path: root/arch/arm/oprofile/common.c
2011-02-15Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix text_poke_smp_batch() deadlock perf tools: Fix thread_map event synthesizing in top and record watchdog, nmi: Lower the severity of error messages ARM: oprofile: Fix backtraces in timer mode oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
2011-02-10ARM: 6654/1: perf/oprofile: fix off-by-one in stack checkRabin Vincent
Since tail is the previous fp - 1, we need to compare the new fp with tail + 1 to ensure that we don't end up passing in the same tail again, in order to avoid a potential infinite loop in the perf interrupt handler (which has been observed to occur). A similar fix seems to be needed in the OProfile code. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-26ARM: oprofile: Fix backtraces in timer modeAri Kauppi
Always allow backtraces when using oprofile on ARM, even if a PMU isn't present. Restores functionality originally introduced in commit 1b7b56982fdcd9d85effd76f3928cf5d6eb26155 ("oprofile: Always allow backtraces on ARM") by Richard Purdie. It is not that obvious, but there is now only one oprofile_arch_init() function. So the .backtrace callback is available also in timer mode. Implemented by removing code and using stubs for oprofile_perf_{init, exit} provided by <linux/oprofile.h>. This allows cleaning of other architecture specific implementations too. Cc: stable@kernel.org # 37.x Signed-off-by: Ari Kauppi <kauppi@papupata.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11oprofile: Abstract the perf-events backendMatt Fleming
Move the perf-events backend from arch/arm/oprofile into drivers/oprofile so that the code can be shared between architectures. This allows each architecture to maintain only a single copy of the PMU accessor functions instead of one for both perf and OProfile. It also becomes possible for other architectures to delete much of their OProfile code in favour of the common code now available in drivers/oprofile/oprofile_perf.c. Signed-off-by: Matt Fleming <matt@console-pimps.org> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11ARM: oprofile: Move non-ARM code into separate init/exitMatt Fleming
In preparation for moving the majority of this oprofile code into an architecture-neutral place separate the architecture-independent code into oprofile_perf_init() and oprofile_perf_exit(). Signed-off-by: Matt Fleming <matt@console-pimps.org> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11ARM: oprofile: Rename op_arm to oprofile_perfMatt Fleming
In preparation for moving the generic functions out of this file, give the functions more general names (e.g. remove "arm" from the names). Signed-off-by: Matt Fleming <matt@console-pimps.org> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11oprofile: Make op_name_from_perf_id() globalMatt Fleming
Make op_name_from_perf_id() global so that we have a way for each architecture to construct an oprofile name for op->cpu_type. We need to remove the argument from the function prototype so that we can hide all implementation details inside the function. Signed-off-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-10-11perf: Add helper function to return number of countersMatt Fleming
The number of counters for the registered pmu is needed in a few places so provide a helper function that returns this number. Signed-off-by: Matt Fleming <matt@console-pimps.org> Tested-by: Will Deacon <will.deacon@arm.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-08-31oprofile, arm: initialize perf_event pointers with NULLRobert Richter
The pointers must be NULL'ed to avoid double-freeing the pointers in rare cases during reinitialization. Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-08-31ARM: oprofile: fix and simplify init/exit functionsWill Deacon
Now that oprofile_arch_exit is only called when the OProfile module is unloaded, it can assume that init completed successfully and not have to worry about double frees or releasing NULL perf events. This patch ensures that oprofile_arch_init fails gracefully on ARM and simplifies the exit code based on the above. Cc: Robert Richter <robert.richter@amd.com> Cc: Matt Fleming <matt@console-pimps.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-05-17ARM: 6074/1: oprofile: convert from sysdev to platform deviceWill Deacon
This is a reworking of an original patch posted by Aaro Koskinen: oprofile does not work with PM, because sysdev_suspend() is done with interrupts disabled and oprofile needs a mutex. Implementing oprofile as a platform device solves this problem. Cc: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-17ARM: 6072/1: oprofile: use perf-events framework as backendWill Deacon
There are currently two hardware performance monitoring subsystems in the kernel for ARM: OProfile and perf-events. This creates the following problems: 1.) Duplicate PMU accessor code. Inevitable code drift may lead to bugs in one framework that are fixed in the other. 2.) Locking issues. OProfile doesn't reprogram hardware counters between profiling runs if the events to be monitored have not been changed. This means that other profiling frameworks cannot use the counters if OProfile is in use. 3.) Due to differences in the two frameworks, it may not be possible to compare the results obtained by OProfile with those obtained by perf. This patch removes the OProfile PMU driver code and replaces it with calls to perf, therefore solving the issues mentioned above. The only userspace-visible change is the lack of SCU counter support for 11MPCore. This is currently unsupported by OProfile userspace tools anyway and therefore shouldn't cause any problems. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Jamie Iles <jamie.iles@picochip.com> Cc: Jean Pihet <jpihet@mvista.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-01[ARM] 5195/1: ARMv7 Oprofile supportJean PIHET
Add Oprofile kernel support for ARMv7. Tested on OMAP3430 and OMAP3530 chipsets (Cortex-A8). Signed-off-by: Jean Pihet <jpihet@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-02[ARM] 4237/2: oprofile: Always allow backtraces on ARMRichard Purdie
Always allow backtrace when using oprofile on ARM, even if a PMU isn't present. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] oprofile: add ARM11 SMP supportRussell King
Add the glue for ARM11 SMP oprofile support, which also supports the performance monitor in the coherency unit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] oprofile: add ARM11 UP supportRussell King
Add oprofile glue for ARM11 (ARMv6) oprofile support. This connects the ARM11 core profiling support to the oprofile code for uniprocessor configurations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Use kcalloc to allocate counter_config array rather than kmallocRussell King
We need this to be zero initialised. Since this is an array, use kcalloc rather than kzalloc or kmalloc. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Oprofile: dynamically allocate counter_configRussell King
2006-03-21[ARM] Oprofile: Convert semaphore to mutexRussell King
op_arm_sem is being used as a mutex, so convert it to use real mutexes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-01[ARM] 3295/1: Fix oprofile init return valueRuss Dill
Patch from Russ Dill The oprofile init code was broken in commit c6b9da. The new logic will always return -ENODEV. This fixes oprofile_arch_init to return 0 on success, and return the return value of spec->init() if applicable. Signed-off-by: Russ Dill <Russ.Dill@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 4/4 Combine oprofile common and init codeRussell King
There is nothing special about having the init code separate from the common code, so combine the two. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 3/4 Rename common oprofile codeRussell King
The common oprofile code assumes the name "PMU" (from Intel's performance management unit). This is misleading when we start adding oprofile support for other machine types which don't use the same terminology. Call it op_arm_* instead of pmu_*. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2/4 Fix oprofile suspend/resumeRussell King
The oprofile suspend/resume was missing locking. If we failed to start oprofile on resume, we still reported that it was enabled. Instead, disable oprofile on error. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 1/4 Move oprofile driver model codeRussell King
