path: root/arch/arm/plat-omap/include/mach/serial.h
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-09-03OMAP2/3 board-*.c files: read bootloader configuration earlierPaul Walmsley
Most board-*.c files read configuration data from the bootloader in their .init_machine() function. This needs to happen earlier, at some point before omap2_init_common_hw() is called. This is because a future patch will use the bootloader serial console port information to enable the UART clocks earlier, immediately after omap2_clk_init(). This is in turn necessary since otherwise clock tree usecounts on clocks like dpll4_m2x2_ck will be bogus, which can cause the currently-active console UART clock to be disabled during boot. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2009-08-05OMAP3: Fixed crash bug with serial + suspendTero Kristo
It was possible for an unhandled interrupt to occur if there was incoming serial traffic during wakeup from suspend. This was caused by the code in arch-arm/mach-omap2/serial.c keeping interrupt enabled all the time, but not acking its interrupts. Applies on top of PM branch. Use the PM begin/end hooks to ensure that the "serial idle" interrupts are disabled during the suspend path. Also, since begin/end hooks are now used, use the suspend_state that is passed in the begin hook instead of the enter hook as per the platform_suspend_ops docs. Signed-off-by: Tero Kristo <tero.kristo@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-28Merge branch 'omap4' into for-nextTony Lindgren
2009-05-28ARM: OMAP4: Add minimal support for omap4Santosh Shilimkar
This patch adds the support for OMAP4. The platform and machine specific headers and sources updated for OMAP4430 SDP platform. OMAP4430 is Texas Instrument's SOC based on ARM Cortex-A9 SMP architecture. It's a dual core SOC with GIC used for interrupt handling and SCU for cache coherency. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-28OMAP3: PM: UART: disable clocks when idle and off-mode supportKevin Hilman
This patch allows the UART clocks to be disabled when the OMAP UARTs are inactive, thus permitting the chip to hit retention in idle. After the expiration of an activity timer, each UART is allowed to disable its clocks so the system can enter retention. The activity timer is (re)activated on any UART interrupt, UART wake event or any IO pad wakeup. The actual disable of the UART clocks is done in the 'prepare_idle' hook called from the OMAP idle loop. While the activity timer is active, the smart-idle mode of the UART is also disabled. This is due to a "feature" of the UART module that after a UART wakeup, the smart-idle mode may be entered before the UART has communicated the interrupt, or upon TX, an idle mode may be entered before the TX FIFOs are emptied. Upon suspend, the 'prepare_suspend' hook cancels any pending activity timers and allows the clocks to be disabled immediately. In addition, upon disabling clocks the UART state is saved in case of an off-mode transition while clocks are off. Special thanks to Tero Kristo for the initial ideas and first versions of UART idle support, and to Jouni Hogander for extra testing and bugfixes. Tested on OMAP3 (Beagle, RX51, SDP, EVM) and OMAP2 (n810) Cc: Tero Kristo <tero.kristo@nokia.com> Cc: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2008-10-06ARM: OMAP2 Provide function to enable/disable uart clocksJouni Hogander
This patch adds common function to enable/disable omap2/3 uart clocks. Enabled uarts are passed by bootloader in atags and clocks for these enabled uarts are touched. Signed-off-by: Jouni Hogander <jouni.hogander@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-09-05[ARM] omap: improve is_omap_port()Russell King
Make is_omap_port() take the uart_8250_port structure so it can do whatever test it desires. Convert the test to compare the physical addresses rather than virtual addresses. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
