The irq data for rng module defined in hwmod data previously
missed the OMAP_INTC_START relative offset, so the interrupt
number is probably misconfigured during the DT node addition
adjusting for this OMAP_INTC_START. Interrupt #36 is associated
with a watchdog timer, so fix the rng module's interrupt to the
appropriate interrupt #52.
Signed-off-by: Suman Anna <s-anna@ti.com>
The omap3_pmx_core pinmux device in the device tree handles the system
controller module (SCM) PADCONFS fonction. Its control registers are
split in two distinct areas, with other SCM registers in-between. Those
other registers can't thus be requested by other drivers as the memory
region gets reserved by the pinmux driver.
Split the omap3_pmx_core device tree node in two for the two memory
regions. The second region address and size depends on the SoC model.
The change in omap3.dtsi fixes an "external abort on non-linefetch" when
doing
cat /sys/kernel/debug/pinctrl/.../pins
on a Nokia N900.
Note that the core2 padconf region is different for 3430 vs 3630,
and does not exist on 3517 as noted by Nishanth Menon <nm@ti.com>.
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-By: Sebastian Reichel <sre@debian.org>
Signed-off-by: Nishanth Menon <nm@ti.com>
[tony@atomide.com: updated for 3430 vs 3630 core2 based on Nishant's patch]
This adds support for CompuLab SBC-T3530, also known as cm-t3730:
http://compulab.co.il/products/sbcs/sbc-t3530/
It seems that with the sbc-3xxx mainboard is also used on
SBC-T3517 and SBC-T3730 with just a different CPU module:
http://compulab.co.il/products/sbcs/sbc-t3517/
http://compulab.co.il/products/sbcs/sbc-t3730/
So let's add a common omap3-sb-t35.dtsi and then separate SoC
specific omap3-sbc-t3730.dts, omap3-sbc-t3530.dts and
omap3-sbc-t3517.dts.
I've tested this with SBC-T3730 as that's the only one I have.
At least serial, both Ethernet controllers, MMC, and wl12xx WLAN
work.
Note that WLAN seems to be different for SBC-T3530. And SBC-T3517
may need some changes for the EMAC Ethernet if that's used
instead of the smsc911x.
Cc: devicetree@vger.kernel.org
Cc: Mike Rapoport <mike@compulab.co.il>
Let's add the Ethernet so NFSroot works and the first MMC card
so people can patch in more support easily.
As the emac uses the system control module registers for
reset and interrupts, we need to pass those in the platform
data until we have a separate system control module driver.
As we currently need to support a mix of legacy platform data and
device tree intialized data, let's make sure things keep working
for the TWL GPIOs.
Mostly the issue is caused by the fact that DSS does not yet have
device tree bindings, so we need to rely on the TWL GPIO callback
for setting up things like LCD backlight for some boards.
As of_platform_populate() for the TWL GPIO is called by twl-core
after the I2C bus has been initialized, we cannot pass the auxdata
table from the board init code to twl-core like we used to with
just legacy platform data.
So let's use the omap_device bus hook to patch in the platform
data for TWL GPIO until we have sorted out the issues with the
TWL GPIOs and device tree bindings.
The other option was be to initialize twl core using legacy
platform data, which seems like a step backwards as we're moving
to device tree only initialization. And we really don't want to
add custom configuration functions to the TWL GPIO driver either
for this.
