path: root/arch/arm/mm/proc-mohawk.S
2012-09-25ARM: mm: implement LoUIS API for cache maintenance opsLorenzo Pieralisi
ARM v7 architecture introduced the concept of cache levels and related control registers. New processors like A7 and A15 embed an L2 unified cache controller that becomes part of the cache level hierarchy. Some operations in the kernel like cpu_suspend and __cpu_disable do not require a flush of the entire cache hierarchy to DRAM but just the cache levels belonging to the Level of Unification Inner Shareable (LoUIS), which in most of ARM v7 systems correspond to L1. The current cache flushing API used in cpu_suspend and __cpu_disable, flush_cache_all(), ends up flushing the whole cache hierarchy since for v7 it cleans and invalidates all cache levels up to Level of Coherency (LoC) which cripples system performance when used in hot paths like hotplug and cpuidle. Therefore a new kernel cache maintenance API must be added to cope with latest ARM system requirements. This patch adds flush_cache_louis() to the ARM kernel cache maintenance API. This function cleans and invalidates all data cache levels up to the Level of Unification Inner Shareable (LoUIS) and invalidates the instruction cache for processors that support it (> v7). This patch also creates an alias of the cache LoUIS function to flush_kern_all for all processor versions prior to v7, so that the current cache flushing behaviour is unchanged for those processors. v7 cache maintenance code implements a cache LoUIS function that cleans and invalidates the D-cache up to LoUIS and invalidates the I-cache, according to the new API. Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Tested-by: Shawn Guo <shawn.guo@linaro.org>
2012-05-22Merge tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc power management changes from Olof Johansson: "Power management changes here are mostly for the omap platform, but also include cpuidle changes for ux500 and suspend/resume code for mmp." * tag 'pm' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits) ARM: OMAP2+: WDTIMER integration: fix !PM boot crash, disarm timer after hwmod reset ARM: OMAP2/3: hwmod data: Add 32k-sync timer data to hwmod database ARM: OMAP4: hwmod_data: Name the common irq for McBSP ports ARM: OMAP4: hwmod data: I2C: add flag for context restore ARM: OMAP3: hwmod_data: Rename the common irq for McBSP ports ARM: OMAP2xxx: hwmod data: add HDQ/1-wire hwmod ARM: OMAP3: hwmod data: add HDQ/1-wire hwmod ARM: OMAP2+: hwmod data: add HDQ/1-wire hwmod shared data ARM: OMAP2+: HDQ1W: add custom reset function ARM: OMAP2420: hwmod data: Add MMC hwmod data for 2420 arm: omap3: clockdomain data: Remove superfluous commas from gfx_sgx_3xxx_wkdeps[] ARM: OMAP2+: powerdomain: Get rid off duplicate pwrdm_clkdm_state_switch() API ARM: OMAP3: clock data: add clockdomain for HDQ functional clock ARM: OMAP3+: dpll: Configure autoidle mode only if it's supported ARM: OMAP2+: dmtimer: cleanup iclk usage ARM: OMAP4+: Add prm and cm base init function. ARM: OMAP2/3: Add idle_st bits for ST_32KSYNC timer to prcm-common header ARM: OMAP3: Fix CM register bit masks ARM: OMAP: clock: convert AM3517/3505 detection/flags to AM35xx ARM: OMAP3: clock data: treat all AM35x devices the same ...
2012-05-07ARM: mm: proc-mohawk: add suspend resume for mohawkChao Xie
When enable ARCH_SUSPEND_POSSIBLE, it need defintion of cpu_mohawk_do_suspend and cpu_mohawk_do_resume Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Haojian Zhuang <<haojian.zhuang@gmail.com>
2012-05-02ARM: 7408/1: cacheflush: return error to userspace when flushing syscall failsWill Deacon
The cacheflush syscall can fail for two reasons: (1) The arguments are invalid (nonsensical address range or no VMA) (2) The region generates a translation fault on a VIPT or PIPT cache This patch allows do_cache_op to return an error code to userspace in the case of the above. The various coherent_user_range implementations are modified to return 0 in the case of VIVT caches or -EFAULT in the case of an abort on v6/v7 cores. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-06ARM: proc-*.S: place cpu_reset functions into .idmap.text sectionWill Deacon
The CPU reset functions disable the MMU and therefore must be executed with an identity mapping in place. This patch places the CPU reset functions into the .idmap.text section, causing the idmap code to include them as part of the identity mapping. Acked-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-07-07ARM: mm: proc-mohawk: Use the new processor struct macrosDave Martin
This patch also defines a suitable flush_icache_all implementation which would otherwise be missing, resulting in a link failure. Thanks to Nicolas Pitre for suggesting the code for this. Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-02-22ARM: pm: add generic CPU suspend/resume supportRussell King
This adds core support for saving and restoring CPU coprocessor registers for suspend/resume support. This contains support for suspend with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs. Tested on Assabet and Tegra 2. Tested-by: Colin Cross <ccross@android.com> Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-08ARM: hotplug cpu: Keep processor information, startup code & ↵Russell King
__lookup_processor_type When hotplug CPU is enabled, we need to keep the list of supported CPUs, their setup functions, and __lookup_processor_type in place so that we can find and initialize secondary CPUs. Move these into the __CPUINIT section. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: Factor out common code from cpu_proc_fin()Russell King
All implementations of cpu_proc_fin() start by disabling interrupts and then flush caches. Rather than have every processors proc_fin() implementation do this, move it out into generic code - and move the cache flush past setup_mm_for_reboot() (so it can benefit from having caches still enabled.) This allows cpu_proc_fin() to become independent of the L1/L2 cache types, and eventually move the L2 cache flushing into the L2 support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: dma-mapping: remove dmac_clean_range and dmac_inv_rangeRussell King
These are now unused, and so can be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-15ARM: dma-mapping: provide per-cpu type map/unmap functionsRussell King
2009-12-14ARM: add size argument to __cpuc_flush_dcache_pageRussell King
... and rename the function since it no longer operates on just pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-23[ARM] pxa: add base support for Marvell's PXA168 processor lineEric Miao
"""The Marvell® PXA168 processor is the first in a family of application processors targeted at mass market opportunities in computing and consumer devices. It balances high computing and multimedia performance with low power consumption to support extended battery life, and includes a wealth of integrated peripherals to reduce overall BOM cost .... """ See http://www.marvell.com/featured/pxa168.jsp for more information. 1. Marvell Mohawk core is a hybrid of xscale3 and its own ARM core, there are many enhancements like instructions for flushing the whole D-cache, and so on 2. Clock reuses Russell's common clkdev, and added the basic support for UART1/2. 3. Devices are a bit different from the 'mach-pxa' way, the platform devices are now dynamically allocated only when necessary (i.e. when pxa_register_device() is called). Description for each device are stored in an array of 'struct pxa_device_desc'. Now that: a. this array of device description is marked with __initdata and can be freed up system is fully up b. which means board code has to add all needed devices early in his initializing function c. platform specific data can now be marked as __initdata since they are allocated and copied by platform_device_add_data() 4. only the basic UART1/2/3 are added, more devices will come later. Signed-off-by: Jason Chagas <chagas@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
