path: root/arch/arm
2013-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS patches (part 1) from Al Viro: "The major change in this pile is ->readdir() replacement with ->iterate(), dealing with ->f_pos races in ->readdir() instances for good. There's a lot more, but I'd prefer to split the pull request into several stages and this is the first obvious cutoff point." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (67 commits) [readdir] constify ->actor [readdir] ->readdir() is gone [readdir] convert ecryptfs [readdir] convert coda [readdir] convert ocfs2 [readdir] convert fatfs [readdir] convert xfs [readdir] convert btrfs [readdir] convert hostfs [readdir] convert afs [readdir] convert ncpfs [readdir] convert hfsplus [readdir] convert hfs [readdir] convert befs [readdir] convert cifs [readdir] convert freevxfs [readdir] convert fuse [readdir] convert hpfs reiserfs: switch reiserfs_readdir_dentry to inode reiserfs: is_privroot_deh() needs only directory inode, actually ...
2013-06-29ARM: dt: Only print warning, not WARN() on bad cpu map in device treeOlof Johansson
Due to recent changes and expecations of proper cpu bindings, there are now cases for many of the in-tree devicetrees where a WARN() will hit on boot due to badly formatted /cpus nodes. Downgrade this to a pr_warn() to be less alarmist, since it's not a new problem. Tested on Arndale, Cubox, Seaboard and Panda ES. Panda hits the WARN without this, the others do not. Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29consolidate io_remap_pfn_range definitionsAl Viro
2013-06-24ARM: 7773/1: PJ4B: Add support for errata 4742Gregory CLEMENT
This commit fixes the regression on Armada 370 (the kernal hang during boot) introduced by the commit: "ARM: 7691/1: mm: kill unused TLB_CAN_READ_FROM_L1_CACHE and use ALT_SMP instead". When coming out of either a Wait for Interrupt (WFI) or a Wait for Event (WFE) IDLE states, a specific timing sensitivity exists between the retiring WFI/WFE instructions and the newly issued subsequent instructions. This sensitivity can result in a CPU hang scenario. The workaround is to insert either a Data Synchronization Barrier (DSB) or Data Memory Barrier (DMB) command immediately after the WFI/WFE instruction. This commit was based on the work of Lior Amsalem, but heavily modified to apply the errata fix dynamically according to the processor type thanks to the suggestions of Russell King and Nicolas Pitre. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Willy Tarreau <w@1wt.eu> Cc: <stable@vger.kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-24ARM: 7772/1: Fix missing flush_kernel_dcache_page() for noMMUSimon Baatz
Commit 1bc3974 (ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_page) moved the implementation of flush_kernel_dcache_page() into mm/flush.c but did not implement it on noMMU ARM. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Acked-by: Kevin Hilman <khilman@linaro.org> Cc: <stable@vger.kernel.org> # 3.2+: 1bc3974: ARM: 7755/1 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-24ARM: 7763/1: kernel: fix __cpu_logical_map default initializationLorenzo Pieralisi
The __cpu_logical_map array is statically initialized to 0, which is a valid MPIDR value. To prevent issues with the current implementation, this patch defines an MPIDR_INVALID value, and statically initializes the __cpu_logical_map[] array to it. Entries in the arm_dt_init_cpu_maps() tmp_map array used to stash DT reg properties while parsing DT are initialized with the MPIDR_INVALID value as well for consistency. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-24ARM: 7762/1: kernel: fix arm_dt_init_cpu_maps() to skip non-cpu nodesLorenzo Pieralisi
The introduction of the cpu-map topology node in the cpus node implies that cpus node might have children that are not cpu nodes. The DT parsing code needs updating otherwise it would check for cpu nodes properties in nodes that are not required to contain them, resulting in warnings that have no bearing on bindings defined in the dts source file. Cc: <stable@vger.kernel.org> [3.8+] Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-24ARM: 7760/1: cpu_fa526_do_idle: remove WFIJonas Jensen
