path: root/arch/arm
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-08-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (291 commits) ARM: AMBA: Add pclk support to AMBA bus infrastructure ARM: 6278/2: fix regression in RealView after the introduction of pclk ARM: 6277/1: mach-shmobile: Allow users to select HZ, default to 128 ARM: 6276/1: mach-shmobile: remove duplicate NR_IRQS_LEGACY ARM: 6246/1: mmci: support larger MMCIDATALENGTH register ARM: 6245/1: mmci: enable hardware flow control on Ux500 variants ARM: 6244/1: mmci: add variant data and default MCICLOCK support ARM: 6243/1: mmci: pass power_mode to the translate_vdd callback ARM: 6274/1: add global control registers definition header file for nuc900 mx2_camera: fix type of dma buffer virtual address pointer mx2_camera: Add soc_camera support for i.MX25/i.MX27 arm/imx/gpio: add spinlock protection ARM: Add support for the LPC32XX arch ARM: LPC32XX: Arch config menu supoport and makefiles ARM: LPC32XX: Phytec 3250 platform support ARM: LPC32XX: Misc support functions ARM: LPC32XX: Serial support code ARM: LPC32XX: System suspend support ARM: LPC32XX: GPIO, timer, and IRQ drivers ARM: LPC32XX: Clock driver ...
2010-07-31Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/kernel/setup.c arch/arm/mm/init.c
2010-07-31Merge branch 'misc' into develRussell King
Conflicts: arch/arm/mm/init.c
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
2010-07-31Merge branch 'shmobile' into develRussell King
2010-07-31ARM: 6278/2: fix regression in RealView after the introduction of pclkLinus Walleij
The patch to add the apb_pclk to the AMBA/PrimeCell bus broke RealView, since the clockdevice is not registered at probe() time. This moves clock initialization to a core_initcall() [rmk:moved before the problematical commit to avoid bisect problems] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: cyber2000fb: fix console in truecolor modes cyber2000fb: fix machine hang on module load SA1111: Eliminate use after free ARM: Fix Versatile/Realview/VExpress MMC card detection sense ARM: 6279/1: highmem: fix SMP preemption bug in kmap_high_l1_vipt ARM: Add barriers to io{read,write}{8,16,32} accessors as well ARM: 6273/1: Add barriers to the I/O accessors if ARM_DMA_MEM_BUFFERABLE ARM: 6272/1: Convert L2x0 to use the IO relaxed operations ARM: 6271/1: Introduce *_relaxed() I/O accessors ARM: 6275/1: ux500: don't use writeb() in uncompress.h ARM: 6270/1: clean files in arch/arm/boot/compressed/ ARM: Fix csum_partial_copy_from_user()
2010-07-30SA1111: Eliminate use after freeJulia Lawall
__sa1111_remove always frees its argument, so the subsequent reference to sachip->saved_state represents a use after free. __sa1111_remove does not appear to use the saved_state field, so the patch simply frees it first. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E2; @@ __sa1111_remove(E) ... ( E = E2 | * E ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30ARM: Fix Versatile/Realview/VExpress MMC card detection senseRussell King
The MMC card detection sense has become really confused with negations at various levels, leading to some platforms not detecting inserted cards. Fix this by converting everything to positive logic throughout, thereby getting rid of these negations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30ARM: 6279/1: highmem: fix SMP preemption bug in kmap_high_l1_viptGary King
smp_processor_id() must not be called from a preemptible context (this is checked by CONFIG_DEBUG_PREEMPT). kmap_high_l1_vipt() was doing so. This lead to a problem where the wrong per_cpu kmap_high_l1_vipt_depth could be incremented, causing a BUG_ON(*depth <= 0); in kunmap_high_l1_vipt(). The solution is to move the call to smp_processor_id() after the call to preempt_disable(). Originally by: Andrew Howe <ahowe@nvidia.com> Signed-off-by: Gary King <gking@nvidia.com> Acked-by: Nicolas Pitre <nico.as.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6277/1: mach-shmobile: Allow users to select HZ, default to 128Magnus Damm
Introduce SHMOBILE_TIMER_HZ for SH-Mobile. Allow users to select HZ on their system to minimize potential timer drift. Use 128 Hz as default to work well with the 32768 Hz RCLK. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6276/1: mach-shmobile: remove duplicate NR_IRQS_LEGACYMagnus Damm
NR_IRQS_LEGACY is now defined in asm/irq.h, so drop it in mach/irqs.h. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29Merge branch 'arm/booting' of git://git.pengutronix.de/git/ukl/linux-2.6 ↵Russell King
into devel-stable Conflicts: arch/arm/Kconfig
2010-07-29Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2010-07-29Merge branch 'wells/lpc32xx-arch_v2' of git://git.lpclinux.com/linux-2.6-lpc ↵Russell King
into devel-stable
2010-07-29ARM: Add barriers to io{read,write}{8,16,32} accessors as wellRussell King
The ioread/iowrite accessors also need barriers as they're used in place of readl/writel et.al. in portable drivers. Create __iormb() and __iowmb() which are conditionally defined to be barriers dependent on ARM_DMA_MEM_BUFFERABLE, and always use these macros in the accessors. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6273/1: Add barriers to the I/O accessors if ARM_DMA_MEM_BUFFERABLECatalin Marinas
