path: root/arch/arm/mm
2009-12-11fix broken aliasing checks for MAP_FIXED on sparc32, mips, arm and shAl Viro
We want addr - (pgoff << PAGE_SHIFT) consistently coloured... Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-05Merge branch 'devel-stable' into develRussell King
2009-12-04Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel-stable
2009-12-04Merge branch 'pending-dma-coherent' into develRussell King
2009-12-04Merge branch 'pending-misc' (early part) into develRussell King
2009-12-04ARM: I-cache: flush executable mappings in flush_cache_range()Russell King
Dirk Behme reported instability on ARM11 SMP (VIPT non-aliasing cache) caused by the dynamic linker changing protection on text pages to write GOT entries. The problem is due to an interaction between the write faulting code providing new anonymous pages which are incoherent with the I-cache due to write buffering, and the I-cache not having been invalidated. a4db94d plugs the hole with the data cache coherency. This patch provides the other half of the fix by flushing the I-cache in flush_cache_range() for VM_EXEC VMAs (which is what we have when the region is being made executable again.) This ensures that the I-cache will be up to date with the newly COW'd pages. Note: if users are writing instructions, then they still need to use the ARM sys_cacheflush API to ensure that the caches are correctly synchronized. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-04ARM: I-cache: avoid flushing in flush_cache_mm()Russell King
flush_cache_mm() is called in two cases: 1. when a process exits, just before the page tables are torn down. We can allow the stale lines to evict themselves over time without causing any harm. 2. when a process forks, and we've allocated a new ASID. The instruction cache issues are dealt with as pages are brought into the new process address space. Flushing the I-cache here is therefore unnecessary. However, we must keep the VIPT aliasing D-cache flush to ensure that any dirty cache lines are not written back after the pages have been reallocated for some other use - which would result in corruption. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-04ARM: I-cache: Add invalidation for VIVT ASID tagged cachesRussell King
2009-12-04ARM: 5794/1: Flush the D-cache during copy_user_highpage()Catalin Marinas
The I and D caches for copy-on-write pages on processors with write-allocate caches become incoherent causing problems on application relying on CoW for text pages (dynamic linker relocating symbols in a text page). This patch flushes the D-cache for such pages. Cc: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-04ARM: Remove __flush_icache_all() from __flush_dcache_page()Russell King
Both call sites for __flush_dcache_page() end up calling __flush_icache_all() themselves, so having __flush_dcache_page() do this as well is wasteful. Remove the duplicated icache flushing. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-04ARM: Move __flush_icache_all() out of flush_pfn_alias()Russell King
2009-12-04ARM: Reduce __flush_dcache_page() visibilityRussell King
2009-12-03ARM: 5845/1: l2x0: check whether l2x0 already enabledSrinidhi Kasagar
If running in non-secure mode accessing some registers of l2x0 will fault. So check if l2x0 is already enabled, if so do not access those secure registers. Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01Merge branch 'for-rmk' of git://git.marvell.com/orion into devel-stableRussell King
2009-12-01ARM: ZERO_PAGE: Avoid flush_dcache_page() for zero pageRussell King
The zero page is read-only, and has its cache state cleared during boot. No further maintanence for this page is required. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01ARM: Avoid evaluating page_address() multiple timesRussell King
page_address() is a function call rather than a macro, and so: if (page_address(page)) do_something(page_address(page)); results in two calls to this function. This is unnecessary; remove the duplication. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01ARM: Avoid duplicated implementation for VIVT cache flushingRussell King
We had two copies of the wrapper code for VIVT cache flushing - one in asm/cacheflush.h and one in arch/arm/mm/flush.c. Reduce this down to one common copy. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-01[ARM] pxa/treo: add Palm Centro 685 supportTomáš Čech
Signed-off-by: Tomáš Čech <sleep_walker@suse.cz> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-11-27ARM: Add Tauros2 L2 cache controller supportLennert Buytenhek
Support for the Tauros2 L2 cache controller as used with the PJ1 and PJ4 CPUs. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-27ARM: add base support for Marvell Dove SoCSaeed Bishara
