path: root/arch/arm/vfp/entry.S
2013-05-22ARM: 7729/1: vfp: ensure VFP_arch is non-zero when VFP is not supportedWill Deacon
Commit d3f79584a8b5 ("ARM: cleanup undefined instruction entry code") improved the register scheduling when handling undefined instructions. A side effect of this is that r5 is now used as a temporary, whilst the VFP probing code relies on r5 containing a non-zero value when VFP is not supported. This patch fixes the VFP detection code so that we don't rely on the contents of r5. Without this patch, Linux dies loudly on CPUs without VFP support. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-16ARM: 7627/1: Predicate preempt logic on PREEMP_COUNT not PREEMPT aloneStephen Boyd
Patrik Kluba reports that the preempt count becomes invalid due to the preempt_enable() call being unbalanced with a preempt_disable() call in the vfp assembly routines. This happens because preempt_enable() and preempt_disable() update preempt counts under PREEMPT_COUNT=y but the vfp assembly routines do so under PREEMPT=y. In a configuration where PREEMPT=n and DEBUG_ATOMIC_SLEEP=y, PREEMPT_COUNT=y and so the preempt_enable() call in VFP_bounce() keeps subtracting from the preempt count until it goes negative. Fix this by always using PREEMPT_COUNT to decided when to update preempt counts in the ARM assembly code. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reported-by: Patrik Kluba <pkluba@dension.com> Tested-by: Patrik Kluba <pkluba@dension.com> Cc: <stable@vger.kernel.org> # 2.6.30 Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31ARM: Fix undefined instruction exception handlingRussell King
While trying to get a v3.5 kernel booted on the cubox, I noticed that VFP does not work correctly with VFP bounce handling. This is because of the confusion over 16-bit vs 32-bit instructions, and where PC is supposed to point to. The rule is that FP handlers are entered with regs->ARM_pc pointing at the _next_ instruction to be executed. However, if the exception is not handled, regs->ARM_pc points at the faulting instruction. This is easy for ARM mode, because we know that the next instruction and previous instructions are separated by four bytes. This is not true of Thumb2 though. Since all FP instructions are 32-bit in Thumb2, it makes things easy. We just need to select the appropriate adjustment. Do this by moving the adjustment out of do_undefinstr() into the assembly code, as only the assembly code knows whether it's dealing with a 32-bit or 16-bit instruction. Cc: <stable@vger.kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Add some .align statements to the .S filesCatalin Marinas
Since the Thumb-2 instructions can be 16-bit wide, data in the .text sections may not be aligned to a 32-bit word and this leads to unaligned exceptions. This patch does not affect the ARM code generation. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-04-01[ARM] 5440/1: Fix VFP state corruption due to preemption during VFP exceptionsGeorge G. Davis
We've observed that ARM VFP state can be corrupted during VFP exception handling when PREEMPT is enabled. The exact conditions are difficult to reproduce but appear to occur during VFP exception handling when a task causes a VFP exception which is handled via VFP_bounce and is then preempted by yet another task which in turn causes yet another VFP exception. Since the VFP_bounce code is not preempt safe, VFP state then becomes corrupt. In order to prevent preemption from occuring while handling a VFP exception, this patch disables preemption while handling VFP exceptions. Signed-off-by: George G. Davis <gdavis@mvista.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5227/1: Add the ENDPROC declarations to the .S filesCatalin Marinas
This declaration specifies the "function" type and size for various assembly functions, mainly needed for generating the correct branch instructions in Thumb-2. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-06-10[ARM] VFP: fix section mismatch errorRussell King
Fix a real section mismatch issue; the test code is thrown away after initialisation, but if we do not detect the VFP hardware, it is left hooked into the exception handler. Any VFP instructions which are subsequently executed risk calling the discarded exception handler. Introduce a new "null" handler which returns to the "unrecognised fault" return address. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-01-25[ARM] 4111/1: Allow VFP to work with thread migration on SMPCatalin Marinas
The current lazy saving of the VFP registers is no longer possible with thread migration on SMP. This patch implements a per-CPU vfp-state pointer and the saving of the VFP registers at every context switch. The registers restoring is still performed in a lazy way. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-23[ARM] Move enable_irq and disable_irq to assembler.hRussell King
5d25ac038a317d454a4321cba955f756400835a5 broke VFP builds due to enable_irq not being defined as an assembly macro. Move it to assembler.h so everyone can use it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move IRQ enable after coprocessor number decodeRussell King
Allow the individual coprocessor handlers to decide when to enable interrupts, rather than unconditionally enabling them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09kbuild: arm - use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted stuff from arch Makefile and rename constants.h to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
