path: root/arch/arm/mm/alignment.c
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01parse errors in ifdefsYoann Padioleau
Fix various bits of obviously-busted code which we're not happening to compile, due to ifdefs. Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Jan Kara <jack@ucw.cz> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-21[ARM] Remove needless linux/ptrace.h includesRussell King
Lots of places in arch/arm were needlessly including linux/ptrace.h, resumably because we used to pass a struct pt_regs to interrupt handlers. Now that we don't, all these ptrace.h includes are redundant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] do_bad_area() always takes current and current->active_mmRussell King
Since do_bad_area() always takes the currently active task and (supposed to) take the currently active MM, there's no point passing them to this function. Instead, obtain references to them inside do_bad_area(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-12[ARM] 2969/1: miscellaneous whitespace cleanupGeorge G. Davis
Patch from George G. Davis Fix leading, trailing and other miscellaneous whitespace issues in arch/arm/kernel/alignment.c. Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-10[ARM] 2959/1: Add test for invalid LDRD/STRD Rd cases in ARM alignment handlerGeorge G. Davis
Patch from George G. Davis Add test for invalid LDRD/STRD Rd cases in ARM alignment handler and restore SWP printk KERN_ERR. Signed-off-by: Steve Longerbeam <slongerbeam@mvista.com> Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-31[ARM] 2867/2: unaligned ldrd/strd fixupsSteve Longerbeam
Patch from Steve Longerbeam Adds an implementation of unaligned LDRD and STRD fixups. Also fixes a bug where do_alignment() would misinterpret and fixup an unaligned LDRD/STRD as LDRH/STRH, causing memory corruption. This is the same as Patch #2867/1, but with minor whitespace and comments changes, plus a check for arch-level >= v5TE before printing ai_dword count in proc_alignment_read(). Signed-off-by: Steve Longerbeam <stevel@mwwireless.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