As it was already suggested by Russell King and Arnd Bergmann: https://lkml.org/lkml/2013/5/16/133 moxart and gemini seem to be the only platforms using CPU_FA526, and instead of pointing arm_pm_idle to an empty function from platform code, it makes sense to remove WFI code from the processor specific idle function. Applies to arm-soc/for-next (and 3.10-rc1). Changes since v1: 1. remove WFI but make sure cpu_fa526_do_idle do not fall through to cpu_fa526_dcache_clean_area Note: moxart boots and prints to UART without this patch, but input is broken. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "These are two fixes that came in this week, one for a regression we introduced in 3.10 in the GIC interrupt code, and the other one fixes a typo in newly introduced code" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: irqchip: gic: call gic_cpu_init() as well in CPU_STARTING_FROZEN case ARM: dts: Correct the base address of pinctrl_3 on Exynos5250
2013-06-19Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "The larger changes this time are - "ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_page" which fixes more data corruption problems with O_DIRECT - "ARM: 7759/1: decouple CPU offlining from reboot/shutdown" which gets us back to working shutdown/reboot on SMP platforms - "ARM: 7752/1: errata: LoUIS bit field in CLIDR register is incorrect" which fixes a shutdown regression found in v3.10 on Versatile Express platforms. The remainder are the quite small, maybe one or two line changes" * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7759/1: decouple CPU offlining from reboot/shutdown ARM: 7756/1: zImage/virt: remove hyp-stub.S during distclean ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_page ARM: 7754/1: Fix the CPU ID and the mask associated to the PJ4B ARM: 7753/1: map_init_section flushes incorrect pmd ARM: 7752/1: errata: LoUIS bit field in CLIDR register is incorrect
2013-06-17ARM: 7759/1: decouple CPU offlining from reboot/shutdownStephen Warren
Add comments to machine_shutdown()/halt()/power_off()/restart() that describe their purpose and/or requirements re: CPUs being active/not. In machine_shutdown(), replace the call to smp_send_stop() with a call to disable_nonboot_cpus(). This completely disables all but one CPU, thus satisfying the requirement that only a single CPU be active for kexec. Adjust Kconfig dependencies for this change. In machine_halt()/power_off()/restart(), call smp_send_stop() directly, rather than via machine_shutdown(); these functions don't need to completely de-activate all CPUs using hotplug, but rather just quiesce them. Remove smp_kill_cpus(), and its call from smp_send_stop(). smp_kill_cpus() was indirectly calling smp_ops.cpu_kill() without calling smp_ops.cpu_die() on the target CPUs first. At least some implementations of smp_ops had issues with this; it caused cpu_kill() to hang on Tegra, for example. Since smp_send_stop() is only used for shutdown, halt, and power-off, there is no need to attempt any kind of CPU hotplug here. Adjust Kconfig to reflect that machine_shutdown() (and hence kexec) relies upon disable_nonboot_cpus(). However, this alone doesn't guarantee that hotplug will work, or even that hotplug is implemented for a particular piece of HW that a multi-platform zImage runs on. Hence, add error-checking to machine_kexec() to determine whether it did work. Suggested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Will Deacon <will.deacon@arm.com> Tested-by: Zhangfei Gao <zhangfei.gao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-17ARM: dts: Correct the base address of pinctrl_3 on Exynos5250Padmavathi Venna
This patch corrects the base address of pinctrl_3 on Exynos5250 platform. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-17ARM: 7756/1: zImage/virt: remove hyp-stub.S during distcleanMagnus Damm
