path: root/arch/arm/mm/proc-macros.S
2014-09-24ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] opsBartlomiej Zolnierkiewicz
Ifdef around cpu_\name\()_do_suspend and cpu_\name\()_do_resume ops in proc-macros.S should check for CONFIG_ARM_CPU_SUSPEND and not CONFIG_PM_SLEEP. Fix it. [ Please note that cpu_v7_do_[suspend,resume] code in proc-v7.S already correctly checks for CONFIG_ARM_CPU_SUSPEND, same is true for functions for other architectures. ] This fix is needed for decoupling suspend/resume and advanced cpuidle support on Exynos platform (next patch fixes build for config with CONFIG_PM_SLEEP=n and CONFIG_ARM_EXYNOS_CPUIDLE=y). If this fix is not present then the following OOPS happens on the first attempt to go into advanced cpuidle mode (AFTR): [ 22.244143] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 22.250759] pgd = c0004000 [ 22.253445] [00000000] *pgd=00000000 [ 22.257012] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM [ 22.262906] Modules linked in: [ 22.265949] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.16.0-next-20140811-dirty #730 [ 22.273757] task: c05dce68 ti: c05d2000 task.ti: c05d2000 [ 22.279139] PC is at 0x0 [ 22.281661] LR is at __cpu_suspend_save+0x4c/0xa8 [ 22.286344] pc : [<00000000>] lr : [<c00125e0>] psr: a0000093 [ 22.286344] sp : c05d3ef4 ip : c05da414 fp : 00000001 [ 22.297799] r10: c05da414 r9 : c0609cb0 r8 : 0000000f [ 22.303008] r7 : c05da444 r6 : 00000038 r5 : ea802c00 r4 : c05d3f14 [ 22.309517] r3 : 00000000 r2 : c05d3f4c r1 : 00000038 r0 : c05d3f20 [ 22.316029] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 22.323406] Control: 10c5387d Table: 69d5404a DAC: 00000015 [ 22.329135] Process swapper/0 (pid: 0, stack limit = 0xc05d2240) [ 22.335124] Stack: (0xc05d3ef4 to 0xc05d4000) [ 22.339466] 3ee0: ea802c00 00000038 c05d3f4c [ 22.347626] 3f00: 00000000 00000007 c00123bc 00000000 c001d468 6a888000 c05d3f4c 80000000 [ 22.355785] 3f20: 00000007 c003d3a0 0000193d eaf9dde4 eaf9dde4 c02ef0c8 c000969c fffffffe [ 22.363944] 3f40: 00000000 c0037b54 eaf9dbb8 e9d1a380 00000000 c001d468 c0609cb0 00000000 [ 22.372103] 3f60: c0609cb0 c061649e 00000001 c001250c eaf9dbb8 00000001 c0609cb0 c001d618 [ 22.380262] 3f80: c001d5d0 c02ef56c 2d9d2e1e 00000005 eaf9dbb8 c02edcc4 2d9d2e1e 00000005 [ 22.388421] 3fa0: c040446c c05da4ec c040446c eaf9dbb8 c05cfbb0 c004c580 c05dce68 c05b3ae8 [ 22.396580] 3fc0: 00000000 c058bb24 ffffffff ffffffff c058b5e4 00000000 00000000 c05b3ae8 [ 22.404740] 3fe0: c0616994 c05da47c c05b3ae4 c05ddeec 4000406a 40008074 00000000 00000000 [ 22.412909] [<c00125e0>] (__cpu_suspend_save) from [<c00123bc>] (__cpu_suspend+0x5c/0x70) [ 22.421074] [<c00123bc>] (__cpu_suspend) from [<c05d3f4c>] (init_thread_union+0x1f4c/0x2000) [ 22.429479] Code: bad PC value [ 22.432518] ---[ end trace fb90ebf4217d0ad9 ]--- [ 22.437116] Kernel panic - not syncing: Attempted to kill the idle task! [ 22.443800] Rebooting in 5 seconds.. This patch has been tested on Exynos4210 based Origen board. Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-02-10ARM: 7954/1: mm: remove remaining domain support from ARMv6Will Deacon
CPU_32v6 currently selects CPU_USE_DOMAINS if CPU_V6 and MMU. This is because ARM 1136 r0pX CPUs lack the v6k extensions, and therefore do not have hardware thread registers. The lack of these registers requires the kernel to update the vectors page at each context switch in order to write a new TLS pointer. This write must be done via the userspace mapping, since aliasing caches can lead to expensive flushing when using kmap. Finally, this requires the vectors page to be mapped r/w for kernel and r/o for user, which has implications for things like put_user which must trigger CoW appropriately when targetting user pages. The upshot of all this is that a v6/v7 kernel makes use of domains to segregate kernel and user memory accesses. This has the nasty side-effect of making device mappings executable, which has been observed to cause subtle bugs on recent cores (e.g. Cortex-A15 performing a speculative instruction fetch from the GIC and acking an interrupt in the process). This patch solves this problem by removing the remaining domain support from ARMv6. A new memory type is added specifically for the vectors page which allows that page (and only that page) to be mapped as user r/o, kernel r/w. All other user r/o pages are mapped also as kernel r/o. Patch co-developed with Russell King. Cc: <stable@vger.kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-06-24ARM: 7773/1: PJ4B: Add support for errata 4742Gregory CLEMENT
This commit fixes the regression on Armada 370 (the kernal hang during boot) introduced by the commit: "ARM: 7691/1: mm: kill unused TLB_CAN_READ_FROM_L1_CACHE and use ALT_SMP instead". When coming out of either a Wait for Interrupt (WFI) or a Wait for Event (WFE) IDLE states, a specific timing sensitivity exists between the retiring WFI/WFE instructions and the newly issued subsequent instructions. This sensitivity can result in a CPU hang scenario. The workaround is to insert either a Data Synchronization Barrier (DSB) or Data Memory Barrier (DMB) command immediately after the WFI/WFE instruction. This commit was based on the work of Lior Amsalem, but heavily modified to apply the errata fix dynamically according to the processor type thanks to the suggestions of Russell King and Nicolas Pitre. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Reviewed-by: Will Deacon <will.deacon@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Willy Tarreau <w@1wt.eu> Cc: <stable@vger.kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-02-16ARM: 7649/1: mm: mm->context.id fix for big-endianBen Dooks