When the coherent DMA buffers are mapped as Normal Non-cacheable (ARM_DMA_MEM_BUFFERABLE enabled), buffer accesses are no longer ordered with Device memory accesses causing failures in device drivers that do not use the mandatory memory barriers before starting a DMA transfer. LKML discussions led to the conclusion that such barriers have to be added to the I/O accessors: http://thread.gmane.org/gmane.linux.kernel/683509/focus=686153 http://thread.gmane.org/gmane.linux.ide/46414 http://thread.gmane.org/gmane.linux.kernel.cross-arch/5250 This patch introduces a wmb() barrier to the write*() I/O accessors to handle the situations where Normal Non-cacheable writes are still in the processor (or L2 cache controller) write buffer before a DMA transfer command is issued. For the read*() accessors, a rmb() is introduced after the I/O to avoid speculative loads where the driver polls for a DMA transfer ready bit. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6272/1: Convert L2x0 to use the IO relaxed operationsCatalin Marinas
This patch is in preparation for a subsequent patch which adds barriers to the I/O accessors. Since the mandatory barriers may do an L2 cache sync, this patch avoids a recursive call into l2x0_cache_sync() via the write*() accessors and wmb() and a call into l2x0_cache_sync() with the l2x0_lock held. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6271/1: Introduce *_relaxed() I/O accessorsCatalin Marinas
This patch introduces readl*_relaxed()/write*_relaxed() as the main I/O accessors (when __mem_pci is defined). The standard read*()/write*() macros are now based on the relaxed accessors. This patch is in preparation for a subsequent patch which adds barriers to the I/O accessors. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6275/1: ux500: don't use writeb() in uncompress.hRabin Vincent
Don't use writeb() in uncompress.h, to avoid the following build errors when the "Add barriers to the I/O accessors" series is applied. Use __raw_writeb() instead. arch/arm/boot/compressed/misc.o: In function `putc': arch/arm/mach-ux500/include/mach/uncompress.h:41: undefined reference to `outer_cache' Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6274/1: add global control registers definition header file for nuc900wanzongshun
add global control registers definition header file for nuc900 Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29ARM: 6270/1: clean files in arch/arm/boot/compressed/Magnus Damm
Update the compressed boot Makefile for ARM to remove files during clean. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied high regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH register wm8350-regulator: fix wm8350_register_regulator error handling ab3100: fix off-by-one value range checking for voltage selector
2010-07-28davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied highSekhar Nori
Per the da850/omap-l138 Beta EVM SOM schematic, the DEFDCDC2 and DEFDCDC3 lines are tied high. This leads to a 3.3V IO and 1.2V CVDD voltage. Pass the right platform data to the TPS6507x driver so it can operate on the DEFDCDC{2,3}_HIGH register to read and change voltage levels. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-28mx2_camera: Add soc_camera support for i.MX25/i.MX27Baruch Siach
This is the soc_camera support developed by Sascha Hauer for the i.MX27. Alan Carvalho de Assis modified the original driver to get it working on more recent kernels. I modified it further to add support for i.MX25. This driver has been tested on i.MX25 and i.MX27 based platforms. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-28arm/imx/gpio: add spinlock protectionBaruch Siach
The GPIO registers need protection from concurrent access for operations that are not atomic. Cc: stable@kernel.org Cc: Juergen Beisert <j.beisert@pengutronix.de> Cc: Daniel Mack <daniel@caiaq.de> Reported-by: rpkamiak@rockwellcollins.com Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-27ARM: Add support for the LPC32XX archKevin Wells
Add LPC32XX support in arch/arm/Kconfig and arch/arm/Makefile Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Arch config menu supoport and makefilesKevin Wells
2010-07-27ARM: LPC32XX: Phytec 3250 platform supportKevin Wells
Platform support file for the PHY3250 mach id Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Misc support functionsKevin Wells
Misc support functions and prototypes used in the LPC32XX arch and platforms Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Serial support codeKevin Wells
Serial port setup support code Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: System suspend supportKevin Wells
Support for system suspend and resume Signed-off-by: Kevin Wells <wellsk40@gmail.com>
2010-07-27ARM: LPC32XX: GPIO, timer, and IRQ driversKevin Wells
Common drivers for the LPC32XX used on all platforms Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Clock driverKevin Wells
