path: root/arch/arm/plat-omap/include/mach/uncompress.h
2009-10-19omap: headers: Create headers necessary for compile under mach-omap1 and ↵Tony Lindgren
mach-omap2 Create the headers needed for compiling under mach-omap1/include/mach and mach-omap2/include/mach. This was done with the following script: #!/bin/bash mach_files="clkdev.h gpio.h hardware.h io.h irqs.h memory.h \ smp.h system.h timex.h uncompress.h vmalloc.h" omaps="mach-omap1 mach-omap2" mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" mkdir -p $plat_dir_new git add $plat_dir_new for dir in $omaps; do mach_dir_new="arch/arm/$dir/include/mach" for header in $mach_files; do file="$mach_dir_new/$header" if [ ! -f $file ]; then echo -ne "/*\n * $file\n */\n\n#include <plat/$header>\n" > $file git add $file if [ ! -f $plat_dir_new/$header ]; then git mv $mach_dir_old/$header $plat_dir_new/$header fi fi done done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-07OMAP850: Fix zImage bootingAlistair Buxton
This adds the OMAP850 JTAG ID to the IDs checked by OMAP uncompress.h putc. Without this putc hangs up trying to check the uarts and zImage crashes. Signed-off-by: Alistair Buxton <a.j.buxton@gmail.com>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
