path: root/arch/arm
2011-03-01arm: omap: usb: Invoke usbhs core device initializationKeshava Munegowda
The usbhs intialization is invoked by all omap3 and omap4 variant board files. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01arm: omap: usb: usbhs core device initializationKeshava Munegowda
A new usbhs platform device is defined; this device will be the parent device of ehci and ohci platform devices. the usbhs_init function is defined which does the usbhs device initialization and I/O mux of ehci and ohci. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01usb: host: omap: common usb host core driverKeshava Munegowda
enabling and disabling the common clocks for ehci and ohci is implemented. usbhs is a common parent platform driver for EHCI and OHCI driver. This driver receives the clock enable and disable requests from ehci and ohci drivers.The UHH and TLL initialization is also performed. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01arm: omap: usb: create common enums and structures for ehci and ohciKeshava Munegowda
Create the ehci and ohci specific platform data structures. The port enum values are made common for both ehci and ohci. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01arm: omap2: usb: rename usb-ehci.c to usb-host.cFelipe Balbi
We already have both EHCI and OHCI there, so let's rename to be sure everybody will understand the entire USB HOST functionality is setup on this file. Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01arm: omap: usb: host: add names to resourcesFelipe Balbi
add names to EHCI and OHCI resources. That will help us identify the resource correctly when moving to a setup where OHCI and EHCI play well together. Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01usb: musb: OMAP4430: Power down the PHY during board initHema HK
Powerdown the internal PHY during board init for OMAP44xx. So that when musb is disabled core transition to retention/off is not blocked. Signed-off-by: Hema HK <hemahk@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-03-01usb: otg: OMAP4430: Save/restore the contextHema HK
Add the context save/restore for the control module register used for OMAP4430 musb with UTMI embedded PHY interface. Signed-off-by: Hema HK <hemahk@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-18usb: otg: OMAP4430: Introducing suspend function for power managementHema HK
Introduced the suspend/resume function for the OMAP4430 internal PHY. This will be used by the twl6030-usb transceiver driver. Moved the clock enable/disable function calls and power on/off of the PHY code from power on/off functions to suspend/resume function. Pass the suspend function through board data for OMAP4430sdp and OMAP4panda. This will be used by the twl6030-usb transceiver driver. Signed-off-by: Hema HK <hemahk@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-15Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix text_poke_smp_batch() deadlock perf tools: Fix thread_map event synthesizing in top and record watchdog, nmi: Lower the severity of error messages ARM: oprofile: Fix backtraces in timer mode oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
2011-02-15Merge branch 'urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
2011-02-14Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6657/1: hw_breakpoint: fix ptrace breakpoint advertising on unsupported arch ARM: 6656/1: hw_breakpoint: avoid UNPREDICTABLE behaviour when reading DBGDSCR ARM: 6658/1: collie: do actually pass locomo_info to locomo driver ARM: 6659/1: Thumb-2: Make CONFIG_OABI_COMPAT depend on !CONFIG_THUMB2_KERNEL ARM: 6654/1: perf/oprofile: fix off-by-one in stack check ARM: fixup SMP alternatives in modules ARM: make SWP emulation explicit on !CPU_USE_DOMAINS ARM: Avoid building unsafe kernels on OMAP2 and MX3 ARM: pxa: Properly configure PWM period for palm27x ARM: pxa: only save/restore registers when pm functions are defined ARM: pxa/colibri: use correct SD detect pin ARM: pxa: fix mfpr_sync to read from valid offset
2011-02-11Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
2011-02-11ARM: 6657/1: hw_breakpoint: fix ptrace breakpoint advertising on unsupported ↵Will Deacon
arch The ptrace debug information register was advertising breakpoint and watchpoint resources for unsupported debug architectures. This meant that setting breakpoints on these architectures would appear to succeed, although they would never fire in reality. This patch fixes the breakpoint slot probing so that it returns 0 when running on an unsupported debug architecture. Reported-by: Ulrich Weigand <ulrich.weigand@de.ibm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11ARM: 6656/1: hw_breakpoint: avoid UNPREDICTABLE behaviour when reading DBGDSCRWill Deacon
Reading baseline CP14 registers, other than DBGDIDR, when the OS Lock is set leads to UNPREDICTABLE behaviour. This patch ensures that we clear the OS lock before accessing anything other than the DBGDIDR, thereby avoiding this behaviour. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11ARM: 6658/1: collie: do actually pass locomo_info to locomo driverDmitry Eremin-Solenikov
locomo_info isn't actually used as a platform_data on collie platform: arm/mach-sa1100/collie.c:237: warning: ‘locomo_info’ defined but not used So locomo driver doesn't setup IRQs correctly. Pass locomo_info to the driver. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11ARM: 6659/1: Thumb-2: Make CONFIG_OABI_COMPAT depend on !CONFIG_THUMB2_KERNELDave Martin