The Marvell Dove (88AP510) is a high-performance, highly integrated, low power SoC with high-end ARM-compatible processor (known as PJ4), graphics processing unit, high-definition video decoding acceleration hardware, and a broad range of peripherals. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-11-24ARM: dma-mapping: switch ARMv7 DMA mappings to retain 'memory' attributeRussell King
On ARMv7, it is invalid to map the same physical address multiple times with different memory types. Since system RAM is already mapped as 'memory', subsequent remapping of it must retain this attribute. However, DMA memory maps it as "strongly ordered". Fix this by introducing 'pgprot_dmacoherent()' which provides the necessary page table bits for DMA mappings. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-24ARM: dma-mapping: get rid of setting/clearing the reserved page bitRussell King
It's unnecessary; x86 doesn't do it, and ALSA doesn't require it anymore. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: Factor out noMMU dma buffer allocation codeRussell King
This entirely separates the DMA coherent buffer remapping code from the allocation code, and gets rid of the duplicate copy in the !MMU section. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: clean up coherent arch dma allocationRussell King
IXP23xx added support for dma_alloc_coherent() for DMA arches with an exception in dma_alloc_coherent(). This is a subset of what goes on in __dma_alloc(), and there is no reason why dma_alloc_writecombine() should not be given the same treatment (except, maybe, that IXP23xx doesn't use it.) We can better deal with this by moving the arch_is_coherent() test inside __dma_alloc() and killing the code duplication. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: move consistent_init into CONFIG_MMU sectionRussell King
No point wrapping the contents of this function with #ifdef CONFIG_MMU when we can place it and the core_initcall() entirely within the existing conditional block. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: factor dma_free_coherent() common codeRussell King
We effectively have three implementations of dma_free_coherent() mixed up in the code; the incoherent MMU, coherent MMU and noMMU versions. The coherent MMU and noMMU versions are actually functionally identical. The incoherent MMU version is almost the same, but with the additional step of unmapping the secondary mapping. Separate out this additional step into __dma_free_remap() and simplify the resulting dma_free_coherent() code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: fix nommu dma_alloc_coherent()Russell King
The nommu version of dma_alloc_coherent was using kmalloc/kfree to manage the memory. dma_alloc_coherent() is expected to work with a granularity of a page, so this is wrong. Fix it by using the helper functions now provided. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: fix coherent arch dma_alloc_coherent()Russell King
The coherent architecture dma_alloc_coherent was using kmalloc/kfree to manage the memory. dma_alloc_coherent() is expected to work with a granularity of a page, so this is wrong. Fix it by using the helper functions now provided. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org>
2009-11-24ARM: dma-mapping: functions to allocate/free a coherent bufferRussell King
2009-11-24ARM: dma-mapping: split out vmregion code from dma coherent mapping codeRussell King
2009-11-24ARM: 5791/1: ARM: MM: use 64bytes of L1 cache on plat S5PC1xxMarek Szyprowski
Samsung S5PC1xx SoCs are based on ARM Coretex8, which has 64 bytes of L1 cache line size. Enable proper handling of L1 cache on these SoCs. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-11-20Merge branch 'next' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/xscaleiop into devel-stable
2009-11-04ARMv7: Check whether the SMP/nAMP mode was already enabledTony Thompson
If running in non-secure mode, enabling this register will fault. Signed-off-by: Tony Thompson <Anthony.Thompson@arm.com> Acked-by: Srinidhi Kasagar <srinidhikasagar@gmail.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-11-02ARM: ensure initial page tables are setup for SMP systemsRussell King
Mapping the same memory using two different attributes (memory type, shareability, cacheability) is unpredictable. During boot, we encounter a situation when we're updating the kernel's page tables which can lead to dirty cache lines existing in the cache which are subsequently missed. This causes stack corruption, and therefore a crash. Therefore, ensure that the shared and cacheability settings matches the configuration that will be used later; this together with the restriction in early_cachepolicy() ensures that we won't create a mismatch during boot. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-29ARM: Fix errata 411920 workaroundsRussell King
