A zero value for prot_sect in the memory types table implies that
section mappings should never be created for the memory type in question.
This is checked for in alloc_init_section().
With LPAE, we set a bit to mask access flag faults for kernel mappings.
This breaks the aforementioned (!prot_sect) check in alloc_init_section().
This patch fixes this bug by first checking for a non-zero
prot_sect before setting the PMD_SECT_AF flag.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: <stable@vger.kernel.org>
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
The vfp_enable function enables access to the VFP co-processor register
space (cp10 and cp11) on the current CPU and must be called with
preemption disabled. Unfortunately, the vfp_init late initcall does not
disable preemption and can lead to an oops during boot if thread
migration occurs at the wrong time and we end up attempting to access
the FPSID on a CPU with VFP access disabled.
This patch fixes the initcall to call vfp_enable from a non-preemptible
context on each CPU and adds a BUG_ON(preemptible) to ensure that any
similar problems are easily spotted in the future.
Cc: stable@vger.kernel.org
Reported-by: Hyungwoo Yang <hwoo.yang@gmail.com>
Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com>
Commit 4e8ee7de227e3ab9a72040b448ad728c5428a042 (ARM: SMP: use
idmap_pgd for mapping MMU enable during secondary booting)
switched secondary boot to use idmap_pgd, which is initialized
during early_initcall, instead of a page table initialized during
__cpu_up. This causes idmap_pgd to contain the static mappings
but be missing all dynamic mappings.
If a console is registered that creates a dynamic mapping, the
printk in secondary_start_kernel will trigger a data abort on
the missing mapping before the exception handlers have been
initialized, leading to a hang. Initial boot is not affected
because no consoles have been registered, and resume is usually
not affected because the offending console is suspended.
Onlining a cpu with hotplug triggers the problem.
A workaround is to the printk in secondary_start_kernel until
after the page tables have been switched back to init_mm.
Signed-off-by: Colin Cross <ccross@android.com>
The machine endianness has no direct correspondence to the syscall ABI,
so use only AUDIT_ARCH_ARM when identifying the ABI to the audit tools
in userspace.
The ARM audit code incorrectly uses the saved application ip register
value to infer syscall entry or exit. Additionally, the saved value will
be clobbered if the current task is not being traced, which can lead to
libc corruption if ip is live (apparently glibc uses it for the TLS
pointer).
This patch fixes the syscall tracing code so that the why parameter is
used to infer the syscall direction and the saved ip is only updated if
we know that we will be signalling a ptrace trap.
Reported-and-Tested-by: Jon Masters <jcm@jonmasters.org>
Cc: Eric Paris <eparis@redhat.com>
The inline assembly in kernel_execve() uses r8 and r9. Since this
code sequence does not return, it usually doesn't matter if the
register clobber list is accurate. However, I saw a case where a
particular version of gcc used r8 as an intermediate for the value
eventually passed to r9. Because r8 is used in the inline
assembly, and not mentioned in the clobber list, r9 was set
to an incorrect value.
This resulted in a kernel panic on execution of the first user-space
program in the system. r9 is used in ret_to_user as the thread_info
pointer, and if it's wrong, bad things happen.
Signed-off-by: Tim Bird <tim.bird@am.sony.com>
Pull ARM fixes from Russell King.
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7406/1: hotplug: copy the affinity mask when forcefully migrating IRQs
ARM: 7405/1: kexec: call platform_cpu_kill on the killer rather than the victim
ARM: 7403/1: tls: remove covert channel via TPIDRURW
ARM: 7401/1: mm: Fix section mismatches
ARM: OMAP: fix DMA vs memory ordering
ARM: 7390/1: dts: versatile-pb/ab fix MMC IRQs
ARM: 7400/1: vfp: clear fpscr length and stride bits on entry to sig handler
ARM: 7399/1: vfp: move user vfp state save/restore code out of signal.c
ARM: 7398/1: l2x0: only write to debug registers on PL310
ARM: 7397/1: l2x0: only apply workaround for erratum #753970 on PL310
ARM: 7396/1: errata: only handle ARM erratum #326103 on affected cores
Pull ARM SoC fixes from Olof Johansson:
"Nothing controversial, just another batch of fixes:
- Samsung/exynos fixes for more merge window fallout: build errors
and warnings mostly, but also some clock/device setup issues on
exynos4/5
- PXA bug and warning fixes related to gpio and pinmux
- IRQ domain conversion bugfixes for U300 and MSM
- A regulator setup fix for U300"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: PXA2xx: MFP: fix potential direction bug
ARM: PXA2xx: MFP: fix bug with MFP_LPM_KEEP_OUTPUT
arm/sa1100: fix sa1100-rtc memory resource
ARM: pxa: fix gpio wakeup setting
ARM: SAMSUNG: add missing MMC_CAP2_BROKEN_VOLTAGE capability
ARM: EXYNOS: Fix compilation error when CONFIG_OF is not defined
ARM: EXYNOS: Fix resource on dev-dwmci.c
ARM: S3C24XX: Fix build warning for S3C2410_PM
ARM: mini2440_defconfig: Fix build error
ARM: msm: Fix gic irqdomain support
ARM: EXYNOS: Fix incorrect initialization of GIC
ARM: EXYNOS: use 'exynos4-sdhci' as device name for sdhci controllers
ARM: u300: bump all IRQ numbers by one
ARM: ux300: Fix unimplementable regulation constraints
When a CPU is hotplugged off, we migrate any IRQs currently affine to it
away and onto another online CPU by calling the irq_set_affinity
function of the relevant interrupt controller chip. This function
returns either IRQ_SET_MASK_OK or IRQ_SET_MASK_OK_NOCOPY, to indicate
whether irq_data.affinity was updated.