Clock driver for the LPC32XX architecture Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Debug and IRQ macrosKevin Wells
Debug (printascii) and IRQ handler macros for the LPC32XX arch Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: LPC32XX: Initial arch header filesKevin Wells
Header files for the LPC32xx arch Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-07-27ARM: call machine_shutdown() from machine_halt(), etcRussell King
x86 calls machine_shutdown() from the various machine_*() calls which take the machine down ready for halting, restarting, etc, and uses this to bring the system safely to a point where those actions can be performed. Such actions are stopping the secondary CPUs. So, change the ARM implementation of these to reflect what x86 does. This solves kexec problems on ARM SMP platforms, where the secondary CPUs were left running across the kexec call. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: SMP: Always enable clock event broadcast supportRussell King
The TWD local timers are unable to wake up the CPU when it is placed into a low power mode, eg. C3. Therefore, we need to adapt things such that the TWD code can cope with this. We do this by always providing a broadcast tick function, and marking the fact that the TWD local timer will stop in low power modes. This means that when the CPU is placed into a low power mode, the core timer code marks this fact, and allows an IPI to be given to the core. Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2010-07-27ARM: Factor out common code from cpu_proc_fin()Russell King
All implementations of cpu_proc_fin() start by disabling interrupts and then flush caches. Rather than have every processors proc_fin() implementation do this, move it out into generic code - and move the cache flush past setup_mm_for_reboot() (so it can benefit from having caches still enabled.) This allows cpu_proc_fin() to become independent of the L1/L2 cache types, and eventually move the L2 cache flushing into the L2 support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6268/1: ARMv6K and ARMv7 use fault statuses 3 and 6 as Access Flag faultKirill A. Shutemov
Statuses 3 (0b00011) and 6 (0x00110) of DFSR are Access Flags faults on ARMv6K and ARMv7. Let's patch fsr_info[] at runtime if we are on ARMv7 or later. Unfortunately, we don't have runtime check for 'K' extension, so we can't check for it. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6256/1: Check arch version and modify fsr_info[] depends on it at runtimeKirill A. Shutemov
2010-07-27ARM: 6255/1: Workaround infinity loop in handling of translation faultsKirill A. Shutemov
On ARM one Linux PGD entry contains two hardware entries (see page tables layout in pgtable.h). We normally guarantee that we always fill both L1 entries. But create_mapping() doesn't follow the rule. It can create inidividual L1 entries, so here we have to call pmd_none() check in do_translation_fault() for the entry really corresponded to address, not for the first of pair. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6252/1: Use SIGBUS for unaligned access instead of SIGILLKirill A. Shutemov
POSIX specify to use signal SIGBUS with code BUS_ADRALN for invalid address alignment. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6251/1: Make SPARSE_IRQ a hidden optioneric miao
SPARSE_IRQ doesn't need to be a visible option, only those platforms supporting that will select it. Signed-off-by: Eric Miao <eric.miao@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: DMA coherent allocator: align remapped addressesRussell King
The DMA coherent remap area is used to provide an uncached mapping of memory for coherency with DMA engines. Currently, we look for any free hole which our allocation will fit in with page alignment. However, this can lead to fragmentation of the area, and allows small allocations to cross L1 entry boundaries. This is undesirable as we want to move towards allocating sections of memory. Align allocations according to the size, limiting the alignment between the page and section sizes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: use generic ioremap_page_range()Russell King
We don't need our own implementation of this, use the generic library implementation instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27Merge branch 'origin' into miscRussell King
2010-07-27ARM: 6225/1: make TCM allocation static and common for all archsLinus Walleij
This changes the TCM handling so that a fixed area is reserved at 0xfffe0000-0xfffeffff for TCM. This areas is used by XScale but XScale does not have TCM so the mechanisms are mutually exclusive. This change is needed to make TCM detection more dynamic while still being able to compile code into it, and is a must for the unified ARM goals: the current TCM allocation at different places in memory for each machine would be a nightmare if you want to compile a single image for more than one machine with TCM so it has to be nailed down in one place. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