Since the new ASID code in b5466f8728527a05a493cc4abe9e6f034a1bbaab ("ARM: mm: remove IPI broadcasting on ASID rollover") was changed to use 64bit operations it has broken the BE operation due to an issue with the MM code accessing sub-fields of mm->context.id. When running in BE mode we see the values in mm->context.id are stored with the highest value first, so the LDR in the arch/arm/mm/proc-macros.S reads the wrong part of this field. To resolve this, change the LDR in the mmid macro to load from +4. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-11-09ARM: mm: introduce present, faulting entries for PAGE_NONEWill Deacon
PROT_NONE mappings apply the page protection attributes defined by _P000 which translate to PAGE_NONE for ARM. These attributes specify an XN, RDONLY pte that is inaccessible to userspace. However, on kernels configured without support for domains, such a pte *is* accessible to the kernel and can be read via get_user, allowing tasks to read PROT_NONE pages via syscalls such as read/write over a pipe. This patch introduces a new software pte flag, L_PTE_NONE, that is set to identify faulting, present entries. Signed-off-by: Will Deacon <will.deacon@arm.com>
2012-09-25ARM: mm: implement LoUIS API for cache maintenance opsLorenzo Pieralisi
ARM v7 architecture introduced the concept of cache levels and related control registers. New processors like A7 and A15 embed an L2 unified cache controller that becomes part of the cache level hierarchy. Some operations in the kernel like cpu_suspend and __cpu_disable do not require a flush of the entire cache hierarchy to DRAM but just the cache levels belonging to the Level of Unification Inner Shareable (LoUIS), which in most of ARM v7 systems correspond to L1. The current cache flushing API used in cpu_suspend and __cpu_disable, flush_cache_all(), ends up flushing the whole cache hierarchy since for v7 it cleans and invalidates all cache levels up to Level of Coherency (LoC) which cripples system performance when used in hot paths like hotplug and cpuidle. Therefore a new kernel cache maintenance API must be added to cope with latest ARM system requirements. This patch adds flush_cache_louis() to the ARM kernel cache maintenance API. This function cleans and invalidates all data cache levels up to the Level of Unification Inner Shareable (LoUIS) and invalidates the instruction cache for processors that support it (> v7). This patch also creates an alias of the cache LoUIS function to flush_kern_all for all processor versions prior to v7, so that the current cache flushing behaviour is unchanged for those processors. v7 cache maintenance code implements a cache LoUIS function that cleans and invalidates the D-cache up to LoUIS and invalidates the I-cache, according to the new API. Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Tested-by: Shawn Guo <shawn.guo@linaro.org>
2011-12-08ARM: LPAE: MMU setup for the 3-level page table formatCatalin Marinas
This patch adds the MMU initialisation for the LPAE page table format. The swapper_pg_dir size with LPAE is 5 rather than 4 pages. A new proc-v7-3level.S file contains the TTB initialisation, context switch and PTE setting code with the LPAE. The TTBRx split is based on the PAGE_OFFSET with TTBR1 used for the kernel mappings. The 36-bit mappings (supersections) and a few other memory types in mmu.c are conditionally compiled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2011-07-21ARM: Fix build errors caused by adding generic macrosRussell King
Commit 66a625a (ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macros) introduced build errors when PM_SLEEP is not enabled. The per-CPU do_suspend/do_resume functions are defined via the preprocessor to constant 0. However, the macros which use these were converted to assembly, resulting in undefined references to these functions. Fix that by moving the ! ifdef section into proc-macros.S and deleting it from all effected proc-*.S files. Acked-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-07ARM: mm: proc-macros: Add generic proc/cache/tlb struct definition macrosDave Martin
This patch adds some generic macros to reduce boilerplate when declaring certain common structures in arch/arm/mm/*.S Thanks to Russell King for outlining what the define_processor_functions macro could look like. Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-01-06Merge branch 'pgt' (early part) into develRussell King
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-22ARM: pgtable: provide RDONLY page table bit rather than WRITE bitRussell King
2010-12-22ARM: pgtable: invert L_PTE_EXEC to L_PTE_XNRussell King