omap-for-v3.14/omap3-board-removal
Commit 7ce93f3 (ARM: OMAP2+: Fix more missing data for omap3.dtsi file)
fixed missing device tree data for omaps, but did not account for some of the
hardware modules being inaccessible for secure omaps. This causes the
following error on secure omaps:
Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa0c5048
SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.13.0-rc2+ #446
task: ce057b40 ti: ce058000 task.ti: ce058000
PC is at omap_aes_dma_stop+0x24/0x3c
LR is at omap_aes_probe+0x1cc/0x584
psr: 60000113
sp : ce059e20 ip : ce0b4ee0 fp : 00000000
r10: c0573ae8 r9 : c0749508 r8 : 00000000
r7 : ce0b4e00 r6 : 00000000 r5 : ce0b4e10 r4 : ce274890
r3 : fa0c5048 r2 : 00000048 r1 : 0000002c r0 : ce274890
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 80004019 DAC: 00000015
Process swapper/0 (pid: 1, stack limit = 0xce058248)
Stack: (0xce059e20 to 0xce05a000)
9e20: c0749508 0000a1ff 00000000 c016cd8c c06b5a06 ce2a45f0 ce2a4570 ce0b5fb0
9e40: 00000000 480c5000 480c504f c0abe4e4 00000200 00000000 00000000 00000000
9e60: ce0b4e10 ce0b4e10 c082da3c c082da3c c02b8c70 c077c610 c0749508 00000000
9e80: 00000000 c02b9e7c c02b9e64 ce0b4e10 00000000 c02b8b20 ce0b4e10 ce0b4e44
9ea0: c082da3c c02b8cd8 00000000 ce059eb8 c082da3c c02b7408 ce079edc ce0b1a34
9ec0: c082da3c c082da3c ce2a0280 00000000 c08158d8 c02b8358 c0663405 c0663405
9ee0: 00000073 c082da3c c079e4e8 c07ab3bc c0844340 c02b9334 00000000 00000006
9f00: c079e4e8 c0008920 c067f6bf c0ac7c6b 00000000 c0712e28 00000000 00000000
9f20: c0712e38 ce059f38 00000093 c0ac7c82 00000000 c0058994 00000000 c07130e8
9f40: c07127b8 00000093 00000006 00000006 00000001 00000006 00000006 c079e4e8
9f60: c07ab3bc c0844340 00000093 c0749508 c079e4f4 c0749c64 00000006 00000006
9f80: c0749508 00000000 00000000 c0517e2c 00000000 00000000 00000000 00000000
9fa0: 00000000 c0517e34 00000000 c000dfb8 00000000 00000000 00000000 00000000
9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
(omap_aes_probe+0x1cc/0x584)
(platform_drv_probe+0x18/0x48)
(driver_probe_device+0xb0/0x200)
(__driver_attach+0x68/0x8c)
(bus_for_each_dev+0x50/0x88)
(bus_add_driver+0xcc/0x1c8)
(driver_register+0x9c/0xe0)
(do_one_initcall+0x98/0x140)
(kernel_init_freeable+0x16c/0x23c)
(kernel_init+0x8/0x100)
(ret_from_fork+0x14/0x3c)
Code: e1811002 e5932020 e590300c e0833002 (e593c000)
Let's fix the issue by adding omap34xx-hs.dtsi and omap36xx-hs.dtsi and make
n900, n9 and n950 to use them. This way we have the aes, sham and timer12
disabled for secure devices the same way legacy booting does based on the
omap34xx_gp_hwmod_ocp_ifs and omap36xx_gp_hwmod_ocp_ifs arrays in
omap_hwmod_3xxx_data.c.
Reported-by: Sebastian Reichel <sre@debian.org>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
The am3517 is wrongly booting as omap3 which means that the am3517
specific devices like Ethernet won't work when booted with device
tree. Now with the new devices defined in am3517.dtsi, let's use
that instead of the omap3.dtsi, and add a separate machine entry
for am3517 so am3517-evm can use it.
[tony@atomide.com: updated comments and fixed build without omap3]
On am3517 there are some extra devices compared to omap3.dtsi that
we currently have not defined. Let's fix that by adding am3517.dtsi
file.
We have some device tree properties where the ti,hwmod have multiple
values:
am33xx.dtsi: ti,hwmods = "tpcc", "tptc0", "tptc1", "tptc2";
am4372.dtsi: ti,hwmods = "tpcc", "tptc0", "tptc1", "tptc2";
dra7.dtsi: ti,hwmods = "l3_main_1", "l3_main_2";
omap3.dtsi: ti,hwmods = "mcbsp2", "mcbsp2_sidetone";
omap3.dtsi: ti,hwmods = "mcbsp3", "mcbsp3_sidetone";
omap4.dtsi: ti,hwmods = "l3_main_1", "l3_main_2", "l3_main_3";
omap5.dtsi: ti,hwmods = "l3_main_1", "l3_main_2", "l3_main_3";
That's not correct way of doing things in this case because these are
separate devices with their own address space, interrupts, SYSCONFIG
registers and can set their PM states independently.
So they should all be fixed up to be separate devices in the .dts files.
