path: root/arch/arm/mm/fault.c
2011-10-17ARM: 7115/4: move __exception and friends to asm/exception.hJamie Iles
The definition of __exception_irq_entry for CONFIG_FUNCTION_GRAPH_TRACER=y needs linux/ftrace.h, but this creates a circular dependency with it's current home in asm/system.h. Create asm/exception.h and update all current users. v4: - rebase to rmk/for-next v3: - remove redundant includes of linux/ftrace.h v2: - document the usage restricitions of __exception* Cc: Zoltan Devai <zdevai@gmail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (237 commits) ARM: 7004/1: fix traps.h compile warnings ARM: 6998/2: kernel: use proper memory barriers for bitops ARM: 6997/1: ep93xx: increase NR_BANKS to 16 for support of 128MB RAM ARM: Fix build errors caused by adding generic macros ARM: CPU hotplug: ensure we migrate all IRQs off a downed CPU ARM: CPU hotplug: pass in proper affinity mask on IRQ migration ARM: GIC: avoid routing interrupts to offline CPUs ARM: CPU hotplug: fix abuse of irqdesc->node ARM: 6981/2: mmci: adjust calculation of f_min ARM: 7000/1: LPAE: Use long long printk format for displaying the pud ARM: 6999/1: head, zImage: Always Enter the kernel in ARM state ARM: btc: avoid invalidating the branch target cache on kernel TLB maintanence ARM: ARM_DMA_ZONE_SIZE is no more ARM: mach-shark: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-sa1100: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-realview: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-pxa: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size ...
2011-07-22Merge branches 'btc', 'dma', 'entry', 'fixes', 'linker-layout', 'misc', ↵Russell King
'mmci', 'suspend' and 'vfp' into for-next
2011-07-19ARM: 7000/1: LPAE: Use long long printk format for displaying the pudCatalin Marinas
Currently using just long but this is not enough for the LPAE format (64-bit entries). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-02ARM: entry: avoid enabling interrupts in prefetch/data abort handlersRussell King
Avoid enabling interrupts if the parent context had interrupts enabled in the abort handler assembly code, and move this into the breakpoint/ page/alignment fault handlers instead. This gets rid of some special-casing for the breakpoint fault handlers from the low level abort handler path. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-21ARM: pgtable: add pud-level codeRussell King
Add pud_offset() et.al. between the pgd and pmd code in preparation of using pgtable-nopud.h rather than 4level-fixup.h. This incorporates a fix from Jamie Iles <jamie@jamieiles.com> for uaccess_with_memcpy.c. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-15ARM: 6674/1: LPAE: use long long format when printing physical addresses and ↵Will Deacon
ptes For the Kernel to support 2 level and 3 level page tables, physical addresses (and also page table entries) need to be 32 or 64-bits depending upon the configuration. This patch uses the %08llx conversion specifier for physical addresses and page table entries, ensuring that they are cast to (long long) so that common code can be used regardless of the datatype widths. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: pgtable: switch order of Linux vs hardware page tablesRussell King
This switches the ordering of the Linux vs hardware page tables in each page, thereby eliminating some of the arithmetic in the page table walks. As we now place the Linux page table at the beginning of the page, we can deal with the offset in the pgt by simply masking it away, along with the other control bits. This also makes the arithmetic all be positive, rather than a mixture. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-08ARM: 6355/1: hw-breakpoint: add mechanism for hooking into prefetch abortsWill Deacon
On ARM processors with hardware breakpoint and watchpoint support, triggering these events results in a debug exception. These manifest as prefetch and data aborts respectively. arch/arm/mm/fault.c already provides hook_fault_code for hooking into data aborts dependent on the DFSR. This patch adds a new function, hook_ifault_code for hooking into prefetch aborts in the same manner. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: S. Karthikeyan <informkarthik@gmail.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6268/1: ARMv6K and ARMv7 use fault statuses 3 and 6 as Access Flag faultKirill A. Shutemov
Statuses 3 (0b00011) and 6 (0x00110) of DFSR are Access Flags faults on ARMv6K and ARMv7. Let's patch fsr_info[] at runtime if we are on ARMv7 or later. Unfortunately, we don't have runtime check for 'K' extension, so we can't check for it. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6256/1: Check arch version and modify fsr_info[] depends on it at runtimeKirill A. Shutemov