Make sure hyp-stub.S gets removed during make distclean, this left over file was introduced in commit: 424e599 ARM: zImage/virt: hyp mode entry support for the zImage loader Signed-off-by: Magnus Damm <damm@opensource.se> Acked-by: Dave Martin <dave.martin@linaro.org> Reviewed-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-17ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_pageSimon Baatz
Commit f8b63c1 made flush_kernel_dcache_page a no-op assuming that the pages it needs to handle are kernel mapped only. However, for example when doing direct I/O, pages with user space mappings may occur. Thus, continue to do lazy flushing if there are no user space mappings. Otherwise, flush the kernel cache lines directly. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Cc: <stable@vger.kernel.org> # 3.2+ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-17ARM: 7754/1: Fix the CPU ID and the mask associated to the PJ4BGregory CLEMENT
This commit fixes the ID and mask for the PJ4B which was too restrictive and didn't match the CPU of the Armada 370 SoC. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-17ARM: 7753/1: map_init_section flushes incorrect pmdPo-Yu Chuang
This bug was introduced in commit e651eab0. Some v4/v5 platforms failed to boot due to this. Signed-off-by: Po-Yu Chuang <ratbert.chuang@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-17ARM: 7752/1: errata: LoUIS bit field in CLIDR register is incorrectJon Medhurst
On Cortex-A9 before version r1p0, the LoUIS bit field of the CLIDR register returns zero when it should return one. This leads to cache maintenance operations which rely on this value to not function as intended, causing data corruption. The workaround for this errata is to detect affected CPUs and correct the LoUIS value read. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: stable@vger.kernel.org Signed-off-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-15Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "These are a little later than I planned on since I got caught up with handling merges for 3.11 most of the week. Another week, another batch of fixes for arm-soc platforms. Again, nothing controversial. A few more than would be ideal, but all are valid fixes. In particular the prima2 panic patch is critical since it fixes a problem where multiplatform kernels panic on all but prima2 hardware." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: SAMSUNG: pm: Adjust for pinctrl- and DT-enabled platforms ARM: prima2: fix incorrect panic usage arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe range ARM: Kirkwood: handle mv88f6282 cpu in __kirkwood_variant(). ARM: omap3: clock: fix wrong container_of in clock36xx.c ARM: dts: OMAP5: Fix missing PWM capability to timer nodes ARM: dts: omap4-panda|sdp: Fix mux for twl6030 IRQ pin and msecure line ARM: dts: AM33xx: Fix properties on gpmc node arm: omap2: fix AM33xx hwmod infos for UART2 ARM: OMAP3: Fix iva2_pwrdm settings for 3703
2013-06-11Merge tag 'fixes-3.10-4' of git://git.infradead.org/users/jcooper/linux into ↵Olof Johansson
fixes From Jason Cooper, mvebu fixes for v3.10 round 4: - mvebu - fix PCIe ranges property so NOR flash is visible - kirkwood - fix identification of 88f6282 so MPPs can be set correctly * tag 'fixes-3.10-4' of git://git.infradead.org/users/jcooper/linux: arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe range ARM: Kirkwood: handle mv88f6282 cpu in __kirkwood_variant(). Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: SAMSUNG: pm: Adjust for pinctrl- and DT-enabled platformsTomasz Figa
This patch makes legacy code on suspend/resume path being executed conditionally, on non-DT platforms only, to fix suspend/resume of DT-enabled systems, for which the code is inappropriate. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [olof: add #include <linux/of.h>] Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: prima2: fix incorrect panic usageHaojian Zhuang