If we are forcefully migrating an interrupt (because the affinity mask
no longer identifies any online CPUs) then we should update the IRQ
affinity mask to reflect the new CPU set. Failure to do so can
potentially leave /proc/irq/n/smp_affinity identifying only offline
CPUs, which may confuse userspace IRQ balancing daemons.
This patch updates migrate_one_irq to copy the affinity mask when
the interrupt chip returns IRQ_SET_MASK_OK after forcefully changing the
affinity of an interrupt.
Reported-by: Leif Lindholm <leif.lindholm@arm.com>
When performing a kexec on an SMP system, the secondary cores are stopped
by calling machine_shutdown(), which in turn issues IPIs to offline the
other CPUs. Unfortunately, this isn't enough to reboot the cores into
a new kernel (since they are just executing a cpu_relax loop somewhere
in memory) so we make use of platform_cpu_kill, part of the CPU hotplug
implementation, to place the cores somewhere safe. This function expects
to be called on the killing CPU for each core that it takes out.
This patch moves the platform_cpu_kill callback out of the IPI handler
and into smp_send_stop, therefore ensuring that it executes on the
killing CPU rather than on the victim, matching what the hotplug code
requires.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
TPIDRURW is a user read/write register forming part of the group of
thread registers in more recent versions of the ARM architecture (~v6+).
Currently, the kernel does not touch this register, which allows tasks
to communicate covertly by reading and writing to the register without
context-switching affecting its contents.
This patch clears TPIDRURW when TPIDRURO is updated via the set_tls
macro, which is called directly from __switch_to. Since the current
behaviour makes the register useless to userspace as far as thread
pointers are concerned, simply clearing the register (rather than saving
and restoring it) will not cause any problems to userspace.
WARNING: vmlinux.o(.text+0x111b8): Section mismatch in reference
from the function arm_memory_present() to the function
.init.text:memory_present()
The function arm_memory_present() references
the function __init memory_present().
This is often because arm_memory_present lacks a __init
annotation or the annotation of memory_present is wrong.
WARNING: arch/arm/mm/built-in.o(.text+0x1edc): Section mismatch
in reference from the function alloc_init_pud() to the function
.init.text:alloc_init_section()
The function alloc_init_pud() references
the function __init alloc_init_section().
This is often because alloc_init_pud lacks a __init
annotation or the annotation of alloc_init_section is wrong.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
* 'v3.4-samsung-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
* 'fixes' of git://github.com/hzhuang1/linux:
Pins configured as input and have MFP_LPM_DRIVE_* flag set, can have a
wrong output value for some period of time (spike) during the suspend
sequence.
This can happen because the direction of the pins (GPDR) is set by
software and the output level is set by hardware (PGSR) at a later
stage.
Fix the above potential bug by setting the output levels first.
Also save the actual levels of the pins before the suspend and restore
them after the resume, but before the direction settings take place, so
the same bug as described above will not happen in the resume sequence.
Reported-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Paul Parsons <lost.distance@yahoo.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Pins that have MFP_LPM_KEEP_OUTPUT set and are configured for output
must retain the output state in low power mode.
Currently, the pin direction configuration is overrided with values
in gpdr_lpm[] array and do not obey the MFP_LPM_KEEP_OUTPUT setting.
Fix the above bug and add some documentation to clarify the
MFP_LPM_KEEP_OUTPUT setting purpose.