We also have the related data removed for at least omap4 in commit
3b9b10151c68 (ARM: OMAP4: hwmod data: Clean up the data file), so
that data is wrongly initialized as null data.
So we need to fix two bugs:
1. We are only checking the first entry of the ti,hwmods property
This means that we're only initializing the first hwmods entry
instead of the ones listed in the ti,hwmods property.
2. We are only checking the child nodes, not the nodes themselves
This means that anything listed at OCP level is currently just
ignored and unitialized and at least the omap4 case, with the
legacy data missing from the hwmod.
Fix both of the issues by using an index to the ti,hwmods property
and changing the hwmod lookup function to also check the current node
for ti,hwmods property instead of just the children.
While at it, let's also add some warnings for the bad data so it's
easier to fix.
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Acked-by: Paul Walmsley <paul@pwsan.com>
Pull ARM SoC fixes from Olof Johansson:
"Another batch of fixes for ARM SoCs for 3.13. The diffstat is large,
mostly because of:
- Another set of fixes to fix regressions caused by moving OMAP from
board files to DT. Tony thinks this was the last major set of
fixes, with maybe just a few small patches to follow.
- More fixes for Marvell platforms, most dealing with misdescribed
PCIe hardware, i.e. incorrect number of busses on some SoCs, etc.
The line delta adds up due to various ranges moving around when
this is fixed.
But there's also:
- Some smaller tweaks to defconfigs to make more boards bootable in
my test setup for better coverage.
- There are also a few other smaller fixes, a short series for at91,
a couple of reverts for ux500, etc"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (39 commits)
arm: dts: socfpga: Change some clocks of gate-clk type to perip-clk
arm: socfpga: Enable ARM_TWD for socfpga
ARM: multi_v7_defconfig: enable SDHCI_BCM_KONA and MMC_BLOCK_MINORS=16
ARM: sunxi_defconfig: enable NFS, TMPFS, PRINTK_TIME and nfsroot support
ARM: multi_v7_defconfig: enable network for BeagleBone Black
ARM: dts: Fix the name of supplies for smsc911x shared by OMAP
ARM: OMAP2+: Powerdomain: Fix unchecked dereference of arch_pwrdm
ARM: dts: omap3-beagle: Add omap-twl4030 audio support
ARM: dts: omap4-sdp: Fix pin muxing for wl12xx
ARM: dts: omap4-panda-common: Fix pin muxing for wl12xx
ARM: at91: fixed unresolved symbol "at91_pm_set_standby" when built without CONFIG_PM
ARM: at91: add usart3 alias to dtsi
ARM: at91: sama5d3: reduce TWI internal clock frequency
mmc: omap: Fix I2C dependency and make driver usable with device tree
mmc: omap: Fix DMA configuration to not rely on device id
ARM: dts: omap3-beagle: Fix USB host on beagle boards (for 3.13)
ARM: dts: omap3-igep0020: name twl4030 VPLL2 regulator as vdds_dsi
ARM: dts: AM33XX IGEP0033: add USB support
ARM: dts: AM33XX BASE0033: add 32KBit EEPROM support
ARM: dts: AM33XX BASE0033: add pinmux and user led support
Pull timer fixes from Thomas Gleixner:
- timekeeping: Cure a subtle drift issue on GENERIC_TIME_VSYSCALL_OLD
- nohz: Make CONFIG_NO_HZ=n and nohz=off command line option behave the
same way. Fixes a long standing load accounting wreckage.
- clocksource/ARM: Kconfig update to avoid ARM=n wreckage
- clocksource/ARM: Fixlets for the AT91 and SH clocksource/clockevents
- Trivial documentation update and kzalloc conversion from akpms pile
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: Fix another inconsistency between CONFIG_NO_HZ=n and nohz=off
time: Fix 1ns/tick drift w/ GENERIC_TIME_VSYSCALL_OLD
clocksource: arm_arch_timer: Hide eventstream Kconfig on non-ARM
clocksource: sh_tmu: Add clk_prepare/unprepare support
clocksource: sh_tmu: Release clock when sh_tmu_register() fails
clocksource: sh_mtu2: Add clk_prepare/unprepare support
clocksource: sh_mtu2: Release clock when sh_mtu2_register() fails
ARM: at91: rm9200: switch back to clockevents_config_and_register
tick: Document tick_do_timer_cpu
timer: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node(...)