The hardware page tables use an XN bit 'execute never'. Historically, we've had a Linux 'execute allow' bit, in the positive sense. Get rid of this artifact as future hardware will continue to have the XN sense. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: pgtable: switch order of Linux vs hardware page tablesRussell King
This switches the ordering of the Linux vs hardware page tables in each page, thereby eliminating some of the arithmetic in the page table walks. As we now place the Linux page table at the beginning of the page, we can deal with the offset in the pgt by simply masking it away, along with the other control bits. This also makes the arithmetic all be positive, rather than a mixture. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-12ARM: 6528/1: Use CTR for the I-cache line size on ARMv7Catalin Marinas
The current implementation of the v7_coherent_*_range function assumes that the D and I cache lines have the same size, which is incorrect architecturally. This patch adds the icache_line_size macro which reads the CTR register. The main loop in v7_coherent_*_range is split in two independent loops or the D and I caches. This also has the performance advantage that the DSB is moved outside the main loop. Reported-by: Kevin Sapp <ksapp@quicinc.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-12ARM: 6527/1: Use CTR instead of CCSIDR for the D-cache line size on ARMv7Catalin Marinas
The current implementation of the dcache_line_size macro reads the L1 cache size from the CCSIDR register. This, however, is not guaranteed to be the smallest cache line in the cache hierarchy. The patch changes to the macro to use the more architecturally correct CTR register. Reported-by: Kevin Sapp <ksapp@quicinc.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-04ARM: 6384/1: Remove the domain switching on ARMv6k/v7 CPUsCatalin Marinas
This patch removes the domain switching functionality via the set_fs and __switch_to functions on cores that have a TLS register. Currently, the ioremap and vmalloc areas share the same level 1 page tables and therefore have the same domain (DOMAIN_KERNEL). When the kernel domain is modified from Client to Manager (via the __set_fs or in the __switch_to function), the XN (eXecute Never) bit is overridden and newer CPUs can speculatively prefetch the ioremap'ed memory. Linux performs the kernel domain switching to allow user-specific functions (copy_to/from_user, get/put_user etc.) to access kernel memory. In order for these functions to work with the kernel domain set to Client, the patch modifies the LDRT/STRT and related instructions to the LDR/STR ones. The user pages access rights are also modified for kernel read-only access rather than read/write so that the copy-on-write mechanism still works. CPU_USE_DOMAINS gets disabled only if the hardware has a TLS register (CPU_32v6K is defined) since writing the TLS value to the high vectors page isn't possible. The user addresses passed to the kernel are checked by the access_ok() function so that they do not point to the kernel space. Tested-by: Anton Vorontsov <cbouatmailru@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-07-24nommu: Add #ifdef CONFIG_MMU around the PTE sanity checksCatalin Marinas
2009-07-11[ARM] remove L_PTE_BUFFERABLE and L_PTE_CACHEABLERussell King
These old symbols are meaningless now that we have memory type support implemented. The entire memory type field needs to be modified rather than just a few bits twiddled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Remove MT_DEVICE_IXP2000 and associated definitionsRussell King
As of the previous commit, MT_DEVICE_IXP2000 encodes to the same PTE bit encoding as MT_DEVICE, so it's now redundant. Convert MT_DEVICE_IXP2000 to use MT_DEVICE instead, and remove its aliases. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Convert ARMv6 and ARMv7 to use new memory typesRussell King
2008-10-01[ARM] Convert set_pte_ext implementions to macrosRussell King
There are actually only four separate implementations of set_pte_ext. Use assembler macros to insert code for these into the proc-*.S files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] armv7: add support for ARMv7 cores.Catalin Marinas
This patch adds support for the ARMv7 cores. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] nommu: provide a way for correct control register value selectionRussell King
Most MMU-based CPUs have a restriction on the setting of the data cache enable and mmu enable bits in the control register, whereby if the data cache is enabled, the MMU must also be enabled. Enabling the data cache without the MMU is an invalid combination. However, there are CPUs where the data cache can be enabled without the MMU. In order to allow these CPUs to take advantage of that, provide a method whereby each proc-*.S file defines the control regsiter value for use with nommu (with the MMU disabled.) Later on, when we add support for enabling the MMU on these devices, we can adjust the "crval" macro to also enable the data cache for nommu. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09kbuild: arm - use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted stuff from arch Makefile and rename constants.h to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