2010-07-27ARM: 6255/1: Workaround infinity loop in handling of translation faultsKirill A. Shutemov
On ARM one Linux PGD entry contains two hardware entries (see page tables layout in pgtable.h). We normally guarantee that we always fill both L1 entries. But create_mapping() doesn't follow the rule. It can create inidividual L1 entries, so here we have to call pmd_none() check in do_translation_fault() for the entry really corresponded to address, not for the first of pair. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6269/1: Add 'code' parameter for hook_fault_code()Kirill A. Shutemov
Add one more parameter to hook_fault_code() to be able to set 'code' field of struct fsr_info. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: 6252/1: Use SIGBUS for unaligned access instead of SIGILLKirill A. Shutemov
POSIX specify to use signal SIGBUS with code BUS_ADRALN for invalid address alignment. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-08ARM: 6166/1: Proper prefetch abort handling on pre-ARMv6Anfei
Instruction faults on pre-ARMv6 CPUs are interpreted as a 'translation fault', but do_translation_fault doesn't handle well if user mode trying to run instruction above TASK_SIZE, and result in the infinite retry of that instruction. CC: <stable@kernel.org> Signed-off-by: Anfei Zhou <anfei.zhou@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-15ARM: 6134/1: Handle instruction cache maintenance fault properlyKirill A. Shutemov
Between "clean D line..." and "invalidate I line" operations in v7_coherent_user_range(), the memory page may get swapped out. And the fault on "invalidate I line" could not be properly handled causing the oops. In ARMv6 "external abort on linefetch" replaced by "instruction cache maintenance fault". Let's handle it as translation fault. It fixes the issue. I'm not sure if it's reasonable to check arch version in run-time. Let's do it in compile time for now. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Siarhei Siamashka <siarhei.siamashka@nokia.com> Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5900/2: arm: enable support for software perf eventsJamie Iles
The perf events subsystem allows counting of both hardware and software events. This patch implements the bare minimum for software performance events. Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jamie Iles <jamie.iles@picochip.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-05ARM: 5742/1: ARM: add debug check for invalid kernel page faultsImre Deak
According to the following in arch/arm/mm/fault.c page faults from kernel mode are invalid if mmap_sem is already held and there is no exception handler defined for the faulting instruction: /* * As per x86, we may deadlock here. However, since the kernel only * validly references user space from well defined areas of the code, * we can bug out early if this is from code which shouldn't. */ if (!down_read_trylock(&mm->mmap_sem)) { if (!user_mode(regs) && !search_exception_tables(regs->ARM_pc)) goto no_context; Since mmap_sem can be held at arbitrary times by another thread this also means that any page faults from kernel mode are invalid if no exception handler is defined for them, regardless whether mmap_sem is held at the time of fault. To easier detect code that can trigger the above error, add a check also for the case where mmap_sem is acquired. As this has an overhead make it a VM debug check. Signed-off-by: Imre Deak <imre.deak@nokia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5728/1: Proper prefetch abort handling on ARMv6 and ARMv7Kirill A. Shutemov
Currently, on ARMv6 and ARMv7, if an application tries to execute code (or garbage) on non-executable page it hangs. It caused by incorrect prefetch abort handling. Now every prefetch abort processes as a translation fault. To fix this we have to analyze instruction fault status register to figure out reason why we've got the abort and process it accordingly. To make IFSR different from DFSR we set bit 31 which is reserved in both IFSR and DFSR. This patch also tries to protect from future hangs on unexpected exceptions. An application will be killed if unexpected exception type was received. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-20ARM: Add support for checking access permissions on prefetch abortsRussell King
ARMv6 introduces non-executable mappings, which can cause prefetch aborts when an attempt is made to execute from such a mapping. Currently, this causes us to loop in the page fault handler since we don't correctly check for proper permissions. Fix this by checking that VMAs have VM_EXEC set for prefetch aborts. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-20ARM: Separate out access error checkingRussell King