DEFINE_RES_MEM() takes the size of resource as a second argument,
not the end address. Passing end address leads to following error
in runtime during device registration:
sa1100-rtc: failed to claim resource 0
Fix it.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
In 3.3, gpio wakeup setting was broken. The call
enable_irq_wake() didn't set up the PXA gpio registers
(PWER, ...) anymore.
Fix it at least for pxa27x. The driver doesn't seem to be
used in pxa25x (weird ...), and the fix doesn't extend to
pxa3xx and pxa95x (which don't have a gpio_set_wake()
available).
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Merge fixes from Andrew Morton:
"13 fixes. The acerhdf patches aren't (really) fixes. But they've
been stuck in my tree for up to two years, sent to Matthew multiple
times and the developers are unhappy."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (13 patches)
mm: fix NULL ptr dereference in move_pages
mm: fix NULL ptr dereference in migrate_pages
revert "proc: clear_refs: do not clear reserved pages"
drivers/rtc/rtc-ds1307.c: fix BUG shown with lock debugging enabled
arch/arm/mach-ux500/mbox-db5500.c: world-writable sysfs fifo file
hugetlbfs: lockdep annotate root inode properly
acerhdf: lowered default temp fanon/fanoff values
acerhdf: add support for new hardware
acerhdf: add support for Aspire 1410 BIOS v1.3314
fs/buffer.c: remove BUG() in possible but rare condition
mm: fix up the vmscan stat in vmstat
epoll: clear the tfile_check_list on -ELOOP
mm/hugetlb: fix warning in alloc_huge_page/dequeue_huge_page_vma
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into fixes
* 'u300-fixes-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
Don't allow everybody to use a modem.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm into fixes
* 'msm-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/davidb/linux-msm:
Commit 6e8201f57c935 "mmc: core: add the capability for broken voltage"
introduced a new quirk to indicate that MMC core should ignore voltage
change errors reported by the regulators core. This is required to get
SDHCI working on UniversalC210, NURI and GONI boards again after commit
ceb6143b2df81c ("mmc: sdhci: fix vmmc handling").
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Fixed following compile time error.
arch/arm/mach-exynos/common.c: In function 'exynos5_init_irq':
arch/arm/mach-exynos/common.c:539:2: error: implicit declaration of function 'of_irq_init'
arch/arm/mach-exynos/common.c:539:14: error: 'exynos4_dt_irq_match' undeclared (first use in this function)
arch/arm/mach-exynos/common.c:539:14: note: each undeclared identifier is reported only once for each function it appears in
Cc: Thomas Abraham <thomas.abraham@linaro.org>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Should be EXYNOS4_IRQ_DWMCI instead of IRQ_DWMCI,
and use DEFINE_RES_{MEM,IRQ}.
Reported-by: Jaehoon Chung <jh80.chung@samsung.com>
warning: (CPU_S3C2440 && CPU_S3C2442) selects S3C2410_PM which has unmet direct dependencies (ARCH_S3C24XX && CPU_S3C2410)
This is needed to fix mini2440_defconfig after the platform
files have been moved around.
arm-none-linux-gnueabi-ld: no machine record defined
make: *** [.tmp_vmlinux1] Error 1
As of
commit 75294957be1dee7d22dd7d90bd31334ba410e836
Author: Grant Likely <grant.likely@secretlab.ca>
Date: Tue Feb 14 14:06:57 2012 -0700
irq_domain: Remove 'new' irq_domain in favour of the ppc one
the ARM gic controller uses proper irq domains. Fix the MSM gic
initialization and DT so that it works again.
Signed-off-by: David Brown <davidb@codeaurora.org>
Using coherent DMA memory with the OMAP DMA engine results in
unpredictable behaviour due to memory ordering issues; as things stand,
there is no guarantee that data written to coherent DMA memory will be
visible to the DMA hardware.
This is because the OMAP dma_write() accessor contains no barriers,
necessary on ARMv6 and above. The effect of this can be seen in comments
in the OMAP serial driver, which incorrectly talks about cache flushing
for the coherent DMA stuff.
Rather than adding barriers to the accessors, add it in the DMA support
code just before we enable DMA, and just after we disable DMA. This
avoids having barriers for every DMA register access.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The MMCI driver will not work without two IRQs since this is not
flagged as a single-irq variant. Looking through the complex IRQ
definition for the MMCI on the versatile (including an #if 1
statement forcing MMCI IRQ0 to the VIC) this appears to the the
correct IRQ number for both models.
