relax capability ID checks on newer hardware
Input: twl40300-keypad - fix handling of "all ground" rows
Input: gamecon - reference correct pad in gc_psx_command()
Input: gamecon - reference correct input device in NES mode
Input: w90p910_keypad - change platfrom driver name to 'nuc900-kpi'
Input: i8042 - add Gigabyte Spring Peak to dmi_noloop_table
Input: qt2160 - rename kconfig symbol name
Delete a wrong redundant right parenthesis in
arch/arm/mach-footbridge/common.c
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
This patch is to fix nuc900 touchscreen clk definition bug,the .dev_id's
name should be 'nuc900-ts', it should be the same to pdev.name. or else,
the touchscreen driver will be not working well due to clock engine disabled.
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
The Nokia RX51 board code (arch/arm/mach-omap2/board-rx51-peripherals.c)
defines a key map for the matrix keypad keyboard. The hardware seems to
use all of the 8 rows and 8 columns of the keypad, although not all
possible locations are used.
The TWL4030 supports keypads with at most 8 rows and 8 columns. Most keys
are defined with a row and column number between 0 and 7, except
KEY(0xff, 2, KEY_F9),
KEY(0xff, 4, KEY_F10),
KEY(0xff, 5, KEY_F11),
which represent keycodes that should be emitted when entire row is
connected to the ground. since the driver handles this case as if we
had an extra column in the key matrix. Unfortunately we do not allocate
enough space and end up owerwriting some random memory.
Reported-and-tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: stable@kernel.org
ARM: 6226/1: fix kprobe bug in ldr instruction emulation
ARM: Update mach-types
ARM: lockdep: fix unannotated irqs-on
ARM: 6184/2: ux500: use neutral PRCMU base
ARM: 6212/1: atomic ops: add memory constraints to inline asm
ARM: 6211/1: atomic ops: fix register constraints for atomic64_add_unless
ARM: 6210/1: Do not rely on reset defaults of L2X0_AUX_CTRL
Signed-off-by: Bin Yang <bin.yang@marvell.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
The wrong CONFIG defines were checked, and the <mach/audio.h>
include was missing
Signed-off-by: pieter <p.grimmerink@inepro.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
Reported-by: Dylan Cristiani <d.cristiani@idem-tech.it>
This patch:
1) Simpifies the DRI recomputation routine by pulling out the common code
2) Fixes a bug in PXA27x DRI recomputation caused by incorrect parenthesis
Reported-by: Andrea Adami <andrea.adami@gmail.com>
git://git.pengutronix.de/git/ukl/linux-2.6
* 'arm/defconfig/reduced-v2.6.35-rc1' of git://git.pengutronix.de/git/ukl/linux-2.6:
ARM: reduce defconfigs
This is a big change, but results in no loss of information, despite us
losing almost 200k lines:
177 files changed, 652 insertions(+), 194157 deletions(-)
and Grant Likely thinks powerpc can also use the same reduction
technique.
The python script that did the reduction looks like this:
#! /usr/bin/env python
# vim: set fileencoding=utf-8 :
# Copyright (C) 2010 by Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
import re
import subprocess
import os
import sys
# This prevents including a timestamp in the .config which makes comparing a
# bit easier.
os.environ['KCONFIG_NOTIMESTAMP'] = 'Yes, please'
# XXX: get these using getopt
kernel_tree = '' # os.path.join(os.environ['HOME'], 'gsrc', 'linux-2.6')
arch = 'arm'
target = sys.argv[1]
defconfig_src = os.path.join(kernel_tree, 'arch/%s/configs/%s' % (arch, target))
subprocess.check_call(['make', '-s', 'ARCH=%s' % arch, target])
origconfig = list(open('.config'))
config = list(origconfig)
config_size = os.stat('.config').st_size
i = 0
while i < len(config):
print 'test for %r' % config[i]
defconfig = open(defconfig_src, 'w')
defconfig.writelines(config[:i])
defconfig.writelines(config[i + 1:])
defconfig.close()
if os.stat('.config').st_size == config_size and list(open('.config')) == origconfig:
del config[i]
else:
i += 1
defconfig.writelines(config)
defconfig.close()
which is pretty self-explanatory.