Errata 411920 indicates that any "invalidate entire instruction cache" operation can fail if the right conditions are present. This is not limited just to those operations in flush.c, but elsewhere. Place the workaround in the already existing __flush_icache_all() function instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-29iop: implement sched_clock()Mikael Pettersson
This adds a better sched_clock() to the IOP platform, implemented using its new clocksource support. Tested on n2100, compile-tested for all plat-iop machines. [dan.j.williams@intel.com: allow early cp6 access] Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-10-29ARM: Fix sparsemem with SPARSEMEM_EXTREME enabledRussell King
When SPARSEMEM_EXTREME is enabled, memory_present() wants to use bootmem to allocate data structures. However, we call memory_present() after declaring memory to bootmem, but before we've reserved areas. This leads to sparsemem data structures being overwritten later in the kernel's initialization (when slab initializes.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-25ARM: Use GFP_DMA only for masks _less_ than 32-bitRussell King
We were using GFP_DMA for masks other than 0xffffffff, which is wrong when some masks are initialized to 0xffffffffffffffff. This caused such masks to obtain memory from the precious DMA pool. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-21ARM: 5769/1: CPU_ARM920T: remove dead Maverick EP9312 URLHartley Sweeten
Remove the URL listed for Maverick EP9312 since it is not available and modify the help text appropriately. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-12ARM: force dcache flush if dcache_dirty bit setNitin Gupta
On ARM, update_mmu_cache() does dcache flush for a page only if it has a kernel mapping (page_mapping(page) != NULL). The correct behavior would be to force the flush based on dcache_dirty bit only. One of the cases where present logic would be a problem is when a RAM based block device[1] is used as a swap disk. In this case, we would have in-memory data corruption as shown in steps below: do_swap_page() { - Allocate a new page (if not already in swap cache) - Issue read from swap disk - Block driver issues flush_dcache_page() - flush_dcache_page() simply sets PG_dcache_dirty bit and does not actually issue a flush since this page has no user space mapping yet. - Now, if swap disk is almost full, this newly read page is removed from swap cache and corrsponding swap slot is freed. - Map this page anonymously in user space. - update_mmu_cache() - Since this page does not have kernel mapping (its not in page/swap cache and is mapped anonymously), it does not issue dcache flush even if dcache_dirty bit is set by flush_dcache_page() above. <user now gets stale data since dcache was never flushed> } Same problem exists on mips too. [1] example: - brd (RAM based block device) - ramzswap (RAM based compressed swap device) Signed-off-by: Nitin Gupta <ngupta@vflare.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-11ARM: Add kmap_atomic type debuggingRussell King
Seemingly this support was missed when highmem was added, so DEBUG_HIGHMEM wouldn't have checked the kmap_atomic type. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07ARM: 5747/1: Fix the start_pg value in free_memmap()Catalin Marinas
If sparsemem is enabled, the start_pfn passed to the free_memmap() function corresponds to an area of memory not known to the kernel and pfn_to_page returns a wrong value. The (start_pfn - 1), however, is known to the kernel. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07ARM: 5746/1: Handle possible translation errors in ARMv6/v7 coherent_user_rangeCatalin Marinas
This is needed because applications using the sys_cacheflush system call can pass a memory range which isn't mapped yet even though the corresponding vma is valid. The patch also adds unwinding annotations for correct backtraces from the coherent_user_range() functions. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-05ARM: 5742/1: ARM: add debug check for invalid kernel page faultsImre Deak