Since we get notified separately about prefetch aborts, which may be permission faults, we need to check for appropriate access permissions when handling a fault. This patch prepares us for doing this by separating out the access error checking. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-20ARM: Ensure correct might_sleep() check in pagefault pathRussell King
2009-09-20ARM: Update page fault handling for new OOM techniquesRussell King
2009-09-20ARM: Provide definitions and helpers for decoding the FSR registerRussell King
2009-09-12Merge branch 'devel-stable' into develRussell King
Conflicts: MAINTAINERS arch/arm/mm/fault.c
2009-08-17ARM: implement highpteRussell King
Add the ARM implementation of highpte, which allows PTE tables to be placed in highmem. Unfortunately, we do not offer highpte support when support for L2 cache is enabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Include linux/sched.h in arch/arm/mm/fault.cCatalin Marinas
When building with !MMU, task_struct is not defined. Just include the relevant file. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-07-24nommu: Fix the fault processing for the MMU-less caseCatalin Marinas
The patch adds the necessary ifdefs around functions that only make sense when the MMU is enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-06-21Move FAULT_FLAG_xyz into handle_mm_fault() callersLinus Torvalds
This allows the callers to now pass down the full set of FAULT_FLAG_xyz flags to handle_mm_fault(). All callers have been (mechanically) converted to the new calling convention, there's almost certainly room for architectures to clean up their code and then add FAULT_FLAG_RETRY when that support is added. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-17Merge branch 'mxc-pu-imxfb' of ↵Russell King
git://pasiphae.extern.pengutronix.de/git/imx/linux-2.6 into devel
2008-12-15[ARM] Ensure linux/hardirqs.h is included where requiredRussell King
... for the removal of it from asm-generic/local.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove bogus #ifdef CONFIG_HIGHMEM in show_pte()Nicolas Pitre
The restriction on !CONFIG_HIGHMEM is unneeded since page tables are currently never allocated with highmem pages, and actually disable PTE dump whenever highmem is configured. Let's have a dynamic test to better describe the current limitation instead. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-30[ARM] 5272/1: remove conditional compilation in show_pte()Nicolas Pitre
The PTRS_PER_PMD != 1 condition can be evaluated with C code and optimized at compile time. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/uaccess.h to linux/uaccess.hRussell King
2008-01-26ARM kprobes: prevent some functions involved with kprobes from being probedNicolas Pitre
2008-01-26ARM kprobes: add the kprobes hook to the page fault handlerNicolas Pitre
2007-10-19pid namespaces: define is_global_init() and is_container_init()Serge E. Hallyn
is_init() is an ambiguous name for the pid==1 check. Split it into is_global_init() and is_container_init(). A cgroup init has it's tsk->pid == 1. A global init also has it's tsk->pid == 1 and it's active pid namespace is the init_pid_ns. But rather than check the active pid namespace, compare the task structure with 'init_pid_ns.child_reaper', which is initialized during boot to the /sbin/init process and never changes. Changelog: 2.6.22-rc4-mm2-pidns1: - Use 'init_pid_ns.child_reaper' to determine if a given task is the global init (/sbin/init) process. This would improve performance and remove dependence on the task_pid(). 2.6.21-mm2-pidns2: - [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc, ppc,avr32}/traps.c for the _exception() call to is_global_init(). This way, we kill only the cgroup if the cgroup's init has a bug rather than force a kernel panic. [akpm@linux-foundation.org: fix comment] [sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c] [bunk@stusta.de: kernel/pid.c: remove unused exports] [sukadev@us.ibm.com: Fix capability.c to work with threaded init] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Acked-by: Pavel Emelianov <xemul@openvz.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzel <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16During VM oom condition, kill all threads in process groupWill Schmidt