Acked-by: Russell King <linux@arm.linux.org.uk>
CPU: Testing write buffer coherency: ok
WARNING: at kernel/lockdep.c:3145 check_flags+0xcc/0x1dc()
Modules linked in:
[<c0035120>] (unwind_backtrace+0x0/0xf8) from [<c0355374>] (dump_stack+0x20/0x24)
[<c0355374>] (dump_stack+0x20/0x24) from [<c0060c04>] (warn_slowpath_common+0x58/0x70)
[<c0060c04>] (warn_slowpath_common+0x58/0x70) from [<c0060c3c>] (warn_slowpath_null+0x20/0x24)
[<c0060c3c>] (warn_slowpath_null+0x20/0x24) from [<c008f224>] (check_flags+0xcc/0x1dc)
[<c008f224>] (check_flags+0xcc/0x1dc) from [<c00945dc>] (lock_acquire+0x50/0x140)
[<c00945dc>] (lock_acquire+0x50/0x140) from [<c0358434>] (_raw_spin_lock+0x50/0x88)
[<c0358434>] (_raw_spin_lock+0x50/0x88) from [<c00fd114>] (set_task_comm+0x2c/0x60)
[<c00fd114>] (set_task_comm+0x2c/0x60) from [<c007e184>] (kthreadd+0x30/0x108)
[<c007e184>] (kthreadd+0x30/0x108) from [<c0030104>] (kernel_thread_exit+0x0/0x8)
---[ end trace 1b75b31a2719ed1c ]---
possible reason: unannotated irqs-on.
irq event stamp: 3
hardirqs last enabled at (2): [<c0059bb0>] finish_task_switch+0x48/0xb0
hardirqs last disabled at (3): [<c002f0b0>] ret_slow_syscall+0xc/0x1c
softirqs last enabled at (0): [<c005f3e0>] copy_process+0x394/0xe5c
softirqs last disabled at (0): [<(null)>] (null)
Fix this by ensuring that the lockdep interrupt state is manipulated in
the appropriate places. We essentially treat userspace as an entirely
separate environment which isn't relevant to lockdep (lockdep doesn't
monitor userspace.) We don't tell lockdep that IRQs will be enabled
in that environment.
Instead, when creating kernel threads (which is a rare event compared
to entering/leaving userspace) we have to update the lockdep state. Do
this by starting threads with IRQs disabled, and in the kthread helper,
tell lockdep that IRQs are enabled, and enable them.
This provides lockdep with a consistent view of the current IRQ state
in kernel space.
This also revert portions of 0d928b0b616d1c5c5fe76019a87cba171ca91633
which didn't fix the problem.
Tested-by: Ming Lei <tom.leiming@gmail.com>
The MTU wallclock timing fix-up patch was hardwired to the DB8500
causing a regression. This makes it work on the DB5500 as well.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Currently, the 32-bit and 64-bit atomic operations on ARM do not
include memory constraints in the inline assembly blocks. In the
case of barrier-less operations [for example, atomic_add], this
means that the compiler may constant fold values which have actually
been modified by a call to an atomic operation.
This issue can be observed in the atomic64_test routine in
<kernel root>/lib/atomic64_test.c:
00000000 <test_atomic64>:
0: e1a0c00d mov ip, sp
4: e92dd830 push {r4, r5, fp, ip, lr, pc}
8: e24cb004 sub fp, ip, #4
c: e24dd008 sub sp, sp, #8
10: e24b3014 sub r3, fp, #20
14: e30d000d movw r0, #53261 ; 0xd00d
18: e3011337 movw r1, #4919 ; 0x1337
1c: e34c0001 movt r0, #49153 ; 0xc001
20: e34a1aa3 movt r1, #43683 ; 0xaaa3
24: e16300f8 strd r0, [r3, #-8]!
28: e30c0afe movw r0, #51966 ; 0xcafe
2c: e30b1eef movw r1, #48879 ; 0xbeef
30: e34d0eaf movt r0, #57007 ; 0xdeaf
34: e34d1ead movt r1, #57005 ; 0xdead
38: e1b34f9f ldrexd r4, [r3]
3c: e1a34f90 strexd r4, r0, [r3]
40: e3340000 teq r4, #0
44: 1afffffb bne 38 <test_atomic64+0x38>
48: e59f0004 ldr r0, [pc, #4] ; 54 <test_atomic64+0x54>
4c: e3a0101e mov r1, #30
50: ebfffffe bl 0 <__bug>
54: 00000000 .word 0x00000000
The atomic64_set (0x38-0x44) writes to the atomic64_t, but the
compiler doesn't see this, assumes the test condition is always
false and generates an unconditional branch to __bug. The rest of the
test is optimised away.