In prima2, some functions of checking DT is registered in initcall level. If it doesn't match the compatible name of sirf, kernel will panic. It blocks the usage of multiplatform on other verndor. The error message is in below. Knic - not syncing: unable to find compatible pwrc node in dtb CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-rc3-00006-gd7f26ea-dirty #86 [<c0013adc>] (unwind_backtrace+0x0/0xf8) from [<c0011430>] (show_stack+0x10/0x1) [<c0011430>] (show_stack+0x10/0x14) from [<c026f724>] (panic+0x90/0x1e8) [<c026f724>] (panic+0x90/0x1e8) from [<c03267fc>] (sirfsoc_of_pwrc_init+0x24/0x) [<c03267fc>] (sirfsoc_of_pwrc_init+0x24/0x58) from [<c0320864>] (do_one_initcal) [<c0320864>] (do_one_initcall+0x90/0x150) from [<c0320a20>] (kernel_init_freeab) [<c0320a20>] (kernel_init_freeable+0xfc/0x1c4) from [<c026b9e8>] (kernel_init+0) [<c026b9e8>] (kernel_init+0x8/0xe4) from [<c000e158>] (ret_from_fork+0x14/0x3c) Signen-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-09Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "The biggest two fixes are fixing a compilation error with the decompressor, and a problem with our __my_cpu_offset implementation. Other changes are very trivial and small, which seems to be the way for most -rc stuff." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7747/1: pcpu: ensure __my_cpu_offset cannot be re-ordered across barrier() ARM: 7750/1: update legacy CPU ID in decompressor cache support jump table ARM: 7743/1: compressed/head.S: work around new binutils warning ARM: 7742/1: topology: export cpu_topology ARM: 7737/1: fix kernel decompressor compilation error with CONFIG_DEBUG_SEMIHOSTING
2013-06-09Merge tag 'omap-for-v3.10/fixes-v3.10-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren, a set of small fixes for omaps for the -rc cycle: - am7303 iva2 reset PM regression fix - am33xx uart2 dma channel fix - am33xx gpmc properties fix - omap44xx rtc wake-up mux fix for nirq pins - omap36xx clock divider restore fix There's also one tiny non-critical .dts fix for omap5 timer pwm properties. * tag 'omap-for-v3.10/fixes-v3.10-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: omap3: clock: fix wrong container_of in clock36xx.c ARM: dts: OMAP5: Fix missing PWM capability to timer nodes ARM: dts: omap4-panda|sdp: Fix mux for twl6030 IRQ pin and msecure line ARM: dts: AM33xx: Fix properties on gpmc node arm: omap2: fix AM33xx hwmod infos for UART2 ARM: OMAP3: Fix iva2_pwrdm settings for 3703
2013-06-08Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another week, another batch of fixes for arm-soc platforms. Nothing controversial here, a handful of fixes for regressions and/or serious problems across several of the platforms. Things are slowing down nicely on fix rates for 3.10" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: exynos: add debug_ll_io_init() call in exynos_init_io() ARM: EXYNOS: uncompress - print debug messages if DEBUG_LL is defined ARM: shmobile: sh73a0: Update CMT clockevent rating to 80 sh-pfc: r8a7779: Don't group USB OVC and PENC pins ARM: mxs: icoll: Fix interrupts gpio bank 0 ARM: imx: clk-imx6q: AXI clock select index is incorrect ARM: bcm2835: override the HW UART periphid ARM: mvebu: Fix bug in coherency fabric low level init function ARM: Kirkwood: TS219: Fix crash by double PCIe instantiation ARM: ux500: Provide supplies for AUX1, AUX2 and AUX3 ARM: ux500: Only configure wake-up reasons on ux500 based platforms ARM: dts: imx: fix clocks for cspi ARM i.MX6q: fix for ldb_di_sels
2013-06-07Merge tag 'imx-fixes-3.10-2' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes From Shawn Guo, imx fixes for 3.10, take 2: - One device tree fix for all spi node to have per clock added. The clock is needed by spi driver to calculate bit rate divisor. The spi node in the current device trees either does not have the clock or is defined as dummy clock, in which case the driver probe will fail or spi will run at a wrong bit rate. - Two imx6q clock fixes, which correct axi_sels and ldb_di_sels. * tag 'imx-fixes-3.10-2' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: imx: clk-imx6q: AXI clock select index is incorrect ARM: dts: imx: fix clocks for cspi ARM i.MX6q: fix for ldb_di_sels Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-07ARM: exynos: add debug_ll_io_init() call in exynos_init_io()Doug Anderson
