path: root/arch/arm/plat-omap/include/plat/uncompress.h
2009-11-22omap: introduce OMAP_LL_DEBUG_NONE DEBUG_LL configvikram pandita
Zoom2/Zoom3 kind of boards do not use omap uarts for console. These use external debug board for console. So these boards should not have "Uncompressing Kernel...." log put on omap uarts. By interoducing OMAP_LL_DEBUG_NONE option, unnecessary writes to omap uarts is avoided. In future, the DEBUG_LL interface will be enhanced to use external debug board. Signed-off-by: Vikram Pandita <vikram.pandita@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-19omap: headers: Create headers necessary for compile under mach-omap1 and ↵Tony Lindgren
mach-omap2 Create the headers needed for compiling under mach-omap1/include/mach and mach-omap2/include/mach. This was done with the following script: #!/bin/bash mach_files="clkdev.h gpio.h hardware.h io.h irqs.h memory.h \ smp.h system.h timex.h uncompress.h vmalloc.h" omaps="mach-omap1 mach-omap2" mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" mkdir -p $plat_dir_new git add $plat_dir_new for dir in $omaps; do mach_dir_new="arch/arm/$dir/include/mach" for header in $mach_files; do file="$mach_dir_new/$header" if [ ! -f $file ]; then echo -ne "/*\n * $file\n */\n\n#include <plat/$header>\n" > $file git add $file if [ ! -f $plat_dir_new/$header ]; then git mv $mach_dir_old/$header $plat_dir_new/$header fi fi done done Signed-off-by: Tony Lindgren <tony@atomide.com>