NOHZ: Check for nohz active instead of nohz enabled
Some of the clocks that were designated gate-clk do not have a gate, so
change those clocks to be of periph-clk type.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Update Kconfig to enable TWD.
Reviewed-by: Pavel Machek <pavel@denx.de>
Enable MMC/SD on the Broadcom mobile platforms, and increase the block
minors from the default 8 to 16 (since the Broadcom board by default
has root on the 8th partition).
Cc: stable@vger.kernel.org # v3.12
This enables a few more options on the sunxi defconfigs such that I can
use nfsroot to boot them (there is no local storage support yet). It
also enables PRINTK_TIME and tmpfs since it's a common distro requirement.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
From Tony Lindgren:
Few more legacy booting vs device tree booting fixes that people
have noticed while booting things with device tree for things like
omap4 WLAN, smsc911x, and beagle audio. Hopefully this will be it
for the legacy booting vs device tree fixes for this -rc cycle.
* tag 'omap-for-v3.13/more-dt-regressions' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
BeagleBone Black uses the TI CPSW ethernet controller, enable it in the
multi_v7_defconfig for testing coverage purposes.
From Nicolas Ferre:
AT91: second round of fixes for 3.13
- reduce IP frequency for I2C on sama5d3
- missing aliases directive for USART3 on 9x5 family
- a PM symbol is missing if !CONFIG_PM
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
fixes
From Jason Cooper, mvebu DT fixes for v3.13:
- mvebu
- PCIe fixes now that we have test devices with more ports.
- fix access to coherency registers
* tag 'mvebu-dt-fixes-3.13' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: re-enable PCIe on Armada 370 DB
ARM: mvebu: use the virtual CPU registers to access coherency registers
ARM: mvebu: fix second and third PCIe unit of Armada XP mv78260
ARM: mvebu: second PCIe unit of Armada XP mv78230 is only x1 capable
From Tony Lindgren:
Some omap related fixes that have come up with people moving to device
tree only based booting for omap2+.
The series contains a handful of fixes for the igep boards as they were
one of the first omap3 boards to jump over completely to device tree
based booting. So these can be considered regressions compared to
booting igep in legacy mode with board files in v3.12.
Also included are few other device tree vs legacy booting regressions:
- yet more missing omap3 .dtsi entries that have showed up booting
various boards with device tree only
- n900 eMMC device tree fix
- fixes for beagle USB EHCI
- two fixes to make omap2420 MMC work
As we're moving omap2+ to be device tree only for v3.14, I'd like to
have v3.13 work equally well for legacy based booting and device tree
based booting. So there will be likely few more device tree related
booting patches trickling in.
This series also includes a regression fix for the omap timer posted
mode that may wrongly stay on from the bootloader for some SoCs.
* tag 'omap-for-v3.13/fixes-against-rc1-take2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: dts: AM33XX BASE0033: add pinmux and hdmi node to enable display
ARM: dts: omap3-igep0020: Add pinmuxing for DVI output
ARM: dts: omap3-igep0020: Add pinmux setup for i2c devices
ARM: dts: omap3-igep: Update to use the TI AM/DM37x processor
ARM: dts: omap3-igep: Add support for LBEE1USJYC WiFi connected to SDIO
ARM: dts: omap3-igep: Fix bus-width for mmc1
ARM: OMAP2+: dss-common: change IGEP's DVI DDC i2c bus
ARM: OMAP2+: Disable POSTED mode for errata i103 and i767
ARM: OMAP2+: Fix eMMC on n900 with device tree
ARM: OMAP2+: Add fixed regulator to omap2plus_defconfig
drivers/net/ethernet/smsc/smsc911x.c is expecting supplies named
"vdd33a" and "vddvario". Currently the shared DTS file provides
"vmmc" and "vmmc_aux", and the supply lookup will fail:
smsc911x 2c000000.ethernet: Looking up vdd33a-supply from device tree
smsc911x 2c000000.ethernet: Looking up vdd33a-supply property in node /ocp/gpmc@6e000000/ethernet@gpmc failed
smsc911x 2c000000.ethernet: Looking up vddvario-supply from device tree
smsc911x 2c000000.ethernet: Looking up vddvario-supply property in node /ocp/gpmc@6e000000/ethernet@gpmc failed
Fix it!
