Signed-off-by: Ed Nash <ed@kidlearn.com>
Signed-off-by: Russell Robinson Jr <rrobinson@phytec.com>
note: there are still intermittent detection errors with USB0
ehci changes are currently only used with phyCORE-Vybrid (pcm052)
manually integrate from the CAAM part by Jason
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
From Singh Pradip-B09147. Integrate by Jason Jin
Signed-off-by: Alison Wang <b18965@freescale.com>
Add platform support for ADC driver.
Signed-off-by: Wang Xiaojun <b41435@freescale.com>
Handle usb suspend/resume, currently the BSP doesn't
support usb plug/unplug wakeup.
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Fix layers blending and reinitialization issue for DCU driver.
Update power management part for DCU driver.
System could run into STOP and LPRun modes. When system was working in STOP mode,
pressing SW1 button or inserting or removing SD card could wake up it.
Add platform support for Vybrid L2 switch driver.
Add second FEC support for Vybrid.
Add platform support for watchdog driver.
Add hardware flow control support,
Add transmit DMA support,
Add FIFO operation support,
Add MSB/LSB on data support,
Add 9-bits MARK/SPACE support.
Add platform support for Quad SPI driver.
Xiaochun Li <b41219@freescale.com>
Add platform support for touch screen driver.
Update platform support for dspi driver after debugging on board.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
Four LEDS are connected to FTM0 ch0~3 on TWR-MVF600 board,
the PWM signal can use control these LEDS on/off or demo.
The FlexTimer work on PWM mode with EPWM and CPWM supported.
The API configures each FTM channels the same due to pwm subsystem
interface restriction.
This patch enable the ADMA2 function for the SDHC module used
on Faraday board. Please note that the ADMA address should be 16
bytes aligned other than 4 byte in the spec.
This patch also increased the SDHC module frequency to 200MHz.
Enable the softecc in the config to make the NFC use softecc.
also include the defconfig update for:
ENGR220009:The LCD panel goes blank after a long time
This patch increase the delay time for the pll clock to lock. otherwise
the kernel will panic for the locking failure.
The PKE and PUE should be declared for the GPIO pull up, otherwise the pin
will not be pulled up for the SDHC card detect input.
Add default kernel config for Faraday.
OTG1 acts as gadget and OTG2 acts as host on TWR-MVF600 board.
Add platform support for dspi driver.
Add platform support for SAI driver.
Add platform support for dcu driver.
Add platform support for NFC driver.
Add platform support for RTC driver.
Add platform support for I2C controller.
Add platform support for edma driver.
Signed-off-by: Xiaochun Li <b41219@freescale.com>
Add platform support for esdhc driver.
Add platform support for FEC driver.
Add platform support for UART driver.
Add gpio API for MVF platform.
The MVF GPIO framwork is different with i.mx.
Add IOMUX definiation and initialization.
Add the iomux initialization support for Faraday.
Define the io pad settings for some function modules. Those
pad ctrl settings may need to adjust during the feature tuning
process.
Add MSL support for MVF platform.
This patch adds processor info for ARM Ltd. Cortex A5,
which has SCU initialisation procedure identical to A9.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
(cherry picked from commit 15eb169bfec291faf25b158cfa9842b72f7803ad)
The PMUv2 specification reserves a number of event encodings
for common events.
This patch adds these events to the common event enumeration
in preparation for PMUv2 cores, such as Cortex-A15.
Acked-by: Jean Pihet <j-pihet@ti.com>
(cherry picked from commit 6d4eaf991c654af54a19c0fa48e0ad62cefbc37c)
