path: root/arch/arm/mm/cache-v4.S
2008-11-28[ARM] Remove unnecessary mach/hardware.h includes in arch/arm/mmRussell King
2008-10-17[ARM] 5310/1: Fix cache flush functions for ARMv4Anders Grafström
ARMv4 (ARM720T) cache flush functions are broken in 2.6.19+ kernels. The issue was introduced by commit f12d0d7c7786af39435ef6ae9defe47fb58f6091 This patch corrects the CPU_CP15 ifdef statements so that they actually do something. Signed-off-by: Anders Grafström <grfstrm@users.sourceforge.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: manage the CP15 thingsHyok S. Choi
All the current CP15 access codes in ARM arch can be categorized and conditioned by the defines as follows: Related operation Safe condition a. any CP15 access !CPU_CP15 b. alignment trap CPU_CP15_MMU c. D-cache(C-bit) CPU_CP15 d. I-cache CPU_CP15 && !( CPU_ARM610 || CPU_ARM710 || CPU_ARM720 || CPU_ARM740 || CPU_XSCALE || CPU_XSC3 ) e. alternate vector CPU_CP15 && !CPU_ARM740 f. TTB CPU_CP15_MMU g. Domain CPU_CP15_MMU h. FSR/FAR CPU_CP15_MMU For example, alternate vector is supported if and only if "CPU_CP15 && !CPU_ARM740" is satisfied. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