Looks like commmit 6b2978ac40e4 (ARM: dts: Shared file for omap GPMC
connected smsc911x) made the problem more visible by moving the smc911x
configuration from the omap3-igep0020.dts file to the generic file.
But it seems we've had this problem since commit d72b4415011e
(ARM: dts: omap3-igep0020: Add SMSC911x LAN chip support).
Tested on OMAP3 Overo platform.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
[tony@atomide.com: updated comments for the commits causing the problem]
Commit 'cd8abed' "ARM: OMAP2+: Powerdomain: Remove the need to
always have a voltdm associated to a pwrdm" leads to the following
Smatch complaint:
arch/arm/mach-omap2/powerdomain.c:131 _pwrdm_register()
error: we previously assumed 'arch_pwrdm' could be null (see line 105)
So, fix the unchecked dereference of arch_pwrdm.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
This adds typical McBSP2-TWL4030 audio description to the legacy
Beagle Board.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Mux mode for wlan/sdmmc5 should be MODE0 in pinmux_wl12xx_pins and
Enable Pull up on sdmmc5_clk to detect SDIO card.
This fixes WLAN on omap4-sdp that got broken in v3.10 when we
moved omap4 to boot using device tree only as I did not have
the WL12XX card in my omap4 SDP to test with. The commit that
attempted to make WL12XX working on omap4 SDP was 775d2418f309
(ARM: dts: Fix muxing and regulator for wl12xx on the SDIO
bus for blaze).
Signed-off-by: Balaji T K <balajitk@ti.com>
[tony@atomide.com: updated comments for the regression]
pin mux wl12xx_gpio and wl12xx_pins should be part of omap4_pmx_core
and not omap4_pmx_wkup. So, move wl12xx_* to omap4_pmx_core.
Fix the following error message:
pinctrl-single 4a31e040.pinmux: mux offset out of range: 0x38 (0x38)
pinctrl-single 4a31e040.pinmux: could not add functions for pinmux_wl12xx_pins 56x
SDIO card is not detected after moving pin mux to omap4_pmx_core since
sdmmc5_clk pull is disabled. Enable Pull up on sdmmc5_clk to detect SDIO card.
This fixes a regression where WLAN did not work after a warm reset
or after one up/down cycle that happened when we move omap4 to boot
using device tree only. For reference, the kernel bug is described at:
https://bugzilla.kernel.org/show_bug.cgi?id=63821
Cc: stable@vger.kernel.org # v3.10+
[tony@atomide.com: update comments to describe the regression]
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen bug-fixes from Konrad Rzeszutek Wilk:
"Fixes to patches that went in this merge window along with a latent
bug:
- Fix lazy flushing in case m2p override fails.
- Fix module compile issues with ARM/Xen
- Add missing call to DMA map page for Xen SWIOTLB for ARM"
* tag 'stable/for-linus-3.13-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/gnttab: leave lazy MMU mode in the case of a m2p override failure
xen/arm: p2m_init and p2m_lock should be static
arm/xen: Export phys_to_mach to fix Xen module link errors
swiotlb-xen: add missing xen_dma_map_page call
CONFIG_PM
If CONFIG_PM is not defined, then arch/arm/mach-at91/pm.c is not
compiled in. This patch creates an inline function that does nothing
if CONFIG_PM is not defined.
Signed-off-by: Brent Taylor <motobud@gmail.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Alias was missing for SoC of the at91sam9x5 familly that embed USART3.
Reported-by: Jiri Prchal <jiri.prchal@aksignal.cz>
[b.brezillon@overkiz.com: advised to place changes in at91sam9x5_usart3.dtsi]
Acked-by: Boris BREZILLON <b.brezillon@overkiz.com>
With some devices, transfer hangs during I2C frame transmission. This issue
disappears when reducing the internal frequency of the TWI IP. Even if it is
indicated that internal clock max frequency is 66MHz, it seems we have
oversampling on I2C signals making TWI believe that a transfer in progress
is done.
This fix has no impact on the I2C bus frequency.