If the early MMU mapping of the UART happens to get booted out of the TLB between the start of paging_init() and when we finally re-add the UART at the very end of s3c_init_cpu(), we'll get a hang at bootup if we've got early_printk enabled. Avoid this hang by calling debug_ll_io_init() early. Without this patch, you can reliably reproduce a hang when early printk is enabled by adding flush_tlb_all() at the start of exynos_init_io(). After this patch the hang goes away. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-07Merge tag 'renesas-fixes-for-v3.10' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes From Simon Horman, Renesas ARM based SoC fixes for v3.10: - Correction to USB OVC and PENC pin groupings on r8a7779 SoC. This avoids conflicts when the USB_OVCn pins are used by another function. This has been observed to be a problem in v3.10-rc1. - Update CMT clock rating for sh73a0 SoC to resolve boot failure on kzm9g-reference. This resolves a regression between v3.9 and v3.10-rc1. * tag 'renesas-fixes-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: ARM: shmobile: sh73a0: Update CMT clockevent rating to 80 sh-pfc: r8a7779: Don't group USB OVC and PENC pins Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-07ARM: EXYNOS: uncompress - print debug messages if DEBUG_LL is definedTushar Behera
Printing low-level debug messages make an assumption that the specified UART port has been preconfigured by the bootloader. Incorrectly specified UART port results in system getting stalled while printing the message "Uncompressing Linux... done, booting the kernel" This UART port number is specified through S3C_LOWLEVEL_UART_PORT. Since the UART port might different for different board, it is not possible to specify it correctly for every board that use a common defconfig file. Calling this print subroutine only when DEBUG_LL fixes the problem. By disabling DEBUG_LL in default config file, we would be able to boot multiple boards with different default UART ports. With this current approach, we miss the print "Uncompressing Linux... done, booting the kernel." when DEBUG_LL is not defined. Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-07Merge tag 'omap-fixes-b-for-3.10-rc' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.10/fixes More OMAP hwmod and clock fixes for v3.10-rc. Fixes the AM33xx UART2. Also fixes some CCF-related breakage on OMAP36xx/37xx, affecting DSS at the very least. Basic test logs for this branch are here: http://www.pwsan.com/omap/testlogs/fixes_b_v3.10-rc/20130606093449/
2013-06-07Merge branch 'dts-fixes-for-3.10' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/bcousson/linux-omap-dt into omap-for-v3.10/fixes
2013-06-06arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe rangeThomas Petazzoni
The ranges DT entry needed by the PCIe controller is defined at the SoC .dtsi level. However, some boards have a NOR flash, and to support it, they need to override the SoC-level ranges property to add an additional range. Since PCIe and NOR support came separately, some boards were not properly changed to include the PCIe range in their ranges property at the .dts level. This commit fixes those platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-06-06ARM: Kirkwood: handle mv88f6282 cpu in __kirkwood_variant().Nicolas Schichan
MPP_F6281_MASK would be previously be returned when on mv88f6282, which would disallow some valid MPP configurations. Commit 830f8b91 (arm: plat-orion: fix printing of "MPP config unavailable on this hardware") made this problem visible as an invalid MPP configuration is now correctly detected and not applied. Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Cc: <stable@vger.kernel.org> # v3.9.x Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-06-06ARM: omap3: clock: fix wrong container_of in clock36xx.cJean-Philippe Francois