This patch adds suitable memory constraints to the atomic operations on ARM
to ensure that the compiler is informed of the correct data hazards. We have
to use the "Qo" constraints to avoid hitting the GCC anomaly described at
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=44492 , where the compiler
makes assumptions about the writeback in the addressing mode used by the
inline assembly. These constraints forbid the use of auto{inc,dec} addressing
modes, so it doesn't matter if we don't use the operand exactly once.
Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org>
The atomic64_add_unless function compares an atomic variable with
a given value and, if they are not equal, adds another given value
to the atomic variable. The function returns zero if the addition
did not occur and non-zero otherwise.
On ARM, the return value is initialised to 1 in C code. Inline assembly
code then performs the atomic64_add_unless operation, setting the
return value to 0 iff the addition does not occur. This means that
when the addition *does* occur, the value of ret must be preserved
across the inline assembly and therefore requires a "+r" constraint
rather than the current one of "=&r".
Thanks to Nicolas Pitre for helping to spot this.
On i.MX35 the L2X0_AUX_CTRL register does not have sensible reset
default values. Allow them to be overwritten with the aux_val/aux_mask
arguments passed to l2x0_init().
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This patch fixes on wrong function name in include/plat/sdhci.h for Samsung.
The 's5pc100_default_sdhci0()' function should be chnaged to
's5pv210_default_sdhci0()'. Because 's5pv210_default_sdhci0()' must be pair.
Signed-off-by: Hyuk Lee <hyuk1.lee@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
The S5P6442 PLL setting announce message incorrectly displays S5P6440
as the SoC. Change it to S5P6442.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
This patch fixes the following compilation problem if only NCP machine
is selected:
arch/arm/mach-s3c64xx/s3c6410.c: In function 's3c6410_map_io':
arch/arm/mach-s3c64xx/s3c6410.c:51: error: implicit declaration of function 's3c6410_default_sdhci2'
And also adds missed 's3c6400_default_sdhci2'.
[kgene.kim@samsung.com: minor title fix and added comments]
1. Corrected shift values of I2S and UART clocks (CLK_GATE_IP3), which were
defined incorrectly.
2. Corrected shift values of sclk_audio, uclk1, sclk_fimd, sclk_mmc,
sclk_spi, sclk_pwm, which had duplicated .enable/.ctrlbit with their
twins defined in struct clk init_clocks_disable[] and struct clk
init_clocks[]. We've changed their .enable/.ctrlbit to use CLK_SRC_MASK
register to avoid the duplicated clock problem described below.
NOTE: Duplicated Clock Problem
Please note that each clock definition should access different control
register; otherwise, the system may suffer lockups. For example, if we
have two clock definitions "a" and "b" which access the same register
(and the shift value). Then, when we do:
module A
clk = clk_get("a");
clk->clk_enable(clk);
module B (context switch)
clk = clk_get("b");
do something with clk.
clk->clk_disable(clk);
module A (context switch)
* At this point, the system may hang.
Therefore, there should be no clock definitions with the same contol
register/shift. If we need to create "aliases", then, creating child
clocks sharing the clock should be fine.
3. Corrected other sclk_* shift values and access registers.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
[kgene.kim@samsung.com: minor title and message fix]
This patch fixes bug on eint type set function, s5p_irq_eint_set_type().
In the IRQ_TYPE_EDGE_FALLING case, S5P_EXTINT_FALLEDGE is right
instead of S5P_EXTINT_RISEEDGE
Signed-off-by: Boojin Kim <boojin.kim@samsung.com>
Hardware performance counters on ARM are 32-bits wide but atomic64_t
variables are used to represent counter data in the hw_perf_event structure.
The armpmu_event_update function right-shifts a signed 64-bit delta variable
and adds the result to the event count. This can lead to shifting in sign-bits
if the MSB of the 32-bit counter value is set. This results in perf output
such as:
Performance counter stats for 'sleep 20':
18446744073460670464 cycles <-- 0xFFFFFFFFF12A6000
7783773 instructions # 0.000 IPC
465 context-switches
161 page-faults
1172393 branches
20.154242147 seconds time elapsed
This patch ensures that the delta value is treated as unsigned so that the
right shift sets the upper bits to zero.
