path: root/arch/arm/plat-s5pc1xx/setup-fb-24bpp.c
2010-05-19ARM: S5PC100: Move frame buffer helpers from plat-s5pc1xx to mach-s5pc100Marek Szyprowski
Move frame buffer helpers from plat-s5pc1xx to mach-s5pc100. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-05-19ARM: SAMSUNG: move driver strength gpio configuration helper to common dirMarek Szyprowski
Driver strength parameter can be changed not only on S5PC100 but also on S5PV210/S5PC110 platforms, so move the helper functions to the common plat-samsung directory. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-12-01ARM: S5PC1xx: add platform helpers for s3c-fb devicePawel Osciak
Samsung S5PC100 has LCD-controller compatible with the one known from previous SoCs series. Add required platform setup and support code that it can be used with s3c-fb driver. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