According to the following in arch/arm/mm/fault.c page faults from kernel mode are invalid if mmap_sem is already held and there is no exception handler defined for the faulting instruction: /* * As per x86, we may deadlock here. However, since the kernel only * validly references user space from well defined areas of the code, * we can bug out early if this is from code which shouldn't. */ if (!down_read_trylock(&mm->mmap_sem)) { if (!user_mode(regs) && !search_exception_tables(regs->ARM_pc)) goto no_context; Since mmap_sem can be held at arbitrary times by another thread this also means that any page faults from kernel mode are invalid if no exception handler is defined for them, regardless whether mmap_sem is held at the time of fault. To easier detect code that can trigger the above error, add a check also for the case where mmap_sem is acquired. As this has an overhead make it a VM debug check. Signed-off-by: Imre Deak <imre.deak@nokia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5728/1: Proper prefetch abort handling on ARMv6 and ARMv7Kirill A. Shutemov
Currently, on ARMv6 and ARMv7, if an application tries to execute code (or garbage) on non-executable page it hangs. It caused by incorrect prefetch abort handling. Now every prefetch abort processes as a translation fault. To fix this we have to analyze instruction fault status register to figure out reason why we've got the abort and process it accordingly. To make IFSR different from DFSR we set bit 31 which is reserved in both IFSR and DFSR. This patch also tries to protect from future hangs on unexpected exceptions. An application will be killed if unexpected exception type was received. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5740/1: fix valid_phys_addr_range() range checkGreg Ungerer
Commit 1522ac3ec95ff0230e7aa516f86b674fdf72866c ("Fix virtual to physical translation macro corner cases") breaks the end of memory check in valid_phys_addr_range(). The modified expression results in the apparent /dev/mem size being 2 bytes smaller than what it actually is. This patch reworks the expression to correctly check the address, while maintaining use of a valid address to __pa(). Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-28ARM: Don't allow highmem on SMP platforms without h/w TLB ops broadcastRussell King
We suffer an unfortunate combination of "features" which makes highmem support on platforms without hardware TLB maintainence broadcast difficult: - we need kmap_high_get() support for DMA cache coherence - this requires kmap_high() to take a spinlock with IRQs disabled - kmap_high() occasionally calls flush_all_zero_pkmaps() to clear out old mappings - flush_all_zero_pkmaps() calls flush_tlb_kernel_range(), which on s/w IPI'd systems eventually calls smp_call_function_many() - smp_call_function_many() must not be called with IRQs disabled: WARNING: at kernel/smp.c:380 smp_call_function_many+0xc4/0x240() Modules linked in: Backtrace: [<c00306f0>] (dump_backtrace+0x0/0x108) from [<c0286e6c>] (dump_stack+0x18/0x1c) r6:c007cd18 r5:c02ff228 r4:0000017c [<c0286e54>] (dump_stack+0x0/0x1c) from [<c0053e08>] (warn_slowpath_common+0x50/0x80) [<c0053db8>] (warn_slowpath_common+0x0/0x80) from [<c0053e50>] (warn_slowpath_null+0x18/0x1c) r7:00000003 r6:00000001 r5:c1ff4000 r4:c035fa34 [<c0053e38>] (warn_slowpath_null+0x0/0x1c) from [<c007cd18>] (smp_call_function_many+0xc4/0x240) [<c007cc54>] (smp_call_function_many+0x0/0x240) from [<c007cec0>] (smp_call_function+0x2c/0x38) [<c007ce94>] (smp_call_function+0x0/0x38) from [<c005980c>] (on_each_cpu+0x1c/0x38) [<c00597f0>] (on_each_cpu+0x0/0x38) from [<c0031788>] (flush_tlb_kernel_range+0x50/0x58) r6:00000001 r5:00000800 r4:c05f3590 [<c0031738>] (flush_tlb_kernel_range+0x0/0x58) from [<c009c600>] (flush_all_zero_pkmaps+0xc0/0xe8) [<c009c540>] (flush_all_zero_pkmaps+0x0/0xe8) from [<c009c6b4>] (kmap_high+0x8c/0x1e0) [<c009c628>] (kmap_high+0x0/0x1e0) from [<c00364a8>] (kmap+0x44/0x5c) [<c0036464>] (kmap+0x0/0x5c) from [<c0109dfc>] (cramfs_readpage+0x3c/0x194) [<c0109dc0>] (cramfs_readpage+0x0/0x194) from [<c0090c14>] (__do_page_cache_readahead+0x1f0/0x290) [<c0090a24>] (__do_page_cache_readahead+0x0/0x290) from [<c0090ce4>] (ra_submit+0x30/0x38) [<c0090cb4>] (ra_submit+0x0/0x38) from [<c0089384>] (filemap_fault+0x3dc/0x438) r4:c1819988 [<c0088fa8>] (filemap_fault+0x0/0x438) from [<c009d21c>] (__do_fault+0x58/0x43c) [<c009d1c4>] (__do_fault+0x0/0x43c) from [<c009e8cc>] (handle_mm_fault+0x104/0x318) [<c009e7c8>] (handle_mm_fault+0x0/0x318) from [<c0033c98>] (do_page_fault+0x188/0x1e4) [<c0033b10>] (do_page_fault+0x0/0x1e4) from [<c0033ddc>] (do_translation_fault+0x7c/0x84) [<c0033d60>] (do_translation_fault+0x0/0x84) from [<c002b474>] (do_DataAbort+0x40/0xa4) r8:c1ff5e20 r7:c0340120 r6:00000805 r5:c1ff5e54 r4:c03400d0 [<c002b434>] (do_DataAbort+0x0/0xa4) from [<c002bcac>] (__dabt_svc+0x4c/0x60) ... So we disable highmem support on these systems. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-28ARM: Fix warning: unused variable 'highmem'Russell King
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
