path: root/arch/arm/plat-mxc/include/mach/system.h
2011-05-19ARM: remove support for mxc91231Uwe Kleine-König
Since support for mxc91231 was introduced 2009 it only saw patches that were part of (mxc or arm) global cleanups. The only supported machine only had 4 devices (2x UART, sdhc, watchdog). Cc: Dmitriy Taychenachev <dimichxp@gmail.com> LAKML-Reference: 1302211482-17926-1-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-03-23ARM: mx51: Implement code to allow mx51 to enter WFIDinh Nguyen
Implement code for MX51 that allows the SoC to enter WFI when arch_idle is called. This patch is also necessary for correctly suspending the system. Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-10-19i.MX31 and i.MX35 : fix errate TLSbo65953 and ENGcm09472Eric Bénard
Without this exiting WFI can result in cache corruption. Code taken from Freescale's 2.6.27 BSP and tested on i.MX35 Signed-off-by: Eric Bénard <eric@eukrea.com>
2010-06-30ARM: mxc: remove paragraphs with old address of the FSFUwe Kleine-König
As the kernel contains a copy of the GPL anyhow just get rid of the address specification instead of fixing it. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2009-08-14MXC: add basic MXC91231 supportDmitriy Taychenachev
Signed-off-by: Dmitriy Taychenachev <dimichxp@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-27mxc: add arch_reset() functionIlya Yanok
This patch adds arch_reset() function for all mxc platforms. It also removes (unsused) arch/arm/mach-mx2/system.c file. This patch has been tested on i.MX1/27/31/35 Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