rmk says: "You might as well make OABI_COMPAT depend on !THUMB2_KERNEL. OABI userland is useless without FPA support." nwfpe doesn't work with Thumb-2 anyway and will probably never get ported, so I can't argue with that. This patch implements the dependency change. Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11ARM: SAMSUNG: Ensure struct sys_device is declared in plat/pm.hMark Brown
Previously we were relying on it being pulled in by other headers for the prototype of s3c24xx_irq_suspend() and s3c24xx_irq_resume(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-11ARM: S5PV310: Cleanup System MMUKukjin Kim
This patch cleans following up. - Moved definition of System MMU IPNUM into mach/sysmmu.h - Removed useless SYSMMU_DEBUG configuration - Removed useless header file plat/sysmmu.h Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-11ARM: S5PV310: Add support System MMU on SMDKV310Thomas Abraham
The 's5pv310_device_sysmmu' is used on SMDKV310. But since it is not compiled now, there is a build error. To fix this compilation error, S5PV310_DEV_SYSMMU needs to be selected for SMDKV310 board. This patch enables System MMU support on SMDKV310. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> [kgene.kim@samsung.com: Adding description] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-02-10ARM: 6654/1: perf/oprofile: fix off-by-one in stack checkRabin Vincent
Since tail is the previous fp - 1, we need to compare the new fp with tail + 1 to ensure that we don't end up passing in the same tail again, in order to avoid a potential infinite loop in the perf interrupt handler (which has been observed to occur). A similar fix seems to be needed in the OProfile code. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-10ARM: fixup SMP alternatives in modulesRussell King
With certain configurations, we inline the unlock functions in modules, which results in SMP alternatives being created in modules. We need to fix those up when loading a module to prevent undefined instruction faults. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-10ARM: make SWP emulation explicit on !CPU_USE_DOMAINSRussell King
SWP emulation requires that CPU domain support is disabled in order to work safely. Make that explicit in the kernel configuration to prevent illegal configurations being generated. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-09ARM: Avoid building unsafe kernels on OMAP2 and MX3Russell King
OMAP2 (armv6) and MX3 turn off support for the V6K instructions, which when they include support for SMP kernels means that the resulting kernel is unsafe on SMP and can result in corrupted filesystems as we end up using unsafe bitops. Re-enable the use of V6K instructions on such kernels, and let such kernels running on V6 CPUs eat undefined instruction faults which will be much safer than filesystem corruption. Next merge window we can fix this properly (as it requires a much bigger set of changes.) Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-09ARM: pxa: Properly configure PWM period for palm27xMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-09ARM: pxa: only save/restore registers when pm functions are definedEric Miao
Reported-and-tested-by: Sven Neumann <s.neumann@raumfeld.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-09ARM: pxa/colibri: use correct SD detect pinBjørn Forsman
The use of wrong SD detect pin was introduced by this commit: ARM: pxa: Push Colibri evalboard MFP into module files This fixes it. Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-09ARM: pxa: fix mfpr_sync to read from valid offsetYu Tang
Since mfpr_mmio_base[0] is not always valid on later SoCs, fixed mpfr_sync() to read back from valid mfp offset always. Signed-off-by: Yu Tang <ytang5@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-02-07Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ALSA: AACI: allow writes to MAINCR to take effect ARM: Update mach-types ARM: 6652/1: ep93xx: correct the end address of the AC97 memory resource ARM: mxs/imx28: remove now unused clock lookup "fec.0" ARM: mxs: fix clock base address missing ARM: mxs: acknowledge gpio irq ARM: mach-imx/mach-mx25_3ds: Fix section type ARM: imx: Add VPR200 and MX51_3DS entries to uncompress.h ARM i.MX23: use correct register for setting the rate ARM i.MX23/28: remove secondary field from struct clk. It's unused ARM i.MX28: use correct register for setting the rate ARM i.MX28: fix bit operation
2011-02-07Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: arm: omap4: panda: remove usb_nop_xceiv_register(v1) OMAP1: Fix non-working LCD on OMAP310 OMAP3: Devkit8000: Change lcd power pin omap1: remove duplicated #include arm: mach-omap2: mux: free allocated memory on error exit arm: mach-omap2: board-rm680: fix rm680_vemmc regulator constraints OMAP: PM: SmartReflex: Fix possible null pointer read access OMAP: PM: SmartReflex: Fix possible memory leak arm: mach-omap2: voltage: debugfs: fix memory leak OMAP3: PM: fix save secure RAM to restore MPU power state OMAP: PM: SmartReflex: Add missing IS_ERR test
2011-02-07Merge branch 'fixes'Russell King
2011-02-07Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into fixesRussell King
2011-02-07ARM: Update mach-typesRussell King
2011-02-06arm/ixp4xx: Rename FREQ macro to avoid collisionsBen Hutchings
FREQ is a ridiculously short name for a platform-specific macro in a generic header, and it now conflicts with an enumeration in the gspca/ov519 driver. Also delete conditional reference to ixp4xx_get_board_tick_rate() which is not defined anywhere. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2011-02-06IXP4xx: Fix qmgr_release_queue() flushing unexpected queue entries.Krzysztof Hałasa