We have had complaints where a threaded application is left in a bad state after one of it's threads is killed when we hit a VM: out_of_memory condition. Killing just one of the process threads can leave the application in a bad state, whereas killing the entire process group would allow for the application to restart, or be otherwise handled, and makes it very obvious that something has gone wrong. This change allows the entire process group to be taken down, rather than just the one thread. Signed-off-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20arm: fix up handle_mm_fault changesNick Piggin
Update arm to use bitwise types for its VM_FAULT_ constants. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Add ability to dump exception stacks to kernel backtracesRussell King
2006-12-07[PATCH] mm: arch do_page_fault() vs in_atomic()Peter Zijlstra
In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. arch/x86_64 - good arch/powerpc - good arch/cris - fixed arch/i386 - good arch/parisc - fixed arch/sh - good arch/sparc - good arch/s390 - good arch/m68k - fixed arch/ppc - good arch/alpha - fixed arch/mips - good arch/sparc64 - good arch/ia64 - good arch/arm - fixed arch/um - good arch/avr32 - good arch/h8300 - NA arch/m32r - good arch/v850 - good arch/frv - fixed arch/m68knommu - NA arch/arm26 - fixed arch/sh64 - fixed arch/xtensa - good Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] pidspace: is_init()Sukadev Bhattiprolu
This is an updated version of Eric Biederman's is_init() patch. (http://lkml.org/lkml/2006/2/6/280). It applies cleanly to 2.6.18-rc3 and replaces a few more instances of ->pid == 1 with is_init(). Further, is_init() checks pid and thus removes dependency on Eric's other patches for now. Eric's original description: There are a lot of places in the kernel where we test for init because we give it special properties. Most significantly init must not die. This results in code all over the kernel test ->pid == 1. Introduce is_init to capture this case. With multiple pid spaces for all of the cases affected we are looking for only the first process on the system, not some other process that has pid == 1. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: <lxc-devel@lists.sourceforge.net> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] make PROT_WRITE imply PROT_READJason Baron
Make PROT_WRITE imply PROT_READ for a number of architectures which don't support write only in hardware. While looking at this, I noticed that some architectures which do not support write only mappings already take the exact same approach. For example, in arch/alpha/mm/fault.c: " if (cause < 0) { if (!(vma->vm_flags & VM_EXEC)) goto bad_area; } else if (!cause) { /* Allow reads even for write-only mappings */ if (!(vma->vm_flags & (VM_READ | VM_WRITE))) goto bad_area; } else { if (!(vma->vm_flags & VM_WRITE)) goto bad_area; } " Thus, this patch brings other architectures which do not support write only mappings in-line and consistent with the rest. I've verified the patch on ia64, x86_64 and x86. Additional discussion: Several architectures, including x86, can not support write-only mappings. The pte for x86 reserves a single bit for protection and its two states are read only or read/write. Thus, write only is not supported in h/w. Currently, if i 'mmap' a page write-only, the first read attempt on that page creates a page fault and will SEGV. That check is enforced in arch/blah/mm/fault.c. However, if i first write that page it will fault in and the pte will be set to read/write. Thus, any subsequent reads to the page will succeed. It is this inconsistency in behavior that this patch is attempting to address. Furthermore, if the page is swapped out, and then brought back the first read will also cause a SEGV. Thus, any arbitrary read on a page can potentially result in a SEGV. According to the SuSv3 spec, "if the application requests only PROT_WRITE, the implementation may also allow read access." Also as mentioned, some archtectures, such as alpha, shown above already take the approach that i am suggesting. The counter-argument to this raised by Arjan, is that the kernel is enforcing the write only mapping the best it can given the h/w limitations. This is true, however Alan Cox, and myself would argue that the inconsitency in behavior, that is applications can sometimes work/sometimes fails is highly undesireable. If you read through the thread, i think people, came to an agreement on the last patch i posted, as nobody has objected to it... Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Andi Kleen <ak@muc.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[ARM] do_bad_area() always takes current and current->active_mmRussell King
Since do_bad_area() always takes the currently active task and (supposed to) take the currently active MM, there's no point passing them to this function. Instead, obtain references to them inside do_bad_area(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