Cc: Niklas Hernaeus <niklas.hernaeus@linaro.org>
The ARM PCS mandates that the length and stride bits of the fpscr are
cleared on entry to and return from a public interface. Although signal
handlers run asynchronously with respect to the interrupted function,
the handler itself expects to run as though it has been called like a
normal function.
This patch updates the state mirroring the VFP hardware before entry to
a signal handler so that it adheres to the PCS. Furthermore, we disable
VFP to ensure that we trap on any floating point operation performed by
the signal handler and synchronise the hardware appropriately. A check
is inserted after the signal handler to avoid redundant flushing if VFP
was not used.
Reported-by: Peter Maydell <peter.maydell@linaro.org>
The user VFP state must be preserved (subject to ucontext modifications)
across invocation of a signal handler and this is currently handled by
vfp_{preserve,restore}_context in signal.c
Since this code requires intimate low-level knowledge of the VFP state,
this patch moves it into vfpmodule.c.
PL310 errata #588369 and #727915 require writes to the debug registers
of the cache controller to work around known problems. Writing these
registers on L220 may cause deadlock, so ensure that we only perform
this operation when we identify a PL310 at probe time.
The workaround for PL310 erratum #753970 can lead to deadlock on systems
with an L220 cache controller.
This patch makes the workaround effective only when the cache controller
is identified as a PL310 at probe time.
Erratum #326103 ("FSR write bit incorrect on a SWP to read-only memory")
only affects the ARM 1136 core prior to r1p0. The workaround
disassembles the faulting instruction to determine whether it was a read
or write access on all v6 cores.
An issue has been reported on the ARM 11MPCore whereby loading the
faulting instruction may happen in parallel with that page being
unmapped, resulting in a deadlock due to the lack of TLB broadcasting
in hardware:
http://lists.infradead.org/pipermail/linux-arm-kernel/2012-March/091561.html
This patch limits the workaround so that it is only used on affected
cores, which are known to be UP only. Other v6 cores can rely on the
FSR to indicate the access type correctly.
Pull ARM fixes from Russell King:
"Here's my usual Sunday push, just for one revert which PeterZ hollered
about after last weeks push. Other than that, all seems strangely
quiet as far as fixes go in non-platform ARM land at the moment."
Revert "ARM: 7359/2: smp_twd: Only wait for reprogramming on active cpus"
Pull "ARM: SoC fixes" from Olof Johansson:
* at91, ux500, imx, omap and bcmring:
- at91 fixes for =m driver build issues, irqdomain fixes and config
dependency fixes
- ux500 kconfig dependency fixes and a smp wakeup bugfix
- imx idle bugfix and build fix due to irq domain changes
- omap uart pinmux fixes, softreset regression revert and misc fixes
- bcmring build error regression fix
* ux500 and imx had some small defconfig updates in this branch
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (27 commits)
ARM: bcmring: fix UART declarations
ARM: imx: Fix imx5 idle logic bug
ARM: imx27-dt: Fix build due to removal of irq_domain_add_simple()
ARM: imx_v4_v5_defconfig: Add support for CONFIG_REGULATOR_FIXED_VOLTAGE
ARM: OMAP1: DMTIMER: fix broken timer clock source selection
ARM: OMAP: serial: Fix the ocp smart idlemode handling bug
ARM: OMAP2+: UART: Fix incorrect population of default uart pads
ARM: OMAP: sram: fix BUG in dpll code for !PM case
dmaengine: Kconfig: fix Atmel at_hdmac entry
USB: gadget/at91_udc: add gpio_to_irq() function to vbus interrupt
USB: ohci-at91: change annotations for probe/remove functions
leds-atmel-pwm.c: Make pwmled_probe() __devinit
ARM: at91: fix at91sam9261ek Ethernet dm9000 irq
ARM: at91: fix rm9200ek flash size
ARM: at91: remove empty at91_init_serial function
ARM: at91: fix typo in at91_pmc_base assembly declaration
ARM: at91: Export at91_matrix_base
ARM: at91: Export at91_pmc_base
ARM: at91: Export at91_ramc_base
ARM: at91: Export at91_st_base
Use the of_irq_init() call to setup the gic which also properly
registers the gic device node pointer with gic irq domain,
without which all interrupt specifier translations for gic fail.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
With the addition of platform specific driver data in the sdhci driver
for EXYNOS4 and EXYNOS5, the device name of sdhci controllers on EXYNOS4
and EXYNOS5 are changed accordingly.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
[kgene.kim@samsung.com: re-worked on top of v3.4-rc2]
Since the VIC was converted to use generic IRQ domains IRQ 0
is silently ignored. This IRQ is used on the U300 so we're
missing it now. Bump all IRQ numbers by one since they are
now decoupled from the hardware IRQ numbers.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
It doesn't make sense to grant permission to change the status of a
regulator that is also set as always on and similarly it doesn't make
sense to allow a driver to change the voltage of a regulator which can
only be set to a single voltage.