Queues should be empty when released, if not, there is a safety valve. Make sure the queue is usable after it triggers. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2011-02-05ARM: 6652/1: ep93xx: correct the end address of the AC97 memory resourceMika Westerberg
The last register is at offset 0xa8 making the resource end to be 0xac - 1 instead of 0xb0 - 1. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-02arm: omap4: panda: remove usb_nop_xceiv_register(v1)Ming Lei
Panda uses both twl6030 otg phy(vbus, id) and internal phy(data lines, DP/DM), so removes usb_nop_xceiv_register to make twl6030 otg driver working since current otg code only supports one global transceiver. Otherwise, musb doesn't work without the remove. Reviewd-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-02OMAP1: Fix non-working LCD on OMAP310Marek Vasut
This patch fixes bug introduced in revision: f8e9e98454606e43b728269de21db349f57861c7 omap1: DMA: move LCD related code from plat-omap to mach-omap1 The code introduced by this patch didn't consider any other CPUs but OMAP1510, which rendered OMAP310 -- which has the same LCD controller -- non-working. Use cpu_is_omap15xx() instead of cpu_is_omap1510() to squash this issue. Bug found on Palm Zire 71 hardware. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-01OMAP3: Devkit8000: Change lcd power pinThomas Weber
This patch fixes a wrongly used lcd enable pin. The Devkit8000 uses twl4030_ledA configured as output gpio only for the lcd enable line. twl4030_gpio.1 is used through the generic gpio functions while ledA is used via low level twl4030 calls. This patch removes the low level calls and use the generic gpio functions for initialization and use of ledA. This patch also fixes a bug where the lcd would not power down when blanking. Further this patch fixes an indentation issue. The comment line uses eight whitespace and is replaced with a hard tab. gpio_request + gpio_direction_output are replaced with gpio_request_one. The return value of gpio_request_one is used to set the value of the gpio to -EINVAL when unsuccessful, so that gpio_is_valid can detect the unsuccessful request. But already successful requested gpios are not freed. Reported-by: Daniel Morsing <daniel.morsing@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-01omap1: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/arm/mach-omap1/time.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-01arm: mach-omap2: mux: free allocated memory on error exitAaro Koskinen
Free allocated memory on error exit. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-01arm: mach-omap2: board-rm680: fix rm680_vemmc regulator constraintsAaro Koskinen
With the commit 757902513019e6ee469791ff76f954b19ca8d036 (regulator: Factor out voltage set operation into a separate function) fixed voltage regulator setup will fail if there are voltage constraints defined. This made MMC unusable on this board. Fix by just deleting those redundant constraints. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Reviewed-by: Jarkko Nikula <jhnikula@gmail.com> [tony@atomide.com: updated comments] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-01ARM: mxs/imx28: remove now unused clock lookup "fec.0"Uwe Kleine-König
Commit b2878fa (ARM: mx28: update clock and device name for dual fec support) added only the new lookups without removing the old one. Cc: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-02-01ARM: mxs: fix clock base address missingShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-02-01Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: smp_on_up: allow non-ARM SMP processors ARM: io: ensure inb/outb() et.al. are properly ordered on ARMv6+ ARM: initrd: disable initrd if passed address overlaps reserved region ARM: footbridge: fix debug macros ARM: mmci: round down the bytes transferred on error ARM: mmci: complete the transaction on error ARM: 6642/1: mmci: calculate remaining bytes at error correctly
2011-02-01Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: arch/arm/mach-omap2/dma.c: Convert IS_ERR result to PTR_ERR arm: omap2: mux: fix compile warning omap1: Simplify use of omap_irq_flags omap2+: Fix unused variable warning for omap_irq_base
2011-01-31ARM: smp_on_up: allow non-ARM SMP processorsRussell King
Allow non-ARM SMP processors to use the SMP_ON_UP feature. CPUs supporting SMP must have the new CPU ID format, so check for this first. Then check for ARM11MPCore, which fails the MPIDR check. Lastly check the MPIDR reports multiprocessing extensions and that the CPU is part of a multiprocessing system. Cc: <stable@kernel.org> Reported-and-Tested-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31Merge branch 'for_2.6.38/pm-fixes' of ↵Tony Lindgren
ssh://master.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into devel-fixes
2011-01-31OMAP: PM: SmartReflex: Fix possible null pointer read accessStefan Weil
These errors were found by cppcheck: arch/arm/mach-omap2/smartreflex.c:784: error: Possible null pointer dereference: sr_info arch/arm/mach-omap2/smartreflex.c:799: error: Possible null pointer dereference: sr_info Both conditional statements are executed when sr_info == NULL, so accessing sr_info->voltdm would fail. Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-01-31OMAP: PM: SmartReflex: Fix possible memory leakStefan Weil
sr_info was allocated and needs a kfree before returning. This error was reported by cppcheck: arch/arm/mach-omap2/smartreflex.c:837: error: Memory leak: sr_info To: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-omap@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Acked-by: Shweta Gulati <shweta.gulati@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com>