Cc: <stable@kernel.org>
Acked-by: Jamie Iles <jamie.iles@picochip.com>
RealView boards with certain revisions of the L210/L220 cache controller
may have issues (hardware deadlock) with the mandatory barriers (DSB
followed by an L2 cache sync) when ARM_DMA_MEM_BUFFERABLE is enabled.
The patch disables ARM_DMA_MEM_BUFFERABLE for these boards.
Tested-by: Linus Walleij <linus.walleij@stericsson.com>
RealView boards with certain revisions of the L220 cache controller (ARM11*
processors only) may have issues (hardware deadlock) with the recent changes to
the mb() barrier implementation (DSB followed by an L2 cache sync). The patch
redefines the RealView ARM11MPCore mandatory barriers without the outer_sync()
call.
CPU performance event counters on v7 cores will only operate
if either the NIDEN or DBGEN signals are driven high.
For the OMAP3 platform, these signals are driven low by default
but DBGEN can be asserted by selecting the OMAP3_EMU Kconfig option,
which enables the virtual clock for hardware debugging peripherals.
Acked-by: Jean Pihet <jpihet@mvista.com>
Linux expects that if a CPU modifies a memory location, then that
modification will eventually become visible to other CPUs in the system.
On an ARM11MPCore processor, loads are prioritised over stores so it is
possible for a store operation to be postponed if a polling loop immediately
follows it. If the variable being polled indirectly depends on the outstanding
store [for example, another CPU may be polling the variable that is pending
modification] then there is the potential for deadlock if interrupts are
disabled. This deadlock occurs in the KGDB testsuire when executing on an
SMP ARM11MPCore configuration.
This patch changes the definition of cpu_relax() to smp_mb() for ARMv6 cores,
forcing a flushing of the write buffer on SMP systems before the next load
takes place. If the Kernel is not compiled for SMP support, this will expand
to a barrier() as before.
When not aligned, random bits could be written in the initial page table
by the __create_page_tables() function.
workaround
Commit f4d6477f introduced a workaround for the lack of hardware
broadcasting of the cache maintenance operations on ARM11MPCore.
However, the workaround is only valid on CPUs that do not do speculative
loads into the D-cache.
This patch adds a Kconfig option with the corresponding help to make the
above clear. When the DMA_CACHE_RWFO option is disabled, the kernel
behaviour is that prior to the f4d6477f commit. This also allows ARMv6
UP processors with speculative loads to work correctly.
For other processors, a different workaround may be needed.
Cc: Ronen Shitrit <rshitrit@marvell.com>
A recent patch for DMA cache maintenance on ARM11MPCore added a write
for ownership trick to the v6_dma_inv_range() function. Such operation
destroys data already present in the buffer. However, this function is
used with with dma_sync_single_for_device() which is supposed to
preserve the existing data transfered into the buffer. This patch adds a
combination of read/write for ownership to preserve the original data.
Reported-by: Ronen Shitrit <rshitrit@marvell.com>
This macro is not defined when !CONFIG_MMU so this patch moves the
CONSISTENT_* definitions to the CONFIG_MMU section.
arch/arm/mach-mx3/built-in.o: In function `mx31lilly_board_init':
mach-kzm_arm11_01.c:(.init.text+0x674): undefined reference to `otg_ulpi_create'
mach-kzm_arm11_01.c:(.init.text+0x68c): undefined reference to `otg_ulpi_create'
mach-kzm_arm11_01.c:(.init.text+0x744): undefined reference to `mxc_ulpi_access_ops'
make: *** [.tmp_vmlinux1] Error 1
Signed-off-by: Daniel Mack <daniel@caiaq.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6:
OMAP: hwmod: Fix the missing braces
OMAP4: clock: Fix multi-omap boot with reset un-used clocks
OMAP3: PM: fix IO daisy chain enable to use PM_WKEN reg
omap: GPIO: fix auto-disable of debounce clock
omap: DMTIMER: Ack pending interrupt always when stopping a timer
omap: Stalker board: switch over to gpio_set_debounce
omap: fix build failure due to missing include dma-mapping.h
omap iommu: Fix Memory leak
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