This reverts commit 9f85550347f51c79a917b2aec04c90691c11e20a.
Peter Zijlstra says:
| Argh, how did that ever make it upstream, please drop.
| Russell, please make that go away upstream.
| Like I said, this is both completely the wrong way to solve, and you're
| so not paying attention, see:
| 5fbd036b552f633abb394a319f7c62a5c86a9cd7
| 2baab4e90495ebc9826c93f79d74d6e60a828d24
| e3831edd59edf57ca11fc289f08961b20baf5146
| What's even worse:
| git describe --contains 9f85550347f51c79a917b2aec04c90691c11e20a --match "v*"
| v3.4-rc3~1^2~3
| that nonsense got merged long after those other commits.
Linus Walleij says:
| My bad, was because the initial patch was submitted march 9th before
| these fixes were merged:
| http://marc.info/?l=linux-arm-kernel&m=133159655513844&w=2
| It was pending for a while in Russell's patch tracker and I
| rebased it to -rc2 without paying enough attention to recent
| related scheduler fixes ... lesson learned.
Here is another fixes series for AT91 designed for 3.4-rc.
We experienced some issues while compiling some drivers as modules: Joachim has
corrected several of them. We may reduce this number of exported values by
reworking some drivers, in the future.
Some drivers are also modified here, I would like to keep them in the series
as the modifications are really related with our recent move to irqdomains or
simply related with compiler annotations.
I keep dmaengine Kconfig modification in this "fixes" series. The DMA
driver will not be available for 9x5 SoC family otherwise.
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
* 'fixes-for-arm-soc-20120416' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
ARM: ux500: update defconfig
ARM: ux500: Fix unmet direct dependency
ARM: ux500: wake secondary cpu via resched
into fixes
ARM i.MX misc fixes for -rc
* tag 'v3.4-rc3-imx-fixes' of git://git.pengutronix.de/git/imx/linux-2.6:
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Fix regression for bad uart muxing and oops when PM is not set.
Revert one softreset regression and few other minor fixes.
* tag 'omap-fixes-for-v3.4-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2/3: VENC hwmods: Remove OCPIF_SWSUP_IDLE flag from VENC slave interface
ARM: OMAP2+: hwmod: Revert "ARM: OMAP2+: hwmod: Make omap_hwmod_softreset wait for reset status"
ARM: OMAP2+: hwmod: add softreset delay field and OMAP4 data
ARM: OMAP1: mux: add missing include
This error appeared in the bcmring_defconfig build:
CC arch/arm/mach-bcmring/core.o
arch/arm/mach-bcmring/core.c:55: error: macro "AMBA_APB_DEVICE" requires 6 arguments, but only 5 given
arch/arm/mach-bcmring/core.c:55: warning: type defaults to 'int' in declaration of 'AMBA_APB_DEVICE'
arch/arm/mach-bcmring/core.c:56: error: macro "AMBA_APB_DEVICE" requires 6 arguments, but only 5 given
arch/arm/mach-bcmring/core.c:56: warning: type defaults to 'int' in declaration of 'AMBA_APB_DEVICE'
arch/arm/mach-bcmring/core.c:134: error: 'uartA_device' undeclared here (not in a function)
arch/arm/mach-bcmring/core.c:135: error: 'uartB_device' undeclared here (not in a function)
make[2]: *** [arch/arm/mach-bcmring/core.o] Error 1
It appeared as of commit 8ede1ae65e61282cddba39bde4142be3885a6f5a
"ARM: amba: bcmring: use common amba device initializers"
Note that in include/linux/amba/bus.h we have:
#define AMBA_APB_DEVICE(name, busid, id, base, irqs, data) ...
There is an a --> A case error in the busid and a missing zero
placeholder for the id field.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
[olof: reworded patch subject]
The imx5_idle() check of the tzic_eanble_wake() return value uses
incorrect (inverted) logic causing all attempt to idle to fail.
Signed-off-by: Robert Lee <rob.lee@linaro.org>
commit 6b783f7c (irq_domain: Remove irq_domain_add_simple()
replaced irq_domain_add_simple with irq_domain_add_legacy()
Implement this conversion so that imx27-dt can be built again.
Reported-by: Chris Ball <cjb@laptop.org>