Cc: <stable@vger.kernel.org> #3.10+
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Pull ARM fixes from Russell King:
"Some ARM fixes, the biggest of which is the fix for the signal return
codes; this came up due to an interaction between the V7M nommu
changes and the BE8 changes. Dave Martin spotted that the kexec
trampoline wasn't being correctly copied (in a way which allows
Thumb-2 to work).
I've also fixed a number of breakages on footbridge platforms as I've
upgraded one of my machines to v3.12... one which had a 1200 day
uptime"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 7907/1: lib: delay-loop: Add align directive to fix BogoMIPS calculation
ARM: 7897/1: kexec: Use the right ISA for relocate_new_kernel
ARM: 7895/1: signal: fix armv7-m build issue in sigreturn_codes.S
ARM: footbridge: fix EBSA285 LEDs
ARM: footbridge: fix VGA initialisation
ARM: fix booting low-vectors machines
ARM: dma-mapping: check DMA mask against available memory
Currently mx53 (CortexA8) running at 1GHz reports:
Calibrating delay loop... 663.55 BogoMIPS (lpj=3317760)
Tom Evans verified that alignments of 0x0 and 0x8 run the two instructions of __loop_delay in one clock cycle (1 clock/loop), while alignments of 0x4 and 0xc take 3 clocks to run the loop twice. (1.5 clock/loop)
The original object code looks like this:
00000010 <__loop_const_udelay>:
10: e3e01000 mvn r1, #0
14: e51f201c ldr r2, [pc, #-28] ; 0 <__loop_udelay-0x8>
18: e5922000 ldr r2, [r2]
1c: e0800921 add r0, r0, r1, lsr #18
20: e1a00720 lsr r0, r0, #14
24: e0822b21 add r2, r2, r1, lsr #22
28: e1a02522 lsr r2, r2, #10
2c: e0000092 mul r0, r2, r0
30: e0800d21 add r0, r0, r1, lsr #26
34: e1b00320 lsrs r0, r0, #6
38: 01a0f00e moveq pc, lr
0000003c <__loop_delay>:
3c: e2500001 subs r0, r0, #1
40: 8afffffe bhi 3c <__loop_delay>
44: e1a0f00e mov pc, lr
After adding the 'align 3' directive to __loop_delay (align to 8 bytes):
3c: e320f000 nop {0}
00000040 <__loop_delay>:
40: e2500001 subs r0, r0, #1
44: 8afffffe bhi 40 <__loop_delay>
48: e1a0f00e mov pc, lr
4c: e320f000 nop {0}
, which now reports:
Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
Some more test results:
On mx31 (ARM1136) running at 532 MHz, before the patch:
Calibrating delay loop... 351.43 BogoMIPS (lpj=1757184)
On mx31 (ARM1136) running at 532 MHz after the patch:
Calibrating delay loop... 528.79 BogoMIPS (lpj=2643968)
Also tested on mx6 (CortexA9) and on mx27 (ARM926), which shows the same
BogoMIPS value before and after this patch.
Reported-by: Tom Evans <tom_usenet@optusnet.com.au>
Suggested-by: Tom Evans <tom_usenet@optusnet.com.au>
Copying a function with memcpy() and then trying to execute the
result isn't trivially portable to Thumb.
This patch modifies the kexec soft restart code to copy its
assembler trampoline relocate_new_kernel() using fncpy() instead,
so that relocate_new_kernel can be in the same ISA as the rest of
the kernel without problems.
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Reported-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Tested-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
After "ARM: signal: sigreturn_codes should be endian neutral to
work in BE8" commit, thumb only platforms, like armv7m, fails to
compile sigreturn_codes.S. The reason is that for such arch
values '.arm' directive and arm opcodes are not allowed.
Fix conditionally enables arm opcodes only if no CONFIG_CPU_THUMBONLY
defined and it uses .org instructions to keep sigreturn_codes
layout.
Suggested-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
- The LEDs register is write-only: it can't be read-modify-written.
- The LEDs are write-1-for-off not 0.
- The check for the platform was inverted.
