path: root/arch/arm/plat-s3c/dev-i2c0.c
2009-04-07i2c-s3c2410: Simplify bus frequency calculationDaniel Silverstone
The platform data for the i2c-s3c2410 driver used to allow a min, max and desired frequency for the I2C bus. This patch reduces it to simply a desired frequency ceiling and corrects all the uses of the platform data appropriately. This means, for example, that on a system with a 66MHz fclk, a request for 100KHz will achieve 65KHz which is safe and acceptable, rather than 378KHz which it would have achieved without this change. Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk> [ben-linux@fluff.org: tidy subject and description] Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2009-04-07i2c-s3c2410: sda_delay should be in ns, not clock ticksBen Dooks
The sda_delay field should be specified in ns, not in clock ticks as when using cpufreq we could be changing the bus rate. Signed-off-by: Ben Dooks <ben@simtec.co.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-15[ARM] S3C: Add i2c1 device definitionBen Dooks
Add device definition and support functions for the second i2c device (i2c1). If this is selected, the first i2c bus will become index 0 instead of index -1. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-15[ARM] S3C: Make i2c device definition common to plat-s3cBen Dooks
Make the device i2c0 common to plat-s3c and move the definitions from arch/arm/plat-s3c24xx/devs.c Signed-off-by: Ben Dooks <ben-linux@fluff.org>