omap36xx_pwrdn_clk_enable_with_hsdiv_restore expects the parent hw of the clock to be a clk_hw_omap. However, looking at cclock3xxx_data.c, all concerned clock have parent defined as clk_divider. Fix the function to use clk_divider. Tested with 3.9 on dm3730. Signed-off-by: Jean-Philippe François <jp.francois@cynove.com> Cc: NeilBrown <neilb@suse.de> Cc: Mike Turquette <mturquette@linaro.org> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-06-06arch, mm: Remove tlb_fast_mode()Peter Zijlstra
Since the introduction of preemptible mmu_gather TLB fast mode has been broken. TLB fast mode relies on there being absolutely no concurrency; it frees pages first and invalidates TLBs later. However now we can get concurrency and stuff goes *bang*. This patch removes all tlb_fast_mode() code; it was found the better option vs trying to patch the hole by entangling tlb invalidation with the scheduler. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Reported-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-05ARM: 7747/1: pcpu: ensure __my_cpu_offset cannot be re-ordered across barrier()Will Deacon
__my_cpu_offset is non-volatile, since we want its value to be cached when we access several per-cpu variables in a row with preemption disabled. This means that we rely on preempt_{en,dis}able to hazard with the operation via the barrier() macro, so that we can't end up migrating CPUs without reloading the per-cpu offset. Unfortunately, GCC doesn't treat a "memory" clobber on a non-volatile asm block as a side-effect, and will happily re-order it before other memory clobbers (including those in prempt_disable()) and cache the value. This has been observed to break the cmpxchg logic in the slub allocator, leading to livelock in kmem_cache_alloc in mainline kernels. This patch adds a dummy memory input operand to __my_cpu_offset, forcing it to be ordered with respect to the barrier() macro. Cc: <stable@vger.kernel.org> Cc: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-05ARM: 7750/1: update legacy CPU ID in decompressor cache support jump tableMarc C
The previous mask values for the legacy ARM CPU IDs were conflicting with the CPU ID assignments for late-generation CPUs (like the Qualcomm MSM/QSD or Broadcom Brahma-15 processors). This change corrects the legacy ARM CPU ID value so that the jump table can fall-through to the appropriate cache maintenance / MMU functions. Signed-off-by: Marc C <marc.ceeeee@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-05ARM: 7743/1: compressed/head.S: work around new binutils warningArnd Bergmann
In August 2012, Matthew Gretton-Dann checked a change into binutils labelled "Error on obsolete & warn on deprecated registers", apparently as part of ARMv8 support. Apparently, this was supposed to emit the message "Warning: This coprocessor register access is deprecated in ARMv8" when using certain mcr/mrc instructions and building for ARMv8. Unfortunately, the message that is actually emitted appears to be '(null)', which is less helpful in comparison. Even more unfortunately, this is biting us on every single kernel build with a new gas, because arch/arm/boot/compressed/head.S and some other files in that directory are built with -march=all since kernel commit 80cec14a8 "[ARM] Add -march=all to assembly file build in arch/arm/boot/compressed" back in v2.6.28. This patch reverts Russell's nice solution and instead marks the head.S file to be built for armv7-a, which fortunately lets us build all instructions in that file without warnings even on the broken binutils. Without this patch, building anything results in: arch/arm/boot/compressed/head.S: Assembler messages: arch/arm/boot/compressed/head.S:565: Warning: (null) arch/arm/boot/compressed/head.S:676: Warning: (null) arch/arm/boot/compressed/head.S:698: Warning: (null) arch/arm/boot/compressed/head.S:722: Warning: (null) arch/arm/boot/compressed/head.S:726: Warning: (null) arch/arm/boot/compressed/head.S:957: Warning: (null) arch/arm/boot/compressed/head.S:996: Warning: (null) arch/arm/boot/compressed/head.S:997: Warning: (null) arch/arm/boot/compressed/head.S:1027: Warning: (null) arch/arm/boot/compressed/head.S:1035: Warning: (null) arch/arm/boot/compressed/head.S:1046: Warning: (null) arch/arm/boot/compressed/head.S:1060: Warning: (null) arch/arm/boot/compressed/head.S:1092: Warning: (null) arch/arm/boot/compressed/head.S:1094: Warning: (null) arch/arm/boot/compressed/head.S:1095: Warning: (null) arch/arm/boot/compressed/head.S:1102: Warning: (null) arch/arm/boot/compressed/head.S:1134: Warning: (null) Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: stable@vger.kernel.org Cc: Matthew Gretton-Dann <matthew.gretton-dann@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-05ARM: 7742/1: topology: export cpu_topologyArnd Bergmann