Fixes: cf6856d693dd ("ARM: mach-footbridge: retire custom LED code")
It's no good setting vga_base after the VGA console has been
initialised, because if we do that we get this:
Unable to handle kernel paging request at virtual address 000b8000
pgd = c0004000
[000b8000] *pgd=07ffc831, *pte=00000000, *ppte=00000000
0Internal error: Oops: 5017 [#1] ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.12.0+ #49
task: c03e2974 ti: c03d8000 task.ti: c03d8000
PC is at vgacon_startup+0x258/0x39c
LR is at request_resource+0x10/0x1c
pc : [<c01725d0>] lr : [<c0022b50>] psr: 60000053
sp : c03d9f68 ip : 000b8000 fp : c03d9f8c
r10: 000055aa r9 : 4401a103 r8 : ffffaa55
r7 : c03e357c r6 : c051b460 r5 : 000000ff r4 : 000c0000
r3 : 000b8000 r2 : c03e0514 r1 : 00000000 r0 : c0304971
Flags: nZCv IRQs on FIQs off Mode SVC_32 ISA ARM Segment kernel
which is an access to the 0xb8000 without the PCI offset required to
make it work.
Fixes: cc22b4c18540 ("ARM: set vga memory base at run-time")
Commit f6f91b0d9fd9 (ARM: allow kuser helpers to be removed from the
vector page) required two pages for the vectors code. Although the
code setting up the initial page tables was updated, the code which
allocates page tables for new processes wasn't, neither was the code
which tears down the mappings. Fix this.
Fixes: f6f91b0d9fd9 ("ARM: allow kuser helpers to be removed from the vector page")
Some buses have negative offsets, which causes the DMA mask checks to
falsely fail. Fix this by using the actual amount of memory fitted in
the system.
Beagle (rev. C4) and Beagle-XM (all revs) need VAUX2 1.8V supply
for the USB PHY.
As the generic PHY driver can't handle more than one supply
at the moment, we configure this supply to be always on.
This will cause a very small power impact if the USB host subsystem
is not in use, about 76.86 micro-W + LDO power.
Older Beagle boards (prior to C4) don't have VAUX2 connected anywhere,
so there won't be any functional impact on those boards other than
some additional LDO power consumption.
Reported-by: Nishanth Menon <nm@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
On Device Tree boot the VDDS_DSI regulator is not linked to
the DPI device so omapfb driver probing fails with:
[ 3.186035] OMAPFB: omapfb_probe
[ 3.190704] omapdss DPI error: can't get VDDS_DSI regulator
[ 3.196594] omapfb omapfb: failed to connect default display
[ 3.202667] omapfb omapfb: failed to init overlay connections
[ 3.208892] OMAPFB: free_resources
[ 3.212493] OMAPFB: free all fbmem
[ 3.216735] omapfb omapfb: failed to setup omapfb
As a workaround name the VPLL2 regulator from twl4030 as vdds_dsi
so getting the VDDS_DSI regulator will succeed on dpi_init_regulator().
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Add node to support the USB Host and the USB OTG on the IGEP AQUILA
Processor Board.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
The IGEP AQUILA EXPANSION has a 32KBit EEPROM for user data storage.
Enable the user leds on the IGEP AQUILA EXPANSION. The has two leds,
one green and one red, that are controllable by software.
Enable the hdmi output and the LCD Controller on IGEP AQUILA. Also
configure the correct pinmux for output of video data from the SoC
to the HDMI encoder.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
The IGEPv2 has a TFP410 DPI-to-DVI encoder attached to OMAP's
Display SubSystem (DSS).
Add mux setup for DSS pins and also for the GPIO 170 pin that
is used to ensure that the DVI-D is powered down on power up.
Add pin muxing support for IGEP boards i2c controllers.
Most of the boards are using the TI AM/DM37x processor, there is only a small
quantity of IGEP Processor Boards based on TI OMAP3530. So it's better use the
omap36xx.dtsi include instead of omap34xx.dtsi include. We can add support
for the 34xx based variant later on as needed.
To avoid confusion we have added to the model the (TI AM/DM37x) comment.
[tony@atomide.com: updated comments for the 34xx to 36xx include change]
The LBEE1USJYC is a WiFi/BT combo module used on OMAP3-based IGEP boards. In
both cases, IGEPv2 Rev. C and IGEP COM MODULE, the module is connected using
the same MMC interface and uses the same GPIOs.
Both, IGEPv2 and IGEP COM MODULE have a bus-width of 4 not 8, so fix this and
do not mux data pins from mmc1_data4 to mmc1_data7.