The cpu_topology symbol is required by any driver using the topology interfaces, which leads to a couple of build errors: ERROR: "cpu_topology" [drivers/net/ethernet/sfc/sfc.ko] undefined! ERROR: "cpu_topology" [drivers/cpufreq/arm_big_little.ko] undefined! ERROR: "cpu_topology" [drivers/block/mtip32xx/mtip32xx.ko] undefined! The obvious solution is to export this symbol. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Cc: Nicolas Pitre <nico@linaro.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-05ARM: 7737/1: fix kernel decompressor compilation error with ↵Nicolas Pitre
CONFIG_DEBUG_SEMIHOSTING Selecting this option produces: AS arch/arm/boot/compressed/debug.o arch/arm/boot/compressed/debug.S:4:33: fatal error: mach/debug-macro.S: No such file or directory compilation terminated. make[3]: *** [arch/arm/boot/compressed/debug.o] Error 1 The semihosting support cannot be modelled into a senduart macro as it requires memory space for argument passing. So the CONFIG_DEBUG_LL_INCLUDE may not have any sensible value and the include directive should be omitted. While at it, let's add proper semihosting output support to the decompressor. Signed-off-by: Nicolas Pitre <nico@linaro.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-05Merge branch 'fixes' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm bugfixes from Gleb Natapov: "The bulk of the fixes is in MIPS KVM kernel<->userspace ABI. MIPS KVM is new for 3.10 and some problems were found with current ABI. It is better to fix them now and do not have a kernel with broken one" * 'fixes' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Fix race in apic->pending_events processing KVM: fix sil/dil/bpl/spl in the mod/rm fields KVM: Emulate multibyte NOP ARM: KVM: be more thorough when invalidating TLBs ARM: KVM: prevent NULL pointer dereferences with KVM VCPU ioctl mips/kvm: Use ENOIOCTLCMD to indicate unimplemented ioctls. mips/kvm: Fix ABI by moving manipulation of CP0 registers to KVM_{G,S}ET_ONE_REG mips/kvm: Use ARRAY_SIZE() instead of hardcoded constants in kvm_arch_vcpu_ioctl_{s,g}et_regs mips/kvm: Fix name of gpr field in struct kvm_regs. mips/kvm: Fix ABI for use of 64-bit registers. mips/kvm: Fix ABI for use of FPU.
2013-06-04ARM: shmobile: sh73a0: Update CMT clockevent rating to 80Simon Horman
Update the CMT clockevent rating from 125 to 80. This resolves a boot-failure regression for kzm9g-reference in v3.10-rc1 introduced by f7db706b132f11c79ae1d74b2382e0926cf31644 ("ARM: 7674/1: smp: Avoid dummy clockevent being preferred over real"). The patch noted above reduces the rating of dummy clockevent from 400 to 100. This patch reduces the rating of CMT so that it is once again less than that of the dummy clockevent. Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2013-06-03ARM: dts: OMAP5: Fix missing PWM capability to timer nodesSuman Anna
OMAP5 has 6 timers (GPTimers 5, 6, 8 to 11) that are capable of PWM. The PWM capability property is missing from the node definitions of couple of timers. Add ti,timer-pwm attribute for timer 5, 6, 8 and 11. Signed-off-by: Suman Anna <s-anna@ti.com> [benoit.cousson@linaro.org: Update changelog and subject to highlight the fix] Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-03ARM: dts: omap4-panda|sdp: Fix mux for twl6030 IRQ pin and msecure lineKevin Hilman
Earlier commits ensured proper muxing of pins related to proper TWL6030 behavior: see commit 265a2bc8 (ARM: OMAP3: TWL4030: ensure sys_nirq1 is mux'd and wakeup enabled) and commit 1ef43369 (ARM: OMAP4: TWL: mux sys_drm_msecure as output for PMIC). However these only fixed legacy boot and not DT boot. For DT boot, the default mux values need to be set properly in DT. Special thanks to Nishanth Menon for the review and catching some major flaws in earlier versions. Tested on OMAP4430/Panda and OMAP4460/Panda-ES. Cc: Nishanth Menon <nm@ti.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Kevin Hilman <khilman@linaro.org> Acked-by: Grygorii Strashko <grygorii.strashko@ti.com> [benoit.cousson@linaro.org: Slightly change the subject to align board name with file name] Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-03ARM: dts: AM33xx: Fix properties on gpmc nodeLars Poeschel
The gpmc driver is actually looking for "gpmc,num-cs" and "gpmc,num-waitpins" properties in DT. The binding doc also states this. Correct the properties in the dts to provide the right values for the gpmc driver. Signed-off-by: Lars Poeschel <poeschel@lemonage.de> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
2013-06-03arm: omap2: fix AM33xx hwmod infos for UART2Thomas Petazzoni
The UART2 hwmod structure is pointing to the EDMA channels of UART1, which doesn't look right. This patch fixes this by making the UART2 hwmod structure to a new structure that lists the EDMA channels to be used by the UART2. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Vaibhav Hiremath <hvaibhav@ti.com> [paul@pwsan.com: updated to apply] Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-06-03ARM: KVM: be more thorough when invalidating TLBsMarc Zyngier
The KVM/ARM MMU code doesn't take care of invalidating TLBs before freeing a {pte,pmd} table. This could cause problems if the page is reallocated and then speculated into by another CPU. Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-06-03ARM: KVM: prevent NULL pointer dereferences with KVM VCPU ioctlAndre Przywara
Some ARM KVM VCPU ioctls require the vCPU to be properly initialized with the KVM_ARM_VCPU_INIT ioctl before being used with further requests. KVM_RUN checks whether this initialization has been done, but other ioctls do not. Namely KVM_GET_REG_LIST will dereference an array with index -1 without initialization and thus leads to a kernel oops. Fix this by adding checks before executing the ioctl handlers. [ Removed superflous comment from static function - Christoffer ] Changes from v1: * moved check into a static function with a meaningful name Signed-off-by: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-06-03ARM: imx: clk-imx6q: AXI clock select index is incorrectAnson Huang
The AXI clock mux should be as below: 00: periph; 01: pll2_pfd2_396m; 10: periph; 11: pll3_pfd1_540m; Signed-off-by: Anson Huang <b20788@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-02Merge tag 'ux500-arm-soc-v3.10-fixes-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into fixes From Linus Walleij, ux500 fixes for v3.10: - A multiplatform fix making sure ux500_idle_init() is only executed on ux500. - A regulator fix making sure the MMC/SD card regulator is not disabled on boot. Signed-off-by: Olof Johansson <olof@lixom.net> * tag 'ux500-arm-soc-v3.10-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson: ARM: ux500: Provide supplies for AUX1, AUX2 and AUX3 ARM: ux500: Only configure wake-up reasons on ux500 based platforms
2013-06-02ARM: bcm2835: override the HW UART periphidJongsung Kim
Stephen Warren reported the recent commit 78506f2 (add support for extended FIFO-size of PL011-r1p5) breaks the serial port on the BCM2835 ARM SoC. A UART compatible with the ARM PL011-r1p5 should have 32-deep FIFOs. The BCM2835 UART just looks like an ARM PL011-r1p5, but has 16-deep FIFOs just like PL011-r1p4 or earlier revisions. As a workaround for this compatibility issue, this patch overrides the HW UART periphid register values with the actually compatible UART periphid 0x00241011 (r1p3 or r1p4). Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jongsung Kim <neidhard.kim@lge.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
